[Nek5000-users] plunging flat plate doesn't start
Thu Sep 14 00:14:01 CDT 2017
I am trying to simulate a plunging flat plate at various reduced
frequency and amplitude.
I successfully played a fixed plate invested by a freestream flow, with
Wall conditions on the infintely thin plate, dirichelt upstream, on the
top and on the bottom and outlet downstream.
Mesh is composed by six box around the plate.
When I tried to switch on the plunging plate case, changing the Wall
condition to mv, I can't see the plate moving (I tried to increase both
frequency and amplitude, but I can't see the movement), and the
simulation, after
two steps suddendly diverges. You can see in the attachement the box,
rea, usr map and SIZE I used. I need the vorticity field, and later on,
its time derivative, all over the fluid flow.
Can you help me?
Thanks, Mario
Mario Ostieri
Ph.D. Student
University of Naples Federico II
Department of Industrial Engineering
Piazzale V. Tecchio 80
80125 Napoli, Italy
tel. +390817682184
email: mario.ostieri at unina.it
Type: application/vnd.previewsystems.box
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170914/d6bdfff7/attachment-0001.box>
        1536        1617          10        1024        6144        1617           0
          85          36         137          35         136
          87         137          34         136         135
          87          34         151         135         150
          93         151         145         150         144
          95         145          33         144         143
          95          33         203         143         202
         117         203         177         202         176
         119         177          32         176         175
         119          32         190         175         189
         125         190         184         189         183
         127         184          31         183         182
         127          31         403         182         402
         189         403         280         402         279
         191         280          30         279         278
         191          30         286         278         285
         183         286          29         285         273
          85          35         136         140         139
          84         136         135         139         138
          86         135         150         138         149
          93         150         144         149         147
          92         144         143         147         146
          94         143         202         146         201
         117         202         176         201         179
         116         176         175         179         178
         118         175         189         178         188
         125         189         183         188         186
         124         183         182         186         185
         126         182         402         185         401
         189         402         279         401         282
         188         279         278         282         281
         190         278         285         281         284
         182         285         273         284         275
          81         140         139          28         134
          83         139         138         134         133
          83         138         149         133         148
          89         149         147         148         142
          91         147         146         142         141
          91         146         201         141         200
         113         201         179         200         174
         115         179         178         174         173
         115         178         188         173         187
         121         188         186         187         181
         123         186         185         181         180
         123         185         401         180         400
         185         401         282         400         277
         187         282         281         277         276
         187         281         284         276         283
         179         284         275         283         270
          81          28         134         157         156
          80         134         133         156         155
          82         133         148         155         154
          89         148         142         154         153
          88         142         141         153         152
          90         141         200         152         199
         113         200         174         199         195
         112         174         173         195         194
         114         173         187         194         193
         121         187         181         193         192
         120         181         180         192         191
         122         180         400         191         399
         185         400         277         399         291
         184         277         276         291         290
         186         276         283         290         289
         178         283         270         289         288
          69         157         156          27         120
          71         156         155         120         119
          71         155         154         119         132
          77         154         153         132         127
          79         153         152         127         126
          79         152         199         126         198
         101         199         195         198         161
         103         195         194         161         160
         103         194         193         160         172
         109         193         192         172         167
         111         192         191         167         166
         111         191         399         166         398
         173         399         291         398         263
         175         291         290         263         262
         175         290         289         262         268
         167         289         288         268         257
          69          27         120         123         122
          68         120         119         122         121
          70         119         132         121         131
          77         132         127         131         129
          76         127         126         129         128
          78         126         198         128         197
         101         198         161         197         163
         100         161         160         163         162
         102         160         172         162         171
         109         172         167         171         169
         108         167         166         169         168
         110         166         398         168         397
         173         398         263         397         265
         172         263         262         265         264
         174         262         268         264         267
         166         268         257         267         259
          65         123         122          26         118
          67         122         121         118         117
          67         121         131         117         130
          73         131         129         130         125
          75         129         128         125         124
          75         128         197         124         196
          97         197         163         196         159
          99         163         162         159         158
          99         162         171         158         170
         105         171         169         170         165
         107         169         168         165         164
         107         168         397         164         396
         169         397         265         396         261
         171         265         264         261         260
         171         264         267         260         266
         163         267         259         266         255
          65          26         118         215         214
          64         118         117         214         213
          66         117         130         213         212
          73         130         125         212         211
          72         125         124         211         210
          74         124         196         210         209
          97         196         159         209         208
          96         159         158         208         207
          98         158         170         207         206
         105         170         165         206         205
         104         165         164         205         204
         106         164         396         204         395
         169         396         261         395         387
         168         261         260         387         386
         170         260         266         386         385
         162         266         255         385         384
          21         215         214          25          56
          23         214         213          56          55
          23         213         212          55          68
          29         212         211          68          63
          31         211         210          63          62
          31         210         209          62         116
          53         209         208         116          93
          55         208         207          93          92
          55         207         206          92         104
          61         206         205         104          99
          63         205         204          99          98
          63         204         395          98         394
         253         395         387         394         359
         255         387         386         359         358
         255         386         385         358         364
         247         385         384         364         353
          21          25          56          59          58
          20          56          55          58          57
          22          55          68          57          67
          29          68          63          67          65
          28          63          62          65          64
          30          62         116          64         115
          53         116          93         115          95
          52          93          92          95          94
          54          92         104          94         103
          61         104          99         103         101
          60          99          98         101         100
          62          98         394         100         393
         253         394         359         393         361
         252         359         358         361         360
         254         358         364         360         363
         246         364         353         363         355
          17          59          58          24          54
          19          58          57          54          53
          19          57          67          53          66
          25          67          65          66          61
          27          65          64          61          60
          27          64         115          60         114
          49         115          95         114          91
          51          95          94          91          90
          51          94         103          90         102
          57         103         101         102          97
          59         101         100          97          96
          59         100         393          96         392
         249         393         361         392         357
         251         361         360         357         356
         251         360         363         356         362
         243         363         355         362         351
          17          24          54          74          73
          16          54          53          73          72
          18          53          66          72          71
          25          66          61          71          70
          24          61          60          70          69
          26          60         114          69         113
          49         114          91         113         109
          48          91          90         109         108
          50          90         102         108         107
          57         102          97         107         106
          56          97          96         106         105
          58          96         392         105         391
         249         392         357         391         369
         248         357         356         369         368
         250         356         362         368         367
         242         362         351         367         366
           5          74          73          23          40
           7          73          72          40          39
           7          72          71          39          52
          13          71          70          52          47
          15          70          69          47          46
          15          69         113          46         112
          37         113         109         112          78
          39         109         108          78          77
          39         108         107          77          89
          45         107         106          89          84
          47         106         105          84          83
          47         105         391          83         390
         237         391         369         390         344
         239         369         368         344         343
         239         368         367         343         349
         231         367         366         349         338
           5          23          40          43          42
           4          40          39          42          41
           6          39          52          41          51
          13          52          47          51          49
          12          47          46          49          48
          14          46         112          48         111
          37         112          78         111          80
          36          78          77          80          79
          38          77          89          79          88
          45          89          84          88          86
          44          84          83          86          85
          46          83         390          85         389
         237         390         344         389         346
         236         344         343         346         345
         238         343         349         345         348
         230         349         338         348         340
           1          43          42          22          38
           3          42          41          38          37
           3          41          51          37          50
           9          51          49          50          45
          11          49          48          45          44
          11          48         111          44         110
          33         111          80         110          76
          35          80          79          76          75
          35          79          88          75          87
          41          88          86          87          82
          43          86          85          82          81
          43          85         389          81         388
         233         389         346         388         342
         235         346         345         342         341
         235         345         348         341         347
         227         348         340         347         336
           1          22          38         802         801
           0          38          37         801         800
           2          37          50         800         799
           9          50          45         799         798
           8          45          44         798         797
          10          44         110         797         796
          33         110          76         796         795
          32          76          75         795         794
          34          75          87         794         793
          41          87          82         793         792
          40          82          81         792         791
          42          81         388         791         790
         233         388         342         790         789
         232         342         341         789         788
         234         341         347         788         787
         226         347         336         787         786
         341         802         801          21         514
         343         801         800         514         513
         343         800         799         513         526
         349         799         798         526         521
         351         798         797         521         520
         351         797         796         520         574
         373         796         795         574         551
         375         795         794         551         550
         375         794         793         550         562
         381         793         792         562         557
         383         792         791         557         556
         383         791         790         556         778
         445         790         789         778         646
         447         789         788         646         645
         447         788         787         645         651
         439         787         786         651         640
         341          21         514         517         516
         340         514         513         516         515
         342         513         526         515         525
         349         526         521         525         523
         348         521         520         523         522
         350         520         574         522         573
         373         574         551         573         553
         372         551         550         553         552
         374         550         562         552         561
         381         562         557         561         559
         380         557         556         559         558
         382         556         778         558         777
         445         778         646         777         648
         444         646         645         648         647
         446         645         651         647         650
         438         651         640         650         642
         337         517         516          20         512
         339         516         515         512         511
         339         515         525         511         524
         345         525         523         524         519
         347         523         522         519         518
         347         522         573         518         572
         369         573         553         572         549
         371         553         552         549         548
         371         552         561         548         560
         377         561         559         560         555
         379         559         558         555         554
         379         558         777         554         776
         441         777         648         776         644
         443         648         647         644         643
         443         647         650         643         649
         435         650         642         649         638
         337          20         512         532         531
         336         512         511         531         530
         338         511         524         530         529
         345         524         519         529         528
         344         519         518         528         527
         346         518         572         527         571
         369         572         549         571         567
         368         549         548         567         566
         370         548         560         566         565
         377         560         555         565         564
         376         555         554         564         563
         378         554         776         563         775
         441         776         644         775         656
         440         644         643         656         655
         442         643         649         655         654
         434         649         638         654         653
         325         532         531          19         498
         327         531         530         498         497
         327         530         529         497         510
         333         529         528         510         505
         335         528         527         505         504
         335         527         571         504         570
         357         571         567         570         536
         359         567         566         536         535
         359         566         565         535         547
         365         565         564         547         542
         367         564         563         542         541
         367         563         775         541         774
         429         775         656         774         631
         431         656         655         631         630
         431         655         654         630         636
         423         654         653         636         625
         325          19         498         501         500
         324         498         497         500         499
         326         497         510         499         509
         333         510         505         509         507
         332         505         504         507         506
         334         504         570         506         569
         357         570         536         569         538
         356         536         535         538         537
         358         535         547         537         546
         365         547         542         546         544
         364         542         541         544         543
         366         541         774         543         773
         429         774         631         773         633
         428         631         630         633         632
         430         630         636         632         635
         422         636         625         635         627
         321         501         500          18         496
         323         500         499         496         495
         323         499         509         495         508
         329         509         507         508         503
         331         507         506         503         502
         331         506         569         502         568
         353         569         538         568         534
         355         538         537         534         533
         355         537         546         533         545
         361         546         544         545         540
         363         544         543         540         539
         363         543         773         539         772
         425         773         633         772         629
         427         633         632         629         628
         427         632         635         628         634
         419         635         627         634         623
         321          18         496         586         585
         320         496         495         585         584
         322         495         508         584         583
         329         508         503         583         582
         328         503         502         582         581
         330         502         568         581         580
         353         568         534         580         579
         352         534         533         579         578
         354         533         545         578         577
         361         545         540         577         576
         360         540         539         576         575
         362         539         772         575         771
         425         772         629         771         762
         424         629         628         762         761
         426         628         634         761         760
         418         634         623         760         759
         277         586         585          17         428
         279         585         584         428         427
         279         584         583         427         440
         285         583         582         440         435
         287         582         581         435         434
         287         581         580         434         494
         309         580         579         494         470
         311         579         578         470         469
         311         578         577         469         481
         317         577         576         481         476
         319         576         575         476         475
         319         575         771         475         770
         509         771         762         770         733
         511         762         761         733         732
         511         761         760         732         738
         503         760         759         738         727
         277          17         428         431         430
         276         428         427         430         429
         278         427         440         429         439
         285         440         435         439         437
         284         435         434         437         436
         286         434         494         436         493
         309         494         470         493         472
         308         470         469         472         471
         310         469         481         471         480
         317         481         476         480         478
         316         476         475         478         477
         318         475         770         477         769
         509         770         733         769         735
         508         733         732         735         734
         510         732         738         734         737
         502         738         727         737         729
         273         431         430          16         426
         275         430         429         426         425
         275         429         439         425         438
         281         439         437         438         433
         283         437         436         433         432
         283         436         493         432         492
         305         493         472         492         468
         307         472         471         468         467
         307         471         480         467         479
         313         480         478         479         474
         315         478         477         474         473
         315         477         769         473         768
         505         769         735         768         731
         507         735         734         731         730
         507         734         737         730         736
         499         737         729         736         725
         273          16         426         446         445
         272         426         425         445         444
         274         425         438         444         443
         281         438         433         443         442
         280         433         432         442         441
         282         432         492         441         491
         305         492         468         491         486
         304         468         467         486         485
         306         467         479         485         484
         313         479         474         484         483
         312         474         473         483         482
         314         473         768         482         767
         505         768         731         767         743
         504         731         730         743         742
         506         730         736         742         741
         498         736         725         741         740
         261         446         445          15         409
         263         445         444         409         408
         263         444         443         408         424
         269         443         442         424         418
         271         442         441         418         417
         271         441         491         417         490
         293         491         486         490         452
         295         486         485         452         451
         295         485         484         451         466
         301         484         483         466         460
         303         483         482         460         459
         303         482         767         459         766
         493         767         743         766         717
         495         743         742         717         716
         495         742         741         716         723
         487         741         740         723         709
         261          15         409         412         411
         260         409         408         411         410
         262         408         424         410         423
         269         424         418         423         420
         268         418         417         420         419
         270         417         490         419         489
         293         490         452         489         454
         292         452         451         454         453
         294         451         466         453         465
         301         466         460         465         462
         300         460         459         462         461
         302         459         766         461         765
         493         766         717         765         719
         492         717         716         719         718
         494         716         723         718         722
         486         723         709         722         711
         257         412         411          14         407
         259         411         410         407         406
         259         410         423         406         422
         265         423         420         422         416
         267         420         419         416         415
         267         419         489         415         488
         289         489         454         488         450
         291         454         453         450         449
         291         453         465         449         464
         297         465         462         464         458
         299         462         461         458         457
         299         461         765         457         764
         489         765         719         764         715
         491         719         718         715         714
         491         718         722         714         721
         483         722         711         721         707
         257          14         407          13         404
         256         407         406         404         405
         258         406         422         405         421
         265         422         416         421         413
         264         416         415         413         414
         266         415         488         414         487
         289         488         450         487         447
         288         450         449         447         448
         290         449         464         448         463
         297         464         458         463         455
         296         458         457         455         456
         298         457         764         456         763
         489         764         715         763         712
         488         715         714         712         713
         490         714         721         713         720
         482         721         707         720         706
         183          29         272         273         271
         181         272         299         271         298
         149         299         235         298         234
         151         235          12         234         233
         151          12         248         233         247
         157         248         242         247         241
         159         242          11         241         240
         159          11        1617         240        1616
         565        1617         861        1616         860
         567         861          10         860         859
         567          10         874         859         873
         573         874         868         873         867
         575         868           9         867         866
         575           9         887         866         886
         543         887         827         886         830
         542         827         829         830         828
         180         273         271         275         274
         181         271         298         274         297
         149         298         234         297         237
         148         234         233         237         236
         150         233         247         236         246
         157         247         241         246         244
         156         241         240         244         243
         158         240        1616         243        1615
         565        1616         860        1615         863
         564         860         859         863         862
         566         859         873         862         872
         573         873         867         872         870
         572         867         866         870         869
         574         866         886         869         885
         543         886         830         885         832
         541         830         828         832         831
         179         275         274         270         269
         177         274         297         269         296
         145         297         237         296         232
         147         237         236         232         231
         147         236         246         231         245
         153         246         244         245         239
         155         244         243         239         238
         155         243        1615         238        1614
         561        1615         863        1614         858
         563         863         862         858         857
         563         862         872         857         871
         569         872         870         871         865
         571         870         869         865         864
         571         869         885         864         884
         539         885         832         884         826
         538         832         831         826         825
         176         270         269         288         287
         177         269         296         287         295
         145         296         232         295         253
         144         232         231         253         252
         146         231         245         252         251
         153         245         239         251         250
         152         239         238         250         249
         154         238        1614         249        1613
         561        1614         858        1613         879
         560         858         857         879         878
         562         857         871         878         877
         569         871         865         877         876
         568         865         864         876         875
         570         864         884         875         883
         539         884         826         883         841
         537         826         825         841         840
         167         288         287         257         256
         165         287         295         256         294
         133         295         253         294         219
         135         253         252         219         218
         135         252         251         218         230
         141         251         250         230         225
         143         250         249         225         224
         143         249        1613         224        1612
         549        1613         879        1612         845
         551         879         878         845         844
         551         878         877         844         856
         557         877         876         856         851
         559         876         875         851         850
         559         875         883         850         882
         527         883         841         882         812
         526         841         840         812         811
         164         257         256         259         258
         165         256         294         258         293
         133         294         219         293         221
         132         219         218         221         220
         134         218         230         220         229
         141         230         225         229         227
         140         225         224         227         226
         142         224        1612         226        1611
         549        1612         845        1611         847
         548         845         844         847         846
         550         844         856         846         855
         557         856         851         855         853
         556         851         850         853         852
         558         850         882         852         881
         527         882         812         881         814
         525         812         811         814         813
         163         259         258         255         254
         161         258         293         254         292
         129         293         221         292         217
         131         221         220         217         216
         131         220         229         216         228
         137         229         227         228         223
         139         227         226         223         222
         139         226        1611         222        1610
         545        1611         847        1610         843
         547         847         846         843         842
         547         846         855         842         854
         553         855         853         854         849
         555         853         852         849         848
         555         852         881         848         880
         523         881         814         880         810
         522         814         813         810         809
         160         255         254         384         383
         161         254         292         383         382
         129         292         217         382         381
         128         217         216         381         380
         130         216         228         380         379
         137         228         223         379         378
         136         223         222         378         377
         138         222        1610         377        1609
         545        1610         843        1609         975
         544         843         842         975         974
         546         842         854         974         973
         553         854         849         973         972
         552         849         848         972         971
         554         848         880         971         970
         523         880         810         970         969
         521         810         809         969         968
         247         384         383         353         352
         245         383         382         352         376
         213         382         381         376         318
         215         381         380         318         317
         215         380         379         317         329
         221         379         378         329         324
         223         378         377         324         323
         223         377        1609         323        1608
         629        1609         975        1608         941
         631         975         974         941         940
         631         974         973         940         952
         637         973         972         952         947
         639         972         971         947         946
         639         971         970         946         964
         607         970         969         964         912
         606         969         968         912         911
         244         353         352         355         354
         245         352         376         354         375
         213         376         318         375         320
         212         318         317         320         319
         214         317         329         319         328
         221         329         324         328         326
         220         324         323         326         325
         222         323        1608         325        1607
         629        1608         941        1607         943
         628         941         940         943         942
         630         940         952         942         951
         637         952         947         951         949
         636         947         946         949         948
         638         946         964         948         963
         607         964         912         963         914
         605         912         911         914         913
         243         355         354         351         350
         241         354         375         350         374
         209         375         320         374         316
         211         320         319         316         315
         211         319         328         315         327
         217         328         326         327         322
         219         326         325         322         321
         219         325        1607         321        1606
         625        1607         943        1606         939
         627         943         942         939         938
         627         942         951         938         950
         633         951         949         950         945
         635         949         948         945         944
         635         948         963         944         962
         603         963         914         962         910
         602         914         913         910         909
         240         351         350         366         365
         241         350         374         365         373
         209         374         316         373         334
         208         316         315         334         333
         210         315         327         333         332
         217         327         322         332         331
         216         322         321         331         330
         218         321        1606         330        1605
         625        1606         939        1605         957
         624         939         938         957         956
         626         938         950         956         955
         633         950         945         955         954
         632         945         944         954         953
         634         944         962         953         961
         603         962         910         961         922
         601         910         909         922         921
         231         366         365         338         337
         229         365         373         337         372
         197         373         334         372         303
         199         334         333         303         302
         199         333         332         302         314
         205         332         331         314         309
         207         331         330         309         308
         207         330        1605         308        1604
         613        1605         957        1604         926
         615         957         956         926         925
         615         956         955         925         937
         621         955         954         937         932
         623         954         953         932         931
         623         953         961         931         960
         591         961         922         960         897
         590         922         921         897         896
         228         338         337         340         339
         229         337         372         339         371
         197         372         303         371         305
         196         303         302         305         304
         198         302         314         304         313
         205         314         309         313         311
         204         309         308         311         310
         206         308        1604         310        1603
         613        1604         926        1603         928
         612         926         925         928         927
         614         925         937         927         936
         621         937         932         936         934
         620         932         931         934         933
         622         931         960         933         959
         591         960         897         959         899
         589         897         896         899         898
         227         340         339         336         335
         225         339         371         335         370
         193         371         305         370         301
         195         305         304         301         300
         195         304         313         300         312
         201         313         311         312         307
         203         311         310         307         306
         203         310        1603         306        1602
         609        1603         928        1602         924
         611         928         927         924         923
         611         927         936         923         935
         617         936         934         935         930
         619         934         933         930         929
         619         933         959         929         958
         587         959         899         958         895
         586         899         898         895         894
         224         336         335         786         785
         225         335         370         785         784
         193         370         301         784         783
         192         301         300         783         782
         194         300         312         782         781
         201         312         307         781         780
         200         307         306         780         779
         202         306        1602         779        1601
         609        1602         924        1601        1584
         608         924         923        1584        1583
         610         923         935        1583        1582
         617         935         930        1582        1581
         616         930         929        1581        1580
         618         929         958        1580        1579
         587         958         895        1579        1578
         585         895         894        1578        1577
         439         786         785         640         639
         437         785         784         639         663
         405         784         783         663         605
         407         783         782         605         604
         407         782         781         604         616
         413         781         780         616         611
         415         780         779         611         610
         415         779        1601         610        1600
         821        1601        1584        1600        1232
         823        1584        1583        1232        1231
         823        1583        1582        1231        1243
         829        1582        1581        1243        1238
         831        1581        1580        1238        1237
         831        1580        1579        1237        1255
         799        1579        1578        1255        1203
         798        1578        1577        1203        1202
         436         640         639         642         641
         437         639         663         641         662
         405         663         605         662         607
         404         605         604         607         606
         406         604         616         606         615
         413         616         611         615         613
         412         611         610         613         612
         414         610        1600         612        1599
         821        1600        1232        1599        1234
         820        1232        1231        1234        1233
         822        1231        1243        1233        1242
         829        1243        1238        1242        1240
         828        1238        1237        1240        1239
         830        1237        1255        1239        1254
         799        1255        1203        1254        1205
         797        1203        1202        1205        1204
         435         642         641         638         637
         433         641         662         637         661
         401         662         607         661         603
         403         607         606         603         602
         403         606         615         602         614
         409         615         613         614         609
         411         613         612         609         608
         411         612        1599         608        1598
         817        1599        1234        1598        1230
         819        1234        1233        1230        1229
         819        1233        1242        1229        1241
         825        1242        1240        1241        1236
         827        1240        1239        1236        1235
         827        1239        1254        1235        1253
         795        1254        1205        1253        1201
         794        1205        1204        1201        1200
         432         638         637         653         652
         433         637         661         652         660
         401         661         603         660         621
         400         603         602         621         620
         402         602         614         620         619
         409         614         609         619         618
         408         609         608         618         617
         410         608        1598         617        1597
         817        1598        1230        1597        1248
         816        1230        1229        1248        1247
         818        1229        1241        1247        1246
         825        1241        1236        1246        1245
         824        1236        1235        1245        1244
         826        1235        1253        1244        1252
         795        1253        1201        1252        1213
         793        1201        1200        1213        1212
         423         653         652         625         624
         421         652         660         624         659
         389         660         621         659         590
         391         621         620         590         589
         391         620         619         589         601
         397         619         618         601         596
         399         618         617         596         595
         399         617        1597         595        1596
         805        1597        1248        1596        1217
         807        1248        1247        1217        1216
         807        1247        1246        1216        1228
         813        1246        1245        1228        1223
         815        1245        1244        1223        1222
         815        1244        1252        1222        1251
         783        1252        1213        1251        1188
         782        1213        1212        1188        1187
         420         625         624         627         626
         421         624         659         626         658
         389         659         590         658         592
         388         590         589         592         591
         390         589         601         591         600
         397         601         596         600         598
         396         596         595         598         597
         398         595        1596         597        1595
         805        1596        1217        1595        1219
         804        1217        1216        1219        1218
         806        1216        1228        1218        1227
         813        1228        1223        1227        1225
         812        1223        1222        1225        1224
         814        1222        1251        1224        1250
         783        1251        1188        1250        1190
         781        1188        1187        1190        1189
         419         627         626         623         622
         417         626         658         622         657
         385         658         592         657         588
         387         592         591         588         587
         387         591         600         587         599
         393         600         598         599         594
         395         598         597         594         593
         395         597        1595         593        1594
         801        1595        1219        1594        1215
         803        1219        1218        1215        1214
         803        1218        1227        1214        1226
         809        1227        1225        1226        1221
         811        1225        1224        1221        1220
         811        1224        1250        1220        1249
         779        1250        1190        1249        1186
         778        1190        1189        1186        1185
         416         623         622         759         758
         417         622         657         758         757
         385         657         588         757         756
         384         588         587         756         755
         386         587         599         755         754
         393         599         594         754         753
         392         594         593         753         752
         394         593        1594         752        1593
         801        1594        1215        1593        1353
         800        1215        1214        1353        1352
         802        1214        1226        1352        1351
         809        1226        1221        1351        1350
         808        1221        1220        1350        1349
         810        1220        1249        1349        1348
         779        1249        1186        1348        1347
         777        1186        1185        1347        1346
         503         759         758         727         726
         501         758         757         726         751
         469         757         756         751         687
         471         756         755         687         686
         471         755         754         686         698
         477         754         753         698         693
         479         753         752         693         692
         479         752        1593         692        1592
         885        1593        1353        1592        1318
         887        1353        1352        1318        1317
         887        1352        1351        1317        1329
         893        1351        1350        1329        1324
         895        1350        1349        1324        1323
         895        1349        1348        1323        1342
         863        1348        1347        1342        1284
         862        1347        1346        1284        1283
         500         727         726         729         728
         501         726         751         728         750
         469         751         687         750         689
         468         687         686         689         688
         470         686         698         688         697
         477         698         693         697         695
         476         693         692         695         694
         478         692        1592         694        1591
         885        1592        1318        1591        1320
         884        1318        1317        1320        1319
         886        1317        1329        1319        1328
         893        1329        1324        1328        1326
         892        1324        1323        1326        1325
         894        1323        1342        1325        1341
         863        1342        1284        1341        1286
         861        1284        1283        1286        1285
         499         729         728         725         724
         497         728         750         724         749
         465         750         689         749         685
         467         689         688         685         684
         467         688         697         684         696
         473         697         695         696         691
         475         695         694         691         690
         475         694        1591         690        1590
         881        1591        1320        1590        1316
         883        1320        1319        1316        1315
         883        1319        1328        1315        1327
         889        1328        1326        1327        1322
         891        1326        1325        1322        1321
         891        1325        1341        1321        1340
         859        1341        1286        1340        1282
         858        1286        1285        1282        1281
         496         725         724         740         739
         497         724         749         739         748
         465         749         685         748         703
         464         685         684         703         702
         466         684         696         702         701
         473         696         691         701         700
         472         691         690         700         699
         474         690        1590         699        1589
         881        1590        1316        1589        1334
         880        1316        1315        1334        1333
         882        1315        1327        1333        1332
         889        1327        1322        1332        1331
         888        1322        1321        1331        1330
         890        1321        1340        1330        1339
         859        1340        1282        1339        1294
         857        1282        1281        1294        1293
         487         740         739         709         708
         485         739         748         708         747
         453         748         703         747         669
         455         703         702         669         668
         455         702         701         668         683
         461         701         700         683         677
         463         700         699         677         676
         463         699        1589         676        1588
         869        1589        1334        1588        1300
         871        1334        1333        1300        1299
         871        1333        1332        1299        1314
         877        1332        1331        1314        1308
         879        1331        1330        1308        1307
         879        1330        1339        1307        1338
         847        1339        1294        1338        1268
         846        1294        1293        1268        1267
         484         709         708         711         710
         485         708         747         710         746
         453         747         669         746         671
         452         669         668         671         670
         454         668         683         670         682
         461         683         677         682         679
         460         677         676         679         678
         462         676        1588         678        1587
         869        1588        1300        1587        1302
         868        1300        1299        1302        1301
         870        1299        1314        1301        1313
         877        1314        1308        1313        1310
         876        1308        1307        1310        1309
         878        1307        1338        1309        1337
         847        1338        1268        1337        1270
         845        1268        1267        1270        1269
         483         711         710         707         705
         481         710         746         705         745
         449         746         671         745         667
         451         671         670         667         666
         451         670         682         666         681
         457         682         679         681         675
         459         679         678         675         674
         459         678        1587         674        1586
         865        1587        1302        1586        1298
         867        1302        1301        1298        1297
         867        1301        1313        1297        1312
         873        1313        1310        1312        1306
         875        1310        1309        1306        1305
         875        1309        1337        1305        1336
         843        1337        1270        1336        1266
         842        1270        1269        1266        1265
         480         707         705         706         704
         481         705         745         704         744
         449         745         667         744         664
         448         667         666         664         665
         450         666         681         665         680
         457         681         675         680         672
         456         675         674         672         673
         458         674        1586         673        1585
         865        1586        1298        1585        1295
         864        1298        1297        1295        1296
         866        1297        1312        1296        1311
         873        1312        1306        1311        1303
         872        1306        1305        1303        1304
         874        1305        1336        1304        1335
         843        1336        1266        1335        1264
         841        1266        1265        1264           8
         540         829         836         828         835
         533         836         822         835         821
         535         822           7         821         820
         535           7        1178         820        1177
         725        1178        1079        1177        1078
         727        1079           6        1078        1077
         727           6        1092        1077        1091
         733        1092        1086        1091        1085
         735        1086           5        1085        1084
         735           5        1150        1084        1149
         757        1150        1120        1149        1119
         759        1120           4        1119        1118
         759           4        1136        1118        1135
         765        1136        1129        1135        1128
         767        1129           3        1128        1127
         767           3           2        1127        1126
         541         828         835         831         834
         533         835         821         834         824
         532         821         820         824         823
         534         820        1177         823        1176
         725        1177        1078        1176        1081
         724        1078        1077        1081        1080
         726        1077        1091        1080        1090
         733        1091        1085        1090        1088
         732        1085        1084        1088        1087
         734        1084        1149        1087        1148
         757        1149        1119        1148        1122
         756        1119        1118        1122        1121
         758        1118        1135        1121        1134
         765        1135        1128        1134        1132
         764        1128        1127        1132        1131
         766        1127        1126        1131        1130
         536         831         834         825         833
         529         834         824         833         819
         531         824         823         819         818
         531         823        1176         818        1175
         721        1176        1081        1175        1076
         723        1081        1080        1076        1075
         723        1080        1090        1075        1089
         729        1090        1088        1089        1083
         731        1088        1087        1083        1082
         731        1087        1148        1082        1147
         753        1148        1122        1147        1117
         755        1122        1121        1117        1116
         755        1121        1134        1116        1133
         761        1134        1132        1133        1125
         763        1132        1131        1125        1124
         763        1131        1130        1124        1123
         537         825         833         840         839
         529         833         819         839         838
         528         819         818         838         837
         530         818        1175         837        1174
         721        1175        1076        1174        1097
         720        1076        1075        1097        1096
         722        1075        1089        1096        1095
         729        1089        1083        1095        1094
         728        1083        1082        1094        1093
         730        1082        1147        1093        1146
         753        1147        1117        1146        1142
         752        1117        1116        1142        1141
         754        1116        1133        1141        1140
         761        1133        1125        1140        1139
         760        1125        1124        1139        1138
         762        1124        1123        1138        1137
         524         840         839         811         817
         517         839         838         817         806
         519         838         837         806         805
         519         837        1174         805        1173
         709        1174        1097        1173        1063
         711        1097        1096        1063        1062
         711        1096        1095        1062        1074
         717        1095        1094        1074        1069
         719        1094        1093        1069        1068
         719        1093        1146        1068        1145
         741        1146        1142        1145        1101
         743        1142        1141        1101        1100
         743        1141        1140        1100        1115
         749        1140        1139        1115        1109
         751        1139        1138        1109        1108
         751        1138        1137        1108        1107
         525         811         817         813         816
         517         817         806         816         808
         516         806         805         808         807
         518         805        1173         807        1172
         709        1173        1063        1172        1065
         708        1063        1062        1065        1064
         710        1062        1074        1064        1073
         717        1074        1069        1073        1071
         716        1069        1068        1071        1070
         718        1068        1145        1070        1144
         741        1145        1101        1144        1103
         740        1101        1100        1103        1102
         742        1100        1115        1102        1114
         749        1115        1109        1114        1112
         748        1109        1108        1112        1111
         750        1108        1107        1111        1110
         520         813         816         809         815
         513         816         808         815         804
         515         808         807         804         803
         515         807        1172         803        1171
         705        1172        1065        1171        1061
         707        1065        1064        1061        1060
         707        1064        1073        1060        1072
         713        1073        1071        1072        1067
         715        1071        1070        1067        1066
         715        1070        1144        1066        1143
         737        1144        1103        1143        1099
         739        1103        1102        1099        1098
         739        1102        1114        1098        1113
         745        1114        1112        1113        1106
         747        1112        1111        1106        1105
         747        1111        1110        1105        1104
         521         809         815         968         967
         513         815         804         967         966
         512         804         803         966         965
         514         803        1171         965        1170
         705        1171        1061        1170        1162
         704        1061        1060        1162        1161
         706        1060        1072        1161        1160
         713        1072        1067        1160        1159
         712        1067        1066        1159        1158
         714        1066        1143        1158        1157
         737        1143        1099        1157        1156
         736        1099        1098        1156        1155
         738        1098        1113        1155        1154
         745        1113        1106        1154        1153
         744        1106        1105        1153        1152
         746        1105        1104        1152        1151
         604         968         967         911         917
         597         967         966         917         906
         599         966         965         906         905
         599         965        1170         905        1169
         661        1170        1162        1169         994
         663        1162        1161         994         993
         663        1161        1160         993        1005
         669        1160        1159        1005        1000
         671        1159        1158        1000         999
         671        1158        1157         999        1059
         693        1157        1156        1059        1032
         695        1156        1155        1032        1031
         695        1155        1154        1031        1046
         701        1154        1153        1046        1040
         703        1153        1152        1040        1039
         703        1152        1151        1039        1038
         605         911         917         913         916
         597         917         906         916         908
         596         906         905         908         907
         598         905        1169         907        1168
         661        1169         994        1168         996
         660         994         993         996         995
         662         993        1005         995        1004
         669        1005        1000        1004        1002
         668        1000         999        1002        1001
         670         999        1059        1001        1058
         693        1059        1032        1058        1034
         692        1032        1031        1034        1033
         694        1031        1046        1033        1045
         701        1046        1040        1045        1043
         700        1040        1039        1043        1042
         702        1039        1038        1042        1041
         600         913         916         909         915
         593         916         908         915         904
         595         908         907         904         903
         595         907        1168         903        1167
         657        1168         996        1167         992
         659         996         995         992         991
         659         995        1004         991        1003
         665        1004        1002        1003         998
         667        1002        1001         998         997
         667        1001        1058         997        1057
         689        1058        1034        1057        1030
         691        1034        1033        1030        1029
         691        1033        1045        1029        1044
         697        1045        1043        1044        1037
         699        1043        1042        1037        1036
         699        1042        1041        1036        1035
         601         909         915         921         920
         593         915         904         920         919
         592         904         903         919         918
         594         903        1167         918        1166
         657        1167         992        1166        1010
         656         992         991        1010        1009
         658         991        1003        1009        1008
         665        1003         998        1008        1007
         664         998         997        1007        1006
         666         997        1057        1006        1056
         689        1057        1030        1056        1052
         688        1030        1029        1052        1051
         690        1029        1044        1051        1050
         697        1044        1037        1050        1049
         696        1037        1036        1049        1048
         698        1036        1035        1048        1047
         588         921         920         896         902
         581         920         919         902         891
         583         919         918         891         890
         583         918        1166         890        1165
         645        1166        1010        1165         979
         647        1010        1009         979         978
         647        1009        1008         978         990
         653        1008        1007         990         985
         655        1007        1006         985         984
         655        1006        1056         984        1055
         677        1056        1052        1055        1014
         679        1052        1051        1014        1013
         679        1051        1050        1013        1028
         685        1050        1049        1028        1022
         687        1049        1048        1022        1021
         687        1048        1047        1021        1020
         589         896         902         898         901
         581         902         891         901         893
         580         891         890         893         892
         582         890        1165         892        1164
         645        1165         979        1164         981
         644         979         978         981         980
         646         978         990         980         989
         653         990         985         989         987
         652         985         984         987         986
         654         984        1055         986        1054
         677        1055        1014        1054        1016
         676        1014        1013        1016        1015
         678        1013        1028        1015        1027
         685        1028        1022        1027        1025
         684        1022        1021        1025        1024
         686        1021        1020        1024        1023
         584         898         901         894         900
         577         901         893         900         889
         579         893         892         889         888
         579         892        1164         888        1163
         641        1164         981        1163         977
         643         981         980         977         976
         643         980         989         976         988
         649         989         987         988         983
         651         987         986         983         982
         651         986        1054         982        1053
         673        1054        1016        1053        1012
         675        1016        1015        1012        1011
         675        1015        1027        1011        1026
         681        1027        1025        1026        1019
         683        1025        1024        1019        1018
         683        1024        1023        1018        1017
         585         894         900        1577        1576
         577         900         889        1576        1575
         576         889         888        1575        1574
         578         888        1163        1574        1573
         641        1163         977        1573        1572
         640         977         976        1572        1571
         642         976         988        1571        1570
         649         988         983        1570        1569
         648         983         982        1569        1568
         650         982        1053        1568        1567
         673        1053        1012        1567        1566
         672        1012        1011        1566        1565
         674        1011        1026        1565        1564
         681        1026        1019        1564        1563
         680        1019        1018        1563        1562
         682        1018        1017        1562        1561
         796        1577        1576        1202        1208
         789        1576        1575        1208        1197
         791        1575        1574        1197        1196
         791        1574        1573        1196        1560
         981        1573        1572        1560        1467
         983        1572        1571        1467        1466
         983        1571        1570        1466        1478
         989        1570        1569        1478        1473
         991        1569        1568        1473        1472
         991        1568        1567        1472        1532
        1013        1567        1566        1532        1505
        1015        1566        1565        1505        1504
        1015        1565        1564        1504        1519
        1021        1564        1563        1519        1513
        1023        1563        1562        1513        1512
        1023        1562        1561        1512        1511
         797        1202        1208        1204        1207
         789        1208        1197        1207        1199
         788        1197        1196        1199        1198
         790        1196        1560        1198        1559
         981        1560        1467        1559        1469
         980        1467        1466        1469        1468
         982        1466        1478        1468        1477
         989        1478        1473        1477        1475
         988        1473        1472        1475        1474
         990        1472        1532        1474        1531
        1013        1532        1505        1531        1507
        1012        1505        1504        1507        1506
        1014        1504        1519        1506        1518
        1021        1519        1513        1518        1516
        1020        1513        1512        1516        1515
        1022        1512        1511        1515        1514
         792        1204        1207        1200        1206
         785        1207        1199        1206        1195
         787        1199        1198        1195        1194
         787        1198        1559        1194        1558
         977        1559        1469        1558        1465
         979        1469        1468        1465        1464
         979        1468        1477        1464        1476
         985        1477        1475        1476        1471
         987        1475        1474        1471        1470
         987        1474        1531        1470        1530
        1009        1531        1507        1530        1503
        1011        1507        1506        1503        1502
        1011        1506        1518        1502        1517
        1017        1518        1516        1517        1510
        1019        1516        1515        1510        1509
        1019        1515        1514        1509        1508
         793        1200        1206        1212        1211
         785        1206        1195        1211        1210
         784        1195        1194        1210        1209
         786        1194        1558        1209        1557
         977        1558        1465        1557        1483
         976        1465        1464        1483        1482
         978        1464        1476        1482        1481
         985        1476        1471        1481        1480
         984        1471        1470        1480        1479
         986        1470        1530        1479        1529
        1009        1530        1503        1529        1525
        1008        1503        1502        1525        1524
        1010        1502        1517        1524        1523
        1017        1517        1510        1523        1522
        1016        1510        1509        1522        1521
        1018        1509        1508        1521        1520
         780        1212        1211        1187        1193
         773        1211        1210        1193        1182
         775        1210        1209        1182        1181
         775        1209        1557        1181        1556
         965        1557        1483        1556        1452
         967        1483        1482        1452        1451
         967        1482        1481        1451        1463
         973        1481        1480        1463        1458
         975        1480        1479        1458        1457
         975        1479        1529        1457        1528
         997        1529        1525        1528        1487
         999        1525        1524        1487        1486
         999        1524        1523        1486        1501
        1005        1523        1522        1501        1495
        1007        1522        1521        1495        1494
        1007        1521        1520        1494        1493
         781        1187        1193        1189        1192
         773        1193        1182        1192        1184
         772        1182        1181        1184        1183
         774        1181        1556        1183        1555
         965        1556        1452        1555        1454
         964        1452        1451        1454        1453
         966        1451        1463        1453        1462
         973        1463        1458        1462        1460
         972        1458        1457        1460        1459
         974        1457        1528        1459        1527
         997        1528        1487        1527        1489
         996        1487        1486        1489        1488
         998        1486        1501        1488        1500
        1005        1501        1495        1500        1498
        1004        1495        1494        1498        1497
        1006        1494        1493        1497        1496
         776        1189        1192        1185        1191
         769        1192        1184        1191        1180
         771        1184        1183        1180        1179
         771        1183        1555        1179        1554
         961        1555        1454        1554        1450
         963        1454        1453        1450        1449
         963        1453        1462        1449        1461
         969        1462        1460        1461        1456
         971        1460        1459        1456        1455
         971        1459        1527        1455        1526
         993        1527        1489        1526        1485
         995        1489        1488        1485        1484
         995        1488        1500        1484        1499
        1001        1500        1498        1499        1492
        1003        1498        1497        1492        1491
        1003        1497        1496        1491        1490
         777        1185        1191        1346        1345
         769        1191        1180        1345        1344
         768        1180        1179        1344        1343
         770        1179        1554        1343        1553
         961        1554        1450        1553        1544
         960        1450        1449        1544        1543
         962        1449        1461        1543        1542
         969        1461        1456        1542        1541
         968        1456        1455        1541        1540
         970        1455        1526        1540        1539
         993        1526        1485        1539        1538
         992        1485        1484        1538        1537
         994        1484        1499        1537        1536
        1001        1499        1492        1536        1535
        1000        1492        1491        1535        1534
        1002        1491        1490        1534        1533
         860        1346        1345        1283        1289
         853        1345        1344        1289        1278
         855        1344        1343        1278        1277
         855        1343        1553        1277        1552
         917        1553        1544        1552        1377
         919        1544        1543        1377        1376
         919        1543        1542        1376        1388
         925        1542        1541        1388        1383
         927        1541        1540        1383        1382
         927        1540        1539        1382        1448
         949        1539        1538        1448        1420
         951        1538        1537        1420        1419
         951        1537        1536        1419        1434
         957        1536        1535        1434        1428
         959        1535        1534        1428        1427
         959        1534        1533        1427        1426
         861        1283        1289        1285        1288
         853        1289        1278        1288        1280
         852        1278        1277        1280        1279
         854        1277        1552        1279        1551
         917        1552        1377        1551        1379
         916        1377        1376        1379        1378
         918        1376        1388        1378        1387
         925        1388        1383        1387        1385
         924        1383        1382        1385        1384
         926        1382        1448        1384        1447
         949        1448        1420        1447        1422
         948        1420        1419        1422        1421
         950        1419        1434        1421        1433
         957        1434        1428        1433        1431
         956        1428        1427        1431        1430
         958        1427        1426        1430        1429
         856        1285        1288        1281        1287
         849        1288        1280        1287        1276
         851        1280        1279        1276        1275
         851        1279        1551        1275        1550
         913        1551        1379        1550        1375
         915        1379        1378        1375        1374
         915        1378        1387        1374        1386
         921        1387        1385        1386        1381
         923        1385        1384        1381        1380
         923        1384        1447        1380        1446
         945        1447        1422        1446        1418
         947        1422        1421        1418        1417
         947        1421        1433        1417        1432
         953        1433        1431        1432        1425
         955        1431        1430        1425        1424
         955        1430        1429        1424        1423
         857        1281        1287        1293        1292
         849        1287        1276        1292        1291
         848        1276        1275        1291        1290
         850        1275        1550        1290        1549
         913        1550        1375        1549        1393
         912        1375        1374        1393        1392
         914        1374        1386        1392        1391
         921        1386        1381        1391        1390
         920        1381        1380        1390        1389
         922        1380        1446        1389        1445
         945        1446        1418        1445        1440
         944        1418        1417        1440        1439
         946        1417        1432        1439        1438
         953        1432        1425        1438        1437
         952        1425        1424        1437        1436
         954        1424        1423        1436        1435
         844        1293        1292        1267        1274
         837        1292        1291        1274        1261
         839        1291        1290        1261        1260
         839        1290        1549        1260        1548
         901        1549        1393        1548        1359
         903        1393        1392        1359        1358
         903        1392        1391        1358        1373
         909        1391        1390        1373        1367
         911        1390        1389        1367        1366
         911        1389        1445        1366        1444
         933        1445        1440        1444        1399
         935        1440        1439        1399        1398
         935        1439        1438        1398        1416
         941        1438        1437        1416        1409
         943        1437        1436        1409        1408
         943        1436        1435        1408        1407
         845        1267        1274        1269        1273
         837        1274        1261        1273        1263
         836        1261        1260        1263        1262
         838        1260        1548        1262        1547
         901        1548        1359        1547        1361
         900        1359        1358        1361        1360
         902        1358        1373        1360        1372
         909        1373        1367        1372        1369
         908        1367        1366        1369        1368
         910        1366        1444        1368        1443
         933        1444        1399        1443        1401
         932        1399        1398        1401        1400
         934        1398        1416        1400        1415
         941        1416        1409        1415        1412
         940        1409        1408        1412        1411
         942        1408        1407        1411        1410
         840        1269        1273        1265        1272
         833        1273        1263        1272        1259
         835        1263        1262        1259        1258
         835        1262        1547        1258        1546
         897        1547        1361        1546        1357
         899        1361        1360        1357        1356
         899        1360        1372        1356        1371
         905        1372        1369        1371        1365
         907        1369        1368        1365        1364
         907        1368        1443        1364        1442
         929        1443        1401        1442        1397
         931        1401        1400        1397        1396
         931        1400        1415        1396        1414
         937        1415        1412        1414        1406
         939        1412        1411        1406        1405
         939        1411        1410        1405        1403
         841        1265        1272           8        1271
         833        1272        1259        1271        1256
         832        1259        1258        1256        1257
         834        1258        1546        1257        1545
         897        1546        1357        1545        1354
         896        1357        1356        1354        1355
         898        1356        1371        1355        1370
         905        1371        1365        1370        1362
         904        1365        1364        1362        1363
         906        1364        1442        1363        1441
         929        1442        1397        1441        1394
         928        1397        1396        1394        1395
         930        1396        1414        1395        1413
         937        1414        1406        1413        1402
         936        1406        1405        1402        1404
         938        1405        1403        1404           1
 ****** PARAMETERS *****
    2.610000     NEKTON VERSION
  2  DIMENSIONAL RUN
          118 PARAMETERS FOLLOW
       1.000000         p01 DENSITY
       -300             p02 VISCOS
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p07 RHOCP
       1.000000         p08 CONDUCT
      0.0000000E+00
      0.0000000E+00     p10 FINTIME
      8000.00         p11 NSTEPS
     -1.5915500E-04     p12 DT
      0.0000000E+00     p13 IOCOMM
      0.0000000E+00     p14 IOTIME
        5.0000        p15 IOSTEP
      0.0000000E+00     p16 PSSOLVER
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      1.0000000E-09     p21 DIVERGENCE
      1.0000000E-09     p22 HELMHOLTZ
  0              p23 NPSCAL
      1.0000000E-10     p24 TOLREL
      1.0000000E-05     p25 TOLABS
       1.000000         p26 COURANT/NTAU
       3.000000         p27 TORDER
      0.0000000E+00     p28 TORDER: mesh velocity (0: p28=p27)
      0.0000000E+00     p29 magnetic visc if > 0, = -1/Rm if < 0
      0.0000000E+00     p30 > 0 ==> properties set in uservp()
      0.0000000E+00     p31 NPERT: #perturbation modes
      0.0000000E+00     p32 #BCs in re2 file, if > 0
      0.1591550E+00
      0.1000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p42 0=gmres/1=pcg
      0.0000000E+00     p43 0=semg/1=schwarz
      0.0000000E+00     p44 0=E-based/1=A-based prec.
