[Nek5000-users] info
Wed Sep 26 16:57:08 CDT 2018
I had gcc and gfortran installed already.
I have installed open-mpi
It still does not work.
I have followed the instructions, however I had to change the second line dragging the tar file from the desktop to the terminal otherwise I would have got the following error:
tar: Error opening archive: Failed to open ‘Nek5000_X.Y.tar.gz'
Is the software supposed to open after the line run?
Kind regards
Federico
On 26 Sep 2018, at 21:33, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
To install the GNU C/Fortran compilers + MPI, just run
brew install gcc
brew install gfortran
brew install open-mpi
To compile and run Nek5000 just follow the instructions outlined in:
http://nek5000.github.io/NekDoc/quickstart.html#running-your-very-first-simulation
-----Original message-----
From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Wednesday 26th September 2018 22:26
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] info
No I haven't installed the software below but I will do. I have tried to install it using the terminal but unsuccessfully, I do not have a great knowledge of it, I have tried with Homebrew.On-line I found a sequence of instructions about installation on ubuntu. Something like that would be really useful.
Thank you for your replies.
Kind Regards
Federico
On 26 Sep 2018, at 17:44, "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov> wrote:
Can you please be more specific. How do the "difficulties" manifest itself?
Sent: Wednesday 26th September 2018 18:39
Subject: [Nek5000-users] info
I am having difficulties with installing the software on a Mac.
I would like to know if somebody can provide some help please.
I have read the documents already.
Thank you.
Federico
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180926/abc7cf4b/attachment.html>
