[Nek5000-users] Restart using second order scheme
Tue Feb 13 06:13:20 CST 2018
if you do not do full restart, your first time step will be first order.
Particularly important is also that if you do not have a good pressure
initial condition, you might get large pressure errors, which might
require you to use the coupled (Uzawa) algorithm (for PnPn-2).
Philipp
On 2018-02-13 12:30, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Neks:
>    I am using second order time time integration scheme for the
> computations.
> Since the second order scheme uses the flow field at (n) and (n-1) to
> compute
> the solution at (n+1) we need two files to do a full restart. If,
> however, we do
> not do a full restart and simply load the file using restart feature in
> .rea file,
> how is the second order scheme implemented for the first time step?
> Thank you.
> Best wishes,
> NN.
> Nek5000-users mailing list