      0.0000000E+00     p45 Relaxation factor for DTFS
      0.0000000E+00      p46 if >0, dont call SETICS
      0.0000000E+00     p47 vnu: mesh matieral prop
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p52 IOHIS
      0.0000000E+00
      0.0000000E+00     p54 1,2,3-->fixed flow rate dir=x,y,z
      0.0000000E+00     p55 vol.flow rate(p54>0) or Ubar(p54<0)
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p59 !=0 --> use std axhelm for all elem
      0.0000000E+00     p60 !=0--> init velocity to small nonzero
      0.0000000E+00
      0.0000000E+00     p62 >0 --> force byte_swap for output
      0.0000000E+00     p63 =8 --> force 8-byte output
      0.0000000E+00     p64 =1 --> perturbation restart
       1.000000         p65 #iofile(eg,0 or 64); <0 --> sep. dirs
       6.000000         p66 write fmt:ONLY postx uses rea value
       6.000000         p67 read fmt: same modes as p66
      1.0000000E+09     p68 iastep: freq for avg_all
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p74 verbose Helmholtz
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p84 !=0 -->sets initial timestep if p12>0
      0.0000000E+00     p85 dt ratio if p84 !=0, for timesteps>0
      0.0000000E+00     p86 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p89 reserved
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p93 Numbr of prev pressure solns saved
      0.0000000E+00     p94 start projecting vel. after p94 step
      0.0000000E+00     p95 start projecting pr after p95 step
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
       3.000000         p99    dealiasing:if <0 disable
      0.0000000E+00     p100 reserved
      0.0000000E+00     p101   No. of additional filter modes
      0.0000000E+00
      0.0000000E+00     p103   weight of stabilizing filter (.01)
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p107   if !=0, add to h2 in sethlm
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00
      0.0000000E+00     p116  =nelx for gtp solver
      0.0000000E+00     p117  =nely for gtp solver
      0.0000000E+00     p118  =nelz for gtp solver
      4  Lines of passive scalar data follows2 CONDUCT; 2RHOCP
   1.00000       1.00000       1.00000       1.00000       1.00000
          13   LOGICAL SWITCHES FOLLOW
  T     IFFLOW
  F     IFHEAT
 T      IFTRAN
 T F F F F F F F F F F  IFNAV & IFADVC (convection in P.S. fields)
 F F T T T T T T T T T T  IFTMSH (IF mesh for this field is T mesh)
 F      IFAXIS
 T      IFSTRS
 F      IFSPLIT
 F      IFMGRID
 F      IFMODEL
 F      IFKEPS
 T      IFMVBD
 T      IFCHAR
   3.33333       3.33333     -0.833333      -1.16667     XFAC,YFAC,XZERO,YZERO
 **MESH DATA** 1st line is X of corner 1,2,3,4. 2nd line is Y.
        1536  2        1536           NEL,NDIM,NELV
            ELEMENT           1 [    1a]  GROUP  0
  -35.0000      -20.9960      -20.9960      -35.0000
  -30.0000      -30.0000      -17.9966      -17.9966
            ELEMENT           2 [    1b]  GROUP  0
  -20.9960      -12.5937      -12.5937      -20.9960
            ELEMENT           3 [    1c]  GROUP  0
  -12.5937      -7.55226      -7.55226      -12.5937
            ELEMENT           4 [    1d]  GROUP  0
  -7.55226      -4.52740      -4.52740      -7.55226
            ELEMENT           5 [    1e]  GROUP  0
  -4.52740      -2.71249      -2.71249      -4.52740
            ELEMENT           6 [    1f]  GROUP  0
  -2.71249      -1.62354      -1.62354      -2.71249
            ELEMENT           7 [    1g]  GROUP  0
  -1.62354     -0.970176     -0.970176      -1.62354
            ELEMENT           8 [    1h]  GROUP  0
 -0.970176     -0.578155     -0.578155     -0.970176
            ELEMENT           9 [    1i]  GROUP  0
 -0.578155     -0.342942     -0.342942     -0.578155
            ELEMENT          10 [    1j]  GROUP  0
 -0.342942     -0.201815     -0.201815     -0.342942
            ELEMENT          11 [    1k]  GROUP  0
 -0.201815     -0.117138     -0.117138     -0.201815
            ELEMENT          12 [    1l]  GROUP  0
 -0.117138     -0.663322E-01 -0.663322E-01 -0.117138
            ELEMENT          13 [    1m]  GROUP  0
 -0.663322E-01 -0.358487E-01 -0.358487E-01 -0.663322E-01
            ELEMENT          14 [    1n]  GROUP  0
 -0.358487E-01 -0.175585E-01 -0.175585E-01 -0.358487E-01
            ELEMENT          15 [    1o]  GROUP  0
 -0.175585E-01 -0.658445E-02 -0.658445E-02 -0.175585E-01
            ELEMENT          16 [    1p]  GROUP  0
 -0.658445E-02   0.00000       0.00000     -0.658445E-02
            ELEMENT          17 [    1q]  GROUP  0
  -17.9966      -17.9966      -10.7946      -10.7946
            ELEMENT          18 [    1r]  GROUP  0
            ELEMENT          19 [    1s]  GROUP  0
            ELEMENT          20 [    1t]  GROUP  0
            ELEMENT          21 [    1u]  GROUP  0
            ELEMENT          22 [    1v]  GROUP  0
            ELEMENT          23 [    1w]  GROUP  0
            ELEMENT          24 [    1x]  GROUP  0
            ELEMENT          25 [    1y]  GROUP  0
            ELEMENT          26 [    1z]  GROUP  0
            ELEMENT          27 [    1A]  GROUP  0
            ELEMENT          28 [    1B]  GROUP  0
            ELEMENT          29 [    1C]  GROUP  0
            ELEMENT          30 [    1D]  GROUP  0
            ELEMENT          31 [    1E]  GROUP  0
            ELEMENT          32 [    1F]  GROUP  0
            ELEMENT          33 [    1G]  GROUP  0
  -10.7946      -10.7946      -6.47336      -6.47336
            ELEMENT          34 [    1H]  GROUP  0
            ELEMENT          35 [    1I]  GROUP  0
            ELEMENT          36 [    1J]  GROUP  0
            ELEMENT          37 [    1K]  GROUP  0
            ELEMENT          38 [    1L]  GROUP  0
            ELEMENT          39 [    1M]  GROUP  0
            ELEMENT          40 [    1N]  GROUP  0
            ELEMENT          41 [    1O]  GROUP  0
            ELEMENT          42 [    1P]  GROUP  0
            ELEMENT          43 [    1Q]  GROUP  0
            ELEMENT          44 [    1R]  GROUP  0
            ELEMENT          45 [    1S]  GROUP  0
            ELEMENT          46 [    1T]  GROUP  0
            ELEMENT          47 [    1U]  GROUP  0
            ELEMENT          48 [    1V]  GROUP  0
            ELEMENT          49 [    1W]  GROUP  0
  -6.47336      -6.47336      -3.88063      -3.88063
            ELEMENT          50 [    1X]  GROUP  0
            ELEMENT          51 [    1Y]  GROUP  0
            ELEMENT          52 [    1Z]  GROUP  0
            ELEMENT          53 [    1a]  GROUP  0
            ELEMENT          54 [    1b]  GROUP  0
            ELEMENT          55 [    1c]  GROUP  0
            ELEMENT          56 [    1d]  GROUP  0
            ELEMENT          57 [    1e]  GROUP  0
            ELEMENT          58 [    1f]  GROUP  0
            ELEMENT          59 [    1g]  GROUP  0
            ELEMENT          60 [    1h]  GROUP  0
            ELEMENT          61 [    1i]  GROUP  0
            ELEMENT          62 [    1j]  GROUP  0
            ELEMENT          63 [    1k]  GROUP  0
            ELEMENT          64 [    1l]  GROUP  0
            ELEMENT          65 [    1m]  GROUP  0
  -3.88063      -3.88063      -2.32499      -2.32499
            ELEMENT          66 [    1n]  GROUP  0
            ELEMENT          67 [    1o]  GROUP  0
            ELEMENT          68 [    1p]  GROUP  0
            ELEMENT          69 [    1q]  GROUP  0
            ELEMENT          70 [    1r]  GROUP  0
            ELEMENT          71 [    1s]  GROUP  0
            ELEMENT          72 [    1t]  GROUP  0
            ELEMENT          73 [    1u]  GROUP  0
            ELEMENT          74 [    1v]  GROUP  0
            ELEMENT          75 [    1w]  GROUP  0
            ELEMENT          76 [    1x]  GROUP  0
            ELEMENT          77 [    1y]  GROUP  0
            ELEMENT          78 [    1z]  GROUP  0
            ELEMENT          79 [    1A]  GROUP  0
            ELEMENT          80 [    1B]  GROUP  0
            ELEMENT          81 [    1C]  GROUP  0
  -2.32499      -2.32499      -1.39161      -1.39161
            ELEMENT          82 [    1D]  GROUP  0
            ELEMENT          83 [    1E]  GROUP  0
            ELEMENT          84 [    1F]  GROUP  0
            ELEMENT          85 [    1G]  GROUP  0
            ELEMENT          86 [    1H]  GROUP  0
            ELEMENT          87 [    1I]  GROUP  0
            ELEMENT          88 [    1J]  GROUP  0
            ELEMENT          89 [    1K]  GROUP  0
            ELEMENT          90 [    1L]  GROUP  0
            ELEMENT          91 [    1M]  GROUP  0
            ELEMENT          92 [    1N]  GROUP  0
            ELEMENT          93 [    1O]  GROUP  0
            ELEMENT          94 [    1P]  GROUP  0
            ELEMENT          95 [    1Q]  GROUP  0
            ELEMENT          96 [    1R]  GROUP  0
            ELEMENT          97 [    1S]  GROUP  0
  -1.39161      -1.39161     -0.831579     -0.831579
            ELEMENT          98 [    1T]  GROUP  0
            ELEMENT          99 [    1U]  GROUP  0
            ELEMENT         100 [    1V]  GROUP  0
            ELEMENT         101 [    1W]  GROUP  0
            ELEMENT         102 [    1X]  GROUP  0
            ELEMENT         103 [    1Y]  GROUP  0
            ELEMENT         104 [    1Z]  GROUP  0
            ELEMENT         105 [    1a]  GROUP  0
            ELEMENT         106 [    1b]  GROUP  0
            ELEMENT         107 [    1c]  GROUP  0
            ELEMENT         108 [    1d]  GROUP  0
            ELEMENT         109 [    1e]  GROUP  0
            ELEMENT         110 [    1f]  GROUP  0
            ELEMENT         111 [    1g]  GROUP  0
            ELEMENT         112 [    1h]  GROUP  0
            ELEMENT         113 [    1i]  GROUP  0
 -0.831579     -0.831579     -0.495561     -0.495561
            ELEMENT         114 [    1j]  GROUP  0
            ELEMENT         115 [    1k]  GROUP  0
            ELEMENT         116 [    1l]  GROUP  0
            ELEMENT         117 [    1m]  GROUP  0
            ELEMENT         118 [    1n]  GROUP  0
            ELEMENT         119 [    1o]  GROUP  0
            ELEMENT         120 [    1p]  GROUP  0
            ELEMENT         121 [    1q]  GROUP  0
            ELEMENT         122 [    1r]  GROUP  0
            ELEMENT         123 [    1s]  GROUP  0
            ELEMENT         124 [    1t]  GROUP  0
            ELEMENT         125 [    1u]  GROUP  0
            ELEMENT         126 [    1v]  GROUP  0
            ELEMENT         127 [    1w]  GROUP  0
            ELEMENT         128 [    1x]  GROUP  0
            ELEMENT         129 [    1y]  GROUP  0
 -0.495561     -0.495561     -0.293950     -0.293950
            ELEMENT         130 [    1z]  GROUP  0
            ELEMENT         131 [    1A]  GROUP  0
            ELEMENT         132 [    1B]  GROUP  0
            ELEMENT         133 [    1C]  GROUP  0
            ELEMENT         134 [    1D]  GROUP  0
            ELEMENT         135 [    1E]  GROUP  0
            ELEMENT         136 [    1F]  GROUP  0
            ELEMENT         137 [    1G]  GROUP  0
            ELEMENT         138 [    1H]  GROUP  0
            ELEMENT         139 [    1I]  GROUP  0
            ELEMENT         140 [    1J]  GROUP  0
            ELEMENT         141 [    1K]  GROUP  0
            ELEMENT         142 [    1L]  GROUP  0
            ELEMENT         143 [    1M]  GROUP  0
            ELEMENT         144 [    1N]  GROUP  0
            ELEMENT         145 [    1O]  GROUP  0
 -0.293950     -0.293950     -0.172984     -0.172984
            ELEMENT         146 [    1P]  GROUP  0
            ELEMENT         147 [    1Q]  GROUP  0
            ELEMENT         148 [    1R]  GROUP  0
            ELEMENT         149 [    1S]  GROUP  0
            ELEMENT         150 [    1T]  GROUP  0
            ELEMENT         151 [    1U]  GROUP  0
            ELEMENT         152 [    1V]  GROUP  0
            ELEMENT         153 [    1W]  GROUP  0
            ELEMENT         154 [    1X]  GROUP  0
            ELEMENT         155 [    1Y]  GROUP  0
            ELEMENT         156 [    1Z]  GROUP  0
            ELEMENT         157 [    1a]  GROUP  0
            ELEMENT         158 [    1b]  GROUP  0
            ELEMENT         159 [    1c]  GROUP  0
            ELEMENT         160 [    1d]  GROUP  0
            ELEMENT         161 [    1e]  GROUP  0
 -0.172984     -0.172984     -0.100404     -0.100404
            ELEMENT         162 [    1f]  GROUP  0
            ELEMENT         163 [    1g]  GROUP  0
            ELEMENT         164 [    1h]  GROUP  0
            ELEMENT         165 [    1i]  GROUP  0
            ELEMENT         166 [    1j]  GROUP  0
            ELEMENT         167 [    1k]  GROUP  0
            ELEMENT         168 [    1l]  GROUP  0
            ELEMENT         169 [    1m]  GROUP  0
            ELEMENT         170 [    1n]  GROUP  0
            ELEMENT         171 [    1o]  GROUP  0
            ELEMENT         172 [    1p]  GROUP  0
            ELEMENT         173 [    1q]  GROUP  0
            ELEMENT         174 [    1r]  GROUP  0
            ELEMENT         175 [    1s]  GROUP  0
            ELEMENT         176 [    1t]  GROUP  0
            ELEMENT         177 [    1u]  GROUP  0
 -0.100404     -0.100404     -0.568562E-01 -0.568562E-01
            ELEMENT         178 [    1v]  GROUP  0
            ELEMENT         179 [    1w]  GROUP  0
            ELEMENT         180 [    1x]  GROUP  0
            ELEMENT         181 [    1y]  GROUP  0
            ELEMENT         182 [    1z]  GROUP  0
            ELEMENT         183 [    1A]  GROUP  0
            ELEMENT         184 [    1B]  GROUP  0
            ELEMENT         185 [    1C]  GROUP  0
            ELEMENT         186 [    1D]  GROUP  0
            ELEMENT         187 [    1E]  GROUP  0
            ELEMENT         188 [    1F]  GROUP  0
            ELEMENT         189 [    1G]  GROUP  0
            ELEMENT         190 [    1H]  GROUP  0
            ELEMENT         191 [    1I]  GROUP  0
            ELEMENT         192 [    1J]  GROUP  0
            ELEMENT         193 [    1K]  GROUP  0
 -0.568562E-01 -0.568562E-01 -0.307274E-01 -0.307274E-01
            ELEMENT         194 [    1L]  GROUP  0
            ELEMENT         195 [    1M]  GROUP  0
            ELEMENT         196 [    1N]  GROUP  0
            ELEMENT         197 [    1O]  GROUP  0
            ELEMENT         198 [    1P]  GROUP  0
            ELEMENT         199 [    1Q]  GROUP  0
            ELEMENT         200 [    1R]  GROUP  0
            ELEMENT         201 [    1S]  GROUP  0
            ELEMENT         202 [    1T]  GROUP  0
            ELEMENT         203 [    1U]  GROUP  0
            ELEMENT         204 [    1V]  GROUP  0
            ELEMENT         205 [    1W]  GROUP  0
            ELEMENT         206 [    1X]  GROUP  0
            ELEMENT         207 [    1Y]  GROUP  0
            ELEMENT         208 [    1Z]  GROUP  0
            ELEMENT         209 [    1a]  GROUP  0
 -0.307274E-01 -0.307274E-01 -0.150502E-01 -0.150502E-01
            ELEMENT         210 [    1b]  GROUP  0
            ELEMENT         211 [    1c]  GROUP  0
            ELEMENT         212 [    1d]  GROUP  0
            ELEMENT         213 [    1e]  GROUP  0
            ELEMENT         214 [    1f]  GROUP  0
            ELEMENT         215 [    1g]  GROUP  0
            ELEMENT         216 [    1h]  GROUP  0
            ELEMENT         217 [    1i]  GROUP  0
            ELEMENT         218 [    1j]  GROUP  0
            ELEMENT         219 [    1k]  GROUP  0
            ELEMENT         220 [    1l]  GROUP  0
            ELEMENT         221 [    1m]  GROUP  0
            ELEMENT         222 [    1n]  GROUP  0
            ELEMENT         223 [    1o]  GROUP  0
            ELEMENT         224 [    1p]  GROUP  0
            ELEMENT         225 [    1q]  GROUP  0
 -0.150502E-01 -0.150502E-01 -0.564381E-02 -0.564381E-02
            ELEMENT         226 [    1r]  GROUP  0
            ELEMENT         227 [    1s]  GROUP  0
            ELEMENT         228 [    1t]  GROUP  0
            ELEMENT         229 [    1u]  GROUP  0
            ELEMENT         230 [    1v]  GROUP  0
            ELEMENT         231 [    1w]  GROUP  0
            ELEMENT         232 [    1x]  GROUP  0
            ELEMENT         233 [    1y]  GROUP  0
            ELEMENT         234 [    1z]  GROUP  0
            ELEMENT         235 [    1A]  GROUP  0
            ELEMENT         236 [    1B]  GROUP  0
            ELEMENT         237 [    1C]  GROUP  0
            ELEMENT         238 [    1D]  GROUP  0
            ELEMENT         239 [    1E]  GROUP  0
            ELEMENT         240 [    1F]  GROUP  0
            ELEMENT         241 [    1G]  GROUP  0
 -0.564381E-02 -0.564381E-02   0.00000       0.00000
            ELEMENT         242 [    1H]  GROUP  0
            ELEMENT         243 [    1I]  GROUP  0
            ELEMENT         244 [    1J]  GROUP  0
            ELEMENT         245 [    1K]  GROUP  0
            ELEMENT         246 [    1L]  GROUP  0
            ELEMENT         247 [    1M]  GROUP  0
            ELEMENT         248 [    1N]  GROUP  0
            ELEMENT         249 [    1O]  GROUP  0
            ELEMENT         250 [    1P]  GROUP  0
            ELEMENT         251 [    1Q]  GROUP  0
            ELEMENT         252 [    1R]  GROUP  0
            ELEMENT         253 [    1S]  GROUP  0
            ELEMENT         254 [    1T]  GROUP  0
            ELEMENT         255 [    1U]  GROUP  0
            ELEMENT         256 [    1V]  GROUP  0
            ELEMENT         257 [    1W]  GROUP  0
   0.00000       0.00000      0.562859E-02  0.562859E-02
            ELEMENT         258 [    1X]  GROUP  0
            ELEMENT         259 [    1Y]  GROUP  0
            ELEMENT         260 [    1Z]  GROUP  0
            ELEMENT         261 [    1a]  GROUP  0
            ELEMENT         262 [    1b]  GROUP  0
            ELEMENT         263 [    1c]  GROUP  0
            ELEMENT         264 [    1d]  GROUP  0
            ELEMENT         265 [    1e]  GROUP  0
            ELEMENT         266 [    1f]  GROUP  0
            ELEMENT         267 [    1g]  GROUP  0
            ELEMENT         268 [    1h]  GROUP  0
            ELEMENT         269 [    1i]  GROUP  0
            ELEMENT         270 [    1j]  GROUP  0
            ELEMENT         271 [    1k]  GROUP  0
            ELEMENT         272 [    1l]  GROUP  0
            ELEMENT         273 [    1m]  GROUP  0
  0.562859E-02  0.562859E-02  0.150115E-01  0.150115E-01
            ELEMENT         274 [    1n]  GROUP  0
            ELEMENT         275 [    1o]  GROUP  0
            ELEMENT         276 [    1p]  GROUP  0
            ELEMENT         277 [    1q]  GROUP  0
            ELEMENT         278 [    1r]  GROUP  0
            ELEMENT         279 [    1s]  GROUP  0
            ELEMENT         280 [    1t]  GROUP  0
            ELEMENT         281 [    1u]  GROUP  0
            ELEMENT         282 [    1v]  GROUP  0
            ELEMENT         283 [    1w]  GROUP  0
            ELEMENT         284 [    1x]  GROUP  0
            ELEMENT         285 [    1y]  GROUP  0
            ELEMENT         286 [    1z]  GROUP  0
            ELEMENT         287 [    1A]  GROUP  0
            ELEMENT         288 [    1B]  GROUP  0
            ELEMENT         289 [    1C]  GROUP  0
  0.150115E-01  0.150115E-01  0.306527E-01  0.306527E-01
            ELEMENT         290 [    1D]  GROUP  0
            ELEMENT         291 [    1E]  GROUP  0
            ELEMENT         292 [    1F]  GROUP  0
            ELEMENT         293 [    1G]  GROUP  0
            ELEMENT         294 [    1H]  GROUP  0
            ELEMENT         295 [    1I]  GROUP  0
            ELEMENT         296 [    1J]  GROUP  0
            ELEMENT         297 [    1K]  GROUP  0
            ELEMENT         298 [    1L]  GROUP  0
            ELEMENT         299 [    1M]  GROUP  0
            ELEMENT         300 [    1N]  GROUP  0
            ELEMENT         301 [    1O]  GROUP  0
            ELEMENT         302 [    1P]  GROUP  0
            ELEMENT         303 [    1Q]  GROUP  0
            ELEMENT         304 [    1R]  GROUP  0
            ELEMENT         305 [    1S]  GROUP  0
  0.306527E-01  0.306527E-01  0.567266E-01  0.567266E-01
            ELEMENT         306 [    1T]  GROUP  0
            ELEMENT         307 [    1U]  GROUP  0
            ELEMENT         308 [    1V]  GROUP  0
            ELEMENT         309 [    1W]  GROUP  0
            ELEMENT         310 [    1X]  GROUP  0
            ELEMENT         311 [    1Y]  GROUP  0
            ELEMENT         312 [    1Z]  GROUP  0
            ELEMENT         313 [    1a]  GROUP  0
            ELEMENT         314 [    1b]  GROUP  0
            ELEMENT         315 [    1c]  GROUP  0
            ELEMENT         316 [    1d]  GROUP  0
            ELEMENT         317 [    1e]  GROUP  0
            ELEMENT         318 [    1f]  GROUP  0
            ELEMENT         319 [    1g]  GROUP  0
            ELEMENT         320 [    1h]  GROUP  0
            ELEMENT         321 [    1i]  GROUP  0
  0.567266E-01  0.567266E-01  0.100192      0.100192
            ELEMENT         322 [    1j]  GROUP  0
            ELEMENT         323 [    1k]  GROUP  0
            ELEMENT         324 [    1l]  GROUP  0
            ELEMENT         325 [    1m]  GROUP  0
            ELEMENT         326 [    1n]  GROUP  0
            ELEMENT         327 [    1o]  GROUP  0
            ELEMENT         328 [    1p]  GROUP  0
            ELEMENT         329 [    1q]  GROUP  0
            ELEMENT         330 [    1r]  GROUP  0
            ELEMENT         331 [    1s]  GROUP  0
            ELEMENT         332 [    1t]  GROUP  0
            ELEMENT         333 [    1u]  GROUP  0
            ELEMENT         334 [    1v]  GROUP  0
            ELEMENT         335 [    1w]  GROUP  0
            ELEMENT         336 [    1x]  GROUP  0
            ELEMENT         337 [    1y]  GROUP  0
  0.100192      0.100192      0.172648      0.172648
            ELEMENT         338 [    1z]  GROUP  0
            ELEMENT         339 [    1A]  GROUP  0
            ELEMENT         340 [    1B]  GROUP  0
            ELEMENT         341 [    1C]  GROUP  0
            ELEMENT         342 [    1D]  GROUP  0
            ELEMENT         343 [    1E]  GROUP  0
            ELEMENT         344 [    1F]  GROUP  0
            ELEMENT         345 [    1G]  GROUP  0
            ELEMENT         346 [    1H]  GROUP  0
            ELEMENT         347 [    1I]  GROUP  0
            ELEMENT         348 [    1J]  GROUP  0
            ELEMENT         349 [    1K]  GROUP  0
            ELEMENT         350 [    1L]  GROUP  0
            ELEMENT         351 [    1M]  GROUP  0
            ELEMENT         352 [    1N]  GROUP  0
            ELEMENT         353 [    1O]  GROUP  0
  0.172648      0.172648      0.293433      0.293433
            ELEMENT         354 [    1P]  GROUP  0
            ELEMENT         355 [    1Q]  GROUP  0
            ELEMENT         356 [    1R]  GROUP  0
            ELEMENT         357 [    1S]  GROUP  0
            ELEMENT         358 [    1T]  GROUP  0
            ELEMENT         359 [    1U]  GROUP  0
            ELEMENT         360 [    1V]  GROUP  0
            ELEMENT         361 [    1W]  GROUP  0
            ELEMENT         362 [    1X]  GROUP  0
            ELEMENT         363 [    1Y]  GROUP  0
            ELEMENT         364 [    1Z]  GROUP  0
            ELEMENT         365 [    1a]  GROUP  0
            ELEMENT         366 [    1b]  GROUP  0
            ELEMENT         367 [    1c]  GROUP  0
            ELEMENT         368 [    1d]  GROUP  0
            ELEMENT         369 [    1e]  GROUP  0
  0.293433      0.293433      0.494782      0.494782
            ELEMENT         370 [    1f]  GROUP  0
            ELEMENT         371 [    1g]  GROUP  0
            ELEMENT         372 [    1h]  GROUP  0
            ELEMENT         373 [    1i]  GROUP  0
            ELEMENT         374 [    1j]  GROUP  0
            ELEMENT         375 [    1k]  GROUP  0
            ELEMENT         376 [    1l]  GROUP  0
            ELEMENT         377 [    1m]  GROUP  0
            ELEMENT         378 [    1n]  GROUP  0
            ELEMENT         379 [    1o]  GROUP  0
            ELEMENT         380 [    1p]  GROUP  0
            ELEMENT         381 [    1q]  GROUP  0
            ELEMENT         382 [    1r]  GROUP  0
            ELEMENT         383 [    1s]  GROUP  0
            ELEMENT         384 [    1t]  GROUP  0
            ELEMENT         385 [    1u]  GROUP  0
  0.494782      0.494782      0.830430      0.830430
            ELEMENT         386 [    1v]  GROUP  0
            ELEMENT         387 [    1w]  GROUP  0
            ELEMENT         388 [    1x]  GROUP  0
            ELEMENT         389 [    1y]  GROUP  0
            ELEMENT         390 [    1z]  GROUP  0
            ELEMENT         391 [    1A]  GROUP  0
            ELEMENT         392 [    1B]  GROUP  0
            ELEMENT         393 [    1C]  GROUP  0
            ELEMENT         394 [    1D]  GROUP  0
            ELEMENT         395 [    1E]  GROUP  0
            ELEMENT         396 [    1F]  GROUP  0
            ELEMENT         397 [    1G]  GROUP  0
            ELEMENT         398 [    1H]  GROUP  0
            ELEMENT         399 [    1I]  GROUP  0
            ELEMENT         400 [    1J]  GROUP  0
            ELEMENT         401 [    1K]  GROUP  0
  0.830430      0.830430       1.38996       1.38996
            ELEMENT         402 [    1L]  GROUP  0
            ELEMENT         403 [    1M]  GROUP  0
            ELEMENT         404 [    1N]  GROUP  0
            ELEMENT         405 [    1O]  GROUP  0
            ELEMENT         406 [    1P]  GROUP  0
            ELEMENT         407 [    1Q]  GROUP  0
            ELEMENT         408 [    1R]  GROUP  0
            ELEMENT         409 [    1S]  GROUP  0
            ELEMENT         410 [    1T]  GROUP  0
            ELEMENT         411 [    1U]  GROUP  0
            ELEMENT         412 [    1V]  GROUP  0
            ELEMENT         413 [    1W]  GROUP  0
            ELEMENT         414 [    1X]  GROUP  0
            ELEMENT         415 [    1Y]  GROUP  0
            ELEMENT         416 [    1Z]  GROUP  0
            ELEMENT         417 [    1a]  GROUP  0
   1.38996       1.38996       2.32269       2.32269
            ELEMENT         418 [    1b]  GROUP  0
            ELEMENT         419 [    1c]  GROUP  0
            ELEMENT         420 [    1d]  GROUP  0
            ELEMENT         421 [    1e]  GROUP  0
            ELEMENT         422 [    1f]  GROUP  0
            ELEMENT         423 [    1g]  GROUP  0
            ELEMENT         424 [    1h]  GROUP  0
            ELEMENT         425 [    1i]  GROUP  0
            ELEMENT         426 [    1j]  GROUP  0
            ELEMENT         427 [    1k]  GROUP  0
            ELEMENT         428 [    1l]  GROUP  0
            ELEMENT         429 [    1m]  GROUP  0
            ELEMENT         430 [    1n]  GROUP  0
            ELEMENT         431 [    1o]  GROUP  0
            ELEMENT         432 [    1p]  GROUP  0
            ELEMENT         433 [    1q]  GROUP  0
   2.32269       2.32269       3.87755       3.87755
            ELEMENT         434 [    1r]  GROUP  0
            ELEMENT         435 [    1s]  GROUP  0
            ELEMENT         436 [    1t]  GROUP  0
            ELEMENT         437 [    1u]  GROUP  0
            ELEMENT         438 [    1v]  GROUP  0
            ELEMENT         439 [    1w]  GROUP  0
            ELEMENT         440 [    1x]  GROUP  0
            ELEMENT         441 [    1y]  GROUP  0
            ELEMENT         442 [    1z]  GROUP  0
            ELEMENT         443 [    1A]  GROUP  0
            ELEMENT         444 [    1B]  GROUP  0
            ELEMENT         445 [    1C]  GROUP  0
            ELEMENT         446 [    1D]  GROUP  0
            ELEMENT         447 [    1E]  GROUP  0
            ELEMENT         448 [    1F]  GROUP  0
            ELEMENT         449 [    1G]  GROUP  0
   3.87755       3.87755       6.46950       6.46950
            ELEMENT         450 [    1H]  GROUP  0
            ELEMENT         451 [    1I]  GROUP  0
            ELEMENT         452 [    1J]  GROUP  0
            ELEMENT         453 [    1K]  GROUP  0
            ELEMENT         454 [    1L]  GROUP  0
            ELEMENT         455 [    1M]  GROUP  0
            ELEMENT         456 [    1N]  GROUP  0
            ELEMENT         457 [    1O]  GROUP  0
            ELEMENT         458 [    1P]  GROUP  0
            ELEMENT         459 [    1Q]  GROUP  0
            ELEMENT         460 [    1R]  GROUP  0
            ELEMENT         461 [    1S]  GROUP  0
            ELEMENT         462 [    1T]  GROUP  0
            ELEMENT         463 [    1U]  GROUP  0
            ELEMENT         464 [    1V]  GROUP  0
            ELEMENT         465 [    1W]  GROUP  0
   6.46950       6.46950       10.7903       10.7903
            ELEMENT         466 [    1X]  GROUP  0
            ELEMENT         467 [    1Y]  GROUP  0
            ELEMENT         468 [    1Z]  GROUP  0
            ELEMENT         469 [    1a]  GROUP  0
            ELEMENT         470 [    1b]  GROUP  0
            ELEMENT         471 [    1c]  GROUP  0
            ELEMENT         472 [    1d]  GROUP  0
            ELEMENT         473 [    1e]  GROUP  0
            ELEMENT         474 [    1f]  GROUP  0
            ELEMENT         475 [    1g]  GROUP  0
            ELEMENT         476 [    1h]  GROUP  0
            ELEMENT         477 [    1i]  GROUP  0
            ELEMENT         478 [    1j]  GROUP  0
            ELEMENT         479 [    1k]  GROUP  0
            ELEMENT         480 [    1l]  GROUP  0
            ELEMENT         481 [    1m]  GROUP  0
   10.7903       10.7903       17.9930       17.9930
            ELEMENT         482 [    1n]  GROUP  0
            ELEMENT         483 [    1o]  GROUP  0
            ELEMENT         484 [    1p]  GROUP  0
            ELEMENT         485 [    1q]  GROUP  0
            ELEMENT         486 [    1r]  GROUP  0
            ELEMENT         487 [    1s]  GROUP  0
            ELEMENT         488 [    1t]  GROUP  0
            ELEMENT         489 [    1u]  GROUP  0
            ELEMENT         490 [    1v]  GROUP  0
            ELEMENT         491 [    1w]  GROUP  0
            ELEMENT         492 [    1x]  GROUP  0
            ELEMENT         493 [    1y]  GROUP  0
            ELEMENT         494 [    1z]  GROUP  0
            ELEMENT         495 [    1A]  GROUP  0
            ELEMENT         496 [    1B]  GROUP  0
            ELEMENT         497 [    1C]  GROUP  0
   17.9930       17.9930       30.0000       30.0000
            ELEMENT         498 [    1D]  GROUP  0
            ELEMENT         499 [    1E]  GROUP  0
            ELEMENT         500 [    1F]  GROUP  0
            ELEMENT         501 [    1G]  GROUP  0
            ELEMENT         502 [    1H]  GROUP  0
            ELEMENT         503 [    1I]  GROUP  0
            ELEMENT         504 [    1J]  GROUP  0
            ELEMENT         505 [    1K]  GROUP  0
            ELEMENT         506 [    1L]  GROUP  0
            ELEMENT         507 [    1M]  GROUP  0
            ELEMENT         508 [    1N]  GROUP  0
            ELEMENT         509 [    1O]  GROUP  0
            ELEMENT         510 [    1P]  GROUP  0
            ELEMENT         511 [    1Q]  GROUP  0
            ELEMENT         512 [    1R]  GROUP  0
            ELEMENT         513 [    1S]  GROUP  0
   0.00000      0.625000E-01  0.625000E-01   0.00000
            ELEMENT         514 [    1T]  GROUP  0
  0.625000E-01  0.125000      0.125000      0.625000E-01
            ELEMENT         515 [    1U]  GROUP  0
  0.125000      0.187500      0.187500      0.125000
            ELEMENT         516 [    1V]  GROUP  0
  0.187500      0.250000      0.250000      0.187500
            ELEMENT         517 [    1W]  GROUP  0
  0.250000      0.312500      0.312500      0.250000
            ELEMENT         518 [    1X]  GROUP  0
  0.312500      0.375000      0.375000      0.312500
            ELEMENT         519 [    1Y]  GROUP  0
  0.375000      0.437500      0.437500      0.375000
            ELEMENT         520 [    1Z]  GROUP  0
  0.437500      0.500000      0.500000      0.437500
            ELEMENT         521 [    1a]  GROUP  0
  0.500000      0.562500      0.562500      0.500000
            ELEMENT         522 [    1b]  GROUP  0
  0.562500      0.625000      0.625000      0.562500
            ELEMENT         523 [    1c]  GROUP  0
  0.625000      0.687500      0.687500      0.625000
            ELEMENT         524 [    1d]  GROUP  0
  0.687500      0.750000      0.750000      0.687500
            ELEMENT         525 [    1e]  GROUP  0
  0.750000      0.812500      0.812500      0.750000
            ELEMENT         526 [    1f]  GROUP  0
  0.812500      0.875000      0.875000      0.812500
            ELEMENT         527 [    1g]  GROUP  0
  0.875000      0.937500      0.937500      0.875000
            ELEMENT         528 [    1h]  GROUP  0
  0.937500       1.00000       1.00000      0.937500
            ELEMENT         529 [    1i]  GROUP  0
            ELEMENT         530 [    1j]  GROUP  0
            ELEMENT         531 [    1k]  GROUP  0
            ELEMENT         532 [    1l]  GROUP  0
            ELEMENT         533 [    1m]  GROUP  0
            ELEMENT         534 [    1n]  GROUP  0
            ELEMENT         535 [    1o]  GROUP  0
            ELEMENT         536 [    1p]  GROUP  0
            ELEMENT         537 [    1q]  GROUP  0
            ELEMENT         538 [    1r]  GROUP  0
            ELEMENT         539 [    1s]  GROUP  0
            ELEMENT         540 [    1t]  GROUP  0
            ELEMENT         541 [    1u]  GROUP  0
            ELEMENT         542 [    1v]  GROUP  0
            ELEMENT         543 [    1w]  GROUP  0
            ELEMENT         544 [    1x]  GROUP  0
            ELEMENT         545 [    1y]  GROUP  0
            ELEMENT         546 [    1z]  GROUP  0
            ELEMENT         547 [    1A]  GROUP  0
            ELEMENT         548 [    1B]  GROUP  0
            ELEMENT         549 [    1C]  GROUP  0
            ELEMENT         550 [    1D]  GROUP  0
            ELEMENT         551 [    1E]  GROUP  0
            ELEMENT         552 [    1F]  GROUP  0
            ELEMENT         553 [    1G]  GROUP  0
            ELEMENT         554 [    1H]  GROUP  0
            ELEMENT         555 [    1I]  GROUP  0
            ELEMENT         556 [    1J]  GROUP  0
            ELEMENT         557 [    1K]  GROUP  0
            ELEMENT         558 [    1L]  GROUP  0
            ELEMENT         559 [    1M]  GROUP  0
            ELEMENT         560 [    1N]  GROUP  0
            ELEMENT         561 [    1O]  GROUP  0
            ELEMENT         562 [    1P]  GROUP  0
            ELEMENT         563 [    1Q]  GROUP  0
            ELEMENT         564 [    1R]  GROUP  0
            ELEMENT         565 [    1S]  GROUP  0
            ELEMENT         566 [    1T]  GROUP  0
            ELEMENT         567 [    1U]  GROUP  0
            ELEMENT         568 [    1V]  GROUP  0
            ELEMENT         569 [    1W]  GROUP  0
            ELEMENT         570 [    1X]  GROUP  0
            ELEMENT         571 [    1Y]  GROUP  0
            ELEMENT         572 [    1Z]  GROUP  0
            ELEMENT         573 [    1a]  GROUP  0
            ELEMENT         574 [    1b]  GROUP  0
            ELEMENT         575 [    1c]  GROUP  0
            ELEMENT         576 [    1d]  GROUP  0
            ELEMENT         577 [    1e]  GROUP  0
            ELEMENT         578 [    1f]  GROUP  0
            ELEMENT         579 [    1g]  GROUP  0
            ELEMENT         580 [    1h]  GROUP  0
            ELEMENT         581 [    1i]  GROUP  0
            ELEMENT         582 [    1j]  GROUP  0
            ELEMENT         583 [    1k]  GROUP  0
            ELEMENT         584 [    1l]  GROUP  0
            ELEMENT         585 [    1m]  GROUP  0
            ELEMENT         586 [    1n]  GROUP  0
            ELEMENT         587 [    1o]  GROUP  0
            ELEMENT         588 [    1p]  GROUP  0
            ELEMENT         589 [    1q]  GROUP  0
            ELEMENT         590 [    1r]  GROUP  0
            ELEMENT         591 [    1s]  GROUP  0
            ELEMENT         592 [    1t]  GROUP  0
            ELEMENT         593 [    1u]  GROUP  0
            ELEMENT         594 [    1v]  GROUP  0
            ELEMENT         595 [    1w]  GROUP  0
            ELEMENT         596 [    1x]  GROUP  0
            ELEMENT         597 [    1y]  GROUP  0
            ELEMENT         598 [    1z]  GROUP  0
            ELEMENT         599 [    1A]  GROUP  0
            ELEMENT         600 [    1B]  GROUP  0
            ELEMENT         601 [    1C]  GROUP  0
            ELEMENT         602 [    1D]  GROUP  0
            ELEMENT         603 [    1E]  GROUP  0
            ELEMENT         604 [    1F]  GROUP  0
            ELEMENT         605 [    1G]  GROUP  0
            ELEMENT         606 [    1H]  GROUP  0
            ELEMENT         607 [    1I]  GROUP  0
            ELEMENT         608 [    1J]  GROUP  0
            ELEMENT         609 [    1K]  GROUP  0
            ELEMENT         610 [    1L]  GROUP  0
            ELEMENT         611 [    1M]  GROUP  0
            ELEMENT         612 [    1N]  GROUP  0
            ELEMENT         613 [    1O]  GROUP  0
            ELEMENT         614 [    1P]  GROUP  0
