[Nek5000-users] info
Wed Sep 26 17:16:00 CDT 2018
I have used your version of the code and the on-line version and I get the same error.
Last login: Wed Sep 26 23:07:14 on ttys000
MacBook-di-Federico-Antonelli:~ maitai2005$ cd ~
MacBook-di-Federico-Antonelli:~ maitai2005$ tar -xvzf Nek5000_X.Y.tar.gz
tar: Error opening archive: Failed to open 'Nek5000_X.Y.tar.gz'
MacBook-di-Federico-Antonelli:~ maitai2005$ tar -zxvf Nek5000-v17.0.tar.gz
tar: Error opening archive: Failed to open 'Nek5000-v17.0.tar.gz'
On 26 Sep 2018, at 23:01, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
First you download the code e.g. using
wget https://github.com/Nek5000/Nek5000/releases/download/v17.0/Nek5000-v17.0.tar.gz
Then untar the file
-----Original message-----
From:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Sent: Wednesday 26th September 2018 23:56
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] info
I had gcc and gfortran installed already.
<br class="" />
I have installed open-mpi
<br class="" />
It still does not work.
<br class="" />
I have followed the instructions, however I had to change the second line dragging the tar file from the desktop to the terminal otherwise I would have got the following error:
tar: Error opening archive: Failed to open ‘Nek5000_X.Y.tar.gz'
<br class="" />
Is the software supposed to open after the line run?
<br class="" />
Kind regards
<br class="" />
Federico
On 26 Sep 2018, at 21:33,
nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
<br class="Apple-interchange-newline" />
To install the GNU C/Fortran compilers  MPI, just run<br class="" />
<br class="" />
brew install gcc<br class="" />
brew install gfortran<br class="" />
brew install open-mpi<br class="" />
<br class="" />
To compile and run Nek5000 just follow the instructions outlined in:<br class="" />
http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation><br class="" />
<br class="" />
-----Original message-----<br class="" />
From:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>><br class="" />
Sent: Wednesday 26th September 2018 22:26<br class="" />
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><br class="" />
Subject: Re: [Nek5000-users] info<br class="" />
<br class="" />
No I haven't installed the software below but I will do. I have tried to install it using the terminal but unsuccessfully, I do not have a great knowledge of it, I have tried with Homebrew.On-line I found a sequence of instructions about installation on ubuntu.
Something like that would be really useful. <br class="" />
Thank you for your replies.<br class="" />
Kind Regards<br class="" />
<br class="" />
Federico <br class="" />
<br class="" />
<br class="" />
<br class="" />
On 26 Sep 2018, at 17:44, "nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> wrote:<br class="" />
<br class="" />
Can you please be more specific. How do the "difficulties" manifest itself?<br class="" />
<br class="" />
Sent: Wednesday 26th September 2018 18:39<br class="" />
Subject: [Nek5000-users] info<br class="" />
<br class="" />
Hi,<br class="" />
I am having difficulties with installing the software on a Mac.<br class="" />
I would like to know if somebody can provide some help please.<br class="" />
I have read the documents already.<br class="" />
Thank you.<br class="" />
<br class="" />
Federico<br class="" />
<br class="" />
_______________________________________________<br class="" />
Nek5000-users mailing list<br class="" />
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" />
<br class="" />
<br class="" />
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180926/81ab17e1/attachment.html>
