[Nek5000-users] Exodus II to Nek
Thu Aug 30 05:40:03 CDT 2018
Sorry for asking again, but I need to check  that the boundary conditions are all satisfied.
I have checked the velocities, the only axial velocity is exactly same. That is may be, I am applying the periodic boundary conditions in the axial direction only, or the way I calculated the azimuthal and radial velocities is not sufficient, is that right?
Hint, I drive the flow using a force like the way of turbChannel example. Also,I am using VisIt to calculate and plot the velocity components. My pipe length is 5D, which I think it is sufficient to capture all turbulence scales.
Ali
Embry-Riddle Aeronautical University
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180830/a982064a/attachment.html>