            ELEMENT         615 [    1Q]  GROUP  0
            ELEMENT         616 [    1R]  GROUP  0
            ELEMENT         617 [    1S]  GROUP  0
            ELEMENT         618 [    1T]  GROUP  0
            ELEMENT         619 [    1U]  GROUP  0
            ELEMENT         620 [    1V]  GROUP  0
            ELEMENT         621 [    1W]  GROUP  0
            ELEMENT         622 [    1X]  GROUP  0
            ELEMENT         623 [    1Y]  GROUP  0
            ELEMENT         624 [    1Z]  GROUP  0
            ELEMENT         625 [    1a]  GROUP  0
            ELEMENT         626 [    1b]  GROUP  0
            ELEMENT         627 [    1c]  GROUP  0
            ELEMENT         628 [    1d]  GROUP  0
            ELEMENT         629 [    1e]  GROUP  0
            ELEMENT         630 [    1f]  GROUP  0
            ELEMENT         631 [    1g]  GROUP  0
            ELEMENT         632 [    1h]  GROUP  0
            ELEMENT         633 [    1i]  GROUP  0
            ELEMENT         634 [    1j]  GROUP  0
            ELEMENT         635 [    1k]  GROUP  0
            ELEMENT         636 [    1l]  GROUP  0
            ELEMENT         637 [    1m]  GROUP  0
            ELEMENT         638 [    1n]  GROUP  0
            ELEMENT         639 [    1o]  GROUP  0
            ELEMENT         640 [    1p]  GROUP  0
            ELEMENT         641 [    1q]  GROUP  0
            ELEMENT         642 [    1r]  GROUP  0
            ELEMENT         643 [    1s]  GROUP  0
            ELEMENT         644 [    1t]  GROUP  0
            ELEMENT         645 [    1u]  GROUP  0
            ELEMENT         646 [    1v]  GROUP  0
            ELEMENT         647 [    1w]  GROUP  0
            ELEMENT         648 [    1x]  GROUP  0
            ELEMENT         649 [    1y]  GROUP  0
            ELEMENT         650 [    1z]  GROUP  0
            ELEMENT         651 [    1A]  GROUP  0
            ELEMENT         652 [    1B]  GROUP  0
            ELEMENT         653 [    1C]  GROUP  0
            ELEMENT         654 [    1D]  GROUP  0
            ELEMENT         655 [    1E]  GROUP  0
            ELEMENT         656 [    1F]  GROUP  0
            ELEMENT         657 [    1G]  GROUP  0
            ELEMENT         658 [    1H]  GROUP  0
            ELEMENT         659 [    1I]  GROUP  0
            ELEMENT         660 [    1J]  GROUP  0
            ELEMENT         661 [    1K]  GROUP  0
            ELEMENT         662 [    1L]  GROUP  0
            ELEMENT         663 [    1M]  GROUP  0
            ELEMENT         664 [    1N]  GROUP  0
            ELEMENT         665 [    1O]  GROUP  0
            ELEMENT         666 [    1P]  GROUP  0
            ELEMENT         667 [    1Q]  GROUP  0
            ELEMENT         668 [    1R]  GROUP  0
            ELEMENT         669 [    1S]  GROUP  0
            ELEMENT         670 [    1T]  GROUP  0
            ELEMENT         671 [    1U]  GROUP  0
            ELEMENT         672 [    1V]  GROUP  0
            ELEMENT         673 [    1W]  GROUP  0
            ELEMENT         674 [    1X]  GROUP  0
            ELEMENT         675 [    1Y]  GROUP  0
            ELEMENT         676 [    1Z]  GROUP  0
            ELEMENT         677 [    1a]  GROUP  0
            ELEMENT         678 [    1b]  GROUP  0
            ELEMENT         679 [    1c]  GROUP  0
            ELEMENT         680 [    1d]  GROUP  0
            ELEMENT         681 [    1e]  GROUP  0
            ELEMENT         682 [    1f]  GROUP  0
            ELEMENT         683 [    1g]  GROUP  0
            ELEMENT         684 [    1h]  GROUP  0
            ELEMENT         685 [    1i]  GROUP  0
            ELEMENT         686 [    1j]  GROUP  0
            ELEMENT         687 [    1k]  GROUP  0
            ELEMENT         688 [    1l]  GROUP  0
            ELEMENT         689 [    1m]  GROUP  0
            ELEMENT         690 [    1n]  GROUP  0
            ELEMENT         691 [    1o]  GROUP  0
            ELEMENT         692 [    1p]  GROUP  0
            ELEMENT         693 [    1q]  GROUP  0
            ELEMENT         694 [    1r]  GROUP  0
            ELEMENT         695 [    1s]  GROUP  0
            ELEMENT         696 [    1t]  GROUP  0
            ELEMENT         697 [    1u]  GROUP  0
            ELEMENT         698 [    1v]  GROUP  0
            ELEMENT         699 [    1w]  GROUP  0
            ELEMENT         700 [    1x]  GROUP  0
            ELEMENT         701 [    1y]  GROUP  0
            ELEMENT         702 [    1z]  GROUP  0
            ELEMENT         703 [    1A]  GROUP  0
            ELEMENT         704 [    1B]  GROUP  0
            ELEMENT         705 [    1C]  GROUP  0
            ELEMENT         706 [    1D]  GROUP  0
            ELEMENT         707 [    1E]  GROUP  0
            ELEMENT         708 [    1F]  GROUP  0
            ELEMENT         709 [    1G]  GROUP  0
            ELEMENT         710 [    1H]  GROUP  0
            ELEMENT         711 [    1I]  GROUP  0
            ELEMENT         712 [    1J]  GROUP  0
            ELEMENT         713 [    1K]  GROUP  0
            ELEMENT         714 [    1L]  GROUP  0
            ELEMENT         715 [    1M]  GROUP  0
            ELEMENT         716 [    1N]  GROUP  0
            ELEMENT         717 [    1O]  GROUP  0
            ELEMENT         718 [    1P]  GROUP  0
            ELEMENT         719 [    1Q]  GROUP  0
            ELEMENT         720 [    1R]  GROUP  0
            ELEMENT         721 [    1S]  GROUP  0
            ELEMENT         722 [    1T]  GROUP  0
            ELEMENT         723 [    1U]  GROUP  0
            ELEMENT         724 [    1V]  GROUP  0
            ELEMENT         725 [    1W]  GROUP  0
            ELEMENT         726 [    1X]  GROUP  0
            ELEMENT         727 [    1Y]  GROUP  0
            ELEMENT         728 [    1Z]  GROUP  0
            ELEMENT         729 [    1a]  GROUP  0
            ELEMENT         730 [    1b]  GROUP  0
            ELEMENT         731 [    1c]  GROUP  0
            ELEMENT         732 [    1d]  GROUP  0
            ELEMENT         733 [    1e]  GROUP  0
            ELEMENT         734 [    1f]  GROUP  0
            ELEMENT         735 [    1g]  GROUP  0
            ELEMENT         736 [    1h]  GROUP  0
            ELEMENT         737 [    1i]  GROUP  0
            ELEMENT         738 [    1j]  GROUP  0
            ELEMENT         739 [    1k]  GROUP  0
            ELEMENT         740 [    1l]  GROUP  0
            ELEMENT         741 [    1m]  GROUP  0
            ELEMENT         742 [    1n]  GROUP  0
            ELEMENT         743 [    1o]  GROUP  0
            ELEMENT         744 [    1p]  GROUP  0
            ELEMENT         745 [    1q]  GROUP  0
            ELEMENT         746 [    1r]  GROUP  0
            ELEMENT         747 [    1s]  GROUP  0
            ELEMENT         748 [    1t]  GROUP  0
            ELEMENT         749 [    1u]  GROUP  0
            ELEMENT         750 [    1v]  GROUP  0
            ELEMENT         751 [    1w]  GROUP  0
            ELEMENT         752 [    1x]  GROUP  0
            ELEMENT         753 [    1y]  GROUP  0
            ELEMENT         754 [    1z]  GROUP  0
            ELEMENT         755 [    1A]  GROUP  0
            ELEMENT         756 [    1B]  GROUP  0
            ELEMENT         757 [    1C]  GROUP  0
            ELEMENT         758 [    1D]  GROUP  0
            ELEMENT         759 [    1E]  GROUP  0
            ELEMENT         760 [    1F]  GROUP  0
            ELEMENT         761 [    1G]  GROUP  0
            ELEMENT         762 [    1H]  GROUP  0
            ELEMENT         763 [    1I]  GROUP  0
            ELEMENT         764 [    1J]  GROUP  0
            ELEMENT         765 [    1K]  GROUP  0
            ELEMENT         766 [    1L]  GROUP  0
            ELEMENT         767 [    1M]  GROUP  0
            ELEMENT         768 [    1N]  GROUP  0
            ELEMENT         769 [    1O]  GROUP  0
            ELEMENT         770 [    1P]  GROUP  0
            ELEMENT         771 [    1Q]  GROUP  0
            ELEMENT         772 [    1R]  GROUP  0
            ELEMENT         773 [    1S]  GROUP  0
            ELEMENT         774 [    1T]  GROUP  0
            ELEMENT         775 [    1U]  GROUP  0
            ELEMENT         776 [    1V]  GROUP  0
            ELEMENT         777 [    1W]  GROUP  0
            ELEMENT         778 [    1X]  GROUP  0
            ELEMENT         779 [    1Y]  GROUP  0
            ELEMENT         780 [    1Z]  GROUP  0
            ELEMENT         781 [    1a]  GROUP  0
            ELEMENT         782 [    1b]  GROUP  0
            ELEMENT         783 [    1c]  GROUP  0
            ELEMENT         784 [    1d]  GROUP  0
            ELEMENT         785 [    1e]  GROUP  0
            ELEMENT         786 [    1f]  GROUP  0
            ELEMENT         787 [    1g]  GROUP  0
            ELEMENT         788 [    1h]  GROUP  0
            ELEMENT         789 [    1i]  GROUP  0
            ELEMENT         790 [    1j]  GROUP  0
            ELEMENT         791 [    1k]  GROUP  0
            ELEMENT         792 [    1l]  GROUP  0
            ELEMENT         793 [    1m]  GROUP  0
            ELEMENT         794 [    1n]  GROUP  0
            ELEMENT         795 [    1o]  GROUP  0
            ELEMENT         796 [    1p]  GROUP  0
            ELEMENT         797 [    1q]  GROUP  0
            ELEMENT         798 [    1r]  GROUP  0
            ELEMENT         799 [    1s]  GROUP  0
            ELEMENT         800 [    1t]  GROUP  0
            ELEMENT         801 [    1u]  GROUP  0
            ELEMENT         802 [    1v]  GROUP  0
            ELEMENT         803 [    1w]  GROUP  0
            ELEMENT         804 [    1x]  GROUP  0
            ELEMENT         805 [    1y]  GROUP  0
            ELEMENT         806 [    1z]  GROUP  0
            ELEMENT         807 [    1A]  GROUP  0
            ELEMENT         808 [    1B]  GROUP  0
            ELEMENT         809 [    1C]  GROUP  0
            ELEMENT         810 [    1D]  GROUP  0
            ELEMENT         811 [    1E]  GROUP  0
            ELEMENT         812 [    1F]  GROUP  0
            ELEMENT         813 [    1G]  GROUP  0
            ELEMENT         814 [    1H]  GROUP  0
            ELEMENT         815 [    1I]  GROUP  0
            ELEMENT         816 [    1J]  GROUP  0
            ELEMENT         817 [    1K]  GROUP  0
            ELEMENT         818 [    1L]  GROUP  0
            ELEMENT         819 [    1M]  GROUP  0
            ELEMENT         820 [    1N]  GROUP  0
            ELEMENT         821 [    1O]  GROUP  0
            ELEMENT         822 [    1P]  GROUP  0
            ELEMENT         823 [    1Q]  GROUP  0
            ELEMENT         824 [    1R]  GROUP  0
            ELEMENT         825 [    1S]  GROUP  0
            ELEMENT         826 [    1T]  GROUP  0
            ELEMENT         827 [    1U]  GROUP  0
            ELEMENT         828 [    1V]  GROUP  0
            ELEMENT         829 [    1W]  GROUP  0
            ELEMENT         830 [    1X]  GROUP  0
            ELEMENT         831 [    1Y]  GROUP  0
            ELEMENT         832 [    1Z]  GROUP  0
            ELEMENT         833 [    1a]  GROUP  0
            ELEMENT         834 [    1b]  GROUP  0
            ELEMENT         835 [    1c]  GROUP  0
            ELEMENT         836 [    1d]  GROUP  0
            ELEMENT         837 [    1e]  GROUP  0
            ELEMENT         838 [    1f]  GROUP  0
            ELEMENT         839 [    1g]  GROUP  0
            ELEMENT         840 [    1h]  GROUP  0
            ELEMENT         841 [    1i]  GROUP  0
            ELEMENT         842 [    1j]  GROUP  0
            ELEMENT         843 [    1k]  GROUP  0
            ELEMENT         844 [    1l]  GROUP  0
            ELEMENT         845 [    1m]  GROUP  0
            ELEMENT         846 [    1n]  GROUP  0
            ELEMENT         847 [    1o]  GROUP  0
            ELEMENT         848 [    1p]  GROUP  0
            ELEMENT         849 [    1q]  GROUP  0
            ELEMENT         850 [    1r]  GROUP  0
            ELEMENT         851 [    1s]  GROUP  0
            ELEMENT         852 [    1t]  GROUP  0
            ELEMENT         853 [    1u]  GROUP  0
            ELEMENT         854 [    1v]  GROUP  0
            ELEMENT         855 [    1w]  GROUP  0
            ELEMENT         856 [    1x]  GROUP  0
            ELEMENT         857 [    1y]  GROUP  0
            ELEMENT         858 [    1z]  GROUP  0
            ELEMENT         859 [    1A]  GROUP  0
            ELEMENT         860 [    1B]  GROUP  0
            ELEMENT         861 [    1C]  GROUP  0
            ELEMENT         862 [    1D]  GROUP  0
            ELEMENT         863 [    1E]  GROUP  0
            ELEMENT         864 [    1F]  GROUP  0
            ELEMENT         865 [    1G]  GROUP  0
            ELEMENT         866 [    1H]  GROUP  0
            ELEMENT         867 [    1I]  GROUP  0
            ELEMENT         868 [    1J]  GROUP  0
            ELEMENT         869 [    1K]  GROUP  0
            ELEMENT         870 [    1L]  GROUP  0
            ELEMENT         871 [    1M]  GROUP  0
            ELEMENT         872 [    1N]  GROUP  0
            ELEMENT         873 [    1O]  GROUP  0
            ELEMENT         874 [    1P]  GROUP  0
            ELEMENT         875 [    1Q]  GROUP  0
            ELEMENT         876 [    1R]  GROUP  0
            ELEMENT         877 [    1S]  GROUP  0
            ELEMENT         878 [    1T]  GROUP  0
            ELEMENT         879 [    1U]  GROUP  0
            ELEMENT         880 [    1V]  GROUP  0
            ELEMENT         881 [    1W]  GROUP  0
            ELEMENT         882 [    1X]  GROUP  0
            ELEMENT         883 [    1Y]  GROUP  0
            ELEMENT         884 [    1Z]  GROUP  0
            ELEMENT         885 [    1a]  GROUP  0
            ELEMENT         886 [    1b]  GROUP  0
            ELEMENT         887 [    1c]  GROUP  0
            ELEMENT         888 [    1d]  GROUP  0
            ELEMENT         889 [    1e]  GROUP  0
            ELEMENT         890 [    1f]  GROUP  0
            ELEMENT         891 [    1g]  GROUP  0
            ELEMENT         892 [    1h]  GROUP  0
            ELEMENT         893 [    1i]  GROUP  0
            ELEMENT         894 [    1j]  GROUP  0
            ELEMENT         895 [    1k]  GROUP  0
            ELEMENT         896 [    1l]  GROUP  0
            ELEMENT         897 [    1m]  GROUP  0
            ELEMENT         898 [    1n]  GROUP  0
            ELEMENT         899 [    1o]  GROUP  0
            ELEMENT         900 [    1p]  GROUP  0
            ELEMENT         901 [    1q]  GROUP  0
            ELEMENT         902 [    1r]  GROUP  0
            ELEMENT         903 [    1s]  GROUP  0
            ELEMENT         904 [    1t]  GROUP  0
            ELEMENT         905 [    1u]  GROUP  0
            ELEMENT         906 [    1v]  GROUP  0
            ELEMENT         907 [    1w]  GROUP  0
            ELEMENT         908 [    1x]  GROUP  0
            ELEMENT         909 [    1y]  GROUP  0
            ELEMENT         910 [    1z]  GROUP  0
            ELEMENT         911 [    1A]  GROUP  0
            ELEMENT         912 [    1B]  GROUP  0
            ELEMENT         913 [    1C]  GROUP  0
            ELEMENT         914 [    1D]  GROUP  0
            ELEMENT         915 [    1E]  GROUP  0
            ELEMENT         916 [    1F]  GROUP  0
            ELEMENT         917 [    1G]  GROUP  0
            ELEMENT         918 [    1H]  GROUP  0
            ELEMENT         919 [    1I]  GROUP  0
            ELEMENT         920 [    1J]  GROUP  0
            ELEMENT         921 [    1K]  GROUP  0
            ELEMENT         922 [    1L]  GROUP  0
            ELEMENT         923 [    1M]  GROUP  0
            ELEMENT         924 [    1N]  GROUP  0
            ELEMENT         925 [    1O]  GROUP  0
            ELEMENT         926 [    1P]  GROUP  0
            ELEMENT         927 [    1Q]  GROUP  0
            ELEMENT         928 [    1R]  GROUP  0
            ELEMENT         929 [    1S]  GROUP  0
            ELEMENT         930 [    1T]  GROUP  0
            ELEMENT         931 [    1U]  GROUP  0
            ELEMENT         932 [    1V]  GROUP  0
            ELEMENT         933 [    1W]  GROUP  0
            ELEMENT         934 [    1X]  GROUP  0
            ELEMENT         935 [    1Y]  GROUP  0
            ELEMENT         936 [    1Z]  GROUP  0
            ELEMENT         937 [    1a]  GROUP  0
            ELEMENT         938 [    1b]  GROUP  0
            ELEMENT         939 [    1c]  GROUP  0
            ELEMENT         940 [    1d]  GROUP  0
            ELEMENT         941 [    1e]  GROUP  0
            ELEMENT         942 [    1f]  GROUP  0
            ELEMENT         943 [    1g]  GROUP  0
            ELEMENT         944 [    1h]  GROUP  0
            ELEMENT         945 [    1i]  GROUP  0
            ELEMENT         946 [    1j]  GROUP  0
            ELEMENT         947 [    1k]  GROUP  0
            ELEMENT         948 [    1l]  GROUP  0
            ELEMENT         949 [    1m]  GROUP  0
            ELEMENT         950 [    1n]  GROUP  0
            ELEMENT         951 [    1o]  GROUP  0
            ELEMENT         952 [    1p]  GROUP  0
            ELEMENT         953 [    1q]  GROUP  0
            ELEMENT         954 [    1r]  GROUP  0
            ELEMENT         955 [    1s]  GROUP  0
            ELEMENT         956 [    1t]  GROUP  0
            ELEMENT         957 [    1u]  GROUP  0
            ELEMENT         958 [    1v]  GROUP  0
            ELEMENT         959 [    1w]  GROUP  0
            ELEMENT         960 [    1x]  GROUP  0
            ELEMENT         961 [    1y]  GROUP  0
            ELEMENT         962 [    1z]  GROUP  0
            ELEMENT         963 [    1A]  GROUP  0
            ELEMENT         964 [    1B]  GROUP  0
            ELEMENT         965 [    1C]  GROUP  0
            ELEMENT         966 [    1D]  GROUP  0
            ELEMENT         967 [    1E]  GROUP  0
            ELEMENT         968 [    1F]  GROUP  0
            ELEMENT         969 [    1G]  GROUP  0
            ELEMENT         970 [    1H]  GROUP  0
            ELEMENT         971 [    1I]  GROUP  0
            ELEMENT         972 [    1J]  GROUP  0
            ELEMENT         973 [    1K]  GROUP  0
            ELEMENT         974 [    1L]  GROUP  0
            ELEMENT         975 [    1M]  GROUP  0
            ELEMENT         976 [    1N]  GROUP  0
            ELEMENT         977 [    1O]  GROUP  0
            ELEMENT         978 [    1P]  GROUP  0
            ELEMENT         979 [    1Q]  GROUP  0
            ELEMENT         980 [    1R]  GROUP  0
            ELEMENT         981 [    1S]  GROUP  0
            ELEMENT         982 [    1T]  GROUP  0
            ELEMENT         983 [    1U]  GROUP  0
            ELEMENT         984 [    1V]  GROUP  0
            ELEMENT         985 [    1W]  GROUP  0
            ELEMENT         986 [    1X]  GROUP  0
            ELEMENT         987 [    1Y]  GROUP  0
            ELEMENT         988 [    1Z]  GROUP  0
            ELEMENT         989 [    1a]  GROUP  0
            ELEMENT         990 [    1b]  GROUP  0
            ELEMENT         991 [    1c]  GROUP  0
            ELEMENT         992 [    1d]  GROUP  0
            ELEMENT         993 [    1e]  GROUP  0
            ELEMENT         994 [    1f]  GROUP  0
            ELEMENT         995 [    1g]  GROUP  0
            ELEMENT         996 [    1h]  GROUP  0
            ELEMENT         997 [    1i]  GROUP  0
            ELEMENT         998 [    1j]  GROUP  0
            ELEMENT         999 [    1k]  GROUP  0
            ELEMENT        1000 [    1l]  GROUP  0
            ELEMENT        1001 [    1m]  GROUP  0
            ELEMENT        1002 [    1n]  GROUP  0
            ELEMENT        1003 [    1o]  GROUP  0
            ELEMENT        1004 [    1p]  GROUP  0
            ELEMENT        1005 [    1q]  GROUP  0
            ELEMENT        1006 [    1r]  GROUP  0
            ELEMENT        1007 [    1s]  GROUP  0
            ELEMENT        1008 [    1t]  GROUP  0
            ELEMENT        1009 [    1u]  GROUP  0
            ELEMENT        1010 [    1v]  GROUP  0
            ELEMENT        1011 [    1w]  GROUP  0
            ELEMENT        1012 [    1x]  GROUP  0
            ELEMENT        1013 [    1y]  GROUP  0
            ELEMENT        1014 [    1z]  GROUP  0
            ELEMENT        1015 [    1A]  GROUP  0
            ELEMENT        1016 [    1B]  GROUP  0
            ELEMENT        1017 [    1C]  GROUP  0
            ELEMENT        1018 [    1D]  GROUP  0
            ELEMENT        1019 [    1E]  GROUP  0
            ELEMENT        1020 [    1F]  GROUP  0
            ELEMENT        1021 [    1G]  GROUP  0
            ELEMENT        1022 [    1H]  GROUP  0
            ELEMENT        1023 [    1I]  GROUP  0
            ELEMENT        1024 [    1J]  GROUP  0
            ELEMENT        1025 [    1K]  GROUP  0
   1.00000       1.00657       1.00657       1.00000
            ELEMENT        1026 [    1L]  GROUP  0
   1.00657       1.01751       1.01751       1.00657
            ELEMENT        1027 [    1M]  GROUP  0
   1.01751       1.03576       1.03576       1.01751
            ELEMENT        1028 [    1N]  GROUP  0
   1.03576       1.06618       1.06618       1.03576
            ELEMENT        1029 [    1O]  GROUP  0
   1.06618       1.11689       1.11689       1.06618
            ELEMENT        1030 [    1P]  GROUP  0
   1.11689       1.20142       1.20142       1.11689
            ELEMENT        1031 [    1Q]  GROUP  0
   1.20142       1.34234       1.34234       1.20142
            ELEMENT        1032 [    1R]  GROUP  0
   1.34234       1.57725       1.57725       1.34234
            ELEMENT        1033 [    1S]  GROUP  0
   1.57725       1.96884       1.96884       1.57725
            ELEMENT        1034 [    1T]  GROUP  0
   1.96884       2.62162       2.62162       1.96884
            ELEMENT        1035 [    1U]  GROUP  0
   2.62162       3.70980       3.70980       2.62162
            ELEMENT        1036 [    1V]  GROUP  0
   3.70980       5.52380       5.52380       3.70980
            ELEMENT        1037 [    1W]  GROUP  0
   5.52380       8.54775       8.54775       5.52380
            ELEMENT        1038 [    1X]  GROUP  0
   8.54775       13.5887       13.5887       8.54775
            ELEMENT        1039 [    1Y]  GROUP  0
   13.5887       21.9919       21.9919       13.5887
            ELEMENT        1040 [    1Z]  GROUP  0
   21.9919       36.0000       36.0000       21.9919
            ELEMENT        1041 [    1a]  GROUP  0
            ELEMENT        1042 [    1b]  GROUP  0
            ELEMENT        1043 [    1c]  GROUP  0
            ELEMENT        1044 [    1d]  GROUP  0
            ELEMENT        1045 [    1e]  GROUP  0
            ELEMENT        1046 [    1f]  GROUP  0
            ELEMENT        1047 [    1g]  GROUP  0
            ELEMENT        1048 [    1h]  GROUP  0
            ELEMENT        1049 [    1i]  GROUP  0
            ELEMENT        1050 [    1j]  GROUP  0
            ELEMENT        1051 [    1k]  GROUP  0
            ELEMENT        1052 [    1l]  GROUP  0
            ELEMENT        1053 [    1m]  GROUP  0
            ELEMENT        1054 [    1n]  GROUP  0
            ELEMENT        1055 [    1o]  GROUP  0
            ELEMENT        1056 [    1p]  GROUP  0
            ELEMENT        1057 [    1q]  GROUP  0
            ELEMENT        1058 [    1r]  GROUP  0
            ELEMENT        1059 [    1s]  GROUP  0
            ELEMENT        1060 [    1t]  GROUP  0
            ELEMENT        1061 [    1u]  GROUP  0
            ELEMENT        1062 [    1v]  GROUP  0
            ELEMENT        1063 [    1w]  GROUP  0
            ELEMENT        1064 [    1x]  GROUP  0
            ELEMENT        1065 [    1y]  GROUP  0
            ELEMENT        1066 [    1z]  GROUP  0
            ELEMENT        1067 [    1A]  GROUP  0
            ELEMENT        1068 [    1B]  GROUP  0
            ELEMENT        1069 [    1C]  GROUP  0
            ELEMENT        1070 [    1D]  GROUP  0
            ELEMENT        1071 [    1E]  GROUP  0
            ELEMENT        1072 [    1F]  GROUP  0
            ELEMENT        1073 [    1G]  GROUP  0
            ELEMENT        1074 [    1H]  GROUP  0
            ELEMENT        1075 [    1I]  GROUP  0
            ELEMENT        1076 [    1J]  GROUP  0
            ELEMENT        1077 [    1K]  GROUP  0
            ELEMENT        1078 [    1L]  GROUP  0
            ELEMENT        1079 [    1M]  GROUP  0
            ELEMENT        1080 [    1N]  GROUP  0
            ELEMENT        1081 [    1O]  GROUP  0
            ELEMENT        1082 [    1P]  GROUP  0
            ELEMENT        1083 [    1Q]  GROUP  0
            ELEMENT        1084 [    1R]  GROUP  0
            ELEMENT        1085 [    1S]  GROUP  0
            ELEMENT        1086 [    1T]  GROUP  0
            ELEMENT        1087 [    1U]  GROUP  0
            ELEMENT        1088 [    1V]  GROUP  0
            ELEMENT        1089 [    1W]  GROUP  0
            ELEMENT        1090 [    1X]  GROUP  0
            ELEMENT        1091 [    1Y]  GROUP  0
            ELEMENT        1092 [    1Z]  GROUP  0
            ELEMENT        1093 [    1a]  GROUP  0
            ELEMENT        1094 [    1b]  GROUP  0
            ELEMENT        1095 [    1c]  GROUP  0
            ELEMENT        1096 [    1d]  GROUP  0
            ELEMENT        1097 [    1e]  GROUP  0
            ELEMENT        1098 [    1f]  GROUP  0
            ELEMENT        1099 [    1g]  GROUP  0
            ELEMENT        1100 [    1h]  GROUP  0
            ELEMENT        1101 [    1i]  GROUP  0
            ELEMENT        1102 [    1j]  GROUP  0
            ELEMENT        1103 [    1k]  GROUP  0
            ELEMENT        1104 [    1l]  GROUP  0
            ELEMENT        1105 [    1m]  GROUP  0
            ELEMENT        1106 [    1n]  GROUP  0
            ELEMENT        1107 [    1o]  GROUP  0
            ELEMENT        1108 [    1p]  GROUP  0
            ELEMENT        1109 [    1q]  GROUP  0
            ELEMENT        1110 [    1r]  GROUP  0
            ELEMENT        1111 [    1s]  GROUP  0
            ELEMENT        1112 [    1t]  GROUP  0
            ELEMENT        1113 [    1u]  GROUP  0
            ELEMENT        1114 [    1v]  GROUP  0
            ELEMENT        1115 [    1w]  GROUP  0
            ELEMENT        1116 [    1x]  GROUP  0
            ELEMENT        1117 [    1y]  GROUP  0
            ELEMENT        1118 [    1z]  GROUP  0
            ELEMENT        1119 [    1A]  GROUP  0
            ELEMENT        1120 [    1B]  GROUP  0
            ELEMENT        1121 [    1C]  GROUP  0
            ELEMENT        1122 [    1D]  GROUP  0
            ELEMENT        1123 [    1E]  GROUP  0
            ELEMENT        1124 [    1F]  GROUP  0
            ELEMENT        1125 [    1G]  GROUP  0
            ELEMENT        1126 [    1H]  GROUP  0
            ELEMENT        1127 [    1I]  GROUP  0
            ELEMENT        1128 [    1J]  GROUP  0
            ELEMENT        1129 [    1K]  GROUP  0
            ELEMENT        1130 [    1L]  GROUP  0
            ELEMENT        1131 [    1M]  GROUP  0
            ELEMENT        1132 [    1N]  GROUP  0
            ELEMENT        1133 [    1O]  GROUP  0
            ELEMENT        1134 [    1P]  GROUP  0
            ELEMENT        1135 [    1Q]  GROUP  0
            ELEMENT        1136 [    1R]  GROUP  0
            ELEMENT        1137 [    1S]  GROUP  0
            ELEMENT        1138 [    1T]  GROUP  0
            ELEMENT        1139 [    1U]  GROUP  0
            ELEMENT        1140 [    1V]  GROUP  0
            ELEMENT        1141 [    1W]  GROUP  0
            ELEMENT        1142 [    1X]  GROUP  0
            ELEMENT        1143 [    1Y]  GROUP  0
            ELEMENT        1144 [    1Z]  GROUP  0
            ELEMENT        1145 [    1a]  GROUP  0
            ELEMENT        1146 [    1b]  GROUP  0
            ELEMENT        1147 [    1c]  GROUP  0
            ELEMENT        1148 [    1d]  GROUP  0
            ELEMENT        1149 [    1e]  GROUP  0
            ELEMENT        1150 [    1f]  GROUP  0
            ELEMENT        1151 [    1g]  GROUP  0
            ELEMENT        1152 [    1h]  GROUP  0
            ELEMENT        1153 [    1i]  GROUP  0
            ELEMENT        1154 [    1j]  GROUP  0
            ELEMENT        1155 [    1k]  GROUP  0
            ELEMENT        1156 [    1l]  GROUP  0
            ELEMENT        1157 [    1m]  GROUP  0
            ELEMENT        1158 [    1n]  GROUP  0
            ELEMENT        1159 [    1o]  GROUP  0
            ELEMENT        1160 [    1p]  GROUP  0
            ELEMENT        1161 [    1q]  GROUP  0
            ELEMENT        1162 [    1r]  GROUP  0
            ELEMENT        1163 [    1s]  GROUP  0
            ELEMENT        1164 [    1t]  GROUP  0
            ELEMENT        1165 [    1u]  GROUP  0
            ELEMENT        1166 [    1v]  GROUP  0
            ELEMENT        1167 [    1w]  GROUP  0
            ELEMENT        1168 [    1x]  GROUP  0
            ELEMENT        1169 [    1y]  GROUP  0
            ELEMENT        1170 [    1z]  GROUP  0
            ELEMENT        1171 [    1A]  GROUP  0
            ELEMENT        1172 [    1B]  GROUP  0
            ELEMENT        1173 [    1C]  GROUP  0
            ELEMENT        1174 [    1D]  GROUP  0
            ELEMENT        1175 [    1E]  GROUP  0
            ELEMENT        1176 [    1F]  GROUP  0
            ELEMENT        1177 [    1G]  GROUP  0
            ELEMENT        1178 [    1H]  GROUP  0
            ELEMENT        1179 [    1I]  GROUP  0
            ELEMENT        1180 [    1J]  GROUP  0
            ELEMENT        1181 [    1K]  GROUP  0
            ELEMENT        1182 [    1L]  GROUP  0
            ELEMENT        1183 [    1M]  GROUP  0
            ELEMENT        1184 [    1N]  GROUP  0
            ELEMENT        1185 [    1O]  GROUP  0
            ELEMENT        1186 [    1P]  GROUP  0
            ELEMENT        1187 [    1Q]  GROUP  0
            ELEMENT        1188 [    1R]  GROUP  0
            ELEMENT        1189 [    1S]  GROUP  0
            ELEMENT        1190 [    1T]  GROUP  0
            ELEMENT        1191 [    1U]  GROUP  0
            ELEMENT        1192 [    1V]  GROUP  0
            ELEMENT        1193 [    1W]  GROUP  0
            ELEMENT        1194 [    1X]  GROUP  0
            ELEMENT        1195 [    1Y]  GROUP  0
            ELEMENT        1196 [    1Z]  GROUP  0
            ELEMENT        1197 [    1a]  GROUP  0
            ELEMENT        1198 [    1b]  GROUP  0
            ELEMENT        1199 [    1c]  GROUP  0
            ELEMENT        1200 [    1d]  GROUP  0
            ELEMENT        1201 [    1e]  GROUP  0
            ELEMENT        1202 [    1f]  GROUP  0
            ELEMENT        1203 [    1g]  GROUP  0
            ELEMENT        1204 [    1h]  GROUP  0
            ELEMENT        1205 [    1i]  GROUP  0
            ELEMENT        1206 [    1j]  GROUP  0
            ELEMENT        1207 [    1k]  GROUP  0
            ELEMENT        1208 [    1l]  GROUP  0
            ELEMENT        1209 [    1m]  GROUP  0
            ELEMENT        1210 [    1n]  GROUP  0
            ELEMENT        1211 [    1o]  GROUP  0
            ELEMENT        1212 [    1p]  GROUP  0
            ELEMENT        1213 [    1q]  GROUP  0
            ELEMENT        1214 [    1r]  GROUP  0
            ELEMENT        1215 [    1s]  GROUP  0
            ELEMENT        1216 [    1t]  GROUP  0
            ELEMENT        1217 [    1u]  GROUP  0
            ELEMENT        1218 [    1v]  GROUP  0
            ELEMENT        1219 [    1w]  GROUP  0
            ELEMENT        1220 [    1x]  GROUP  0
            ELEMENT        1221 [    1y]  GROUP  0
            ELEMENT        1222 [    1z]  GROUP  0
            ELEMENT        1223 [    1A]  GROUP  0
            ELEMENT        1224 [    1B]  GROUP  0
            ELEMENT        1225 [    1C]  GROUP  0
            ELEMENT        1226 [    1D]  GROUP  0
            ELEMENT        1227 [    1E]  GROUP  0
            ELEMENT        1228 [    1F]  GROUP  0
            ELEMENT        1229 [    1G]  GROUP  0
            ELEMENT        1230 [    1H]  GROUP  0
            ELEMENT        1231 [    1I]  GROUP  0
            ELEMENT        1232 [    1J]  GROUP  0
            ELEMENT        1233 [    1K]  GROUP  0
            ELEMENT        1234 [    1L]  GROUP  0
            ELEMENT        1235 [    1M]  GROUP  0
            ELEMENT        1236 [    1N]  GROUP  0
            ELEMENT        1237 [    1O]  GROUP  0
            ELEMENT        1238 [    1P]  GROUP  0
            ELEMENT        1239 [    1Q]  GROUP  0
            ELEMENT        1240 [    1R]  GROUP  0
            ELEMENT        1241 [    1S]  GROUP  0
            ELEMENT        1242 [    1T]  GROUP  0
            ELEMENT        1243 [    1U]  GROUP  0
            ELEMENT        1244 [    1V]  GROUP  0
            ELEMENT        1245 [    1W]  GROUP  0
            ELEMENT        1246 [    1X]  GROUP  0
            ELEMENT        1247 [    1Y]  GROUP  0
            ELEMENT        1248 [    1Z]  GROUP  0
            ELEMENT        1249 [    1a]  GROUP  0
            ELEMENT        1250 [    1b]  GROUP  0
            ELEMENT        1251 [    1c]  GROUP  0
            ELEMENT        1252 [    1d]  GROUP  0
            ELEMENT        1253 [    1e]  GROUP  0
            ELEMENT        1254 [    1f]  GROUP  0
            ELEMENT        1255 [    1g]  GROUP  0
            ELEMENT        1256 [    1h]  GROUP  0
            ELEMENT        1257 [    1i]  GROUP  0
            ELEMENT        1258 [    1j]  GROUP  0
            ELEMENT        1259 [    1k]  GROUP  0
            ELEMENT        1260 [    1l]  GROUP  0
            ELEMENT        1261 [    1m]  GROUP  0
            ELEMENT        1262 [    1n]  GROUP  0
            ELEMENT        1263 [    1o]  GROUP  0
            ELEMENT        1264 [    1p]  GROUP  0
            ELEMENT        1265 [    1q]  GROUP  0
            ELEMENT        1266 [    1r]  GROUP  0
            ELEMENT        1267 [    1s]  GROUP  0
            ELEMENT        1268 [    1t]  GROUP  0
            ELEMENT        1269 [    1u]  GROUP  0
            ELEMENT        1270 [    1v]  GROUP  0
            ELEMENT        1271 [    1w]  GROUP  0
            ELEMENT        1272 [    1x]  GROUP  0
            ELEMENT        1273 [    1y]  GROUP  0
            ELEMENT        1274 [    1z]  GROUP  0
            ELEMENT        1275 [    1A]  GROUP  0
            ELEMENT        1276 [    1B]  GROUP  0
            ELEMENT        1277 [    1C]  GROUP  0
            ELEMENT        1278 [    1D]  GROUP  0
            ELEMENT        1279 [    1E]  GROUP  0
            ELEMENT        1280 [    1F]  GROUP  0
            ELEMENT        1281 [    1G]  GROUP  0
            ELEMENT        1282 [    1H]  GROUP  0
            ELEMENT        1283 [    1I]  GROUP  0
            ELEMENT        1284 [    1J]  GROUP  0
            ELEMENT        1285 [    1K]  GROUP  0
            ELEMENT        1286 [    1L]  GROUP  0
            ELEMENT        1287 [    1M]  GROUP  0
            ELEMENT        1288 [    1N]  GROUP  0
            ELEMENT        1289 [    1O]  GROUP  0
            ELEMENT        1290 [    1P]  GROUP  0
            ELEMENT        1291 [    1Q]  GROUP  0
            ELEMENT        1292 [    1R]  GROUP  0
            ELEMENT        1293 [    1S]  GROUP  0
            ELEMENT        1294 [    1T]  GROUP  0
            ELEMENT        1295 [    1U]  GROUP  0
            ELEMENT        1296 [    1V]  GROUP  0
            ELEMENT        1297 [    1W]  GROUP  0
            ELEMENT        1298 [    1X]  GROUP  0
            ELEMENT        1299 [    1Y]  GROUP  0
            ELEMENT        1300 [    1Z]  GROUP  0
            ELEMENT        1301 [    1a]  GROUP  0
            ELEMENT        1302 [    1b]  GROUP  0
            ELEMENT        1303 [    1c]  GROUP  0
            ELEMENT        1304 [    1d]  GROUP  0
            ELEMENT        1305 [    1e]  GROUP  0
            ELEMENT        1306 [    1f]  GROUP  0
            ELEMENT        1307 [    1g]  GROUP  0
            ELEMENT        1308 [    1h]  GROUP  0
            ELEMENT        1309 [    1i]  GROUP  0
            ELEMENT        1310 [    1j]  GROUP  0
            ELEMENT        1311 [    1k]  GROUP  0
            ELEMENT        1312 [    1l]  GROUP  0
            ELEMENT        1313 [    1m]  GROUP  0
            ELEMENT        1314 [    1n]  GROUP  0
            ELEMENT        1315 [    1o]  GROUP  0
            ELEMENT        1316 [    1p]  GROUP  0
            ELEMENT        1317 [    1q]  GROUP  0
            ELEMENT        1318 [    1r]  GROUP  0
            ELEMENT        1319 [    1s]  GROUP  0
            ELEMENT        1320 [    1t]  GROUP  0
            ELEMENT        1321 [    1u]  GROUP  0
            ELEMENT        1322 [    1v]  GROUP  0
            ELEMENT        1323 [    1w]  GROUP  0
            ELEMENT        1324 [    1x]  GROUP  0
            ELEMENT        1325 [    1y]  GROUP  0
            ELEMENT        1326 [    1z]  GROUP  0
            ELEMENT        1327 [    1A]  GROUP  0
            ELEMENT        1328 [    1B]  GROUP  0
            ELEMENT        1329 [    1C]  GROUP  0
            ELEMENT        1330 [    1D]  GROUP  0
            ELEMENT        1331 [    1E]  GROUP  0
            ELEMENT        1332 [    1F]  GROUP  0
            ELEMENT        1333 [    1G]  GROUP  0
