[Nek5000-users] Exodus II to Nek
Thu Aug 30 06:12:46 CDT 2018
Note, the exo2nek converter doesn't support periodic boundary conditions.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 30th August 2018 12:42
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Exodus II to Nek
> Sorry for asking again, but I need to check  that the boundary conditions are all satisfied.
> I have checked the velocities, the only axial velocity is exactly same. That is may be, I am applying the periodic boundary conditions in the axial direction only, or the way I calculated the azimuthal and radial velocities is not sufficient, is that right?
> Hint, I drive the flow using a force like the way of turbChannel example. Also,I am using VisIt to calculate and plot the velocity components. My pipe length is 5D, which I think it is sufficient to capture all turbulence scales.
> Ali
> Embry-Riddle Aeronautical University
> Nek5000-users mailing list
