[Nek5000-users] Periodic-AUTO using pretex problem
Wed Jun 13 14:17:27 CDT 2018
Dear Sijo,
I would recommend using n2to3 to extrude
the 2D geometry
and then periodicity will be built in.
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Wednesday, June 13, 2018 11:54:13 AM
To: nek5000-users
Subject: [Nek5000-users] Periodic-AUTO using pretex problem
Hello Neks,
I was setting up a mesh of NACA foil in 3D with periodic BC on both sides. Since there was some problem with converting BC's from ICEM to NEK5000. I gave a space as BC and then using prex I fill up the empy spaces by using periodic Auto button.
But its running for a long time. It means its running through the same elements again and again.
I tired on a simple case (example a cube). it worked well.
The difference between the NACA case and cube is that, along the spanwise direction of NACA I did not give any elements (i just give a thickness to the mesh) but for the cube there were 2 elements in Z direction.
So could you please tell me how can I solve this problem?
Thanks in advance
Sijo GEORGE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180613/e4859345/attachment.html>
