[Nek5000-users] Running genmap
Wed Jun 27 16:10:21 CDT 2018
Thanks for the answer Marco,
Unfortunately I am pretty new to the software so I didn't know these kind
of basic things. The problem is solved now.
Thanks.
El dc., 27 de juny 2018, 15:05, <nek5000-users at lists.mcs.anl.gov> va
escriure:
> Roger,
> did you build genmap? If you did you should see a ‘bin’ directory under
> the nek5000 directory that contains executables like genmap, genbox, …
> All executable are build by running './maketools' all in the tools
> directory.
> Marco
> > On Jun 27, 2018, at 5:54 AM, nek5000-users at lists.mcs.anl.gov wrote:
> > Good morning to all users,
> > I've created a mesh on GAMBIT and then converted it to Nek using a
> Matlab software that I found in this community.
> > The conversion seems to have worked fine, but right now I want to launch
> the simulation with several processors. Therefore, I need to run the
> "genmap" function and I am having trouble with it.
> > Could anyone explain me how to create the .map file? I've tried writing
> the command "genmap" in the terminal with the corresponding directories but
> it's not working.
> > The .rea/.usr/SIZE, etc files are in directory /home3/Desktop/R0025
> > While the genmap file is in the directory
> /home3/Programmi/nek5_svn/trunk/tools/genmap.
> > What should I exactly write in the terminal as a command?
> > Thank you very much,
> > Roger
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180627/2543cdb3/attachment.html>
