[Nek5000-users] info
Wed Sep 26 17:01:15 CDT 2018
First you download the code e.g. using
wget https://github.com/Nek5000/Nek5000/releases/download/v17.0/Nek5000-v17.0.tar.gz
Then untar the file
tar -zxvf Nek5000-v17.0.tar.gz
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Wednesday 26th September 2018 23:56
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] info
> I had gcc and gfortran installed already.
> <br class="" />
> I have installed open-mpi
> <br class="" />
> It still does not work.
> <br class="" />
> I have followed the instructions, however I had to change the second line dragging the tar file from the desktop to the terminal otherwise I would have got the following error:
> tar: Error opening archive: Failed to open ‘Nek5000_X.Y.tar.gz'
> <br class="" />
> Is the software supposed to open after the line run?
> <br class="" />
> Kind regards
> <br class="" />
> Federico
> On 26 Sep 2018, at 21:33,
> nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> wrote:
> <br class="Apple-interchange-newline" />
> To install the GNU C/Fortran compilers  MPI, just run<br class="" />
> <br class="" />
> brew install gcc<br class="" />
> brew install gfortran<br class="" />
> brew install open-mpi<br class="" />
> <br class="" />
> To compile and run Nek5000 just follow the instructions outlined in:<br class="" />
> http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation <http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation><br class="" />
> <br class="" />
> -----Original message-----<br class="" />
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov><br class="" />
> Sent: Wednesday 26th September 2018 22:26<br class="" />
> To: nek5000-users at lists.mcs.anl.gov<br class="" />
> Subject: Re: [Nek5000-users] info<br class="" />
> <br class="" />
> No I haven't installed the software below but I will do. I have tried to install it using the terminal but unsuccessfully, I do not have a great knowledge of it, I have tried with Homebrew.On-line I found a sequence of instructions about installation on ubuntu.
>  Something like that would be really useful. <br class="" />
> Thank you for your replies.<br class="" />
> Kind Regards<br class="" />
> <br class="" />
> Federico <br class="" />
> <br class="" />
> <br class="" />
> <br class="" />
> On 26 Sep 2018, at 17:44, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:<br class="" />
> <br class="" />
> Can you please be more specific. How do the "difficulties" manifest itself?<br class="" />
> <br class="" />
> Sent: Wednesday 26th September 2018 18:39<br class="" />
> Subject: [Nek5000-users] info<br class="" />
> <br class="" />
> Hi,<br class="" />
> I am having difficulties with installing the software on a Mac.<br class="" />
> I would like to know if somebody can provide some help please.<br class="" />
> I have read the documents already.<br class="" />
> Thank you.<br class="" />
> <br class="" />
> Federico<br class="" />
> <br class="" />
> _______________________________________________<br class="" />
> Nek5000-users mailing list<br class="" />
> Nek5000-users at lists.mcs.anl.gov<br class="" />
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" />
> <br class="" />
> <br class="" />