            ELEMENT        1334 [    1H]  GROUP  0
            ELEMENT        1335 [    1I]  GROUP  0
            ELEMENT        1336 [    1J]  GROUP  0
            ELEMENT        1337 [    1K]  GROUP  0
            ELEMENT        1338 [    1L]  GROUP  0
            ELEMENT        1339 [    1M]  GROUP  0
            ELEMENT        1340 [    1N]  GROUP  0
            ELEMENT        1341 [    1O]  GROUP  0
            ELEMENT        1342 [    1P]  GROUP  0
            ELEMENT        1343 [    1Q]  GROUP  0
            ELEMENT        1344 [    1R]  GROUP  0
            ELEMENT        1345 [    1S]  GROUP  0
            ELEMENT        1346 [    1T]  GROUP  0
            ELEMENT        1347 [    1U]  GROUP  0
            ELEMENT        1348 [    1V]  GROUP  0
            ELEMENT        1349 [    1W]  GROUP  0
            ELEMENT        1350 [    1X]  GROUP  0
            ELEMENT        1351 [    1Y]  GROUP  0
            ELEMENT        1352 [    1Z]  GROUP  0
            ELEMENT        1353 [    1a]  GROUP  0
            ELEMENT        1354 [    1b]  GROUP  0
            ELEMENT        1355 [    1c]  GROUP  0
            ELEMENT        1356 [    1d]  GROUP  0
            ELEMENT        1357 [    1e]  GROUP  0
            ELEMENT        1358 [    1f]  GROUP  0
            ELEMENT        1359 [    1g]  GROUP  0
            ELEMENT        1360 [    1h]  GROUP  0
            ELEMENT        1361 [    1i]  GROUP  0
            ELEMENT        1362 [    1j]  GROUP  0
            ELEMENT        1363 [    1k]  GROUP  0
            ELEMENT        1364 [    1l]  GROUP  0
            ELEMENT        1365 [    1m]  GROUP  0
            ELEMENT        1366 [    1n]  GROUP  0
            ELEMENT        1367 [    1o]  GROUP  0
            ELEMENT        1368 [    1p]  GROUP  0
            ELEMENT        1369 [    1q]  GROUP  0
            ELEMENT        1370 [    1r]  GROUP  0
            ELEMENT        1371 [    1s]  GROUP  0
            ELEMENT        1372 [    1t]  GROUP  0
            ELEMENT        1373 [    1u]  GROUP  0
            ELEMENT        1374 [    1v]  GROUP  0
            ELEMENT        1375 [    1w]  GROUP  0
            ELEMENT        1376 [    1x]  GROUP  0
            ELEMENT        1377 [    1y]  GROUP  0
            ELEMENT        1378 [    1z]  GROUP  0
            ELEMENT        1379 [    1A]  GROUP  0
            ELEMENT        1380 [    1B]  GROUP  0
            ELEMENT        1381 [    1C]  GROUP  0
            ELEMENT        1382 [    1D]  GROUP  0
            ELEMENT        1383 [    1E]  GROUP  0
            ELEMENT        1384 [    1F]  GROUP  0
            ELEMENT        1385 [    1G]  GROUP  0
            ELEMENT        1386 [    1H]  GROUP  0
            ELEMENT        1387 [    1I]  GROUP  0
            ELEMENT        1388 [    1J]  GROUP  0
            ELEMENT        1389 [    1K]  GROUP  0
            ELEMENT        1390 [    1L]  GROUP  0
            ELEMENT        1391 [    1M]  GROUP  0
            ELEMENT        1392 [    1N]  GROUP  0
            ELEMENT        1393 [    1O]  GROUP  0
            ELEMENT        1394 [    1P]  GROUP  0
            ELEMENT        1395 [    1Q]  GROUP  0
            ELEMENT        1396 [    1R]  GROUP  0
            ELEMENT        1397 [    1S]  GROUP  0
            ELEMENT        1398 [    1T]  GROUP  0
            ELEMENT        1399 [    1U]  GROUP  0
            ELEMENT        1400 [    1V]  GROUP  0
            ELEMENT        1401 [    1W]  GROUP  0
            ELEMENT        1402 [    1X]  GROUP  0
            ELEMENT        1403 [    1Y]  GROUP  0
            ELEMENT        1404 [    1Z]  GROUP  0
            ELEMENT        1405 [    1a]  GROUP  0
            ELEMENT        1406 [    1b]  GROUP  0
            ELEMENT        1407 [    1c]  GROUP  0
            ELEMENT        1408 [    1d]  GROUP  0
            ELEMENT        1409 [    1e]  GROUP  0
            ELEMENT        1410 [    1f]  GROUP  0
            ELEMENT        1411 [    1g]  GROUP  0
            ELEMENT        1412 [    1h]  GROUP  0
            ELEMENT        1413 [    1i]  GROUP  0
            ELEMENT        1414 [    1j]  GROUP  0
            ELEMENT        1415 [    1k]  GROUP  0
            ELEMENT        1416 [    1l]  GROUP  0
            ELEMENT        1417 [    1m]  GROUP  0
            ELEMENT        1418 [    1n]  GROUP  0
            ELEMENT        1419 [    1o]  GROUP  0
            ELEMENT        1420 [    1p]  GROUP  0
            ELEMENT        1421 [    1q]  GROUP  0
            ELEMENT        1422 [    1r]  GROUP  0
            ELEMENT        1423 [    1s]  GROUP  0
            ELEMENT        1424 [    1t]  GROUP  0
            ELEMENT        1425 [    1u]  GROUP  0
            ELEMENT        1426 [    1v]  GROUP  0
            ELEMENT        1427 [    1w]  GROUP  0
            ELEMENT        1428 [    1x]  GROUP  0
            ELEMENT        1429 [    1y]  GROUP  0
            ELEMENT        1430 [    1z]  GROUP  0
            ELEMENT        1431 [    1A]  GROUP  0
            ELEMENT        1432 [    1B]  GROUP  0
            ELEMENT        1433 [    1C]  GROUP  0
            ELEMENT        1434 [    1D]  GROUP  0
            ELEMENT        1435 [    1E]  GROUP  0
            ELEMENT        1436 [    1F]  GROUP  0
            ELEMENT        1437 [    1G]  GROUP  0
            ELEMENT        1438 [    1H]  GROUP  0
            ELEMENT        1439 [    1I]  GROUP  0
            ELEMENT        1440 [    1J]  GROUP  0
            ELEMENT        1441 [    1K]  GROUP  0
            ELEMENT        1442 [    1L]  GROUP  0
            ELEMENT        1443 [    1M]  GROUP  0
            ELEMENT        1444 [    1N]  GROUP  0
            ELEMENT        1445 [    1O]  GROUP  0
            ELEMENT        1446 [    1P]  GROUP  0
            ELEMENT        1447 [    1Q]  GROUP  0
            ELEMENT        1448 [    1R]  GROUP  0
            ELEMENT        1449 [    1S]  GROUP  0
            ELEMENT        1450 [    1T]  GROUP  0
            ELEMENT        1451 [    1U]  GROUP  0
            ELEMENT        1452 [    1V]  GROUP  0
            ELEMENT        1453 [    1W]  GROUP  0
            ELEMENT        1454 [    1X]  GROUP  0
            ELEMENT        1455 [    1Y]  GROUP  0
            ELEMENT        1456 [    1Z]  GROUP  0
            ELEMENT        1457 [    1a]  GROUP  0
            ELEMENT        1458 [    1b]  GROUP  0
            ELEMENT        1459 [    1c]  GROUP  0
            ELEMENT        1460 [    1d]  GROUP  0
            ELEMENT        1461 [    1e]  GROUP  0
            ELEMENT        1462 [    1f]  GROUP  0
            ELEMENT        1463 [    1g]  GROUP  0
            ELEMENT        1464 [    1h]  GROUP  0
            ELEMENT        1465 [    1i]  GROUP  0
            ELEMENT        1466 [    1j]  GROUP  0
            ELEMENT        1467 [    1k]  GROUP  0
            ELEMENT        1468 [    1l]  GROUP  0
            ELEMENT        1469 [    1m]  GROUP  0
            ELEMENT        1470 [    1n]  GROUP  0
            ELEMENT        1471 [    1o]  GROUP  0
            ELEMENT        1472 [    1p]  GROUP  0
            ELEMENT        1473 [    1q]  GROUP  0
            ELEMENT        1474 [    1r]  GROUP  0
            ELEMENT        1475 [    1s]  GROUP  0
            ELEMENT        1476 [    1t]  GROUP  0
            ELEMENT        1477 [    1u]  GROUP  0
            ELEMENT        1478 [    1v]  GROUP  0
            ELEMENT        1479 [    1w]  GROUP  0
            ELEMENT        1480 [    1x]  GROUP  0
            ELEMENT        1481 [    1y]  GROUP  0
            ELEMENT        1482 [    1z]  GROUP  0
            ELEMENT        1483 [    1A]  GROUP  0
            ELEMENT        1484 [    1B]  GROUP  0
            ELEMENT        1485 [    1C]  GROUP  0
            ELEMENT        1486 [    1D]  GROUP  0
            ELEMENT        1487 [    1E]  GROUP  0
            ELEMENT        1488 [    1F]  GROUP  0
            ELEMENT        1489 [    1G]  GROUP  0
            ELEMENT        1490 [    1H]  GROUP  0
            ELEMENT        1491 [    1I]  GROUP  0
            ELEMENT        1492 [    1J]  GROUP  0
            ELEMENT        1493 [    1K]  GROUP  0
            ELEMENT        1494 [    1L]  GROUP  0
            ELEMENT        1495 [    1M]  GROUP  0
            ELEMENT        1496 [    1N]  GROUP  0
            ELEMENT        1497 [    1O]  GROUP  0
            ELEMENT        1498 [    1P]  GROUP  0
            ELEMENT        1499 [    1Q]  GROUP  0
            ELEMENT        1500 [    1R]  GROUP  0
            ELEMENT        1501 [    1S]  GROUP  0
            ELEMENT        1502 [    1T]  GROUP  0
            ELEMENT        1503 [    1U]  GROUP  0
            ELEMENT        1504 [    1V]  GROUP  0
            ELEMENT        1505 [    1W]  GROUP  0
            ELEMENT        1506 [    1X]  GROUP  0
            ELEMENT        1507 [    1Y]  GROUP  0
            ELEMENT        1508 [    1Z]  GROUP  0
            ELEMENT        1509 [    1a]  GROUP  0
            ELEMENT        1510 [    1b]  GROUP  0
            ELEMENT        1511 [    1c]  GROUP  0
            ELEMENT        1512 [    1d]  GROUP  0
            ELEMENT        1513 [    1e]  GROUP  0
            ELEMENT        1514 [    1f]  GROUP  0
            ELEMENT        1515 [    1g]  GROUP  0
            ELEMENT        1516 [    1h]  GROUP  0
            ELEMENT        1517 [    1i]  GROUP  0
            ELEMENT        1518 [    1j]  GROUP  0
            ELEMENT        1519 [    1k]  GROUP  0
            ELEMENT        1520 [    1l]  GROUP  0
            ELEMENT        1521 [    1m]  GROUP  0
            ELEMENT        1522 [    1n]  GROUP  0
            ELEMENT        1523 [    1o]  GROUP  0
            ELEMENT        1524 [    1p]  GROUP  0
            ELEMENT        1525 [    1q]  GROUP  0
            ELEMENT        1526 [    1r]  GROUP  0
            ELEMENT        1527 [    1s]  GROUP  0
            ELEMENT        1528 [    1t]  GROUP  0
            ELEMENT        1529 [    1u]  GROUP  0
            ELEMENT        1530 [    1v]  GROUP  0
            ELEMENT        1531 [    1w]  GROUP  0
            ELEMENT        1532 [    1x]  GROUP  0
            ELEMENT        1533 [    1y]  GROUP  0
            ELEMENT        1534 [    1z]  GROUP  0
            ELEMENT        1535 [    1A]  GROUP  0
            ELEMENT        1536 [    1B]  GROUP  0
  ***** CURVED SIDE DATA *****
           0 Curved sides follow IEDGE,IEL,CURVE(I),I=1,5, CCURVE
  ***** BOUNDARY CONDITIONS *****
  ***** FLUID   BOUNDARY CONDITIONS *****
 v      11   0.00000       0.00000       0.00000       0.00000       0.00000
 E      12   2.00000       4.00000       0.00000       0.00000       0.00000
 E      13   17.0000       1.00000       0.00000       0.00000       0.00000
 v      14   0.00000       0.00000       0.00000       0.00000       0.00000
 v      21   0.00000       0.00000       0.00000       0.00000       0.00000
 E      22   3.00000       4.00000       0.00000       0.00000       0.00000
 E      23   18.0000       1.00000       0.00000       0.00000       0.00000
 E      24   1.00000       2.00000       0.00000       0.00000       0.00000
 v      31   0.00000       0.00000       0.00000       0.00000       0.00000
 E      32   4.00000       4.00000       0.00000       0.00000       0.00000
 E      33   19.0000       1.00000       0.00000       0.00000       0.00000
 E      34   2.00000       2.00000       0.00000       0.00000       0.00000
 v      41   0.00000       0.00000       0.00000       0.00000       0.00000
 E      42   5.00000       4.00000       0.00000       0.00000       0.00000
 E      43   20.0000       1.00000       0.00000       0.00000       0.00000
 E      44   3.00000       2.00000       0.00000       0.00000       0.00000
 v      51   0.00000       0.00000       0.00000       0.00000       0.00000
 E      52   6.00000       4.00000       0.00000       0.00000       0.00000
 E      53   21.0000       1.00000       0.00000       0.00000       0.00000
 E      54   4.00000       2.00000       0.00000       0.00000       0.00000
 v      61   0.00000       0.00000       0.00000       0.00000       0.00000
 E      62   7.00000       4.00000       0.00000       0.00000       0.00000
 E      63   22.0000       1.00000       0.00000       0.00000       0.00000
 E      64   5.00000       2.00000       0.00000       0.00000       0.00000
 v      71   0.00000       0.00000       0.00000       0.00000       0.00000
 E      72   8.00000       4.00000       0.00000       0.00000       0.00000
 E      73   23.0000       1.00000       0.00000       0.00000       0.00000
 E      74   6.00000       2.00000       0.00000       0.00000       0.00000
 v      81   0.00000       0.00000       0.00000       0.00000       0.00000
 E      82   9.00000       4.00000       0.00000       0.00000       0.00000
 E      83   24.0000       1.00000       0.00000       0.00000       0.00000
 E      84   7.00000       2.00000       0.00000       0.00000       0.00000
 v      91   0.00000       0.00000       0.00000       0.00000       0.00000
 E      92   10.0000       4.00000       0.00000       0.00000       0.00000
 E      93   25.0000       1.00000       0.00000       0.00000       0.00000
 E      94   8.00000       2.00000       0.00000       0.00000       0.00000
 v     101   0.00000       0.00000       0.00000       0.00000       0.00000
 E     102   11.0000       4.00000       0.00000       0.00000       0.00000
 E     103   26.0000       1.00000       0.00000       0.00000       0.00000
 E     104   9.00000       2.00000       0.00000       0.00000       0.00000
 v     111   0.00000       0.00000       0.00000       0.00000       0.00000
 E     112   12.0000       4.00000       0.00000       0.00000       0.00000
 E     113   27.0000       1.00000       0.00000       0.00000       0.00000
 E     114   10.0000       2.00000       0.00000       0.00000       0.00000
 v     121   0.00000       0.00000       0.00000       0.00000       0.00000
 E     122   13.0000       4.00000       0.00000       0.00000       0.00000
 E     123   28.0000       1.00000       0.00000       0.00000       0.00000
 E     124   11.0000       2.00000       0.00000       0.00000       0.00000
 v     131   0.00000       0.00000       0.00000       0.00000       0.00000
 E     132   14.0000       4.00000       0.00000       0.00000       0.00000
 E     133   29.0000       1.00000       0.00000       0.00000       0.00000
 E     134   12.0000       2.00000       0.00000       0.00000       0.00000
 v     141   0.00000       0.00000       0.00000       0.00000       0.00000
 E     142   15.0000       4.00000       0.00000       0.00000       0.00000
 E     143   30.0000       1.00000       0.00000       0.00000       0.00000
 E     144   13.0000       2.00000       0.00000       0.00000       0.00000
 v     151   0.00000       0.00000       0.00000       0.00000       0.00000
 E     152   16.0000       4.00000       0.00000       0.00000       0.00000
 E     153   31.0000       1.00000       0.00000       0.00000       0.00000
 E     154   14.0000       2.00000       0.00000       0.00000       0.00000
 v     161   0.00000       0.00000       0.00000       0.00000       0.00000
       162   0.00000       0.00000       0.00000       0.00000       0.00000
 E     163   32.0000       1.00000       0.00000       0.00000       0.00000
 E     164   15.0000       2.00000       0.00000       0.00000       0.00000
 E     171   1.00000       3.00000       0.00000       0.00000       0.00000
 E     172   18.0000       4.00000       0.00000       0.00000       0.00000
 E     173   33.0000       1.00000       0.00000       0.00000       0.00000
 v     174   0.00000       0.00000       0.00000       0.00000       0.00000
 E     181   2.00000       3.00000       0.00000       0.00000       0.00000
 E     182   19.0000       4.00000       0.00000       0.00000       0.00000
 E     183   34.0000       1.00000       0.00000       0.00000       0.00000
 E     184   17.0000       2.00000       0.00000       0.00000       0.00000
 E     191   3.00000       3.00000       0.00000       0.00000       0.00000
 E     192   20.0000       4.00000       0.00000       0.00000       0.00000
 E     193   35.0000       1.00000       0.00000       0.00000       0.00000
 E     194   18.0000       2.00000       0.00000       0.00000       0.00000
 E     201   4.00000       3.00000       0.00000       0.00000       0.00000
 E     202   21.0000       4.00000       0.00000       0.00000       0.00000
 E     203   36.0000       1.00000       0.00000       0.00000       0.00000
 E     204   19.0000       2.00000       0.00000       0.00000       0.00000
 E     211   5.00000       3.00000       0.00000       0.00000       0.00000
 E     212   22.0000       4.00000       0.00000       0.00000       0.00000
 E     213   37.0000       1.00000       0.00000       0.00000       0.00000
 E     214   20.0000       2.00000       0.00000       0.00000       0.00000
 E     221   6.00000       3.00000       0.00000       0.00000       0.00000
 E     222   23.0000       4.00000       0.00000       0.00000       0.00000
 E     223   38.0000       1.00000       0.00000       0.00000       0.00000
 E     224   21.0000       2.00000       0.00000       0.00000       0.00000
 E     231   7.00000       3.00000       0.00000       0.00000       0.00000
 E     232   24.0000       4.00000       0.00000       0.00000       0.00000
 E     233   39.0000       1.00000       0.00000       0.00000       0.00000
 E     234   22.0000       2.00000       0.00000       0.00000       0.00000
 E     241   8.00000       3.00000       0.00000       0.00000       0.00000
 E     242   25.0000       4.00000       0.00000       0.00000       0.00000
 E     243   40.0000       1.00000       0.00000       0.00000       0.00000
 E     244   23.0000       2.00000       0.00000       0.00000       0.00000
 E     251   9.00000       3.00000       0.00000       0.00000       0.00000
 E     252   26.0000       4.00000       0.00000       0.00000       0.00000
 E     253   41.0000       1.00000       0.00000       0.00000       0.00000
 E     254   24.0000       2.00000       0.00000       0.00000       0.00000
 E     261   10.0000       3.00000       0.00000       0.00000       0.00000
 E     262   27.0000       4.00000       0.00000       0.00000       0.00000
 E     263   42.0000       1.00000       0.00000       0.00000       0.00000
 E     264   25.0000       2.00000       0.00000       0.00000       0.00000
 E     271   11.0000       3.00000       0.00000       0.00000       0.00000
 E     272   28.0000       4.00000       0.00000       0.00000       0.00000
 E     273   43.0000       1.00000       0.00000       0.00000       0.00000
 E     274   26.0000       2.00000       0.00000       0.00000       0.00000
 E     281   12.0000       3.00000       0.00000       0.00000       0.00000
 E     282   29.0000       4.00000       0.00000       0.00000       0.00000
 E     283   44.0000       1.00000       0.00000       0.00000       0.00000
 E     284   27.0000       2.00000       0.00000       0.00000       0.00000
 E     291   13.0000       3.00000       0.00000       0.00000       0.00000
 E     292   30.0000       4.00000       0.00000       0.00000       0.00000
 E     293   45.0000       1.00000       0.00000       0.00000       0.00000
 E     294   28.0000       2.00000       0.00000       0.00000       0.00000
 E     301   14.0000       3.00000       0.00000       0.00000       0.00000
 E     302   31.0000       4.00000       0.00000       0.00000       0.00000
 E     303   46.0000       1.00000       0.00000       0.00000       0.00000
 E     304   29.0000       2.00000       0.00000       0.00000       0.00000
 E     311   15.0000       3.00000       0.00000       0.00000       0.00000
 E     312   32.0000       4.00000       0.00000       0.00000       0.00000
 E     313   47.0000       1.00000       0.00000       0.00000       0.00000
 E     314   30.0000       2.00000       0.00000       0.00000       0.00000
 E     321   16.0000       3.00000       0.00000       0.00000       0.00000
       322   0.00000       0.00000       0.00000       0.00000       0.00000
 E     323   48.0000       1.00000       0.00000       0.00000       0.00000
 E     324   31.0000       2.00000       0.00000       0.00000       0.00000
 E     331   17.0000       3.00000       0.00000       0.00000       0.00000
 E     332   34.0000       4.00000       0.00000       0.00000       0.00000
 E     333   49.0000       1.00000       0.00000       0.00000       0.00000
 v     334   0.00000       0.00000       0.00000       0.00000       0.00000
 E     341   18.0000       3.00000       0.00000       0.00000       0.00000
 E     342   35.0000       4.00000       0.00000       0.00000       0.00000
 E     343   50.0000       1.00000       0.00000       0.00000       0.00000
 E     344   33.0000       2.00000       0.00000       0.00000       0.00000
 E     351   19.0000       3.00000       0.00000       0.00000       0.00000
 E     352   36.0000       4.00000       0.00000       0.00000       0.00000
 E     353   51.0000       1.00000       0.00000       0.00000       0.00000
 E     354   34.0000       2.00000       0.00000       0.00000       0.00000
 E     361   20.0000       3.00000       0.00000       0.00000       0.00000
 E     362   37.0000       4.00000       0.00000       0.00000       0.00000
 E     363   52.0000       1.00000       0.00000       0.00000       0.00000
 E     364   35.0000       2.00000       0.00000       0.00000       0.00000
 E     371   21.0000       3.00000       0.00000       0.00000       0.00000
 E     372   38.0000       4.00000       0.00000       0.00000       0.00000
 E     373   53.0000       1.00000       0.00000       0.00000       0.00000
 E     374   36.0000       2.00000       0.00000       0.00000       0.00000
 E     381   22.0000       3.00000       0.00000       0.00000       0.00000
 E     382   39.0000       4.00000       0.00000       0.00000       0.00000
 E     383   54.0000       1.00000       0.00000       0.00000       0.00000
 E     384   37.0000       2.00000       0.00000       0.00000       0.00000
 E     391   23.0000       3.00000       0.00000       0.00000       0.00000
 E     392   40.0000       4.00000       0.00000       0.00000       0.00000
 E     393   55.0000       1.00000       0.00000       0.00000       0.00000
 E     394   38.0000       2.00000       0.00000       0.00000       0.00000
 E     401   24.0000       3.00000       0.00000       0.00000       0.00000
 E     402   41.0000       4.00000       0.00000       0.00000       0.00000
 E     403   56.0000       1.00000       0.00000       0.00000       0.00000
 E     404   39.0000       2.00000       0.00000       0.00000       0.00000
 E     411   25.0000       3.00000       0.00000       0.00000       0.00000
 E     412   42.0000       4.00000       0.00000       0.00000       0.00000
 E     413   57.0000       1.00000       0.00000       0.00000       0.00000
 E     414   40.0000       2.00000       0.00000       0.00000       0.00000
 E     421   26.0000       3.00000       0.00000       0.00000       0.00000
 E     422   43.0000       4.00000       0.00000       0.00000       0.00000
 E     423   58.0000       1.00000       0.00000       0.00000       0.00000
 E     424   41.0000       2.00000       0.00000       0.00000       0.00000
 E     431   27.0000       3.00000       0.00000       0.00000       0.00000
 E     432   44.0000       4.00000       0.00000       0.00000       0.00000
 E     433   59.0000       1.00000       0.00000       0.00000       0.00000
 E     434   42.0000       2.00000       0.00000       0.00000       0.00000
 E     441   28.0000       3.00000       0.00000       0.00000       0.00000
 E     442   45.0000       4.00000       0.00000       0.00000       0.00000
 E     443   60.0000       1.00000       0.00000       0.00000       0.00000
 E     444   43.0000       2.00000       0.00000       0.00000       0.00000
 E     451   29.0000       3.00000       0.00000       0.00000       0.00000
 E     452   46.0000       4.00000       0.00000       0.00000       0.00000
 E     453   61.0000       1.00000       0.00000       0.00000       0.00000
 E     454   44.0000       2.00000       0.00000       0.00000       0.00000
 E     461   30.0000       3.00000       0.00000       0.00000       0.00000
 E     462   47.0000       4.00000       0.00000       0.00000       0.00000
 E     463   62.0000       1.00000       0.00000       0.00000       0.00000
 E     464   45.0000       2.00000       0.00000       0.00000       0.00000
 E     471   31.0000       3.00000       0.00000       0.00000       0.00000
 E     472   48.0000       4.00000       0.00000       0.00000       0.00000
 E     473   63.0000       1.00000       0.00000       0.00000       0.00000
 E     474   46.0000       2.00000       0.00000       0.00000       0.00000
 E     481   32.0000       3.00000       0.00000       0.00000       0.00000
       482   0.00000       0.00000       0.00000       0.00000       0.00000
 E     483   64.0000       1.00000       0.00000       0.00000       0.00000
 E     484   47.0000       2.00000       0.00000       0.00000       0.00000
 E     491   33.0000       3.00000       0.00000       0.00000       0.00000
 E     492   50.0000       4.00000       0.00000       0.00000       0.00000
 E     493   65.0000       1.00000       0.00000       0.00000       0.00000
 v     494   0.00000       0.00000       0.00000       0.00000       0.00000
 E     501   34.0000       3.00000       0.00000       0.00000       0.00000
 E     502   51.0000       4.00000       0.00000       0.00000       0.00000
 E     503   66.0000       1.00000       0.00000       0.00000       0.00000
 E     504   49.0000       2.00000       0.00000       0.00000       0.00000
 E     511   35.0000       3.00000       0.00000       0.00000       0.00000
 E     512   52.0000       4.00000       0.00000       0.00000       0.00000
 E     513   67.0000       1.00000       0.00000       0.00000       0.00000
 E     514   50.0000       2.00000       0.00000       0.00000       0.00000
 E     521   36.0000       3.00000       0.00000       0.00000       0.00000
 E     522   53.0000       4.00000       0.00000       0.00000       0.00000
 E     523   68.0000       1.00000       0.00000       0.00000       0.00000
 E     524   51.0000       2.00000       0.00000       0.00000       0.00000
 E     531   37.0000       3.00000       0.00000       0.00000       0.00000
 E     532   54.0000       4.00000       0.00000       0.00000       0.00000
 E     533   69.0000       1.00000       0.00000       0.00000       0.00000
 E     534   52.0000       2.00000       0.00000       0.00000       0.00000
 E     541   38.0000       3.00000       0.00000       0.00000       0.00000
 E     542   55.0000       4.00000       0.00000       0.00000       0.00000
 E     543   70.0000       1.00000       0.00000       0.00000       0.00000
 E     544   53.0000       2.00000       0.00000       0.00000       0.00000
 E     551   39.0000       3.00000       0.00000       0.00000       0.00000
 E     552   56.0000       4.00000       0.00000       0.00000       0.00000
 E     553   71.0000       1.00000       0.00000       0.00000       0.00000
 E     554   54.0000       2.00000       0.00000       0.00000       0.00000
 E     561   40.0000       3.00000       0.00000       0.00000       0.00000
 E     562   57.0000       4.00000       0.00000       0.00000       0.00000
 E     563   72.0000       1.00000       0.00000       0.00000       0.00000
 E     564   55.0000       2.00000       0.00000       0.00000       0.00000
 E     571   41.0000       3.00000       0.00000       0.00000       0.00000
 E     572   58.0000       4.00000       0.00000       0.00000       0.00000
 E     573   73.0000       1.00000       0.00000       0.00000       0.00000
 E     574   56.0000       2.00000       0.00000       0.00000       0.00000
 E     581   42.0000       3.00000       0.00000       0.00000       0.00000
 E     582   59.0000       4.00000       0.00000       0.00000       0.00000
 E     583   74.0000       1.00000       0.00000       0.00000       0.00000
 E     584   57.0000       2.00000       0.00000       0.00000       0.00000
 E     591   43.0000       3.00000       0.00000       0.00000       0.00000
 E     592   60.0000       4.00000       0.00000       0.00000       0.00000
 E     593   75.0000       1.00000       0.00000       0.00000       0.00000
 E     594   58.0000       2.00000       0.00000       0.00000       0.00000
 E     601   44.0000       3.00000       0.00000       0.00000       0.00000
 E     602   61.0000       4.00000       0.00000       0.00000       0.00000
 E     603   76.0000       1.00000       0.00000       0.00000       0.00000
 E     604   59.0000       2.00000       0.00000       0.00000       0.00000
 E     611   45.0000       3.00000       0.00000       0.00000       0.00000
 E     612   62.0000       4.00000       0.00000       0.00000       0.00000
 E     613   77.0000       1.00000       0.00000       0.00000       0.00000
 E     614   60.0000       2.00000       0.00000       0.00000       0.00000
 E     621   46.0000       3.00000       0.00000       0.00000       0.00000
 E     622   63.0000       4.00000       0.00000       0.00000       0.00000
 E     623   78.0000       1.00000       0.00000       0.00000       0.00000
 E     624   61.0000       2.00000       0.00000       0.00000       0.00000
 E     631   47.0000       3.00000       0.00000       0.00000       0.00000
 E     632   64.0000       4.00000       0.00000       0.00000       0.00000
 E     633   79.0000       1.00000       0.00000       0.00000       0.00000
 E     634   62.0000       2.00000       0.00000       0.00000       0.00000
 E     641   48.0000       3.00000       0.00000       0.00000       0.00000
       642   0.00000       0.00000       0.00000       0.00000       0.00000
 E     643   80.0000       1.00000       0.00000       0.00000       0.00000
 E     644   63.0000       2.00000       0.00000       0.00000       0.00000
 E     651   49.0000       3.00000       0.00000       0.00000       0.00000
 E     652   66.0000       4.00000       0.00000       0.00000       0.00000
 E     653   81.0000       1.00000       0.00000       0.00000       0.00000
 v     654   0.00000       0.00000       0.00000       0.00000       0.00000
 E     661   50.0000       3.00000       0.00000       0.00000       0.00000
 E     662   67.0000       4.00000       0.00000       0.00000       0.00000
 E     663   82.0000       1.00000       0.00000       0.00000       0.00000
 E     664   65.0000       2.00000       0.00000       0.00000       0.00000
 E     671   51.0000       3.00000       0.00000       0.00000       0.00000
 E     672   68.0000       4.00000       0.00000       0.00000       0.00000
 E     673   83.0000       1.00000       0.00000       0.00000       0.00000
 E     674   66.0000       2.00000       0.00000       0.00000       0.00000
 E     681   52.0000       3.00000       0.00000       0.00000       0.00000
 E     682   69.0000       4.00000       0.00000       0.00000       0.00000
 E     683   84.0000       1.00000       0.00000       0.00000       0.00000
 E     684   67.0000       2.00000       0.00000       0.00000       0.00000
 E     691   53.0000       3.00000       0.00000       0.00000       0.00000
 E     692   70.0000       4.00000       0.00000       0.00000       0.00000
 E     693   85.0000       1.00000       0.00000       0.00000       0.00000
 E     694   68.0000       2.00000       0.00000       0.00000       0.00000
 E     701   54.0000       3.00000       0.00000       0.00000       0.00000
 E     702   71.0000       4.00000       0.00000       0.00000       0.00000
 E     703   86.0000       1.00000       0.00000       0.00000       0.00000
 E     704   69.0000       2.00000       0.00000       0.00000       0.00000
 E     711   55.0000       3.00000       0.00000       0.00000       0.00000
 E     712   72.0000       4.00000       0.00000       0.00000       0.00000
 E     713   87.0000       1.00000       0.00000       0.00000       0.00000
 E     714   70.0000       2.00000       0.00000       0.00000       0.00000
 E     721   56.0000       3.00000       0.00000       0.00000       0.00000
 E     722   73.0000       4.00000       0.00000       0.00000       0.00000
 E     723   88.0000       1.00000       0.00000       0.00000       0.00000
 E     724   71.0000       2.00000       0.00000       0.00000       0.00000
 E     731   57.0000       3.00000       0.00000       0.00000       0.00000
 E     732   74.0000       4.00000       0.00000       0.00000       0.00000
 E     733   89.0000       1.00000       0.00000       0.00000       0.00000
 E     734   72.0000       2.00000       0.00000       0.00000       0.00000
 E     741   58.0000       3.00000       0.00000       0.00000       0.00000
 E     742   75.0000       4.00000       0.00000       0.00000       0.00000
 E     743   90.0000       1.00000       0.00000       0.00000       0.00000
 E     744   73.0000       2.00000       0.00000       0.00000       0.00000
 E     751   59.0000       3.00000       0.00000       0.00000       0.00000
 E     752   76.0000       4.00000       0.00000       0.00000       0.00000
 E     753   91.0000       1.00000       0.00000       0.00000       0.00000
 E     754   74.0000       2.00000       0.00000       0.00000       0.00000
 E     761   60.0000       3.00000       0.00000       0.00000       0.00000
 E     762   77.0000       4.00000       0.00000       0.00000       0.00000
 E     763   92.0000       1.00000       0.00000       0.00000       0.00000
 E     764   75.0000       2.00000       0.00000       0.00000       0.00000
 E     771   61.0000       3.00000       0.00000       0.00000       0.00000
 E     772   78.0000       4.00000       0.00000       0.00000       0.00000
 E     773   93.0000       1.00000       0.00000       0.00000       0.00000
 E     774   76.0000       2.00000       0.00000       0.00000       0.00000
 E     781   62.0000       3.00000       0.00000       0.00000       0.00000
 E     782   79.0000       4.00000       0.00000       0.00000       0.00000
 E     783   94.0000       1.00000       0.00000       0.00000       0.00000
 E     784   77.0000       2.00000       0.00000       0.00000       0.00000
 E     791   63.0000       3.00000       0.00000       0.00000       0.00000
 E     792   80.0000       4.00000       0.00000       0.00000       0.00000
 E     793   95.0000       1.00000       0.00000       0.00000       0.00000
 E     794   78.0000       2.00000       0.00000       0.00000       0.00000
 E     801   64.0000       3.00000       0.00000       0.00000       0.00000
       802   0.00000       0.00000       0.00000       0.00000       0.00000
 E     803   96.0000       1.00000       0.00000       0.00000       0.00000
 E     804   79.0000       2.00000       0.00000       0.00000       0.00000
 E     811   65.0000       3.00000       0.00000       0.00000       0.00000
 E     812   82.0000       4.00000       0.00000       0.00000       0.00000
 E     813   97.0000       1.00000       0.00000       0.00000       0.00000
 v     814   0.00000       0.00000       0.00000       0.00000       0.00000
 E     821   66.0000       3.00000       0.00000       0.00000       0.00000
 E     822   83.0000       4.00000       0.00000       0.00000       0.00000
 E     823   98.0000       1.00000       0.00000       0.00000       0.00000
 E     824   81.0000       2.00000       0.00000       0.00000       0.00000
 E     831   67.0000       3.00000       0.00000       0.00000       0.00000
 E     832   84.0000       4.00000       0.00000       0.00000       0.00000
 E     833   99.0000       1.00000       0.00000       0.00000       0.00000
 E     834   82.0000       2.00000       0.00000       0.00000       0.00000
 E     841   68.0000       3.00000       0.00000       0.00000       0.00000
 E     842   85.0000       4.00000       0.00000       0.00000       0.00000
 E     843   100.000       1.00000       0.00000       0.00000       0.00000
 E     844   83.0000       2.00000       0.00000       0.00000       0.00000
 E     851   69.0000       3.00000       0.00000       0.00000       0.00000
 E     852   86.0000       4.00000       0.00000       0.00000       0.00000
 E     853   101.000       1.00000       0.00000       0.00000       0.00000
 E     854   84.0000       2.00000       0.00000       0.00000       0.00000
 E     861   70.0000       3.00000       0.00000       0.00000       0.00000
 E     862   87.0000       4.00000       0.00000       0.00000       0.00000
 E     863   102.000       1.00000       0.00000       0.00000       0.00000
 E     864   85.0000       2.00000       0.00000       0.00000       0.00000
 E     871   71.0000       3.00000       0.00000       0.00000       0.00000
 E     872   88.0000       4.00000       0.00000       0.00000       0.00000
 E     873   103.000       1.00000       0.00000       0.00000       0.00000
 E     874   86.0000       2.00000       0.00000       0.00000       0.00000
 E     881   72.0000       3.00000       0.00000       0.00000       0.00000
 E     882   89.0000       4.00000       0.00000       0.00000       0.00000
 E     883   104.000       1.00000       0.00000       0.00000       0.00000
