[Nek5000-users] Extruding 2D .fld file to 3D
Sun Jul 8 14:16:35 CDT 2018
Hi Wei,
Try using the attached usr file.. Make sure the following parameters are set correctly in userchk:
      resname = 'ext_cyl.fld17'
      nel2m = 1472
where nel2m is the number of elements in 2D mesh (3d mesh should be n2to3 of this 2D mesh, and lx1 should stay the same), and resname is the name of the ascii fld file. This usr file DOES NOT utilize lelx,lely,lelz etc...
If this does not work, we can connect via email and I can try to help you do this.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180708/6e95062b/attachment.html>
Desc: fld2to3.usr
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180708/6e95062b/attachment.obj>
Desc: README
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180708/6e95062b/attachment-0001.obj>
