[Nek5000-users] Extruding 2D .fld file to 3D
Sun Jul 8 01:30:06 CDT 2018
Dear Paul and Neks,
I followed your instructions to extrude a 2D field results to 3D:
What I did are:
1. run the 2D simulation to get a 2D ascii field. I actived UPT, there
should be 6 columns. as followed:
1874   6   6   1 6.0000000E+02    0 X Y U P T
NELT,NX,NY,N
  0.000      0.000      0.000      0.000      0.000      0.000
* 0.000      0.000*
  1.000000E+00  1.550000E+01  9.999999E-01  1.290108E-02  8.919954E-08
0.000000E+00
  8.825276E-01  1.550000E+01  9.999999E-01  1.281575E-02  1.081013E-07
0.000000E+00
  6.426157E-01  1.550000E+01  9.999999E-01  1.264053E-02  1.421044E-07
0.000000E+00
  3.573842E-01  1.550000E+01  1.000000E+00  1.243110E-02  1.706964E-07
0.000000E+00
2.  I get rid the first line,  and the row only contains two-column
3. generated a 3D mesh by n2to3, using 4 levels in 1-spanwise length
4. setup a 3D simulation by a modified SIZE
      parameter (lelx=1874,lely=1,lelz=4) ! global tensor mesh dimensions
5. define usrdat2 as follows
      subroutine usrdat2
      include 'SIZE'
      include 'TOTAL'
       parameter (l2d=lx1*ly1*lelx) ! Number of points in 2D field
       common /mystuff/ u2d(l2d),v2d(l2d)
       nelx=lelx
       nely=lely
       nelz=lelz
       if (nid.eq.0) then
          open(33,file='2D.dat')
          do i=1,l2d
                read(33,*) u2d(i),v2d(i)
          enddo
          close(33)
       endif
       nbytes = 8*l2d
      call bcast(u2d,nbytes)
      call bcast(v2d,nbytes)
       call z_average_transpose(vx,u2d) ! distribute u2d to each plane vx
       call z_average_transpose(vy,v2d)
       call outpost(vx,vy,vz,pr,t,'   ')
       call exitti('Quit in usrdat2.$',nelgt)
      return
      end
6 run the 3D simulation, and it appears
 call usrdat2
Program received signal SIGFPE: Floating-point exception - erroneous
arithmetic operation.
Backtrace for this error:
#0  0x7FB31EDF4407
#1  0x7FB31EDF4A1E
#2  0x7FB31E0F40DF
#0  0x7F66D6B5B407
#1  0x7F66D6B5BA1E
#2  0x7F66D5E5B0DF
#3  0x4ADA8B in get_exyz_
#4  0x4AE100 in z_average_transpose_
#5  0x40381B in usrdat2_
#6  0x404017 in nek_init_
#0  0x7F9A77280407
#1  0x7F9A77280A1E
#2  0x7F9A765800DF
#0  0x7FD15A1FE407
#1  0x7FD15A1FEA1E
#2  0x7FD1594FE0DF
Primary job  terminated normally, but 1 process returne
I tried different parameters, unfortunately none of them works, Would
anyone like to help me?
Thanks!
Wei
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180708/4cba684b/attachment.html>
