[Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
Thu May 31 07:58:17 CDT 2018
Yes, you are correct. 1, 2, .. are the boundary indices in your exodus file. The ‘1’ in bc(5,j,i,1) refers to the velocity field.
Marco
On May 31, 2018, at 8:56 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Thank you .
So here the 1,2,3,4 refers to the Side set numbers that we give as B.C in ICEM?
Thank you very much
Sijo
De: "nek5000-users" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
À: "nek5000-users" <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Envoyé: Jeudi 31 Mai 2018 14:52:40
Objet: Re: [Nek5000-users] How to give NEK5000 boundary conditions to exodus mesh file
I specify the boundary conditions in the usrdat subroutine using the following piece of code
      do i=1,nelt
        do j=1,2*ndim
          if(bc(5,j,i,1).eq.1) then
            cbc(j,i,1)='mv  '
          elseif(bc(5,j,i,1).eq.2) then
            cbc(j,i,1)='W  '
          elseif(bc(5,j,i,1).eq.3) then
            cbc(j,i,1)='W  '
          elseif(bc(5,j,i,1).eq.4) then
            cbc(j,i,1)='W  '
          else
            cbc(j,i,1)='E  '
          endif
        enddo
      enddo
Marco
On May 31, 2018, at 8:50 AM, nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> wrote:
Hi Neks,
I did the conversion of a mesh from ICEM to exodus file then to re2 file.
But I am bit confused on the boundary conditions. Because from ICEM before I export to exodus I give the B.Cs as side set numbers and after the conversion to re2 I wont be able to put the boundary conditions in NEK format.
So could you please tell me how you put the BC in NEK5000 format to a mesh file with exodus format.
Thank you
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180531/6248b462/attachment.html>
