[Nek5000-users] Running genmap
Wed Jun 27 08:03:42 CDT 2018
Roger,
did you build genmap? If you did you should see a ‘bin’ directory under the nek5000 directory that contains executables like genmap, genbox, …
All executable are build by running './maketools' all in the tools directory.
Marco
> On Jun 27, 2018, at 5:54 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Good morning to all users,
> I've created a mesh on GAMBIT and then converted it to Nek using a Matlab software that I found in this community.
> The conversion seems to have worked fine, but right now I want to launch the simulation with several processors. Therefore, I need to run the "genmap" function and I am having trouble with it.
> Could anyone explain me how to create the .map file? I've tried writing the command "genmap" in the terminal with the corresponding directories but it's not working.
> The .rea/.usr/SIZE, etc files are in directory /home3/Desktop/R0025
> While the genmap file is in the directory /home3/Programmi/nek5_svn/trunk/tools/genmap.
> What should I exactly write in the terminal as a command?
> Thank you very much,
> Roger
> Nek5000-users mailing list
