[Nek5000-users] v17.0 vs v17.0.0.beta2 regarding Stress Formulation and Pn/Pn-2
Tue Feb 13 09:53:15 CST 2018
Dear All,
I am using mixed 'W   ' and 'SYM' boundary conditions on a boundary that is
not aligned with x,y,z axes. (with IFSTRS=T)
When using the previous v17.0.0.beta2 version, I could use these mixed
boundary conditions with the Pn/Pn pressure formulation, giving a
continuous pressure field.
After upgrading to v17.0, I get a number of the following runtime errors
when using Pn/Pn:
Mixed B.C. on a side nonaligned with either the X,Y, or Z axis detected for
  Element           8    side           1
  Requires PN/PN-2 STRESS FORMULATION
Pn/Pn-2 runs, as expected. Granted that I have to use Pn/Pn-2 for mixed BC
when not aligned with an axis, the problem is that the pressure is
discontinuous, which is stated in the documentation for the Pn/Pn-2
formulation. This is evident when plotting the pressure in Visit. Is there
a way to obtain a smooth (correct?) pressure field when using Pn/Pn-2? Or
is there a way to use the Pn/Pn formulation with such boundary conditions?
Thank you,
Jean
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180213/1f930c9c/attachment.html>
