[Nek5000-users] Extruding 2D .fld file to 3D
Wed Jul 11 02:25:19 CDT 2018
Dear Ketan,
Thanks for your quick response! I tried your subroutine, and  found that
the output results as followed:
1. the coordinates is correctly written as  I want.
2.  while the u- and v-velocity is replaced by the coordinates values of x
and y, respectively.
3.  The u component is stored in the "pressure variable". no v and pressure
is stored.
I tried to change the *usr setup, but make it more worse, would you like to
help me to solve it? Thanks!
regards,
Wei
On Mon, Jul 9, 2018 at 3:16 AM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Wei,
> Try using the attached usr file.. Make sure the following parameters are
> set correctly in userchk:
>       resname = 'ext_cyl.fld17'
>       nel2m = 1472
> where nel2m is the number of elements in 2D mesh (3d mesh should be n2to3
> of this 2D mesh, and lx1 should stay the same), and resname is the name of
> the ascii fld file. This usr file DOES NOT utilize lelx,lely,lelz etc...
> If this does not work, we can connect via email and I can try to help you
> do this.
> Ketan
> Nek5000-users mailing list
Wei HE 何偉
School of Aeronautics
Universidad Politécnica de Madrid
http://www.cfm.upm.es/
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180711/d8cd9dc7/attachment.html>