 E     884   87.0000       2.00000       0.00000       0.00000       0.00000
 E     891   73.0000       3.00000       0.00000       0.00000       0.00000
 E     892   90.0000       4.00000       0.00000       0.00000       0.00000
 E     893   105.000       1.00000       0.00000       0.00000       0.00000
 E     894   88.0000       2.00000       0.00000       0.00000       0.00000
 E     901   74.0000       3.00000       0.00000       0.00000       0.00000
 E     902   91.0000       4.00000       0.00000       0.00000       0.00000
 E     903   106.000       1.00000       0.00000       0.00000       0.00000
 E     904   89.0000       2.00000       0.00000       0.00000       0.00000
 E     911   75.0000       3.00000       0.00000       0.00000       0.00000
 E     912   92.0000       4.00000       0.00000       0.00000       0.00000
 E     913   107.000       1.00000       0.00000       0.00000       0.00000
 E     914   90.0000       2.00000       0.00000       0.00000       0.00000
 E     921   76.0000       3.00000       0.00000       0.00000       0.00000
 E     922   93.0000       4.00000       0.00000       0.00000       0.00000
 E     923   108.000       1.00000       0.00000       0.00000       0.00000
 E     924   91.0000       2.00000       0.00000       0.00000       0.00000
 E     931   77.0000       3.00000       0.00000       0.00000       0.00000
 E     932   94.0000       4.00000       0.00000       0.00000       0.00000
 E     933   109.000       1.00000       0.00000       0.00000       0.00000
 E     934   92.0000       2.00000       0.00000       0.00000       0.00000
 E     941   78.0000       3.00000       0.00000       0.00000       0.00000
 E     942   95.0000       4.00000       0.00000       0.00000       0.00000
 E     943   110.000       1.00000       0.00000       0.00000       0.00000
 E     944   93.0000       2.00000       0.00000       0.00000       0.00000
 E     951   79.0000       3.00000       0.00000       0.00000       0.00000
 E     952   96.0000       4.00000       0.00000       0.00000       0.00000
 E     953   111.000       1.00000       0.00000       0.00000       0.00000
 E     954   94.0000       2.00000       0.00000       0.00000       0.00000
 E     961   80.0000       3.00000       0.00000       0.00000       0.00000
       962   0.00000       0.00000       0.00000       0.00000       0.00000
 E     963   112.000       1.00000       0.00000       0.00000       0.00000
 E     964   95.0000       2.00000       0.00000       0.00000       0.00000
 E     971   81.0000       3.00000       0.00000       0.00000       0.00000
 E     972   98.0000       4.00000       0.00000       0.00000       0.00000
 E     973   113.000       1.00000       0.00000       0.00000       0.00000
 v     974   0.00000       0.00000       0.00000       0.00000       0.00000
 E     981   82.0000       3.00000       0.00000       0.00000       0.00000
 E     982   99.0000       4.00000       0.00000       0.00000       0.00000
 E     983   114.000       1.00000       0.00000       0.00000       0.00000
 E     984   97.0000       2.00000       0.00000       0.00000       0.00000
 E     991   83.0000       3.00000       0.00000       0.00000       0.00000
 E     992   100.000       4.00000       0.00000       0.00000       0.00000
 E     993   115.000       1.00000       0.00000       0.00000       0.00000
 E     994   98.0000       2.00000       0.00000       0.00000       0.00000
 E    1001   84.0000       3.00000       0.00000       0.00000       0.00000
 E    1002   101.000       4.00000       0.00000       0.00000       0.00000
 E    1003   116.000       1.00000       0.00000       0.00000       0.00000
 E    1004   99.0000       2.00000       0.00000       0.00000       0.00000
 E    1011   85.0000       3.00000       0.00000       0.00000       0.00000
 E    1012   102.000       4.00000       0.00000       0.00000       0.00000
 E    1013   117.000       1.00000       0.00000       0.00000       0.00000
 E    1014   100.000       2.00000       0.00000       0.00000       0.00000
 E    1021   86.0000       3.00000       0.00000       0.00000       0.00000
 E    1022   103.000       4.00000       0.00000       0.00000       0.00000
 E    1023   118.000       1.00000       0.00000       0.00000       0.00000
 E    1024   101.000       2.00000       0.00000       0.00000       0.00000
 E    1031   87.0000       3.00000       0.00000       0.00000       0.00000
 E    1032   104.000       4.00000       0.00000       0.00000       0.00000
 E    1033   119.000       1.00000       0.00000       0.00000       0.00000
 E    1034   102.000       2.00000       0.00000       0.00000       0.00000
 E    1041   88.0000       3.00000       0.00000       0.00000       0.00000
 E    1042   105.000       4.00000       0.00000       0.00000       0.00000
 E    1043   120.000       1.00000       0.00000       0.00000       0.00000
 E    1044   103.000       2.00000       0.00000       0.00000       0.00000
 E    1051   89.0000       3.00000       0.00000       0.00000       0.00000
 E    1052   106.000       4.00000       0.00000       0.00000       0.00000
 E    1053   121.000       1.00000       0.00000       0.00000       0.00000
 E    1054   104.000       2.00000       0.00000       0.00000       0.00000
 E    1061   90.0000       3.00000       0.00000       0.00000       0.00000
 E    1062   107.000       4.00000       0.00000       0.00000       0.00000
 E    1063   122.000       1.00000       0.00000       0.00000       0.00000
 E    1064   105.000       2.00000       0.00000       0.00000       0.00000
 E    1071   91.0000       3.00000       0.00000       0.00000       0.00000
 E    1072   108.000       4.00000       0.00000       0.00000       0.00000
 E    1073   123.000       1.00000       0.00000       0.00000       0.00000
 E    1074   106.000       2.00000       0.00000       0.00000       0.00000
 E    1081   92.0000       3.00000       0.00000       0.00000       0.00000
 E    1082   109.000       4.00000       0.00000       0.00000       0.00000
 E    1083   124.000       1.00000       0.00000       0.00000       0.00000
 E    1084   107.000       2.00000       0.00000       0.00000       0.00000
 E    1091   93.0000       3.00000       0.00000       0.00000       0.00000
 E    1092   110.000       4.00000       0.00000       0.00000       0.00000
 E    1093   125.000       1.00000       0.00000       0.00000       0.00000
 E    1094   108.000       2.00000       0.00000       0.00000       0.00000
 E    1101   94.0000       3.00000       0.00000       0.00000       0.00000
 E    1102   111.000       4.00000       0.00000       0.00000       0.00000
 E    1103   126.000       1.00000       0.00000       0.00000       0.00000
 E    1104   109.000       2.00000       0.00000       0.00000       0.00000
 E    1111   95.0000       3.00000       0.00000       0.00000       0.00000
 E    1112   112.000       4.00000       0.00000       0.00000       0.00000
 E    1113   127.000       1.00000       0.00000       0.00000       0.00000
 E    1114   110.000       2.00000       0.00000       0.00000       0.00000
 E    1121   96.0000       3.00000       0.00000       0.00000       0.00000
      1122   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1123   128.000       1.00000       0.00000       0.00000       0.00000
 E    1124   111.000       2.00000       0.00000       0.00000       0.00000
 E    1131   97.0000       3.00000       0.00000       0.00000       0.00000
 E    1132   114.000       4.00000       0.00000       0.00000       0.00000
 E    1133   129.000       1.00000       0.00000       0.00000       0.00000
 v    1134   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1141   98.0000       3.00000       0.00000       0.00000       0.00000
 E    1142   115.000       4.00000       0.00000       0.00000       0.00000
 E    1143   130.000       1.00000       0.00000       0.00000       0.00000
 E    1144   113.000       2.00000       0.00000       0.00000       0.00000
 E    1151   99.0000       3.00000       0.00000       0.00000       0.00000
 E    1152   116.000       4.00000       0.00000       0.00000       0.00000
 E    1153   131.000       1.00000       0.00000       0.00000       0.00000
 E    1154   114.000       2.00000       0.00000       0.00000       0.00000
 E    1161   100.000       3.00000       0.00000       0.00000       0.00000
 E    1162   117.000       4.00000       0.00000       0.00000       0.00000
 E    1163   132.000       1.00000       0.00000       0.00000       0.00000
 E    1164   115.000       2.00000       0.00000       0.00000       0.00000
 E    1171   101.000       3.00000       0.00000       0.00000       0.00000
 E    1172   118.000       4.00000       0.00000       0.00000       0.00000
 E    1173   133.000       1.00000       0.00000       0.00000       0.00000
 E    1174   116.000       2.00000       0.00000       0.00000       0.00000
 E    1181   102.000       3.00000       0.00000       0.00000       0.00000
 E    1182   119.000       4.00000       0.00000       0.00000       0.00000
 E    1183   134.000       1.00000       0.00000       0.00000       0.00000
 E    1184   117.000       2.00000       0.00000       0.00000       0.00000
 E    1191   103.000       3.00000       0.00000       0.00000       0.00000
 E    1192   120.000       4.00000       0.00000       0.00000       0.00000
 E    1193   135.000       1.00000       0.00000       0.00000       0.00000
 E    1194   118.000       2.00000       0.00000       0.00000       0.00000
 E    1201   104.000       3.00000       0.00000       0.00000       0.00000
 E    1202   121.000       4.00000       0.00000       0.00000       0.00000
 E    1203   136.000       1.00000       0.00000       0.00000       0.00000
 E    1204   119.000       2.00000       0.00000       0.00000       0.00000
 E    1211   105.000       3.00000       0.00000       0.00000       0.00000
 E    1212   122.000       4.00000       0.00000       0.00000       0.00000
 E    1213   137.000       1.00000       0.00000       0.00000       0.00000
 E    1214   120.000       2.00000       0.00000       0.00000       0.00000
 E    1221   106.000       3.00000       0.00000       0.00000       0.00000
 E    1222   123.000       4.00000       0.00000       0.00000       0.00000
 E    1223   138.000       1.00000       0.00000       0.00000       0.00000
 E    1224   121.000       2.00000       0.00000       0.00000       0.00000
 E    1231   107.000       3.00000       0.00000       0.00000       0.00000
 E    1232   124.000       4.00000       0.00000       0.00000       0.00000
 E    1233   139.000       1.00000       0.00000       0.00000       0.00000
 E    1234   122.000       2.00000       0.00000       0.00000       0.00000
 E    1241   108.000       3.00000       0.00000       0.00000       0.00000
 E    1242   125.000       4.00000       0.00000       0.00000       0.00000
 E    1243   140.000       1.00000       0.00000       0.00000       0.00000
 E    1244   123.000       2.00000       0.00000       0.00000       0.00000
 E    1251   109.000       3.00000       0.00000       0.00000       0.00000
 E    1252   126.000       4.00000       0.00000       0.00000       0.00000
 E    1253   141.000       1.00000       0.00000       0.00000       0.00000
 E    1254   124.000       2.00000       0.00000       0.00000       0.00000
 E    1261   110.000       3.00000       0.00000       0.00000       0.00000
 E    1262   127.000       4.00000       0.00000       0.00000       0.00000
 E    1263   142.000       1.00000       0.00000       0.00000       0.00000
 E    1264   125.000       2.00000       0.00000       0.00000       0.00000
 E    1271   111.000       3.00000       0.00000       0.00000       0.00000
 E    1272   128.000       4.00000       0.00000       0.00000       0.00000
 E    1273   143.000       1.00000       0.00000       0.00000       0.00000
 E    1274   126.000       2.00000       0.00000       0.00000       0.00000
 E    1281   112.000       3.00000       0.00000       0.00000       0.00000
      1282   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1283   144.000       1.00000       0.00000       0.00000       0.00000
 E    1284   127.000       2.00000       0.00000       0.00000       0.00000
 E    1291   113.000       3.00000       0.00000       0.00000       0.00000
 E    1292   130.000       4.00000       0.00000       0.00000       0.00000
 E    1293   145.000       1.00000       0.00000       0.00000       0.00000
 v    1294   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1301   114.000       3.00000       0.00000       0.00000       0.00000
 E    1302   131.000       4.00000       0.00000       0.00000       0.00000
 E    1303   146.000       1.00000       0.00000       0.00000       0.00000
 E    1304   129.000       2.00000       0.00000       0.00000       0.00000
 E    1311   115.000       3.00000       0.00000       0.00000       0.00000
 E    1312   132.000       4.00000       0.00000       0.00000       0.00000
 E    1313   147.000       1.00000       0.00000       0.00000       0.00000
 E    1314   130.000       2.00000       0.00000       0.00000       0.00000
 E    1321   116.000       3.00000       0.00000       0.00000       0.00000
 E    1322   133.000       4.00000       0.00000       0.00000       0.00000
 E    1323   148.000       1.00000       0.00000       0.00000       0.00000
 E    1324   131.000       2.00000       0.00000       0.00000       0.00000
 E    1331   117.000       3.00000       0.00000       0.00000       0.00000
 E    1332   134.000       4.00000       0.00000       0.00000       0.00000
 E    1333   149.000       1.00000       0.00000       0.00000       0.00000
 E    1334   132.000       2.00000       0.00000       0.00000       0.00000
 E    1341   118.000       3.00000       0.00000       0.00000       0.00000
 E    1342   135.000       4.00000       0.00000       0.00000       0.00000
 E    1343   150.000       1.00000       0.00000       0.00000       0.00000
 E    1344   133.000       2.00000       0.00000       0.00000       0.00000
 E    1351   119.000       3.00000       0.00000       0.00000       0.00000
 E    1352   136.000       4.00000       0.00000       0.00000       0.00000
 E    1353   151.000       1.00000       0.00000       0.00000       0.00000
 E    1354   134.000       2.00000       0.00000       0.00000       0.00000
 E    1361   120.000       3.00000       0.00000       0.00000       0.00000
 E    1362   137.000       4.00000       0.00000       0.00000       0.00000
 E    1363   152.000       1.00000       0.00000       0.00000       0.00000
 E    1364   135.000       2.00000       0.00000       0.00000       0.00000
 E    1371   121.000       3.00000       0.00000       0.00000       0.00000
 E    1372   138.000       4.00000       0.00000       0.00000       0.00000
 E    1373   153.000       1.00000       0.00000       0.00000       0.00000
 E    1374   136.000       2.00000       0.00000       0.00000       0.00000
 E    1381   122.000       3.00000       0.00000       0.00000       0.00000
 E    1382   139.000       4.00000       0.00000       0.00000       0.00000
 E    1383   154.000       1.00000       0.00000       0.00000       0.00000
 E    1384   137.000       2.00000       0.00000       0.00000       0.00000
 E    1391   123.000       3.00000       0.00000       0.00000       0.00000
 E    1392   140.000       4.00000       0.00000       0.00000       0.00000
 E    1393   155.000       1.00000       0.00000       0.00000       0.00000
 E    1394   138.000       2.00000       0.00000       0.00000       0.00000
 E    1401   124.000       3.00000       0.00000       0.00000       0.00000
 E    1402   141.000       4.00000       0.00000       0.00000       0.00000
 E    1403   156.000       1.00000       0.00000       0.00000       0.00000
 E    1404   139.000       2.00000       0.00000       0.00000       0.00000
 E    1411   125.000       3.00000       0.00000       0.00000       0.00000
 E    1412   142.000       4.00000       0.00000       0.00000       0.00000
 E    1413   157.000       1.00000       0.00000       0.00000       0.00000
 E    1414   140.000       2.00000       0.00000       0.00000       0.00000
 E    1421   126.000       3.00000       0.00000       0.00000       0.00000
 E    1422   143.000       4.00000       0.00000       0.00000       0.00000
 E    1423   158.000       1.00000       0.00000       0.00000       0.00000
 E    1424   141.000       2.00000       0.00000       0.00000       0.00000
 E    1431   127.000       3.00000       0.00000       0.00000       0.00000
 E    1432   144.000       4.00000       0.00000       0.00000       0.00000
 E    1433   159.000       1.00000       0.00000       0.00000       0.00000
 E    1434   142.000       2.00000       0.00000       0.00000       0.00000
 E    1441   128.000       3.00000       0.00000       0.00000       0.00000
      1442   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1443   160.000       1.00000       0.00000       0.00000       0.00000
 E    1444   143.000       2.00000       0.00000       0.00000       0.00000
 E    1451   129.000       3.00000       0.00000       0.00000       0.00000
 E    1452   146.000       4.00000       0.00000       0.00000       0.00000
 E    1453   161.000       1.00000       0.00000       0.00000       0.00000
 v    1454   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1461   130.000       3.00000       0.00000       0.00000       0.00000
 E    1462   147.000       4.00000       0.00000       0.00000       0.00000
 E    1463   162.000       1.00000       0.00000       0.00000       0.00000
 E    1464   145.000       2.00000       0.00000       0.00000       0.00000
 E    1471   131.000       3.00000       0.00000       0.00000       0.00000
 E    1472   148.000       4.00000       0.00000       0.00000       0.00000
 E    1473   163.000       1.00000       0.00000       0.00000       0.00000
 E    1474   146.000       2.00000       0.00000       0.00000       0.00000
 E    1481   132.000       3.00000       0.00000       0.00000       0.00000
 E    1482   149.000       4.00000       0.00000       0.00000       0.00000
 E    1483   164.000       1.00000       0.00000       0.00000       0.00000
 E    1484   147.000       2.00000       0.00000       0.00000       0.00000
 E    1491   133.000       3.00000       0.00000       0.00000       0.00000
 E    1492   150.000       4.00000       0.00000       0.00000       0.00000
 E    1493   165.000       1.00000       0.00000       0.00000       0.00000
 E    1494   148.000       2.00000       0.00000       0.00000       0.00000
 E    1501   134.000       3.00000       0.00000       0.00000       0.00000
 E    1502   151.000       4.00000       0.00000       0.00000       0.00000
 E    1503   166.000       1.00000       0.00000       0.00000       0.00000
 E    1504   149.000       2.00000       0.00000       0.00000       0.00000
 E    1511   135.000       3.00000       0.00000       0.00000       0.00000
 E    1512   152.000       4.00000       0.00000       0.00000       0.00000
 E    1513   167.000       1.00000       0.00000       0.00000       0.00000
 E    1514   150.000       2.00000       0.00000       0.00000       0.00000
 E    1521   136.000       3.00000       0.00000       0.00000       0.00000
 E    1522   153.000       4.00000       0.00000       0.00000       0.00000
 E    1523   168.000       1.00000       0.00000       0.00000       0.00000
 E    1524   151.000       2.00000       0.00000       0.00000       0.00000
 E    1531   137.000       3.00000       0.00000       0.00000       0.00000
 E    1532   154.000       4.00000       0.00000       0.00000       0.00000
 E    1533   169.000       1.00000       0.00000       0.00000       0.00000
 E    1534   152.000       2.00000       0.00000       0.00000       0.00000
 E    1541   138.000       3.00000       0.00000       0.00000       0.00000
 E    1542   155.000       4.00000       0.00000       0.00000       0.00000
 E    1543   170.000       1.00000       0.00000       0.00000       0.00000
 E    1544   153.000       2.00000       0.00000       0.00000       0.00000
 E    1551   139.000       3.00000       0.00000       0.00000       0.00000
 E    1552   156.000       4.00000       0.00000       0.00000       0.00000
 E    1553   171.000       1.00000       0.00000       0.00000       0.00000
 E    1554   154.000       2.00000       0.00000       0.00000       0.00000
 E    1561   140.000       3.00000       0.00000       0.00000       0.00000
 E    1562   157.000       4.00000       0.00000       0.00000       0.00000
 E    1563   172.000       1.00000       0.00000       0.00000       0.00000
 E    1564   155.000       2.00000       0.00000       0.00000       0.00000
 E    1571   141.000       3.00000       0.00000       0.00000       0.00000
 E    1572   158.000       4.00000       0.00000       0.00000       0.00000
 E    1573   173.000       1.00000       0.00000       0.00000       0.00000
 E    1574   156.000       2.00000       0.00000       0.00000       0.00000
 E    1581   142.000       3.00000       0.00000       0.00000       0.00000
 E    1582   159.000       4.00000       0.00000       0.00000       0.00000
 E    1583   174.000       1.00000       0.00000       0.00000       0.00000
 E    1584   157.000       2.00000       0.00000       0.00000       0.00000
 E    1591   143.000       3.00000       0.00000       0.00000       0.00000
 E    1592   160.000       4.00000       0.00000       0.00000       0.00000
 E    1593   175.000       1.00000       0.00000       0.00000       0.00000
 E    1594   158.000       2.00000       0.00000       0.00000       0.00000
 E    1601   144.000       3.00000       0.00000       0.00000       0.00000
      1602   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1603   176.000       1.00000       0.00000       0.00000       0.00000
 E    1604   159.000       2.00000       0.00000       0.00000       0.00000
 E    1611   145.000       3.00000       0.00000       0.00000       0.00000
 E    1612   162.000       4.00000       0.00000       0.00000       0.00000
 E    1613   177.000       1.00000       0.00000       0.00000       0.00000
 v    1614   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1621   146.000       3.00000       0.00000       0.00000       0.00000
 E    1622   163.000       4.00000       0.00000       0.00000       0.00000
 E    1623   178.000       1.00000       0.00000       0.00000       0.00000
 E    1624   161.000       2.00000       0.00000       0.00000       0.00000
 E    1631   147.000       3.00000       0.00000       0.00000       0.00000
 E    1632   164.000       4.00000       0.00000       0.00000       0.00000
 E    1633   179.000       1.00000       0.00000       0.00000       0.00000
 E    1634   162.000       2.00000       0.00000       0.00000       0.00000
 E    1641   148.000       3.00000       0.00000       0.00000       0.00000
 E    1642   165.000       4.00000       0.00000       0.00000       0.00000
 E    1643   180.000       1.00000       0.00000       0.00000       0.00000
 E    1644   163.000       2.00000       0.00000       0.00000       0.00000
 E    1651   149.000       3.00000       0.00000       0.00000       0.00000
 E    1652   166.000       4.00000       0.00000       0.00000       0.00000
 E    1653   181.000       1.00000       0.00000       0.00000       0.00000
 E    1654   164.000       2.00000       0.00000       0.00000       0.00000
 E    1661   150.000       3.00000       0.00000       0.00000       0.00000
 E    1662   167.000       4.00000       0.00000       0.00000       0.00000
 E    1663   182.000       1.00000       0.00000       0.00000       0.00000
 E    1664   165.000       2.00000       0.00000       0.00000       0.00000
 E    1671   151.000       3.00000       0.00000       0.00000       0.00000
 E    1672   168.000       4.00000       0.00000       0.00000       0.00000
 E    1673   183.000       1.00000       0.00000       0.00000       0.00000
 E    1674   166.000       2.00000       0.00000       0.00000       0.00000
 E    1681   152.000       3.00000       0.00000       0.00000       0.00000
 E    1682   169.000       4.00000       0.00000       0.00000       0.00000
 E    1683   184.000       1.00000       0.00000       0.00000       0.00000
 E    1684   167.000       2.00000       0.00000       0.00000       0.00000
 E    1691   153.000       3.00000       0.00000       0.00000       0.00000
 E    1692   170.000       4.00000       0.00000       0.00000       0.00000
 E    1693   185.000       1.00000       0.00000       0.00000       0.00000
 E    1694   168.000       2.00000       0.00000       0.00000       0.00000
 E    1701   154.000       3.00000       0.00000       0.00000       0.00000
 E    1702   171.000       4.00000       0.00000       0.00000       0.00000
 E    1703   186.000       1.00000       0.00000       0.00000       0.00000
 E    1704   169.000       2.00000       0.00000       0.00000       0.00000
 E    1711   155.000       3.00000       0.00000       0.00000       0.00000
 E    1712   172.000       4.00000       0.00000       0.00000       0.00000
 E    1713   187.000       1.00000       0.00000       0.00000       0.00000
 E    1714   170.000       2.00000       0.00000       0.00000       0.00000
 E    1721   156.000       3.00000       0.00000       0.00000       0.00000
 E    1722   173.000       4.00000       0.00000       0.00000       0.00000
 E    1723   188.000       1.00000       0.00000       0.00000       0.00000
 E    1724   171.000       2.00000       0.00000       0.00000       0.00000
 E    1731   157.000       3.00000       0.00000       0.00000       0.00000
 E    1732   174.000       4.00000       0.00000       0.00000       0.00000
 E    1733   189.000       1.00000       0.00000       0.00000       0.00000
 E    1734   172.000       2.00000       0.00000       0.00000       0.00000
 E    1741   158.000       3.00000       0.00000       0.00000       0.00000
 E    1742   175.000       4.00000       0.00000       0.00000       0.00000
 E    1743   190.000       1.00000       0.00000       0.00000       0.00000
 E    1744   173.000       2.00000       0.00000       0.00000       0.00000
 E    1751   159.000       3.00000       0.00000       0.00000       0.00000
 E    1752   176.000       4.00000       0.00000       0.00000       0.00000
 E    1753   191.000       1.00000       0.00000       0.00000       0.00000
 E    1754   174.000       2.00000       0.00000       0.00000       0.00000
 E    1761   160.000       3.00000       0.00000       0.00000       0.00000
      1762   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1763   192.000       1.00000       0.00000       0.00000       0.00000
 E    1764   175.000       2.00000       0.00000       0.00000       0.00000
 E    1771   161.000       3.00000       0.00000       0.00000       0.00000
 E    1772   178.000       4.00000       0.00000       0.00000       0.00000
 E    1773   193.000       1.00000       0.00000       0.00000       0.00000
 v    1774   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1781   162.000       3.00000       0.00000       0.00000       0.00000
 E    1782   179.000       4.00000       0.00000       0.00000       0.00000
 E    1783   194.000       1.00000       0.00000       0.00000       0.00000
 E    1784   177.000       2.00000       0.00000       0.00000       0.00000
 E    1791   163.000       3.00000       0.00000       0.00000       0.00000
 E    1792   180.000       4.00000       0.00000       0.00000       0.00000
 E    1793   195.000       1.00000       0.00000       0.00000       0.00000
 E    1794   178.000       2.00000       0.00000       0.00000       0.00000
 E    1801   164.000       3.00000       0.00000       0.00000       0.00000
 E    1802   181.000       4.00000       0.00000       0.00000       0.00000
 E    1803   196.000       1.00000       0.00000       0.00000       0.00000
 E    1804   179.000       2.00000       0.00000       0.00000       0.00000
 E    1811   165.000       3.00000       0.00000       0.00000       0.00000
 E    1812   182.000       4.00000       0.00000       0.00000       0.00000
 E    1813   197.000       1.00000       0.00000       0.00000       0.00000
 E    1814   180.000       2.00000       0.00000       0.00000       0.00000
 E    1821   166.000       3.00000       0.00000       0.00000       0.00000
 E    1822   183.000       4.00000       0.00000       0.00000       0.00000
 E    1823   198.000       1.00000       0.00000       0.00000       0.00000
 E    1824   181.000       2.00000       0.00000       0.00000       0.00000
 E    1831   167.000       3.00000       0.00000       0.00000       0.00000
 E    1832   184.000       4.00000       0.00000       0.00000       0.00000
 E    1833   199.000       1.00000       0.00000       0.00000       0.00000
 E    1834   182.000       2.00000       0.00000       0.00000       0.00000
 E    1841   168.000       3.00000       0.00000       0.00000       0.00000
 E    1842   185.000       4.00000       0.00000       0.00000       0.00000
 E    1843   200.000       1.00000       0.00000       0.00000       0.00000
 E    1844   183.000       2.00000       0.00000       0.00000       0.00000
 E    1851   169.000       3.00000       0.00000       0.00000       0.00000
 E    1852   186.000       4.00000       0.00000       0.00000       0.00000
 E    1853   201.000       1.00000       0.00000       0.00000       0.00000
 E    1854   184.000       2.00000       0.00000       0.00000       0.00000
 E    1861   170.000       3.00000       0.00000       0.00000       0.00000
 E    1862   187.000       4.00000       0.00000       0.00000       0.00000
 E    1863   202.000       1.00000       0.00000       0.00000       0.00000
 E    1864   185.000       2.00000       0.00000       0.00000       0.00000
 E    1871   171.000       3.00000       0.00000       0.00000       0.00000
 E    1872   188.000       4.00000       0.00000       0.00000       0.00000
 E    1873   203.000       1.00000       0.00000       0.00000       0.00000
 E    1874   186.000       2.00000       0.00000       0.00000       0.00000
 E    1881   172.000       3.00000       0.00000       0.00000       0.00000
 E    1882   189.000       4.00000       0.00000       0.00000       0.00000
 E    1883   204.000       1.00000       0.00000       0.00000       0.00000
 E    1884   187.000       2.00000       0.00000       0.00000       0.00000
 E    1891   173.000       3.00000       0.00000       0.00000       0.00000
 E    1892   190.000       4.00000       0.00000       0.00000       0.00000
 E    1893   205.000       1.00000       0.00000       0.00000       0.00000
 E    1894   188.000       2.00000       0.00000       0.00000       0.00000
 E    1901   174.000       3.00000       0.00000       0.00000       0.00000
 E    1902   191.000       4.00000       0.00000       0.00000       0.00000
 E    1903   206.000       1.00000       0.00000       0.00000       0.00000
 E    1904   189.000       2.00000       0.00000       0.00000       0.00000
 E    1911   175.000       3.00000       0.00000       0.00000       0.00000
 E    1912   192.000       4.00000       0.00000       0.00000       0.00000
 E    1913   207.000       1.00000       0.00000       0.00000       0.00000
 E    1914   190.000       2.00000       0.00000       0.00000       0.00000
 E    1921   176.000       3.00000       0.00000       0.00000       0.00000
      1922   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1923   208.000       1.00000       0.00000       0.00000       0.00000
 E    1924   191.000       2.00000       0.00000       0.00000       0.00000
 E    1931   177.000       3.00000       0.00000       0.00000       0.00000
 E    1932   194.000       4.00000       0.00000       0.00000       0.00000
 E    1933   209.000       1.00000       0.00000       0.00000       0.00000
 v    1934   0.00000       0.00000       0.00000       0.00000       0.00000
 E    1941   178.000       3.00000       0.00000       0.00000       0.00000
 E    1942   195.000       4.00000       0.00000       0.00000       0.00000
 E    1943   210.000       1.00000       0.00000       0.00000       0.00000
 E    1944   193.000       2.00000       0.00000       0.00000       0.00000
 E    1951   179.000       3.00000       0.00000       0.00000       0.00000
 E    1952   196.000       4.00000       0.00000       0.00000       0.00000
 E    1953   211.000       1.00000       0.00000       0.00000       0.00000
 E    1954   194.000       2.00000       0.00000       0.00000       0.00000
 E    1961   180.000       3.00000       0.00000       0.00000       0.00000
 E    1962   197.000       4.00000       0.00000       0.00000       0.00000
 E    1963   212.000       1.00000       0.00000       0.00000       0.00000
 E    1964   195.000       2.00000       0.00000       0.00000       0.00000
 E    1971   181.000       3.00000       0.00000       0.00000       0.00000
 E    1972   198.000       4.00000       0.00000       0.00000       0.00000
 E    1973   213.000       1.00000       0.00000       0.00000       0.00000
 E    1974   196.000       2.00000       0.00000       0.00000       0.00000
 E    1981   182.000       3.00000       0.00000       0.00000       0.00000
 E    1982   199.000       4.00000       0.00000       0.00000       0.00000
 E    1983   214.000       1.00000       0.00000       0.00000       0.00000
 E    1984   197.000       2.00000       0.00000       0.00000       0.00000
 E    1991   183.000       3.00000       0.00000       0.00000       0.00000
 E    1992   200.000       4.00000       0.00000       0.00000       0.00000
 E    1993   215.000       1.00000       0.00000       0.00000       0.00000
 E    1994   198.000       2.00000       0.00000       0.00000       0.00000
 E    2001   184.000       3.00000       0.00000       0.00000       0.00000
 E    2002   201.000       4.00000       0.00000       0.00000       0.00000
 E    2003   216.000       1.00000       0.00000       0.00000       0.00000
 E    2004   199.000       2.00000       0.00000       0.00000       0.00000
 E    2011   185.000       3.00000       0.00000       0.00000       0.00000
 E    2012   202.000       4.00000       0.00000       0.00000       0.00000
 E    2013   217.000       1.00000       0.00000       0.00000       0.00000
 E    2014   200.000       2.00000       0.00000       0.00000       0.00000
 E    2021   186.000       3.00000       0.00000       0.00000       0.00000
 E    2022   203.000       4.00000       0.00000       0.00000       0.00000
 E    2023   218.000       1.00000       0.00000       0.00000       0.00000
 E    2024   201.000       2.00000       0.00000       0.00000       0.00000
 E    2031   187.000       3.00000       0.00000       0.00000       0.00000
 E    2032   204.000       4.00000       0.00000       0.00000       0.00000
 E    2033   219.000       1.00000       0.00000       0.00000       0.00000
 E    2034   202.000       2.00000       0.00000       0.00000       0.00000
 E    2041   188.000       3.00000       0.00000       0.00000       0.00000
 E    2042   205.000       4.00000       0.00000       0.00000       0.00000
 E    2043   220.000       1.00000       0.00000       0.00000       0.00000
 E    2044   203.000       2.00000       0.00000       0.00000       0.00000
 E    2051   189.000       3.00000       0.00000       0.00000       0.00000
 E    2052   206.000       4.00000       0.00000       0.00000       0.00000
 E    2053   221.000       1.00000       0.00000       0.00000       0.00000
 E    2054   204.000       2.00000       0.00000       0.00000       0.00000
 E    2061   190.000       3.00000       0.00000       0.00000       0.00000
 E    2062   207.000       4.00000       0.00000       0.00000       0.00000
 E    2063   222.000       1.00000       0.00000       0.00000       0.00000
 E    2064   205.000       2.00000       0.00000       0.00000       0.00000
 E    2071   191.000       3.00000       0.00000       0.00000       0.00000
 E    2072   208.000       4.00000       0.00000       0.00000       0.00000
 E    2073   223.000       1.00000       0.00000       0.00000       0.00000
 E    2074   206.000       2.00000       0.00000       0.00000       0.00000
 E    2081   192.000       3.00000       0.00000       0.00000       0.00000
      2082   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2083   224.000       1.00000       0.00000       0.00000       0.00000
 E    2084   207.000       2.00000       0.00000       0.00000       0.00000
 E    2091   193.000       3.00000       0.00000       0.00000       0.00000
 E    2092   210.000       4.00000       0.00000       0.00000       0.00000
 E    2093   225.000       1.00000       0.00000       0.00000       0.00000
 v    2094   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2101   194.000       3.00000       0.00000       0.00000       0.00000
 E    2102   211.000       4.00000       0.00000       0.00000       0.00000
 E    2103   226.000       1.00000       0.00000       0.00000       0.00000
 E    2104   209.000       2.00000       0.00000       0.00000       0.00000
 E    2111   195.000       3.00000       0.00000       0.00000       0.00000
