[Nek5000-users] Interpolation with gfldr
Sat Aug 4 08:21:44 CDT 2018
Is your input file SP oder DP? Are you using Pn/Pn or Pn/Pn-2?
On 4 Aug 2018, at 03:37, "nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> " <nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov> > wrote:
Hi, Neks!
I am working with a complex geometry which was built in gambit. I have a velocity fields for my grid. But I want to interpolate these velocity fields to a new grid. The old grid was changed without moving the geometry parameters, I just changed the position of the computational nodes and reduced their number (see pictures old_grid and new_grid *). During interpolation with gfldr:
call userchk
call gfldr wing0.f00001
WARNING: Unable to find all mesh points in source fld 39404
done :: gfldr 0.20E+03 sec
done :: userchk
After that, interpolation ends as usual. The velocity field is interpolated perfectly, but the pressure field is not interpolated correctly (see pictures pressure_field_before_interpolation and pressure_field_after_interpolation **).
Tell me, what is my mistake? Is it possible to interpolate from a larger number of nodes to a smaller number of nodes?
*https://drive.google.com/open?id=1DmsGxc_WR3_aJW0UpLHkcxAVzt5BzABK
 https://drive.google.com/open?id=1RbSsODF49DqGmyHnpz0Bktp-HDjW7j0w
**https://drive.google.com/open?id=16Ueepa1lo_aHjya3BnLn8fHI3ek0kvo8
   https://drive.google.com/open?id=1CNiN8MdE7tNeu8T4jBtZBtMSX5dlXzNM
Best regards,
Elizabeth
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180804/b4a7f925/attachment.html>
