[Nek5000-users] Restart using second order scheme
Tue Feb 13 06:16:16 CST 2018
Thanks very much Philipp.
NN.
On 02/13/2018 01:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> if you do not do full restart, your first time step will be first
> order. Particularly important is also that if you do not have a good
> pressure initial condition, you might get large pressure errors, which
> might require you to use the coupled (Uzawa) algorithm (for PnPn-2).
> Philipp
> On 2018-02-13 12:30, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Neks:
>>    I am using second order time time integration scheme for the
>> computations.
>> Since the second order scheme uses the flow field at (n) and (n-1) to
>> compute
>> the solution at (n+1) we need two files to do a full restart. If,
>> however, we do
>> not do a full restart and simply load the file using restart feature
>> in .rea file,
>> how is the second order scheme implemented for the first time step?
>> Thank you.
>> Best wishes,
>> NN.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