 E    2112   212.000       4.00000       0.00000       0.00000       0.00000
 E    2113   227.000       1.00000       0.00000       0.00000       0.00000
 E    2114   210.000       2.00000       0.00000       0.00000       0.00000
 E    2121   196.000       3.00000       0.00000       0.00000       0.00000
 E    2122   213.000       4.00000       0.00000       0.00000       0.00000
 E    2123   228.000       1.00000       0.00000       0.00000       0.00000
 E    2124   211.000       2.00000       0.00000       0.00000       0.00000
 E    2131   197.000       3.00000       0.00000       0.00000       0.00000
 E    2132   214.000       4.00000       0.00000       0.00000       0.00000
 E    2133   229.000       1.00000       0.00000       0.00000       0.00000
 E    2134   212.000       2.00000       0.00000       0.00000       0.00000
 E    2141   198.000       3.00000       0.00000       0.00000       0.00000
 E    2142   215.000       4.00000       0.00000       0.00000       0.00000
 E    2143   230.000       1.00000       0.00000       0.00000       0.00000
 E    2144   213.000       2.00000       0.00000       0.00000       0.00000
 E    2151   199.000       3.00000       0.00000       0.00000       0.00000
 E    2152   216.000       4.00000       0.00000       0.00000       0.00000
 E    2153   231.000       1.00000       0.00000       0.00000       0.00000
 E    2154   214.000       2.00000       0.00000       0.00000       0.00000
 E    2161   200.000       3.00000       0.00000       0.00000       0.00000
 E    2162   217.000       4.00000       0.00000       0.00000       0.00000
 E    2163   232.000       1.00000       0.00000       0.00000       0.00000
 E    2164   215.000       2.00000       0.00000       0.00000       0.00000
 E    2171   201.000       3.00000       0.00000       0.00000       0.00000
 E    2172   218.000       4.00000       0.00000       0.00000       0.00000
 E    2173   233.000       1.00000       0.00000       0.00000       0.00000
 E    2174   216.000       2.00000       0.00000       0.00000       0.00000
 E    2181   202.000       3.00000       0.00000       0.00000       0.00000
 E    2182   219.000       4.00000       0.00000       0.00000       0.00000
 E    2183   234.000       1.00000       0.00000       0.00000       0.00000
 E    2184   217.000       2.00000       0.00000       0.00000       0.00000
 E    2191   203.000       3.00000       0.00000       0.00000       0.00000
 E    2192   220.000       4.00000       0.00000       0.00000       0.00000
 E    2193   235.000       1.00000       0.00000       0.00000       0.00000
 E    2194   218.000       2.00000       0.00000       0.00000       0.00000
 E    2201   204.000       3.00000       0.00000       0.00000       0.00000
 E    2202   221.000       4.00000       0.00000       0.00000       0.00000
 E    2203   236.000       1.00000       0.00000       0.00000       0.00000
 E    2204   219.000       2.00000       0.00000       0.00000       0.00000
 E    2211   205.000       3.00000       0.00000       0.00000       0.00000
 E    2212   222.000       4.00000       0.00000       0.00000       0.00000
 E    2213   237.000       1.00000       0.00000       0.00000       0.00000
 E    2214   220.000       2.00000       0.00000       0.00000       0.00000
 E    2221   206.000       3.00000       0.00000       0.00000       0.00000
 E    2222   223.000       4.00000       0.00000       0.00000       0.00000
 E    2223   238.000       1.00000       0.00000       0.00000       0.00000
 E    2224   221.000       2.00000       0.00000       0.00000       0.00000
 E    2231   207.000       3.00000       0.00000       0.00000       0.00000
 E    2232   224.000       4.00000       0.00000       0.00000       0.00000
 E    2233   239.000       1.00000       0.00000       0.00000       0.00000
 E    2234   222.000       2.00000       0.00000       0.00000       0.00000
 E    2241   208.000       3.00000       0.00000       0.00000       0.00000
      2242   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2243   240.000       1.00000       0.00000       0.00000       0.00000
 E    2244   223.000       2.00000       0.00000       0.00000       0.00000
 E    2251   209.000       3.00000       0.00000       0.00000       0.00000
 E    2252   226.000       4.00000       0.00000       0.00000       0.00000
 E    2253   241.000       1.00000       0.00000       0.00000       0.00000
 v    2254   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2261   210.000       3.00000       0.00000       0.00000       0.00000
 E    2262   227.000       4.00000       0.00000       0.00000       0.00000
 E    2263   242.000       1.00000       0.00000       0.00000       0.00000
 E    2264   225.000       2.00000       0.00000       0.00000       0.00000
 E    2271   211.000       3.00000       0.00000       0.00000       0.00000
 E    2272   228.000       4.00000       0.00000       0.00000       0.00000
 E    2273   243.000       1.00000       0.00000       0.00000       0.00000
 E    2274   226.000       2.00000       0.00000       0.00000       0.00000
 E    2281   212.000       3.00000       0.00000       0.00000       0.00000
 E    2282   229.000       4.00000       0.00000       0.00000       0.00000
 E    2283   244.000       1.00000       0.00000       0.00000       0.00000
 E    2284   227.000       2.00000       0.00000       0.00000       0.00000
 E    2291   213.000       3.00000       0.00000       0.00000       0.00000
 E    2292   230.000       4.00000       0.00000       0.00000       0.00000
 E    2293   245.000       1.00000       0.00000       0.00000       0.00000
 E    2294   228.000       2.00000       0.00000       0.00000       0.00000
 E    2301   214.000       3.00000       0.00000       0.00000       0.00000
 E    2302   231.000       4.00000       0.00000       0.00000       0.00000
 E    2303   246.000       1.00000       0.00000       0.00000       0.00000
 E    2304   229.000       2.00000       0.00000       0.00000       0.00000
 E    2311   215.000       3.00000       0.00000       0.00000       0.00000
 E    2312   232.000       4.00000       0.00000       0.00000       0.00000
 E    2313   247.000       1.00000       0.00000       0.00000       0.00000
 E    2314   230.000       2.00000       0.00000       0.00000       0.00000
 E    2321   216.000       3.00000       0.00000       0.00000       0.00000
 E    2322   233.000       4.00000       0.00000       0.00000       0.00000
 E    2323   248.000       1.00000       0.00000       0.00000       0.00000
 E    2324   231.000       2.00000       0.00000       0.00000       0.00000
 E    2331   217.000       3.00000       0.00000       0.00000       0.00000
 E    2332   234.000       4.00000       0.00000       0.00000       0.00000
 E    2333   249.000       1.00000       0.00000       0.00000       0.00000
 E    2334   232.000       2.00000       0.00000       0.00000       0.00000
 E    2341   218.000       3.00000       0.00000       0.00000       0.00000
 E    2342   235.000       4.00000       0.00000       0.00000       0.00000
 E    2343   250.000       1.00000       0.00000       0.00000       0.00000
 E    2344   233.000       2.00000       0.00000       0.00000       0.00000
 E    2351   219.000       3.00000       0.00000       0.00000       0.00000
 E    2352   236.000       4.00000       0.00000       0.00000       0.00000
 E    2353   251.000       1.00000       0.00000       0.00000       0.00000
 E    2354   234.000       2.00000       0.00000       0.00000       0.00000
 E    2361   220.000       3.00000       0.00000       0.00000       0.00000
 E    2362   237.000       4.00000       0.00000       0.00000       0.00000
 E    2363   252.000       1.00000       0.00000       0.00000       0.00000
 E    2364   235.000       2.00000       0.00000       0.00000       0.00000
 E    2371   221.000       3.00000       0.00000       0.00000       0.00000
 E    2372   238.000       4.00000       0.00000       0.00000       0.00000
 E    2373   253.000       1.00000       0.00000       0.00000       0.00000
 E    2374   236.000       2.00000       0.00000       0.00000       0.00000
 E    2381   222.000       3.00000       0.00000       0.00000       0.00000
 E    2382   239.000       4.00000       0.00000       0.00000       0.00000
 E    2383   254.000       1.00000       0.00000       0.00000       0.00000
 E    2384   237.000       2.00000       0.00000       0.00000       0.00000
 E    2391   223.000       3.00000       0.00000       0.00000       0.00000
 E    2392   240.000       4.00000       0.00000       0.00000       0.00000
 E    2393   255.000       1.00000       0.00000       0.00000       0.00000
 E    2394   238.000       2.00000       0.00000       0.00000       0.00000
 E    2401   224.000       3.00000       0.00000       0.00000       0.00000
      2402   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2403   256.000       1.00000       0.00000       0.00000       0.00000
 E    2404   239.000       2.00000       0.00000       0.00000       0.00000
 E    2411   225.000       3.00000       0.00000       0.00000       0.00000
 E    2412   242.000       4.00000       0.00000       0.00000       0.00000
      2413   0.00000       0.00000       0.00000       0.00000       0.00000
 v    2414   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2421   226.000       3.00000       0.00000       0.00000       0.00000
 E    2422   243.000       4.00000       0.00000       0.00000       0.00000
      2423   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2424   241.000       2.00000       0.00000       0.00000       0.00000
 E    2431   227.000       3.00000       0.00000       0.00000       0.00000
 E    2432   244.000       4.00000       0.00000       0.00000       0.00000
      2433   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2434   242.000       2.00000       0.00000       0.00000       0.00000
 E    2441   228.000       3.00000       0.00000       0.00000       0.00000
 E    2442   245.000       4.00000       0.00000       0.00000       0.00000
      2443   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2444   243.000       2.00000       0.00000       0.00000       0.00000
 E    2451   229.000       3.00000       0.00000       0.00000       0.00000
 E    2452   246.000       4.00000       0.00000       0.00000       0.00000
      2453   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2454   244.000       2.00000       0.00000       0.00000       0.00000
 E    2461   230.000       3.00000       0.00000       0.00000       0.00000
 E    2462   247.000       4.00000       0.00000       0.00000       0.00000
      2463   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2464   245.000       2.00000       0.00000       0.00000       0.00000
 E    2471   231.000       3.00000       0.00000       0.00000       0.00000
 E    2472   248.000       4.00000       0.00000       0.00000       0.00000
      2473   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2474   246.000       2.00000       0.00000       0.00000       0.00000
 E    2481   232.000       3.00000       0.00000       0.00000       0.00000
 E    2482   249.000       4.00000       0.00000       0.00000       0.00000
      2483   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2484   247.000       2.00000       0.00000       0.00000       0.00000
 E    2491   233.000       3.00000       0.00000       0.00000       0.00000
 E    2492   250.000       4.00000       0.00000       0.00000       0.00000
      2493   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2494   248.000       2.00000       0.00000       0.00000       0.00000
 E    2501   234.000       3.00000       0.00000       0.00000       0.00000
 E    2502   251.000       4.00000       0.00000       0.00000       0.00000
      2503   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2504   249.000       2.00000       0.00000       0.00000       0.00000
 E    2511   235.000       3.00000       0.00000       0.00000       0.00000
 E    2512   252.000       4.00000       0.00000       0.00000       0.00000
      2513   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2514   250.000       2.00000       0.00000       0.00000       0.00000
 E    2521   236.000       3.00000       0.00000       0.00000       0.00000
 E    2522   253.000       4.00000       0.00000       0.00000       0.00000
      2523   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2524   251.000       2.00000       0.00000       0.00000       0.00000
 E    2531   237.000       3.00000       0.00000       0.00000       0.00000
 E    2532   254.000       4.00000       0.00000       0.00000       0.00000
      2533   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2534   252.000       2.00000       0.00000       0.00000       0.00000
 E    2541   238.000       3.00000       0.00000       0.00000       0.00000
 E    2542   255.000       4.00000       0.00000       0.00000       0.00000
      2543   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2544   253.000       2.00000       0.00000       0.00000       0.00000
 E    2551   239.000       3.00000       0.00000       0.00000       0.00000
 E    2552   256.000       4.00000       0.00000       0.00000       0.00000
      2553   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2554   254.000       2.00000       0.00000       0.00000       0.00000
 E    2561   240.000       3.00000       0.00000       0.00000       0.00000
      2562   0.00000       0.00000       0.00000       0.00000       0.00000
      2563   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2564   255.000       2.00000       0.00000       0.00000       0.00000
      2571   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2572   258.000       4.00000       0.00000       0.00000       0.00000
 E    2573   273.000       1.00000       0.00000       0.00000       0.00000
 v    2574   0.00000       0.00000       0.00000       0.00000       0.00000
      2581   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2582   259.000       4.00000       0.00000       0.00000       0.00000
 E    2583   274.000       1.00000       0.00000       0.00000       0.00000
 E    2584   257.000       2.00000       0.00000       0.00000       0.00000
      2591   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2592   260.000       4.00000       0.00000       0.00000       0.00000
 E    2593   275.000       1.00000       0.00000       0.00000       0.00000
 E    2594   258.000       2.00000       0.00000       0.00000       0.00000
      2601   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2602   261.000       4.00000       0.00000       0.00000       0.00000
 E    2603   276.000       1.00000       0.00000       0.00000       0.00000
 E    2604   259.000       2.00000       0.00000       0.00000       0.00000
      2611   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2612   262.000       4.00000       0.00000       0.00000       0.00000
 E    2613   277.000       1.00000       0.00000       0.00000       0.00000
 E    2614   260.000       2.00000       0.00000       0.00000       0.00000
      2621   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2622   263.000       4.00000       0.00000       0.00000       0.00000
 E    2623   278.000       1.00000       0.00000       0.00000       0.00000
 E    2624   261.000       2.00000       0.00000       0.00000       0.00000
      2631   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2632   264.000       4.00000       0.00000       0.00000       0.00000
 E    2633   279.000       1.00000       0.00000       0.00000       0.00000
 E    2634   262.000       2.00000       0.00000       0.00000       0.00000
      2641   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2642   265.000       4.00000       0.00000       0.00000       0.00000
 E    2643   280.000       1.00000       0.00000       0.00000       0.00000
 E    2644   263.000       2.00000       0.00000       0.00000       0.00000
      2651   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2652   266.000       4.00000       0.00000       0.00000       0.00000
 E    2653   281.000       1.00000       0.00000       0.00000       0.00000
 E    2654   264.000       2.00000       0.00000       0.00000       0.00000
      2661   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2662   267.000       4.00000       0.00000       0.00000       0.00000
 E    2663   282.000       1.00000       0.00000       0.00000       0.00000
 E    2664   265.000       2.00000       0.00000       0.00000       0.00000
      2671   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2672   268.000       4.00000       0.00000       0.00000       0.00000
 E    2673   283.000       1.00000       0.00000       0.00000       0.00000
 E    2674   266.000       2.00000       0.00000       0.00000       0.00000
      2681   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2682   269.000       4.00000       0.00000       0.00000       0.00000
 E    2683   284.000       1.00000       0.00000       0.00000       0.00000
 E    2684   267.000       2.00000       0.00000       0.00000       0.00000
      2691   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2692   270.000       4.00000       0.00000       0.00000       0.00000
 E    2693   285.000       1.00000       0.00000       0.00000       0.00000
 E    2694   268.000       2.00000       0.00000       0.00000       0.00000
      2701   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2702   271.000       4.00000       0.00000       0.00000       0.00000
 E    2703   286.000       1.00000       0.00000       0.00000       0.00000
 E    2704   269.000       2.00000       0.00000       0.00000       0.00000
      2711   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2712   272.000       4.00000       0.00000       0.00000       0.00000
 E    2713   287.000       1.00000       0.00000       0.00000       0.00000
 E    2714   270.000       2.00000       0.00000       0.00000       0.00000
      2721   0.00000       0.00000       0.00000       0.00000       0.00000
      2722   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2723   288.000       1.00000       0.00000       0.00000       0.00000
 E    2724   271.000       2.00000       0.00000       0.00000       0.00000
 E    2731   257.000       3.00000       0.00000       0.00000       0.00000
 E    2732   274.000       4.00000       0.00000       0.00000       0.00000
 E    2733   289.000       1.00000       0.00000       0.00000       0.00000
 v    2734   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2741   258.000       3.00000       0.00000       0.00000       0.00000
 E    2742   275.000       4.00000       0.00000       0.00000       0.00000
 E    2743   290.000       1.00000       0.00000       0.00000       0.00000
 E    2744   273.000       2.00000       0.00000       0.00000       0.00000
 E    2751   259.000       3.00000       0.00000       0.00000       0.00000
 E    2752   276.000       4.00000       0.00000       0.00000       0.00000
 E    2753   291.000       1.00000       0.00000       0.00000       0.00000
 E    2754   274.000       2.00000       0.00000       0.00000       0.00000
 E    2761   260.000       3.00000       0.00000       0.00000       0.00000
 E    2762   277.000       4.00000       0.00000       0.00000       0.00000
 E    2763   292.000       1.00000       0.00000       0.00000       0.00000
 E    2764   275.000       2.00000       0.00000       0.00000       0.00000
 E    2771   261.000       3.00000       0.00000       0.00000       0.00000
 E    2772   278.000       4.00000       0.00000       0.00000       0.00000
 E    2773   293.000       1.00000       0.00000       0.00000       0.00000
 E    2774   276.000       2.00000       0.00000       0.00000       0.00000
 E    2781   262.000       3.00000       0.00000       0.00000       0.00000
 E    2782   279.000       4.00000       0.00000       0.00000       0.00000
 E    2783   294.000       1.00000       0.00000       0.00000       0.00000
 E    2784   277.000       2.00000       0.00000       0.00000       0.00000
 E    2791   263.000       3.00000       0.00000       0.00000       0.00000
 E    2792   280.000       4.00000       0.00000       0.00000       0.00000
 E    2793   295.000       1.00000       0.00000       0.00000       0.00000
 E    2794   278.000       2.00000       0.00000       0.00000       0.00000
 E    2801   264.000       3.00000       0.00000       0.00000       0.00000
 E    2802   281.000       4.00000       0.00000       0.00000       0.00000
 E    2803   296.000       1.00000       0.00000       0.00000       0.00000
 E    2804   279.000       2.00000       0.00000       0.00000       0.00000
 E    2811   265.000       3.00000       0.00000       0.00000       0.00000
 E    2812   282.000       4.00000       0.00000       0.00000       0.00000
 E    2813   297.000       1.00000       0.00000       0.00000       0.00000
 E    2814   280.000       2.00000       0.00000       0.00000       0.00000
 E    2821   266.000       3.00000       0.00000       0.00000       0.00000
 E    2822   283.000       4.00000       0.00000       0.00000       0.00000
 E    2823   298.000       1.00000       0.00000       0.00000       0.00000
 E    2824   281.000       2.00000       0.00000       0.00000       0.00000
 E    2831   267.000       3.00000       0.00000       0.00000       0.00000
 E    2832   284.000       4.00000       0.00000       0.00000       0.00000
 E    2833   299.000       1.00000       0.00000       0.00000       0.00000
 E    2834   282.000       2.00000       0.00000       0.00000       0.00000
 E    2841   268.000       3.00000       0.00000       0.00000       0.00000
 E    2842   285.000       4.00000       0.00000       0.00000       0.00000
 E    2843   300.000       1.00000       0.00000       0.00000       0.00000
 E    2844   283.000       2.00000       0.00000       0.00000       0.00000
 E    2851   269.000       3.00000       0.00000       0.00000       0.00000
 E    2852   286.000       4.00000       0.00000       0.00000       0.00000
 E    2853   301.000       1.00000       0.00000       0.00000       0.00000
 E    2854   284.000       2.00000       0.00000       0.00000       0.00000
 E    2861   270.000       3.00000       0.00000       0.00000       0.00000
 E    2862   287.000       4.00000       0.00000       0.00000       0.00000
 E    2863   302.000       1.00000       0.00000       0.00000       0.00000
 E    2864   285.000       2.00000       0.00000       0.00000       0.00000
 E    2871   271.000       3.00000       0.00000       0.00000       0.00000
 E    2872   288.000       4.00000       0.00000       0.00000       0.00000
 E    2873   303.000       1.00000       0.00000       0.00000       0.00000
 E    2874   286.000       2.00000       0.00000       0.00000       0.00000
 E    2881   272.000       3.00000       0.00000       0.00000       0.00000
      2882   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2883   304.000       1.00000       0.00000       0.00000       0.00000
 E    2884   287.000       2.00000       0.00000       0.00000       0.00000
 E    2891   273.000       3.00000       0.00000       0.00000       0.00000
 E    2892   290.000       4.00000       0.00000       0.00000       0.00000
 E    2893   305.000       1.00000       0.00000       0.00000       0.00000
 v    2894   0.00000       0.00000       0.00000       0.00000       0.00000
 E    2901   274.000       3.00000       0.00000       0.00000       0.00000
 E    2902   291.000       4.00000       0.00000       0.00000       0.00000
 E    2903   306.000       1.00000       0.00000       0.00000       0.00000
 E    2904   289.000       2.00000       0.00000       0.00000       0.00000
 E    2911   275.000       3.00000       0.00000       0.00000       0.00000
 E    2912   292.000       4.00000       0.00000       0.00000       0.00000
 E    2913   307.000       1.00000       0.00000       0.00000       0.00000
 E    2914   290.000       2.00000       0.00000       0.00000       0.00000
 E    2921   276.000       3.00000       0.00000       0.00000       0.00000
 E    2922   293.000       4.00000       0.00000       0.00000       0.00000
 E    2923   308.000       1.00000       0.00000       0.00000       0.00000
 E    2924   291.000       2.00000       0.00000       0.00000       0.00000
 E    2931   277.000       3.00000       0.00000       0.00000       0.00000
 E    2932   294.000       4.00000       0.00000       0.00000       0.00000
 E    2933   309.000       1.00000       0.00000       0.00000       0.00000
 E    2934   292.000       2.00000       0.00000       0.00000       0.00000
 E    2941   278.000       3.00000       0.00000       0.00000       0.00000
 E    2942   295.000       4.00000       0.00000       0.00000       0.00000
 E    2943   310.000       1.00000       0.00000       0.00000       0.00000
 E    2944   293.000       2.00000       0.00000       0.00000       0.00000
 E    2951   279.000       3.00000       0.00000       0.00000       0.00000
 E    2952   296.000       4.00000       0.00000       0.00000       0.00000
 E    2953   311.000       1.00000       0.00000       0.00000       0.00000
 E    2954   294.000       2.00000       0.00000       0.00000       0.00000
 E    2961   280.000       3.00000       0.00000       0.00000       0.00000
 E    2962   297.000       4.00000       0.00000       0.00000       0.00000
 E    2963   312.000       1.00000       0.00000       0.00000       0.00000
 E    2964   295.000       2.00000       0.00000       0.00000       0.00000
 E    2971   281.000       3.00000       0.00000       0.00000       0.00000
 E    2972   298.000       4.00000       0.00000       0.00000       0.00000
 E    2973   313.000       1.00000       0.00000       0.00000       0.00000
 E    2974   296.000       2.00000       0.00000       0.00000       0.00000
 E    2981   282.000       3.00000       0.00000       0.00000       0.00000
 E    2982   299.000       4.00000       0.00000       0.00000       0.00000
 E    2983   314.000       1.00000       0.00000       0.00000       0.00000
 E    2984   297.000       2.00000       0.00000       0.00000       0.00000
 E    2991   283.000       3.00000       0.00000       0.00000       0.00000
 E    2992   300.000       4.00000       0.00000       0.00000       0.00000
 E    2993   315.000       1.00000       0.00000       0.00000       0.00000
 E    2994   298.000       2.00000       0.00000       0.00000       0.00000
 E    3001   284.000       3.00000       0.00000       0.00000       0.00000
 E    3002   301.000       4.00000       0.00000       0.00000       0.00000
 E    3003   316.000       1.00000       0.00000       0.00000       0.00000
 E    3004   299.000       2.00000       0.00000       0.00000       0.00000
 E    3011   285.000       3.00000       0.00000       0.00000       0.00000
 E    3012   302.000       4.00000       0.00000       0.00000       0.00000
 E    3013   317.000       1.00000       0.00000       0.00000       0.00000
 E    3014   300.000       2.00000       0.00000       0.00000       0.00000
 E    3021   286.000       3.00000       0.00000       0.00000       0.00000
 E    3022   303.000       4.00000       0.00000       0.00000       0.00000
 E    3023   318.000       1.00000       0.00000       0.00000       0.00000
 E    3024   301.000       2.00000       0.00000       0.00000       0.00000
 E    3031   287.000       3.00000       0.00000       0.00000       0.00000
 E    3032   304.000       4.00000       0.00000       0.00000       0.00000
 E    3033   319.000       1.00000       0.00000       0.00000       0.00000
 E    3034   302.000       2.00000       0.00000       0.00000       0.00000
 E    3041   288.000       3.00000       0.00000       0.00000       0.00000
      3042   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3043   320.000       1.00000       0.00000       0.00000       0.00000
 E    3044   303.000       2.00000       0.00000       0.00000       0.00000
 E    3051   289.000       3.00000       0.00000       0.00000       0.00000
 E    3052   306.000       4.00000       0.00000       0.00000       0.00000
 E    3053   321.000       1.00000       0.00000       0.00000       0.00000
 v    3054   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3061   290.000       3.00000       0.00000       0.00000       0.00000
 E    3062   307.000       4.00000       0.00000       0.00000       0.00000
 E    3063   322.000       1.00000       0.00000       0.00000       0.00000
 E    3064   305.000       2.00000       0.00000       0.00000       0.00000
 E    3071   291.000       3.00000       0.00000       0.00000       0.00000
 E    3072   308.000       4.00000       0.00000       0.00000       0.00000
 E    3073   323.000       1.00000       0.00000       0.00000       0.00000
 E    3074   306.000       2.00000       0.00000       0.00000       0.00000
 E    3081   292.000       3.00000       0.00000       0.00000       0.00000
 E    3082   309.000       4.00000       0.00000       0.00000       0.00000
 E    3083   324.000       1.00000       0.00000       0.00000       0.00000
 E    3084   307.000       2.00000       0.00000       0.00000       0.00000
 E    3091   293.000       3.00000       0.00000       0.00000       0.00000
 E    3092   310.000       4.00000       0.00000       0.00000       0.00000
 E    3093   325.000       1.00000       0.00000       0.00000       0.00000
 E    3094   308.000       2.00000       0.00000       0.00000       0.00000
 E    3101   294.000       3.00000       0.00000       0.00000       0.00000
 E    3102   311.000       4.00000       0.00000       0.00000       0.00000
 E    3103   326.000       1.00000       0.00000       0.00000       0.00000
 E    3104   309.000       2.00000       0.00000       0.00000       0.00000
 E    3111   295.000       3.00000       0.00000       0.00000       0.00000
 E    3112   312.000       4.00000       0.00000       0.00000       0.00000
 E    3113   327.000       1.00000       0.00000       0.00000       0.00000
 E    3114   310.000       2.00000       0.00000       0.00000       0.00000
 E    3121   296.000       3.00000       0.00000       0.00000       0.00000
 E    3122   313.000       4.00000       0.00000       0.00000       0.00000
 E    3123   328.000       1.00000       0.00000       0.00000       0.00000
 E    3124   311.000       2.00000       0.00000       0.00000       0.00000
 E    3131   297.000       3.00000       0.00000       0.00000       0.00000
 E    3132   314.000       4.00000       0.00000       0.00000       0.00000
 E    3133   329.000       1.00000       0.00000       0.00000       0.00000
 E    3134   312.000       2.00000       0.00000       0.00000       0.00000
 E    3141   298.000       3.00000       0.00000       0.00000       0.00000
 E    3142   315.000       4.00000       0.00000       0.00000       0.00000
 E    3143   330.000       1.00000       0.00000       0.00000       0.00000
 E    3144   313.000       2.00000       0.00000       0.00000       0.00000
 E    3151   299.000       3.00000       0.00000       0.00000       0.00000
 E    3152   316.000       4.00000       0.00000       0.00000       0.00000
 E    3153   331.000       1.00000       0.00000       0.00000       0.00000
 E    3154   314.000       2.00000       0.00000       0.00000       0.00000
 E    3161   300.000       3.00000       0.00000       0.00000       0.00000
 E    3162   317.000       4.00000       0.00000       0.00000       0.00000
 E    3163   332.000       1.00000       0.00000       0.00000       0.00000
 E    3164   315.000       2.00000       0.00000       0.00000       0.00000
 E    3171   301.000       3.00000       0.00000       0.00000       0.00000
 E    3172   318.000       4.00000       0.00000       0.00000       0.00000
 E    3173   333.000       1.00000       0.00000       0.00000       0.00000
 E    3174   316.000       2.00000       0.00000       0.00000       0.00000
 E    3181   302.000       3.00000       0.00000       0.00000       0.00000
 E    3182   319.000       4.00000       0.00000       0.00000       0.00000
 E    3183   334.000       1.00000       0.00000       0.00000       0.00000
 E    3184   317.000       2.00000       0.00000       0.00000       0.00000
 E    3191   303.000       3.00000       0.00000       0.00000       0.00000
 E    3192   320.000       4.00000       0.00000       0.00000       0.00000
 E    3193   335.000       1.00000       0.00000       0.00000       0.00000
 E    3194   318.000       2.00000       0.00000       0.00000       0.00000
 E    3201   304.000       3.00000       0.00000       0.00000       0.00000
      3202   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3203   336.000       1.00000       0.00000       0.00000       0.00000
 E    3204   319.000       2.00000       0.00000       0.00000       0.00000
 E    3211   305.000       3.00000       0.00000       0.00000       0.00000
 E    3212   322.000       4.00000       0.00000       0.00000       0.00000
 E    3213   337.000       1.00000       0.00000       0.00000       0.00000
 v    3214   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3221   306.000       3.00000       0.00000       0.00000       0.00000
 E    3222   323.000       4.00000       0.00000       0.00000       0.00000
 E    3223   338.000       1.00000       0.00000       0.00000       0.00000
 E    3224   321.000       2.00000       0.00000       0.00000       0.00000
 E    3231   307.000       3.00000       0.00000       0.00000       0.00000
 E    3232   324.000       4.00000       0.00000       0.00000       0.00000
 E    3233   339.000       1.00000       0.00000       0.00000       0.00000
 E    3234   322.000       2.00000       0.00000       0.00000       0.00000
 E    3241   308.000       3.00000       0.00000       0.00000       0.00000
 E    3242   325.000       4.00000       0.00000       0.00000       0.00000
 E    3243   340.000       1.00000       0.00000       0.00000       0.00000
 E    3244   323.000       2.00000       0.00000       0.00000       0.00000
 E    3251   309.000       3.00000       0.00000       0.00000       0.00000
 E    3252   326.000       4.00000       0.00000       0.00000       0.00000
 E    3253   341.000       1.00000       0.00000       0.00000       0.00000
 E    3254   324.000       2.00000       0.00000       0.00000       0.00000
 E    3261   310.000       3.00000       0.00000       0.00000       0.00000
 E    3262   327.000       4.00000       0.00000       0.00000       0.00000
 E    3263   342.000       1.00000       0.00000       0.00000       0.00000
 E    3264   325.000       2.00000       0.00000       0.00000       0.00000
 E    3271   311.000       3.00000       0.00000       0.00000       0.00000
 E    3272   328.000       4.00000       0.00000       0.00000       0.00000
 E    3273   343.000       1.00000       0.00000       0.00000       0.00000
 E    3274   326.000       2.00000       0.00000       0.00000       0.00000
 E    3281   312.000       3.00000       0.00000       0.00000       0.00000
 E    3282   329.000       4.00000       0.00000       0.00000       0.00000
 E    3283   344.000       1.00000       0.00000       0.00000       0.00000
 E    3284   327.000       2.00000       0.00000       0.00000       0.00000
 E    3291   313.000       3.00000       0.00000       0.00000       0.00000
 E    3292   330.000       4.00000       0.00000       0.00000       0.00000
 E    3293   345.000       1.00000       0.00000       0.00000       0.00000
 E    3294   328.000       2.00000       0.00000       0.00000       0.00000
 E    3301   314.000       3.00000       0.00000       0.00000       0.00000
 E    3302   331.000       4.00000       0.00000       0.00000       0.00000
 E    3303   346.000       1.00000       0.00000       0.00000       0.00000
 E    3304   329.000       2.00000       0.00000       0.00000       0.00000
 E    3311   315.000       3.00000       0.00000       0.00000       0.00000
 E    3312   332.000       4.00000       0.00000       0.00000       0.00000
 E    3313   347.000       1.00000       0.00000       0.00000       0.00000
 E    3314   330.000       2.00000       0.00000       0.00000       0.00000
 E    3321   316.000       3.00000       0.00000       0.00000       0.00000
 E    3322   333.000       4.00000       0.00000       0.00000       0.00000
 E    3323   348.000       1.00000       0.00000       0.00000       0.00000
 E    3324   331.000       2.00000       0.00000       0.00000       0.00000
 E    3331   317.000       3.00000       0.00000       0.00000       0.00000
 E    3332   334.000       4.00000       0.00000       0.00000       0.00000
 E    3333   349.000       1.00000       0.00000       0.00000       0.00000
 E    3334   332.000       2.00000       0.00000       0.00000       0.00000
 E    3341   318.000       3.00000       0.00000       0.00000       0.00000
 E    3342   335.000       4.00000       0.00000       0.00000       0.00000
 E    3343   350.000       1.00000       0.00000       0.00000       0.00000
 E    3344   333.000       2.00000       0.00000       0.00000       0.00000
 E    3351   319.000       3.00000       0.00000       0.00000       0.00000
