[Nek5000-users] info
Wed Sep 26 17:19:22 CDT 2018
did you download the file?
On 2018-09-27 00:16, nek5000-users at lists.mcs.anl.gov wrote:
> I have used your version of the code and the on-line version and I get
> the same error.
>> Last login: Wed Sep 26 23:07:14 on ttys000
>> MacBook-di-Federico-Antonelli:~ maitai2005$ cd ~
>> MacBook-di-Federico-Antonelli:~ maitai2005$ tar -xvzf Nek5000_X.Y.tar.gz
>> tar: Error opening archive: Failed to open 'Nek5000_X.Y.tar.gz'
>> MacBook-di-Federico-Antonelli:~ maitai2005$ tar -zxvf Nek5000-v17.0.tar.gz
>> tar: Error opening archive: Failed to open 'Nek5000-v17.0.tar.gz'
>> On 26 Sep 2018, at 23:01, nek5000-users at lists.mcs.anl.gov
>> <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
>> First you download the code e.g. using
>> wget
>> https://github.com/Nek5000/Nek5000/releases/download/v17.0/Nek5000-v17.0.tar.gz
>> Then untar the file
>> -----Original message-----
>>> From:nek5000-users at lists.mcs.anl.gov
>>> <nek5000-users at lists.mcs.anl.gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov>>
>>> Sent: Wednesday 26th September 2018 23:56
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: Re: [Nek5000-users] info
>>> I had gcc and gfortran installed already.
>>> <br class="" />
>>> I have installed open-mpi
>>> <br class="" />
>>> It still does not work.
>>> <br class="" />
>>> I have followed the instructions, however I had to change the second
>>> line dragging the tar file from the desktop to the terminal otherwise
>>> I would have got the following error:
>>> tar: Error opening archive: Failed to open ‘Nek5000_X.Y.tar.gz'
>>> <br class="" />
>>> Is the software supposed to open after the line run?
>>> <br class="" />
>>> Kind regards
>>> <br class="" />
>>> Federico
>>> On 26 Sep 2018, at 21:33,
>>> <br class="Apple-interchange-newline" />
>>> To install the GNU C/Fortran compilers  MPI, just run<br class="" />
>>> <br class="" />
>>> brew install gcc<br class="" />
>>> brew install gfortran<br class="" />
>>> brew install open-mpi<br class="" />
>>> <br class="" />
>>> To compile and run Nek5000 just follow the instructions outlined
>>> in:<br class="" />
>>> http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation
>>> <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation><br
>>> class="" />
>>> <br class="" />
>>> -----Original message-----<br class="" />
>>> <mailto:nek5000-users at lists.mcs.anl.gov>><br class="" />
>>> Sent: Wednesday 26th September 2018 22:26<br class="" />
>>> <mailto:nek5000-users at lists.mcs.anl.gov><br class="" />
>>> Subject: Re: [Nek5000-users] info<br class="" />
>>> <br class="" />
>>> No I haven't installed the software below but I will do. I have tried
>>> to install it using the terminal but unsuccessfully, I do not have a
>>> great knowledge of it, I have tried with Homebrew.On-line I found a
>>> sequence of instructions about installation on ubuntu.
>>> Something like that would be really useful. <br class="" />
>>> Thank you for your replies.<br class="" />
>>> Kind Regards<br class="" />
>>> <br class="" />
>>> Federico <br class="" />
>>> <br class="" />
>>> <br class="" />
>>> <br class="" />
>>> On 26 Sep 2018, at 17:44, "nek5000-users at lists.mcs.anl.gov
>>> <mailto:nek5000-users at lists.mcs.anl.gov>"
>>> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:<br class="" />
>>> <br class="" />
>>> Can you please be more specific. How do the "difficulties" manifest
>>> itself?<br class="" />
>>> <br class="" />
>>> Sent: Wednesday 26th September 2018 18:39<br class="" />
>>> Subject: [Nek5000-users] info<br class="" />
>>> <br class="" />
>>> Hi,<br class="" />
>>> I am having difficulties with installing the software on a Mac.<br
>>> class="" />
>>> I would like to know if somebody can provide some help please.<br
>>> class="" />
>>> I have read the documents already.<br class="" />
>>> Thank you.<br class="" />
>>> <br class="" />
>>> Federico<br class="" />
>>> <br class="" />
>>> _______________________________________________<br class="" />
>>> Nek5000-users mailing list<br class="" />
>>> Nek5000-users at lists.mcs.anl.gov
>>> <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" />
>>> <br class="" />
>>> <br class="" />
>>> Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
