[Nek5000-users] rst to ix iy iz
Tue Sep 18 08:50:16 CDT 2018
I guess the question is what you would like to do. From your other posts
I assume that you would like to use interpolation to compute the value
of the forcing that you can then input in userf at grid points ix,iy,iz.
If this is correct, I guess what you would need to do is to regularise
the forcing by spreading it among a number of actual grid points, e.g.
using a Gaussian spreading which is centered in the actual point of the
forcing which does not need to coincide with a grid point.
philipp
On 2018-09-18 14:10, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Jian,
> There are an infinite number of r values but only a finite number
> of ix values, so there is no one-to-one mapping of r to ix.
> If you want the closest one, you could check against the positions of
> the Gauss-Lobatto-Legendre points, zgm1(ix,1), for ix=1,...,lx1.
> Paul
> *From:* Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on
> behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> *Sent:* Tuesday, September 18, 2018 6:09 AM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* [Nek5000-users] rst to ix iy iz
> Dear nek,
> Do you know how to convert r, s, t in [-1,1] to ix, iy, iz in an element?
> Actually I didn't see too many documents about reference space
> coordinates. Can you please provide some links for that? Thanks
> Kind regards,
> Jian
> Nek5000-users mailing list