 E    3352   336.000       4.00000       0.00000       0.00000       0.00000
 E    3353   351.000       1.00000       0.00000       0.00000       0.00000
 E    3354   334.000       2.00000       0.00000       0.00000       0.00000
 E    3361   320.000       3.00000       0.00000       0.00000       0.00000
      3362   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3363   352.000       1.00000       0.00000       0.00000       0.00000
 E    3364   335.000       2.00000       0.00000       0.00000       0.00000
 E    3371   321.000       3.00000       0.00000       0.00000       0.00000
 E    3372   338.000       4.00000       0.00000       0.00000       0.00000
 E    3373   353.000       1.00000       0.00000       0.00000       0.00000
 v    3374   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3381   322.000       3.00000       0.00000       0.00000       0.00000
 E    3382   339.000       4.00000       0.00000       0.00000       0.00000
 E    3383   354.000       1.00000       0.00000       0.00000       0.00000
 E    3384   337.000       2.00000       0.00000       0.00000       0.00000
 E    3391   323.000       3.00000       0.00000       0.00000       0.00000
 E    3392   340.000       4.00000       0.00000       0.00000       0.00000
 E    3393   355.000       1.00000       0.00000       0.00000       0.00000
 E    3394   338.000       2.00000       0.00000       0.00000       0.00000
 E    3401   324.000       3.00000       0.00000       0.00000       0.00000
 E    3402   341.000       4.00000       0.00000       0.00000       0.00000
 E    3403   356.000       1.00000       0.00000       0.00000       0.00000
 E    3404   339.000       2.00000       0.00000       0.00000       0.00000
 E    3411   325.000       3.00000       0.00000       0.00000       0.00000
 E    3412   342.000       4.00000       0.00000       0.00000       0.00000
 E    3413   357.000       1.00000       0.00000       0.00000       0.00000
 E    3414   340.000       2.00000       0.00000       0.00000       0.00000
 E    3421   326.000       3.00000       0.00000       0.00000       0.00000
 E    3422   343.000       4.00000       0.00000       0.00000       0.00000
 E    3423   358.000       1.00000       0.00000       0.00000       0.00000
 E    3424   341.000       2.00000       0.00000       0.00000       0.00000
 E    3431   327.000       3.00000       0.00000       0.00000       0.00000
 E    3432   344.000       4.00000       0.00000       0.00000       0.00000
 E    3433   359.000       1.00000       0.00000       0.00000       0.00000
 E    3434   342.000       2.00000       0.00000       0.00000       0.00000
 E    3441   328.000       3.00000       0.00000       0.00000       0.00000
 E    3442   345.000       4.00000       0.00000       0.00000       0.00000
 E    3443   360.000       1.00000       0.00000       0.00000       0.00000
 E    3444   343.000       2.00000       0.00000       0.00000       0.00000
 E    3451   329.000       3.00000       0.00000       0.00000       0.00000
 E    3452   346.000       4.00000       0.00000       0.00000       0.00000
 E    3453   361.000       1.00000       0.00000       0.00000       0.00000
 E    3454   344.000       2.00000       0.00000       0.00000       0.00000
 E    3461   330.000       3.00000       0.00000       0.00000       0.00000
 E    3462   347.000       4.00000       0.00000       0.00000       0.00000
 E    3463   362.000       1.00000       0.00000       0.00000       0.00000
 E    3464   345.000       2.00000       0.00000       0.00000       0.00000
 E    3471   331.000       3.00000       0.00000       0.00000       0.00000
 E    3472   348.000       4.00000       0.00000       0.00000       0.00000
 E    3473   363.000       1.00000       0.00000       0.00000       0.00000
 E    3474   346.000       2.00000       0.00000       0.00000       0.00000
 E    3481   332.000       3.00000       0.00000       0.00000       0.00000
 E    3482   349.000       4.00000       0.00000       0.00000       0.00000
 E    3483   364.000       1.00000       0.00000       0.00000       0.00000
 E    3484   347.000       2.00000       0.00000       0.00000       0.00000
 E    3491   333.000       3.00000       0.00000       0.00000       0.00000
 E    3492   350.000       4.00000       0.00000       0.00000       0.00000
 E    3493   365.000       1.00000       0.00000       0.00000       0.00000
 E    3494   348.000       2.00000       0.00000       0.00000       0.00000
 E    3501   334.000       3.00000       0.00000       0.00000       0.00000
 E    3502   351.000       4.00000       0.00000       0.00000       0.00000
 E    3503   366.000       1.00000       0.00000       0.00000       0.00000
 E    3504   349.000       2.00000       0.00000       0.00000       0.00000
 E    3511   335.000       3.00000       0.00000       0.00000       0.00000
 E    3512   352.000       4.00000       0.00000       0.00000       0.00000
 E    3513   367.000       1.00000       0.00000       0.00000       0.00000
 E    3514   350.000       2.00000       0.00000       0.00000       0.00000
 E    3521   336.000       3.00000       0.00000       0.00000       0.00000
      3522   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3523   368.000       1.00000       0.00000       0.00000       0.00000
 E    3524   351.000       2.00000       0.00000       0.00000       0.00000
 E    3531   337.000       3.00000       0.00000       0.00000       0.00000
 E    3532   354.000       4.00000       0.00000       0.00000       0.00000
 E    3533   369.000       1.00000       0.00000       0.00000       0.00000
 v    3534   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3541   338.000       3.00000       0.00000       0.00000       0.00000
 E    3542   355.000       4.00000       0.00000       0.00000       0.00000
 E    3543   370.000       1.00000       0.00000       0.00000       0.00000
 E    3544   353.000       2.00000       0.00000       0.00000       0.00000
 E    3551   339.000       3.00000       0.00000       0.00000       0.00000
 E    3552   356.000       4.00000       0.00000       0.00000       0.00000
 E    3553   371.000       1.00000       0.00000       0.00000       0.00000
 E    3554   354.000       2.00000       0.00000       0.00000       0.00000
 E    3561   340.000       3.00000       0.00000       0.00000       0.00000
 E    3562   357.000       4.00000       0.00000       0.00000       0.00000
 E    3563   372.000       1.00000       0.00000       0.00000       0.00000
 E    3564   355.000       2.00000       0.00000       0.00000       0.00000
 E    3571   341.000       3.00000       0.00000       0.00000       0.00000
 E    3572   358.000       4.00000       0.00000       0.00000       0.00000
 E    3573   373.000       1.00000       0.00000       0.00000       0.00000
 E    3574   356.000       2.00000       0.00000       0.00000       0.00000
 E    3581   342.000       3.00000       0.00000       0.00000       0.00000
 E    3582   359.000       4.00000       0.00000       0.00000       0.00000
 E    3583   374.000       1.00000       0.00000       0.00000       0.00000
 E    3584   357.000       2.00000       0.00000       0.00000       0.00000
 E    3591   343.000       3.00000       0.00000       0.00000       0.00000
 E    3592   360.000       4.00000       0.00000       0.00000       0.00000
 E    3593   375.000       1.00000       0.00000       0.00000       0.00000
 E    3594   358.000       2.00000       0.00000       0.00000       0.00000
 E    3601   344.000       3.00000       0.00000       0.00000       0.00000
 E    3602   361.000       4.00000       0.00000       0.00000       0.00000
 E    3603   376.000       1.00000       0.00000       0.00000       0.00000
 E    3604   359.000       2.00000       0.00000       0.00000       0.00000
 E    3611   345.000       3.00000       0.00000       0.00000       0.00000
 E    3612   362.000       4.00000       0.00000       0.00000       0.00000
 E    3613   377.000       1.00000       0.00000       0.00000       0.00000
 E    3614   360.000       2.00000       0.00000       0.00000       0.00000
 E    3621   346.000       3.00000       0.00000       0.00000       0.00000
 E    3622   363.000       4.00000       0.00000       0.00000       0.00000
 E    3623   378.000       1.00000       0.00000       0.00000       0.00000
 E    3624   361.000       2.00000       0.00000       0.00000       0.00000
 E    3631   347.000       3.00000       0.00000       0.00000       0.00000
 E    3632   364.000       4.00000       0.00000       0.00000       0.00000
 E    3633   379.000       1.00000       0.00000       0.00000       0.00000
 E    3634   362.000       2.00000       0.00000       0.00000       0.00000
 E    3641   348.000       3.00000       0.00000       0.00000       0.00000
 E    3642   365.000       4.00000       0.00000       0.00000       0.00000
 E    3643   380.000       1.00000       0.00000       0.00000       0.00000
 E    3644   363.000       2.00000       0.00000       0.00000       0.00000
 E    3651   349.000       3.00000       0.00000       0.00000       0.00000
 E    3652   366.000       4.00000       0.00000       0.00000       0.00000
 E    3653   381.000       1.00000       0.00000       0.00000       0.00000
 E    3654   364.000       2.00000       0.00000       0.00000       0.00000
 E    3661   350.000       3.00000       0.00000       0.00000       0.00000
 E    3662   367.000       4.00000       0.00000       0.00000       0.00000
 E    3663   382.000       1.00000       0.00000       0.00000       0.00000
 E    3664   365.000       2.00000       0.00000       0.00000       0.00000
 E    3671   351.000       3.00000       0.00000       0.00000       0.00000
 E    3672   368.000       4.00000       0.00000       0.00000       0.00000
 E    3673   383.000       1.00000       0.00000       0.00000       0.00000
 E    3674   366.000       2.00000       0.00000       0.00000       0.00000
 E    3681   352.000       3.00000       0.00000       0.00000       0.00000
      3682   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3683   384.000       1.00000       0.00000       0.00000       0.00000
 E    3684   367.000       2.00000       0.00000       0.00000       0.00000
 E    3691   353.000       3.00000       0.00000       0.00000       0.00000
 E    3692   370.000       4.00000       0.00000       0.00000       0.00000
 E    3693   385.000       1.00000       0.00000       0.00000       0.00000
 v    3694   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3701   354.000       3.00000       0.00000       0.00000       0.00000
 E    3702   371.000       4.00000       0.00000       0.00000       0.00000
 E    3703   386.000       1.00000       0.00000       0.00000       0.00000
 E    3704   369.000       2.00000       0.00000       0.00000       0.00000
 E    3711   355.000       3.00000       0.00000       0.00000       0.00000
 E    3712   372.000       4.00000       0.00000       0.00000       0.00000
 E    3713   387.000       1.00000       0.00000       0.00000       0.00000
 E    3714   370.000       2.00000       0.00000       0.00000       0.00000
 E    3721   356.000       3.00000       0.00000       0.00000       0.00000
 E    3722   373.000       4.00000       0.00000       0.00000       0.00000
 E    3723   388.000       1.00000       0.00000       0.00000       0.00000
 E    3724   371.000       2.00000       0.00000       0.00000       0.00000
 E    3731   357.000       3.00000       0.00000       0.00000       0.00000
 E    3732   374.000       4.00000       0.00000       0.00000       0.00000
 E    3733   389.000       1.00000       0.00000       0.00000       0.00000
 E    3734   372.000       2.00000       0.00000       0.00000       0.00000
 E    3741   358.000       3.00000       0.00000       0.00000       0.00000
 E    3742   375.000       4.00000       0.00000       0.00000       0.00000
 E    3743   390.000       1.00000       0.00000       0.00000       0.00000
 E    3744   373.000       2.00000       0.00000       0.00000       0.00000
 E    3751   359.000       3.00000       0.00000       0.00000       0.00000
 E    3752   376.000       4.00000       0.00000       0.00000       0.00000
 E    3753   391.000       1.00000       0.00000       0.00000       0.00000
 E    3754   374.000       2.00000       0.00000       0.00000       0.00000
 E    3761   360.000       3.00000       0.00000       0.00000       0.00000
 E    3762   377.000       4.00000       0.00000       0.00000       0.00000
 E    3763   392.000       1.00000       0.00000       0.00000       0.00000
 E    3764   375.000       2.00000       0.00000       0.00000       0.00000
 E    3771   361.000       3.00000       0.00000       0.00000       0.00000
 E    3772   378.000       4.00000       0.00000       0.00000       0.00000
 E    3773   393.000       1.00000       0.00000       0.00000       0.00000
 E    3774   376.000       2.00000       0.00000       0.00000       0.00000
 E    3781   362.000       3.00000       0.00000       0.00000       0.00000
 E    3782   379.000       4.00000       0.00000       0.00000       0.00000
 E    3783   394.000       1.00000       0.00000       0.00000       0.00000
 E    3784   377.000       2.00000       0.00000       0.00000       0.00000
 E    3791   363.000       3.00000       0.00000       0.00000       0.00000
 E    3792   380.000       4.00000       0.00000       0.00000       0.00000
 E    3793   395.000       1.00000       0.00000       0.00000       0.00000
 E    3794   378.000       2.00000       0.00000       0.00000       0.00000
 E    3801   364.000       3.00000       0.00000       0.00000       0.00000
 E    3802   381.000       4.00000       0.00000       0.00000       0.00000
 E    3803   396.000       1.00000       0.00000       0.00000       0.00000
 E    3804   379.000       2.00000       0.00000       0.00000       0.00000
 E    3811   365.000       3.00000       0.00000       0.00000       0.00000
 E    3812   382.000       4.00000       0.00000       0.00000       0.00000
 E    3813   397.000       1.00000       0.00000       0.00000       0.00000
 E    3814   380.000       2.00000       0.00000       0.00000       0.00000
 E    3821   366.000       3.00000       0.00000       0.00000       0.00000
 E    3822   383.000       4.00000       0.00000       0.00000       0.00000
 E    3823   398.000       1.00000       0.00000       0.00000       0.00000
 E    3824   381.000       2.00000       0.00000       0.00000       0.00000
 E    3831   367.000       3.00000       0.00000       0.00000       0.00000
 E    3832   384.000       4.00000       0.00000       0.00000       0.00000
 E    3833   399.000       1.00000       0.00000       0.00000       0.00000
 E    3834   382.000       2.00000       0.00000       0.00000       0.00000
 E    3841   368.000       3.00000       0.00000       0.00000       0.00000
      3842   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3843   400.000       1.00000       0.00000       0.00000       0.00000
 E    3844   383.000       2.00000       0.00000       0.00000       0.00000
 E    3851   369.000       3.00000       0.00000       0.00000       0.00000
 E    3852   386.000       4.00000       0.00000       0.00000       0.00000
 E    3853   401.000       1.00000       0.00000       0.00000       0.00000
 v    3854   0.00000       0.00000       0.00000       0.00000       0.00000
 E    3861   370.000       3.00000       0.00000       0.00000       0.00000
 E    3862   387.000       4.00000       0.00000       0.00000       0.00000
 E    3863   402.000       1.00000       0.00000       0.00000       0.00000
 E    3864   385.000       2.00000       0.00000       0.00000       0.00000
 E    3871   371.000       3.00000       0.00000       0.00000       0.00000
 E    3872   388.000       4.00000       0.00000       0.00000       0.00000
 E    3873   403.000       1.00000       0.00000       0.00000       0.00000
 E    3874   386.000       2.00000       0.00000       0.00000       0.00000
 E    3881   372.000       3.00000       0.00000       0.00000       0.00000
 E    3882   389.000       4.00000       0.00000       0.00000       0.00000
 E    3883   404.000       1.00000       0.00000       0.00000       0.00000
 E    3884   387.000       2.00000       0.00000       0.00000       0.00000
 E    3891   373.000       3.00000       0.00000       0.00000       0.00000
 E    3892   390.000       4.00000       0.00000       0.00000       0.00000
 E    3893   405.000       1.00000       0.00000       0.00000       0.00000
 E    3894   388.000       2.00000       0.00000       0.00000       0.00000
 E    3901   374.000       3.00000       0.00000       0.00000       0.00000
 E    3902   391.000       4.00000       0.00000       0.00000       0.00000
 E    3903   406.000       1.00000       0.00000       0.00000       0.00000
 E    3904   389.000       2.00000       0.00000       0.00000       0.00000
 E    3911   375.000       3.00000       0.00000       0.00000       0.00000
 E    3912   392.000       4.00000       0.00000       0.00000       0.00000
 E    3913   407.000       1.00000       0.00000       0.00000       0.00000
 E    3914   390.000       2.00000       0.00000       0.00000       0.00000
 E    3921   376.000       3.00000       0.00000       0.00000       0.00000
 E    3922   393.000       4.00000       0.00000       0.00000       0.00000
 E    3923   408.000       1.00000       0.00000       0.00000       0.00000
 E    3924   391.000       2.00000       0.00000       0.00000       0.00000
 E    3931   377.000       3.00000       0.00000       0.00000       0.00000
 E    3932   394.000       4.00000       0.00000       0.00000       0.00000
 E    3933   409.000       1.00000       0.00000       0.00000       0.00000
 E    3934   392.000       2.00000       0.00000       0.00000       0.00000
 E    3941   378.000       3.00000       0.00000       0.00000       0.00000
 E    3942   395.000       4.00000       0.00000       0.00000       0.00000
 E    3943   410.000       1.00000       0.00000       0.00000       0.00000
 E    3944   393.000       2.00000       0.00000       0.00000       0.00000
 E    3951   379.000       3.00000       0.00000       0.00000       0.00000
 E    3952   396.000       4.00000       0.00000       0.00000       0.00000
 E    3953   411.000       1.00000       0.00000       0.00000       0.00000
 E    3954   394.000       2.00000       0.00000       0.00000       0.00000
 E    3961   380.000       3.00000       0.00000       0.00000       0.00000
 E    3962   397.000       4.00000       0.00000       0.00000       0.00000
 E    3963   412.000       1.00000       0.00000       0.00000       0.00000
 E    3964   395.000       2.00000       0.00000       0.00000       0.00000
 E    3971   381.000       3.00000       0.00000       0.00000       0.00000
 E    3972   398.000       4.00000       0.00000       0.00000       0.00000
 E    3973   413.000       1.00000       0.00000       0.00000       0.00000
 E    3974   396.000       2.00000       0.00000       0.00000       0.00000
 E    3981   382.000       3.00000       0.00000       0.00000       0.00000
 E    3982   399.000       4.00000       0.00000       0.00000       0.00000
 E    3983   414.000       1.00000       0.00000       0.00000       0.00000
 E    3984   397.000       2.00000       0.00000       0.00000       0.00000
 E    3991   383.000       3.00000       0.00000       0.00000       0.00000
 E    3992   400.000       4.00000       0.00000       0.00000       0.00000
 E    3993   415.000       1.00000       0.00000       0.00000       0.00000
 E    3994   398.000       2.00000       0.00000       0.00000       0.00000
 E    4001   384.000       3.00000       0.00000       0.00000       0.00000
      4002   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4003   416.000       1.00000       0.00000       0.00000       0.00000
 E    4004   399.000       2.00000       0.00000       0.00000       0.00000
 E    4011   385.000       3.00000       0.00000       0.00000       0.00000
 E    4012   402.000       4.00000       0.00000       0.00000       0.00000
 E    4013   417.000       1.00000       0.00000       0.00000       0.00000
 v    4014   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4021   386.000       3.00000       0.00000       0.00000       0.00000
 E    4022   403.000       4.00000       0.00000       0.00000       0.00000
 E    4023   418.000       1.00000       0.00000       0.00000       0.00000
 E    4024   401.000       2.00000       0.00000       0.00000       0.00000
 E    4031   387.000       3.00000       0.00000       0.00000       0.00000
 E    4032   404.000       4.00000       0.00000       0.00000       0.00000
 E    4033   419.000       1.00000       0.00000       0.00000       0.00000
 E    4034   402.000       2.00000       0.00000       0.00000       0.00000
 E    4041   388.000       3.00000       0.00000       0.00000       0.00000
 E    4042   405.000       4.00000       0.00000       0.00000       0.00000
 E    4043   420.000       1.00000       0.00000       0.00000       0.00000
 E    4044   403.000       2.00000       0.00000       0.00000       0.00000
 E    4051   389.000       3.00000       0.00000       0.00000       0.00000
 E    4052   406.000       4.00000       0.00000       0.00000       0.00000
 E    4053   421.000       1.00000       0.00000       0.00000       0.00000
 E    4054   404.000       2.00000       0.00000       0.00000       0.00000
 E    4061   390.000       3.00000       0.00000       0.00000       0.00000
 E    4062   407.000       4.00000       0.00000       0.00000       0.00000
 E    4063   422.000       1.00000       0.00000       0.00000       0.00000
 E    4064   405.000       2.00000       0.00000       0.00000       0.00000
 E    4071   391.000       3.00000       0.00000       0.00000       0.00000
 E    4072   408.000       4.00000       0.00000       0.00000       0.00000
 E    4073   423.000       1.00000       0.00000       0.00000       0.00000
 E    4074   406.000       2.00000       0.00000       0.00000       0.00000
 E    4081   392.000       3.00000       0.00000       0.00000       0.00000
 E    4082   409.000       4.00000       0.00000       0.00000       0.00000
 E    4083   424.000       1.00000       0.00000       0.00000       0.00000
 E    4084   407.000       2.00000       0.00000       0.00000       0.00000
 E    4091   393.000       3.00000       0.00000       0.00000       0.00000
 E    4092   410.000       4.00000       0.00000       0.00000       0.00000
 E    4093   425.000       1.00000       0.00000       0.00000       0.00000
 E    4094   408.000       2.00000       0.00000       0.00000       0.00000
 E    4101   394.000       3.00000       0.00000       0.00000       0.00000
 E    4102   411.000       4.00000       0.00000       0.00000       0.00000
 E    4103   426.000       1.00000       0.00000       0.00000       0.00000
 E    4104   409.000       2.00000       0.00000       0.00000       0.00000
 E    4111   395.000       3.00000       0.00000       0.00000       0.00000
 E    4112   412.000       4.00000       0.00000       0.00000       0.00000
 E    4113   427.000       1.00000       0.00000       0.00000       0.00000
 E    4114   410.000       2.00000       0.00000       0.00000       0.00000
 E    4121   396.000       3.00000       0.00000       0.00000       0.00000
 E    4122   413.000       4.00000       0.00000       0.00000       0.00000
 E    4123   428.000       1.00000       0.00000       0.00000       0.00000
 E    4124   411.000       2.00000       0.00000       0.00000       0.00000
 E    4131   397.000       3.00000       0.00000       0.00000       0.00000
 E    4132   414.000       4.00000       0.00000       0.00000       0.00000
 E    4133   429.000       1.00000       0.00000       0.00000       0.00000
 E    4134   412.000       2.00000       0.00000       0.00000       0.00000
 E    4141   398.000       3.00000       0.00000       0.00000       0.00000
 E    4142   415.000       4.00000       0.00000       0.00000       0.00000
 E    4143   430.000       1.00000       0.00000       0.00000       0.00000
 E    4144   413.000       2.00000       0.00000       0.00000       0.00000
 E    4151   399.000       3.00000       0.00000       0.00000       0.00000
 E    4152   416.000       4.00000       0.00000       0.00000       0.00000
 E    4153   431.000       1.00000       0.00000       0.00000       0.00000
 E    4154   414.000       2.00000       0.00000       0.00000       0.00000
 E    4161   400.000       3.00000       0.00000       0.00000       0.00000
      4162   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4163   432.000       1.00000       0.00000       0.00000       0.00000
 E    4164   415.000       2.00000       0.00000       0.00000       0.00000
 E    4171   401.000       3.00000       0.00000       0.00000       0.00000
 E    4172   418.000       4.00000       0.00000       0.00000       0.00000
 E    4173   433.000       1.00000       0.00000       0.00000       0.00000
 v    4174   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4181   402.000       3.00000       0.00000       0.00000       0.00000
 E    4182   419.000       4.00000       0.00000       0.00000       0.00000
 E    4183   434.000       1.00000       0.00000       0.00000       0.00000
 E    4184   417.000       2.00000       0.00000       0.00000       0.00000
 E    4191   403.000       3.00000       0.00000       0.00000       0.00000
 E    4192   420.000       4.00000       0.00000       0.00000       0.00000
 E    4193   435.000       1.00000       0.00000       0.00000       0.00000
 E    4194   418.000       2.00000       0.00000       0.00000       0.00000
 E    4201   404.000       3.00000       0.00000       0.00000       0.00000
 E    4202   421.000       4.00000       0.00000       0.00000       0.00000
 E    4203   436.000       1.00000       0.00000       0.00000       0.00000
 E    4204   419.000       2.00000       0.00000       0.00000       0.00000
 E    4211   405.000       3.00000       0.00000       0.00000       0.00000
 E    4212   422.000       4.00000       0.00000       0.00000       0.00000
 E    4213   437.000       1.00000       0.00000       0.00000       0.00000
 E    4214   420.000       2.00000       0.00000       0.00000       0.00000
 E    4221   406.000       3.00000       0.00000       0.00000       0.00000
 E    4222   423.000       4.00000       0.00000       0.00000       0.00000
 E    4223   438.000       1.00000       0.00000       0.00000       0.00000
 E    4224   421.000       2.00000       0.00000       0.00000       0.00000
 E    4231   407.000       3.00000       0.00000       0.00000       0.00000
 E    4232   424.000       4.00000       0.00000       0.00000       0.00000
 E    4233   439.000       1.00000       0.00000       0.00000       0.00000
 E    4234   422.000       2.00000       0.00000       0.00000       0.00000
 E    4241   408.000       3.00000       0.00000       0.00000       0.00000
 E    4242   425.000       4.00000       0.00000       0.00000       0.00000
 E    4243   440.000       1.00000       0.00000       0.00000       0.00000
 E    4244   423.000       2.00000       0.00000       0.00000       0.00000
 E    4251   409.000       3.00000       0.00000       0.00000       0.00000
 E    4252   426.000       4.00000       0.00000       0.00000       0.00000
 E    4253   441.000       1.00000       0.00000       0.00000       0.00000
 E    4254   424.000       2.00000       0.00000       0.00000       0.00000
 E    4261   410.000       3.00000       0.00000       0.00000       0.00000
 E    4262   427.000       4.00000       0.00000       0.00000       0.00000
 E    4263   442.000       1.00000       0.00000       0.00000       0.00000
 E    4264   425.000       2.00000       0.00000       0.00000       0.00000
 E    4271   411.000       3.00000       0.00000       0.00000       0.00000
 E    4272   428.000       4.00000       0.00000       0.00000       0.00000
 E    4273   443.000       1.00000       0.00000       0.00000       0.00000
 E    4274   426.000       2.00000       0.00000       0.00000       0.00000
 E    4281   412.000       3.00000       0.00000       0.00000       0.00000
 E    4282   429.000       4.00000       0.00000       0.00000       0.00000
 E    4283   444.000       1.00000       0.00000       0.00000       0.00000
 E    4284   427.000       2.00000       0.00000       0.00000       0.00000
 E    4291   413.000       3.00000       0.00000       0.00000       0.00000
 E    4292   430.000       4.00000       0.00000       0.00000       0.00000
 E    4293   445.000       1.00000       0.00000       0.00000       0.00000
 E    4294   428.000       2.00000       0.00000       0.00000       0.00000
 E    4301   414.000       3.00000       0.00000       0.00000       0.00000
 E    4302   431.000       4.00000       0.00000       0.00000       0.00000
 E    4303   446.000       1.00000       0.00000       0.00000       0.00000
 E    4304   429.000       2.00000       0.00000       0.00000       0.00000
 E    4311   415.000       3.00000       0.00000       0.00000       0.00000
 E    4312   432.000       4.00000       0.00000       0.00000       0.00000
 E    4313   447.000       1.00000       0.00000       0.00000       0.00000
 E    4314   430.000       2.00000       0.00000       0.00000       0.00000
 E    4321   416.000       3.00000       0.00000       0.00000       0.00000
      4322   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4323   448.000       1.00000       0.00000       0.00000       0.00000
 E    4324   431.000       2.00000       0.00000       0.00000       0.00000
 E    4331   417.000       3.00000       0.00000       0.00000       0.00000
 E    4332   434.000       4.00000       0.00000       0.00000       0.00000
 E    4333   449.000       1.00000       0.00000       0.00000       0.00000
 v    4334   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4341   418.000       3.00000       0.00000       0.00000       0.00000
 E    4342   435.000       4.00000       0.00000       0.00000       0.00000
 E    4343   450.000       1.00000       0.00000       0.00000       0.00000
 E    4344   433.000       2.00000       0.00000       0.00000       0.00000
 E    4351   419.000       3.00000       0.00000       0.00000       0.00000
 E    4352   436.000       4.00000       0.00000       0.00000       0.00000
 E    4353   451.000       1.00000       0.00000       0.00000       0.00000
 E    4354   434.000       2.00000       0.00000       0.00000       0.00000
 E    4361   420.000       3.00000       0.00000       0.00000       0.00000
 E    4362   437.000       4.00000       0.00000       0.00000       0.00000
 E    4363   452.000       1.00000       0.00000       0.00000       0.00000
 E    4364   435.000       2.00000       0.00000       0.00000       0.00000
 E    4371   421.000       3.00000       0.00000       0.00000       0.00000
 E    4372   438.000       4.00000       0.00000       0.00000       0.00000
 E    4373   453.000       1.00000       0.00000       0.00000       0.00000
 E    4374   436.000       2.00000       0.00000       0.00000       0.00000
 E    4381   422.000       3.00000       0.00000       0.00000       0.00000
 E    4382   439.000       4.00000       0.00000       0.00000       0.00000
 E    4383   454.000       1.00000       0.00000       0.00000       0.00000
 E    4384   437.000       2.00000       0.00000       0.00000       0.00000
 E    4391   423.000       3.00000       0.00000       0.00000       0.00000
 E    4392   440.000       4.00000       0.00000       0.00000       0.00000
 E    4393   455.000       1.00000       0.00000       0.00000       0.00000
 E    4394   438.000       2.00000       0.00000       0.00000       0.00000
 E    4401   424.000       3.00000       0.00000       0.00000       0.00000
 E    4402   441.000       4.00000       0.00000       0.00000       0.00000
 E    4403   456.000       1.00000       0.00000       0.00000       0.00000
 E    4404   439.000       2.00000       0.00000       0.00000       0.00000
 E    4411   425.000       3.00000       0.00000       0.00000       0.00000
 E    4412   442.000       4.00000       0.00000       0.00000       0.00000
 E    4413   457.000       1.00000       0.00000       0.00000       0.00000
 E    4414   440.000       2.00000       0.00000       0.00000       0.00000
 E    4421   426.000       3.00000       0.00000       0.00000       0.00000
 E    4422   443.000       4.00000       0.00000       0.00000       0.00000
 E    4423   458.000       1.00000       0.00000       0.00000       0.00000
 E    4424   441.000       2.00000       0.00000       0.00000       0.00000
 E    4431   427.000       3.00000       0.00000       0.00000       0.00000
 E    4432   444.000       4.00000       0.00000       0.00000       0.00000
 E    4433   459.000       1.00000       0.00000       0.00000       0.00000
 E    4434   442.000       2.00000       0.00000       0.00000       0.00000
 E    4441   428.000       3.00000       0.00000       0.00000       0.00000
 E    4442   445.000       4.00000       0.00000       0.00000       0.00000
 E    4443   460.000       1.00000       0.00000       0.00000       0.00000
 E    4444   443.000       2.00000       0.00000       0.00000       0.00000
 E    4451   429.000       3.00000       0.00000       0.00000       0.00000
 E    4452   446.000       4.00000       0.00000       0.00000       0.00000
 E    4453   461.000       1.00000       0.00000       0.00000       0.00000
 E    4454   444.000       2.00000       0.00000       0.00000       0.00000
 E    4461   430.000       3.00000       0.00000       0.00000       0.00000
 E    4462   447.000       4.00000       0.00000       0.00000       0.00000
 E    4463   462.000       1.00000       0.00000       0.00000       0.00000
 E    4464   445.000       2.00000       0.00000       0.00000       0.00000
 E    4471   431.000       3.00000       0.00000       0.00000       0.00000
 E    4472   448.000       4.00000       0.00000       0.00000       0.00000
 E    4473   463.000       1.00000       0.00000       0.00000       0.00000
 E    4474   446.000       2.00000       0.00000       0.00000       0.00000
 E    4481   432.000       3.00000       0.00000       0.00000       0.00000
      4482   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4483   464.000       1.00000       0.00000       0.00000       0.00000
 E    4484   447.000       2.00000       0.00000       0.00000       0.00000
 E    4491   433.000       3.00000       0.00000       0.00000       0.00000
 E    4492   450.000       4.00000       0.00000       0.00000       0.00000
 E    4493   465.000       1.00000       0.00000       0.00000       0.00000
 v    4494   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4501   434.000       3.00000       0.00000       0.00000       0.00000
 E    4502   451.000       4.00000       0.00000       0.00000       0.00000
 E    4503   466.000       1.00000       0.00000       0.00000       0.00000
 E    4504   449.000       2.00000       0.00000       0.00000       0.00000
 E    4511   435.000       3.00000       0.00000       0.00000       0.00000
 E    4512   452.000       4.00000       0.00000       0.00000       0.00000
 E    4513   467.000       1.00000       0.00000       0.00000       0.00000
 E    4514   450.000       2.00000       0.00000       0.00000       0.00000
 E    4521   436.000       3.00000       0.00000       0.00000       0.00000
 E    4522   453.000       4.00000       0.00000       0.00000       0.00000
 E    4523   468.000       1.00000       0.00000       0.00000       0.00000
 E    4524   451.000       2.00000       0.00000       0.00000       0.00000
 E    4531   437.000       3.00000       0.00000       0.00000       0.00000
 E    4532   454.000       4.00000       0.00000       0.00000       0.00000
 E    4533   469.000       1.00000       0.00000       0.00000       0.00000
 E    4534   452.000       2.00000       0.00000       0.00000       0.00000
 E    4541   438.000       3.00000       0.00000       0.00000       0.00000
 E    4542   455.000       4.00000       0.00000       0.00000       0.00000
 E    4543   470.000       1.00000       0.00000       0.00000       0.00000
 E    4544   453.000       2.00000       0.00000       0.00000       0.00000
 E    4551   439.000       3.00000       0.00000       0.00000       0.00000
 E    4552   456.000       4.00000       0.00000       0.00000       0.00000
 E    4553   471.000       1.00000       0.00000       0.00000       0.00000
 E    4554   454.000       2.00000       0.00000       0.00000       0.00000
 E    4561   440.000       3.00000       0.00000       0.00000       0.00000
 E    4562   457.000       4.00000       0.00000       0.00000       0.00000
 E    4563   472.000       1.00000       0.00000       0.00000       0.00000
 E    4564   455.000       2.00000       0.00000       0.00000       0.00000
 E    4571   441.000       3.00000       0.00000       0.00000       0.00000
 E    4572   458.000       4.00000       0.00000       0.00000       0.00000
 E    4573   473.000       1.00000       0.00000       0.00000       0.00000
 E    4574   456.000       2.00000       0.00000       0.00000       0.00000
