[Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
Thu May 31 07:56:36 CDT 2018
Thank you .
So here the 1,2,3,4 refers to the Side set numbers that we give as B.C in ICEM?
Thank you very much
Sijo
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov>
Envoyé: Jeudi 31 Mai 2018 14:52:40
Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
I specify the boundary conditions in the usrdat subroutine using the following piece of code
do i=1,nelt
do j=1,2*ndim
if(bc(5,j,i,1).eq.1) then
cbc(j,i,1)='mv '
elseif(bc(5,j,i,1).eq.2) then
cbc(j,i,1)='W '
elseif(bc(5,j,i,1).eq.3) then
cbc(j,i,1)='W '
elseif(bc(5,j,i,1).eq.4) then
cbc(j,i,1)='W '
else
cbc(j,i,1)='E '
endif
enddo
enddo
Marco
On May 31, 2018, at 8:50 AM, [ mailto:nek5000-users at lists.mcs.anl.gov |
nek5000-users at lists.mcs.anl.gov ] wrote:
Hi Neks,
I did the conversion of a mesh from ICEM to exodus file then to re2 file.
But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format.
So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format.
Thank you
Nek5000-users mailing list
[ mailto:Nek5000-users at lists.mcs.anl.gov | Nek5000-users at lists.mcs.anl.gov ]
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180531/814cc3f3/attachment.html>
