[Nek5000-users] Periodic-AUTO using pretex problem
Wed Jun 13 11:54:13 CDT 2018
Hello Neks,
I was setting up a mesh of NACA foil in 3D with periodic BC on both sides. Since there was some problem with converting BC's from ICEM to NEK5000. I gave a space as BC and then using prex I fill up the empy spaces by using periodic Auto button.
But its running for a long time. It means its running through the same elements again and again.
I tired on a simple case (example a cube). it worked well.
The difference between the NACA case and cube is that, along the spanwise direction of NACA I did not give any elements (i just give a thickness to the mesh) but for the cube there were 2 elements in Z direction.
So could you please tell me how can I solve this problem?
Thanks in advance
Sijo GEORGE
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180613/0d14dddb/attachment.html>