 E    4581   442.000       3.00000       0.00000       0.00000       0.00000
 E    4582   459.000       4.00000       0.00000       0.00000       0.00000
 E    4583   474.000       1.00000       0.00000       0.00000       0.00000
 E    4584   457.000       2.00000       0.00000       0.00000       0.00000
 E    4591   443.000       3.00000       0.00000       0.00000       0.00000
 E    4592   460.000       4.00000       0.00000       0.00000       0.00000
 E    4593   475.000       1.00000       0.00000       0.00000       0.00000
 E    4594   458.000       2.00000       0.00000       0.00000       0.00000
 E    4601   444.000       3.00000       0.00000       0.00000       0.00000
 E    4602   461.000       4.00000       0.00000       0.00000       0.00000
 E    4603   476.000       1.00000       0.00000       0.00000       0.00000
 E    4604   459.000       2.00000       0.00000       0.00000       0.00000
 E    4611   445.000       3.00000       0.00000       0.00000       0.00000
 E    4612   462.000       4.00000       0.00000       0.00000       0.00000
 E    4613   477.000       1.00000       0.00000       0.00000       0.00000
 E    4614   460.000       2.00000       0.00000       0.00000       0.00000
 E    4621   446.000       3.00000       0.00000       0.00000       0.00000
 E    4622   463.000       4.00000       0.00000       0.00000       0.00000
 E    4623   478.000       1.00000       0.00000       0.00000       0.00000
 E    4624   461.000       2.00000       0.00000       0.00000       0.00000
 E    4631   447.000       3.00000       0.00000       0.00000       0.00000
 E    4632   464.000       4.00000       0.00000       0.00000       0.00000
 E    4633   479.000       1.00000       0.00000       0.00000       0.00000
 E    4634   462.000       2.00000       0.00000       0.00000       0.00000
 E    4641   448.000       3.00000       0.00000       0.00000       0.00000
      4642   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4643   480.000       1.00000       0.00000       0.00000       0.00000
 E    4644   463.000       2.00000       0.00000       0.00000       0.00000
 E    4651   449.000       3.00000       0.00000       0.00000       0.00000
 E    4652   466.000       4.00000       0.00000       0.00000       0.00000
 E    4653   481.000       1.00000       0.00000       0.00000       0.00000
 v    4654   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4661   450.000       3.00000       0.00000       0.00000       0.00000
 E    4662   467.000       4.00000       0.00000       0.00000       0.00000
 E    4663   482.000       1.00000       0.00000       0.00000       0.00000
 E    4664   465.000       2.00000       0.00000       0.00000       0.00000
 E    4671   451.000       3.00000       0.00000       0.00000       0.00000
 E    4672   468.000       4.00000       0.00000       0.00000       0.00000
 E    4673   483.000       1.00000       0.00000       0.00000       0.00000
 E    4674   466.000       2.00000       0.00000       0.00000       0.00000
 E    4681   452.000       3.00000       0.00000       0.00000       0.00000
 E    4682   469.000       4.00000       0.00000       0.00000       0.00000
 E    4683   484.000       1.00000       0.00000       0.00000       0.00000
 E    4684   467.000       2.00000       0.00000       0.00000       0.00000
 E    4691   453.000       3.00000       0.00000       0.00000       0.00000
 E    4692   470.000       4.00000       0.00000       0.00000       0.00000
 E    4693   485.000       1.00000       0.00000       0.00000       0.00000
 E    4694   468.000       2.00000       0.00000       0.00000       0.00000
 E    4701   454.000       3.00000       0.00000       0.00000       0.00000
 E    4702   471.000       4.00000       0.00000       0.00000       0.00000
 E    4703   486.000       1.00000       0.00000       0.00000       0.00000
 E    4704   469.000       2.00000       0.00000       0.00000       0.00000
 E    4711   455.000       3.00000       0.00000       0.00000       0.00000
 E    4712   472.000       4.00000       0.00000       0.00000       0.00000
 E    4713   487.000       1.00000       0.00000       0.00000       0.00000
 E    4714   470.000       2.00000       0.00000       0.00000       0.00000
 E    4721   456.000       3.00000       0.00000       0.00000       0.00000
 E    4722   473.000       4.00000       0.00000       0.00000       0.00000
 E    4723   488.000       1.00000       0.00000       0.00000       0.00000
 E    4724   471.000       2.00000       0.00000       0.00000       0.00000
 E    4731   457.000       3.00000       0.00000       0.00000       0.00000
 E    4732   474.000       4.00000       0.00000       0.00000       0.00000
 E    4733   489.000       1.00000       0.00000       0.00000       0.00000
 E    4734   472.000       2.00000       0.00000       0.00000       0.00000
 E    4741   458.000       3.00000       0.00000       0.00000       0.00000
 E    4742   475.000       4.00000       0.00000       0.00000       0.00000
 E    4743   490.000       1.00000       0.00000       0.00000       0.00000
 E    4744   473.000       2.00000       0.00000       0.00000       0.00000
 E    4751   459.000       3.00000       0.00000       0.00000       0.00000
 E    4752   476.000       4.00000       0.00000       0.00000       0.00000
 E    4753   491.000       1.00000       0.00000       0.00000       0.00000
 E    4754   474.000       2.00000       0.00000       0.00000       0.00000
 E    4761   460.000       3.00000       0.00000       0.00000       0.00000
 E    4762   477.000       4.00000       0.00000       0.00000       0.00000
 E    4763   492.000       1.00000       0.00000       0.00000       0.00000
 E    4764   475.000       2.00000       0.00000       0.00000       0.00000
 E    4771   461.000       3.00000       0.00000       0.00000       0.00000
 E    4772   478.000       4.00000       0.00000       0.00000       0.00000
 E    4773   493.000       1.00000       0.00000       0.00000       0.00000
 E    4774   476.000       2.00000       0.00000       0.00000       0.00000
 E    4781   462.000       3.00000       0.00000       0.00000       0.00000
 E    4782   479.000       4.00000       0.00000       0.00000       0.00000
 E    4783   494.000       1.00000       0.00000       0.00000       0.00000
 E    4784   477.000       2.00000       0.00000       0.00000       0.00000
 E    4791   463.000       3.00000       0.00000       0.00000       0.00000
 E    4792   480.000       4.00000       0.00000       0.00000       0.00000
 E    4793   495.000       1.00000       0.00000       0.00000       0.00000
 E    4794   478.000       2.00000       0.00000       0.00000       0.00000
 E    4801   464.000       3.00000       0.00000       0.00000       0.00000
      4802   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4803   496.000       1.00000       0.00000       0.00000       0.00000
 E    4804   479.000       2.00000       0.00000       0.00000       0.00000
 E    4811   465.000       3.00000       0.00000       0.00000       0.00000
 E    4812   482.000       4.00000       0.00000       0.00000       0.00000
 E    4813   497.000       1.00000       0.00000       0.00000       0.00000
 v    4814   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4821   466.000       3.00000       0.00000       0.00000       0.00000
 E    4822   483.000       4.00000       0.00000       0.00000       0.00000
 E    4823   498.000       1.00000       0.00000       0.00000       0.00000
 E    4824   481.000       2.00000       0.00000       0.00000       0.00000
 E    4831   467.000       3.00000       0.00000       0.00000       0.00000
 E    4832   484.000       4.00000       0.00000       0.00000       0.00000
 E    4833   499.000       1.00000       0.00000       0.00000       0.00000
 E    4834   482.000       2.00000       0.00000       0.00000       0.00000
 E    4841   468.000       3.00000       0.00000       0.00000       0.00000
 E    4842   485.000       4.00000       0.00000       0.00000       0.00000
 E    4843   500.000       1.00000       0.00000       0.00000       0.00000
 E    4844   483.000       2.00000       0.00000       0.00000       0.00000
 E    4851   469.000       3.00000       0.00000       0.00000       0.00000
 E    4852   486.000       4.00000       0.00000       0.00000       0.00000
 E    4853   501.000       1.00000       0.00000       0.00000       0.00000
 E    4854   484.000       2.00000       0.00000       0.00000       0.00000
 E    4861   470.000       3.00000       0.00000       0.00000       0.00000
 E    4862   487.000       4.00000       0.00000       0.00000       0.00000
 E    4863   502.000       1.00000       0.00000       0.00000       0.00000
 E    4864   485.000       2.00000       0.00000       0.00000       0.00000
 E    4871   471.000       3.00000       0.00000       0.00000       0.00000
 E    4872   488.000       4.00000       0.00000       0.00000       0.00000
 E    4873   503.000       1.00000       0.00000       0.00000       0.00000
 E    4874   486.000       2.00000       0.00000       0.00000       0.00000
 E    4881   472.000       3.00000       0.00000       0.00000       0.00000
 E    4882   489.000       4.00000       0.00000       0.00000       0.00000
 E    4883   504.000       1.00000       0.00000       0.00000       0.00000
 E    4884   487.000       2.00000       0.00000       0.00000       0.00000
 E    4891   473.000       3.00000       0.00000       0.00000       0.00000
 E    4892   490.000       4.00000       0.00000       0.00000       0.00000
 E    4893   505.000       1.00000       0.00000       0.00000       0.00000
 E    4894   488.000       2.00000       0.00000       0.00000       0.00000
 E    4901   474.000       3.00000       0.00000       0.00000       0.00000
 E    4902   491.000       4.00000       0.00000       0.00000       0.00000
 E    4903   506.000       1.00000       0.00000       0.00000       0.00000
 E    4904   489.000       2.00000       0.00000       0.00000       0.00000
 E    4911   475.000       3.00000       0.00000       0.00000       0.00000
 E    4912   492.000       4.00000       0.00000       0.00000       0.00000
 E    4913   507.000       1.00000       0.00000       0.00000       0.00000
 E    4914   490.000       2.00000       0.00000       0.00000       0.00000
 E    4921   476.000       3.00000       0.00000       0.00000       0.00000
 E    4922   493.000       4.00000       0.00000       0.00000       0.00000
 E    4923   508.000       1.00000       0.00000       0.00000       0.00000
 E    4924   491.000       2.00000       0.00000       0.00000       0.00000
 E    4931   477.000       3.00000       0.00000       0.00000       0.00000
 E    4932   494.000       4.00000       0.00000       0.00000       0.00000
 E    4933   509.000       1.00000       0.00000       0.00000       0.00000
 E    4934   492.000       2.00000       0.00000       0.00000       0.00000
 E    4941   478.000       3.00000       0.00000       0.00000       0.00000
 E    4942   495.000       4.00000       0.00000       0.00000       0.00000
 E    4943   510.000       1.00000       0.00000       0.00000       0.00000
 E    4944   493.000       2.00000       0.00000       0.00000       0.00000
 E    4951   479.000       3.00000       0.00000       0.00000       0.00000
 E    4952   496.000       4.00000       0.00000       0.00000       0.00000
 E    4953   511.000       1.00000       0.00000       0.00000       0.00000
 E    4954   494.000       2.00000       0.00000       0.00000       0.00000
 E    4961   480.000       3.00000       0.00000       0.00000       0.00000
      4962   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4963   512.000       1.00000       0.00000       0.00000       0.00000
 E    4964   495.000       2.00000       0.00000       0.00000       0.00000
 E    4971   481.000       3.00000       0.00000       0.00000       0.00000
 E    4972   498.000       4.00000       0.00000       0.00000       0.00000
 v    4973   0.00000       0.00000       0.00000       0.00000       0.00000
 v    4974   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4981   482.000       3.00000       0.00000       0.00000       0.00000
 E    4982   499.000       4.00000       0.00000       0.00000       0.00000
 v    4983   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4984   497.000       2.00000       0.00000       0.00000       0.00000
 E    4991   483.000       3.00000       0.00000       0.00000       0.00000
 E    4992   500.000       4.00000       0.00000       0.00000       0.00000
 v    4993   0.00000       0.00000       0.00000       0.00000       0.00000
 E    4994   498.000       2.00000       0.00000       0.00000       0.00000
 E    5001   484.000       3.00000       0.00000       0.00000       0.00000
 E    5002   501.000       4.00000       0.00000       0.00000       0.00000
 v    5003   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5004   499.000       2.00000       0.00000       0.00000       0.00000
 E    5011   485.000       3.00000       0.00000       0.00000       0.00000
 E    5012   502.000       4.00000       0.00000       0.00000       0.00000
 v    5013   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5014   500.000       2.00000       0.00000       0.00000       0.00000
 E    5021   486.000       3.00000       0.00000       0.00000       0.00000
 E    5022   503.000       4.00000       0.00000       0.00000       0.00000
 v    5023   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5024   501.000       2.00000       0.00000       0.00000       0.00000
 E    5031   487.000       3.00000       0.00000       0.00000       0.00000
 E    5032   504.000       4.00000       0.00000       0.00000       0.00000
 v    5033   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5034   502.000       2.00000       0.00000       0.00000       0.00000
 E    5041   488.000       3.00000       0.00000       0.00000       0.00000
 E    5042   505.000       4.00000       0.00000       0.00000       0.00000
 v    5043   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5044   503.000       2.00000       0.00000       0.00000       0.00000
 E    5051   489.000       3.00000       0.00000       0.00000       0.00000
 E    5052   506.000       4.00000       0.00000       0.00000       0.00000
 v    5053   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5054   504.000       2.00000       0.00000       0.00000       0.00000
 E    5061   490.000       3.00000       0.00000       0.00000       0.00000
 E    5062   507.000       4.00000       0.00000       0.00000       0.00000
 v    5063   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5064   505.000       2.00000       0.00000       0.00000       0.00000
 E    5071   491.000       3.00000       0.00000       0.00000       0.00000
 E    5072   508.000       4.00000       0.00000       0.00000       0.00000
 v    5073   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5074   506.000       2.00000       0.00000       0.00000       0.00000
 E    5081   492.000       3.00000       0.00000       0.00000       0.00000
 E    5082   509.000       4.00000       0.00000       0.00000       0.00000
 v    5083   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5084   507.000       2.00000       0.00000       0.00000       0.00000
 E    5091   493.000       3.00000       0.00000       0.00000       0.00000
 E    5092   510.000       4.00000       0.00000       0.00000       0.00000
 v    5093   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5094   508.000       2.00000       0.00000       0.00000       0.00000
 E    5101   494.000       3.00000       0.00000       0.00000       0.00000
 E    5102   511.000       4.00000       0.00000       0.00000       0.00000
 v    5103   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5104   509.000       2.00000       0.00000       0.00000       0.00000
 E    5111   495.000       3.00000       0.00000       0.00000       0.00000
 E    5112   512.000       4.00000       0.00000       0.00000       0.00000
 v    5113   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5114   510.000       2.00000       0.00000       0.00000       0.00000
 E    5121   496.000       3.00000       0.00000       0.00000       0.00000
      5122   0.00000       0.00000       0.00000       0.00000       0.00000
 v    5123   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5124   511.000       2.00000       0.00000       0.00000       0.00000
 v    5131   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5132   514.000       4.00000       0.00000       0.00000       0.00000
 E    5133   529.000       1.00000       0.00000       0.00000       0.00000
      5134   0.00000       0.00000       0.00000       0.00000       0.00000
 v    5141   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5142   515.000       4.00000       0.00000       0.00000       0.00000
 E    5143   530.000       1.00000       0.00000       0.00000       0.00000
 E    5144   513.000       2.00000       0.00000       0.00000       0.00000
 v    5151   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5152   516.000       4.00000       0.00000       0.00000       0.00000
 E    5153   531.000       1.00000       0.00000       0.00000       0.00000
 E    5154   514.000       2.00000       0.00000       0.00000       0.00000
 v    5161   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5162   517.000       4.00000       0.00000       0.00000       0.00000
 E    5163   532.000       1.00000       0.00000       0.00000       0.00000
 E    5164   515.000       2.00000       0.00000       0.00000       0.00000
 v    5171   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5172   518.000       4.00000       0.00000       0.00000       0.00000
 E    5173   533.000       1.00000       0.00000       0.00000       0.00000
 E    5174   516.000       2.00000       0.00000       0.00000       0.00000
 v    5181   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5182   519.000       4.00000       0.00000       0.00000       0.00000
 E    5183   534.000       1.00000       0.00000       0.00000       0.00000
 E    5184   517.000       2.00000       0.00000       0.00000       0.00000
 v    5191   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5192   520.000       4.00000       0.00000       0.00000       0.00000
 E    5193   535.000       1.00000       0.00000       0.00000       0.00000
 E    5194   518.000       2.00000       0.00000       0.00000       0.00000
 v    5201   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5202   521.000       4.00000       0.00000       0.00000       0.00000
 E    5203   536.000       1.00000       0.00000       0.00000       0.00000
 E    5204   519.000       2.00000       0.00000       0.00000       0.00000
 v    5211   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5212   522.000       4.00000       0.00000       0.00000       0.00000
 E    5213   537.000       1.00000       0.00000       0.00000       0.00000
 E    5214   520.000       2.00000       0.00000       0.00000       0.00000
 v    5221   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5222   523.000       4.00000       0.00000       0.00000       0.00000
 E    5223   538.000       1.00000       0.00000       0.00000       0.00000
 E    5224   521.000       2.00000       0.00000       0.00000       0.00000
 v    5231   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5232   524.000       4.00000       0.00000       0.00000       0.00000
 E    5233   539.000       1.00000       0.00000       0.00000       0.00000
 E    5234   522.000       2.00000       0.00000       0.00000       0.00000
 v    5241   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5242   525.000       4.00000       0.00000       0.00000       0.00000
 E    5243   540.000       1.00000       0.00000       0.00000       0.00000
 E    5244   523.000       2.00000       0.00000       0.00000       0.00000
 v    5251   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5252   526.000       4.00000       0.00000       0.00000       0.00000
 E    5253   541.000       1.00000       0.00000       0.00000       0.00000
 E    5254   524.000       2.00000       0.00000       0.00000       0.00000
 v    5261   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5262   527.000       4.00000       0.00000       0.00000       0.00000
 E    5263   542.000       1.00000       0.00000       0.00000       0.00000
 E    5264   525.000       2.00000       0.00000       0.00000       0.00000
 v    5271   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5272   528.000       4.00000       0.00000       0.00000       0.00000
 E    5273   543.000       1.00000       0.00000       0.00000       0.00000
 E    5274   526.000       2.00000       0.00000       0.00000       0.00000
 v    5281   0.00000       0.00000       0.00000       0.00000       0.00000
      5282   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5283   544.000       1.00000       0.00000       0.00000       0.00000
 E    5284   527.000       2.00000       0.00000       0.00000       0.00000
 E    5291   513.000       3.00000       0.00000       0.00000       0.00000
 E    5292   530.000       4.00000       0.00000       0.00000       0.00000
 E    5293   545.000       1.00000       0.00000       0.00000       0.00000
      5294   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5301   514.000       3.00000       0.00000       0.00000       0.00000
 E    5302   531.000       4.00000       0.00000       0.00000       0.00000
 E    5303   546.000       1.00000       0.00000       0.00000       0.00000
 E    5304   529.000       2.00000       0.00000       0.00000       0.00000
 E    5311   515.000       3.00000       0.00000       0.00000       0.00000
 E    5312   532.000       4.00000       0.00000       0.00000       0.00000
 E    5313   547.000       1.00000       0.00000       0.00000       0.00000
 E    5314   530.000       2.00000       0.00000       0.00000       0.00000
 E    5321   516.000       3.00000       0.00000       0.00000       0.00000
 E    5322   533.000       4.00000       0.00000       0.00000       0.00000
 E    5323   548.000       1.00000       0.00000       0.00000       0.00000
 E    5324   531.000       2.00000       0.00000       0.00000       0.00000
 E    5331   517.000       3.00000       0.00000       0.00000       0.00000
 E    5332   534.000       4.00000       0.00000       0.00000       0.00000
 E    5333   549.000       1.00000       0.00000       0.00000       0.00000
 E    5334   532.000       2.00000       0.00000       0.00000       0.00000
 E    5341   518.000       3.00000       0.00000       0.00000       0.00000
 E    5342   535.000       4.00000       0.00000       0.00000       0.00000
 E    5343   550.000       1.00000       0.00000       0.00000       0.00000
 E    5344   533.000       2.00000       0.00000       0.00000       0.00000
 E    5351   519.000       3.00000       0.00000       0.00000       0.00000
 E    5352   536.000       4.00000       0.00000       0.00000       0.00000
 E    5353   551.000       1.00000       0.00000       0.00000       0.00000
 E    5354   534.000       2.00000       0.00000       0.00000       0.00000
 E    5361   520.000       3.00000       0.00000       0.00000       0.00000
 E    5362   537.000       4.00000       0.00000       0.00000       0.00000
 E    5363   552.000       1.00000       0.00000       0.00000       0.00000
 E    5364   535.000       2.00000       0.00000       0.00000       0.00000
 E    5371   521.000       3.00000       0.00000       0.00000       0.00000
 E    5372   538.000       4.00000       0.00000       0.00000       0.00000
 E    5373   553.000       1.00000       0.00000       0.00000       0.00000
 E    5374   536.000       2.00000       0.00000       0.00000       0.00000
 E    5381   522.000       3.00000       0.00000       0.00000       0.00000
 E    5382   539.000       4.00000       0.00000       0.00000       0.00000
 E    5383   554.000       1.00000       0.00000       0.00000       0.00000
 E    5384   537.000       2.00000       0.00000       0.00000       0.00000
 E    5391   523.000       3.00000       0.00000       0.00000       0.00000
 E    5392   540.000       4.00000       0.00000       0.00000       0.00000
 E    5393   555.000       1.00000       0.00000       0.00000       0.00000
 E    5394   538.000       2.00000       0.00000       0.00000       0.00000
 E    5401   524.000       3.00000       0.00000       0.00000       0.00000
 E    5402   541.000       4.00000       0.00000       0.00000       0.00000
 E    5403   556.000       1.00000       0.00000       0.00000       0.00000
 E    5404   539.000       2.00000       0.00000       0.00000       0.00000
 E    5411   525.000       3.00000       0.00000       0.00000       0.00000
 E    5412   542.000       4.00000       0.00000       0.00000       0.00000
 E    5413   557.000       1.00000       0.00000       0.00000       0.00000
 E    5414   540.000       2.00000       0.00000       0.00000       0.00000
 E    5421   526.000       3.00000       0.00000       0.00000       0.00000
 E    5422   543.000       4.00000       0.00000       0.00000       0.00000
 E    5423   558.000       1.00000       0.00000       0.00000       0.00000
 E    5424   541.000       2.00000       0.00000       0.00000       0.00000
 E    5431   527.000       3.00000       0.00000       0.00000       0.00000
 E    5432   544.000       4.00000       0.00000       0.00000       0.00000
 E    5433   559.000       1.00000       0.00000       0.00000       0.00000
 E    5434   542.000       2.00000       0.00000       0.00000       0.00000
 E    5441   528.000       3.00000       0.00000       0.00000       0.00000
      5442   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5443   560.000       1.00000       0.00000       0.00000       0.00000
 E    5444   543.000       2.00000       0.00000       0.00000       0.00000
 E    5451   529.000       3.00000       0.00000       0.00000       0.00000
 E    5452   546.000       4.00000       0.00000       0.00000       0.00000
 E    5453   561.000       1.00000       0.00000       0.00000       0.00000
      5454   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5461   530.000       3.00000       0.00000       0.00000       0.00000
 E    5462   547.000       4.00000       0.00000       0.00000       0.00000
 E    5463   562.000       1.00000       0.00000       0.00000       0.00000
 E    5464   545.000       2.00000       0.00000       0.00000       0.00000
 E    5471   531.000       3.00000       0.00000       0.00000       0.00000
 E    5472   548.000       4.00000       0.00000       0.00000       0.00000
 E    5473   563.000       1.00000       0.00000       0.00000       0.00000
 E    5474   546.000       2.00000       0.00000       0.00000       0.00000
 E    5481   532.000       3.00000       0.00000       0.00000       0.00000
 E    5482   549.000       4.00000       0.00000       0.00000       0.00000
 E    5483   564.000       1.00000       0.00000       0.00000       0.00000
 E    5484   547.000       2.00000       0.00000       0.00000       0.00000
 E    5491   533.000       3.00000       0.00000       0.00000       0.00000
 E    5492   550.000       4.00000       0.00000       0.00000       0.00000
 E    5493   565.000       1.00000       0.00000       0.00000       0.00000
 E    5494   548.000       2.00000       0.00000       0.00000       0.00000
 E    5501   534.000       3.00000       0.00000       0.00000       0.00000
 E    5502   551.000       4.00000       0.00000       0.00000       0.00000
 E    5503   566.000       1.00000       0.00000       0.00000       0.00000
 E    5504   549.000       2.00000       0.00000       0.00000       0.00000
 E    5511   535.000       3.00000       0.00000       0.00000       0.00000
 E    5512   552.000       4.00000       0.00000       0.00000       0.00000
 E    5513   567.000       1.00000       0.00000       0.00000       0.00000
 E    5514   550.000       2.00000       0.00000       0.00000       0.00000
 E    5521   536.000       3.00000       0.00000       0.00000       0.00000
 E    5522   553.000       4.00000       0.00000       0.00000       0.00000
 E    5523   568.000       1.00000       0.00000       0.00000       0.00000
 E    5524   551.000       2.00000       0.00000       0.00000       0.00000
 E    5531   537.000       3.00000       0.00000       0.00000       0.00000
 E    5532   554.000       4.00000       0.00000       0.00000       0.00000
 E    5533   569.000       1.00000       0.00000       0.00000       0.00000
 E    5534   552.000       2.00000       0.00000       0.00000       0.00000
 E    5541   538.000       3.00000       0.00000       0.00000       0.00000
 E    5542   555.000       4.00000       0.00000       0.00000       0.00000
 E    5543   570.000       1.00000       0.00000       0.00000       0.00000
 E    5544   553.000       2.00000       0.00000       0.00000       0.00000
 E    5551   539.000       3.00000       0.00000       0.00000       0.00000
 E    5552   556.000       4.00000       0.00000       0.00000       0.00000
 E    5553   571.000       1.00000       0.00000       0.00000       0.00000
 E    5554   554.000       2.00000       0.00000       0.00000       0.00000
 E    5561   540.000       3.00000       0.00000       0.00000       0.00000
 E    5562   557.000       4.00000       0.00000       0.00000       0.00000
 E    5563   572.000       1.00000       0.00000       0.00000       0.00000
 E    5564   555.000       2.00000       0.00000       0.00000       0.00000
 E    5571   541.000       3.00000       0.00000       0.00000       0.00000
 E    5572   558.000       4.00000       0.00000       0.00000       0.00000
 E    5573   573.000       1.00000       0.00000       0.00000       0.00000
 E    5574   556.000       2.00000       0.00000       0.00000       0.00000
 E    5581   542.000       3.00000       0.00000       0.00000       0.00000
 E    5582   559.000       4.00000       0.00000       0.00000       0.00000
 E    5583   574.000       1.00000       0.00000       0.00000       0.00000
 E    5584   557.000       2.00000       0.00000       0.00000       0.00000
 E    5591   543.000       3.00000       0.00000       0.00000       0.00000
 E    5592   560.000       4.00000       0.00000       0.00000       0.00000
 E    5593   575.000       1.00000       0.00000       0.00000       0.00000
 E    5594   558.000       2.00000       0.00000       0.00000       0.00000
 E    5601   544.000       3.00000       0.00000       0.00000       0.00000
      5602   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5603   576.000       1.00000       0.00000       0.00000       0.00000
 E    5604   559.000       2.00000       0.00000       0.00000       0.00000
 E    5611   545.000       3.00000       0.00000       0.00000       0.00000
 E    5612   562.000       4.00000       0.00000       0.00000       0.00000
 E    5613   577.000       1.00000       0.00000       0.00000       0.00000
      5614   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5621   546.000       3.00000       0.00000       0.00000       0.00000
 E    5622   563.000       4.00000       0.00000       0.00000       0.00000
 E    5623   578.000       1.00000       0.00000       0.00000       0.00000
 E    5624   561.000       2.00000       0.00000       0.00000       0.00000
 E    5631   547.000       3.00000       0.00000       0.00000       0.00000
 E    5632   564.000       4.00000       0.00000       0.00000       0.00000
 E    5633   579.000       1.00000       0.00000       0.00000       0.00000
 E    5634   562.000       2.00000       0.00000       0.00000       0.00000
 E    5641   548.000       3.00000       0.00000       0.00000       0.00000
 E    5642   565.000       4.00000       0.00000       0.00000       0.00000
 E    5643   580.000       1.00000       0.00000       0.00000       0.00000
 E    5644   563.000       2.00000       0.00000       0.00000       0.00000
 E    5651   549.000       3.00000       0.00000       0.00000       0.00000
 E    5652   566.000       4.00000       0.00000       0.00000       0.00000
 E    5653   581.000       1.00000       0.00000       0.00000       0.00000
 E    5654   564.000       2.00000       0.00000       0.00000       0.00000
 E    5661   550.000       3.00000       0.00000       0.00000       0.00000
 E    5662   567.000       4.00000       0.00000       0.00000       0.00000
 E    5663   582.000       1.00000       0.00000       0.00000       0.00000
 E    5664   565.000       2.00000       0.00000       0.00000       0.00000
 E    5671   551.000       3.00000       0.00000       0.00000       0.00000
 E    5672   568.000       4.00000       0.00000       0.00000       0.00000
 E    5673   583.000       1.00000       0.00000       0.00000       0.00000
 E    5674   566.000       2.00000       0.00000       0.00000       0.00000
 E    5681   552.000       3.00000       0.00000       0.00000       0.00000
 E    5682   569.000       4.00000       0.00000       0.00000       0.00000
 E    5683   584.000       1.00000       0.00000       0.00000       0.00000
 E    5684   567.000       2.00000       0.00000       0.00000       0.00000
 E    5691   553.000       3.00000       0.00000       0.00000       0.00000
 E    5692   570.000       4.00000       0.00000       0.00000       0.00000
 E    5693   585.000       1.00000       0.00000       0.00000       0.00000
 E    5694   568.000       2.00000       0.00000       0.00000       0.00000
 E    5701   554.000       3.00000       0.00000       0.00000       0.00000
 E    5702   571.000       4.00000       0.00000       0.00000       0.00000
 E    5703   586.000       1.00000       0.00000       0.00000       0.00000
 E    5704   569.000       2.00000       0.00000       0.00000       0.00000
 E    5711   555.000       3.00000       0.00000       0.00000       0.00000
 E    5712   572.000       4.00000       0.00000       0.00000       0.00000
 E    5713   587.000       1.00000       0.00000       0.00000       0.00000
 E    5714   570.000       2.00000       0.00000       0.00000       0.00000
 E    5721   556.000       3.00000       0.00000       0.00000       0.00000
 E    5722   573.000       4.00000       0.00000       0.00000       0.00000
 E    5723   588.000       1.00000       0.00000       0.00000       0.00000
 E    5724   571.000       2.00000       0.00000       0.00000       0.00000
 E    5731   557.000       3.00000       0.00000       0.00000       0.00000
 E    5732   574.000       4.00000       0.00000       0.00000       0.00000
 E    5733   589.000       1.00000       0.00000       0.00000       0.00000
 E    5734   572.000       2.00000       0.00000       0.00000       0.00000
 E    5741   558.000       3.00000       0.00000       0.00000       0.00000
 E    5742   575.000       4.00000       0.00000       0.00000       0.00000
 E    5743   590.000       1.00000       0.00000       0.00000       0.00000
 E    5744   573.000       2.00000       0.00000       0.00000       0.00000
 E    5751   559.000       3.00000       0.00000       0.00000       0.00000
 E    5752   576.000       4.00000       0.00000       0.00000       0.00000
 E    5753   591.000       1.00000       0.00000       0.00000       0.00000
 E    5754   574.000       2.00000       0.00000       0.00000       0.00000
 E    5761   560.000       3.00000       0.00000       0.00000       0.00000
      5762   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5763   592.000       1.00000       0.00000       0.00000       0.00000
 E    5764   575.000       2.00000       0.00000       0.00000       0.00000
 E    5771   561.000       3.00000       0.00000       0.00000       0.00000
 E    5772   578.000       4.00000       0.00000       0.00000       0.00000
 E    5773   593.000       1.00000       0.00000       0.00000       0.00000
      5774   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5781   562.000       3.00000       0.00000       0.00000       0.00000
 E    5782   579.000       4.00000       0.00000       0.00000       0.00000
 E    5783   594.000       1.00000       0.00000       0.00000       0.00000
 E    5784   577.000       2.00000       0.00000       0.00000       0.00000
 E    5791   563.000       3.00000       0.00000       0.00000       0.00000
 E    5792   580.000       4.00000       0.00000       0.00000       0.00000
 E    5793   595.000       1.00000       0.00000       0.00000       0.00000
 E    5794   578.000       2.00000       0.00000       0.00000       0.00000
 E    5801   564.000       3.00000       0.00000       0.00000       0.00000
 E    5802   581.000       4.00000       0.00000       0.00000       0.00000
 E    5803   596.000       1.00000       0.00000       0.00000       0.00000
 E    5804   579.000       2.00000       0.00000       0.00000       0.00000
 E    5811   565.000       3.00000       0.00000       0.00000       0.00000
 E    5812   582.000       4.00000       0.00000       0.00000       0.00000
 E    5813   597.000       1.00000       0.00000       0.00000       0.00000
 E    5814   580.000       2.00000       0.00000       0.00000       0.00000
 E    5821   566.000       3.00000       0.00000       0.00000       0.00000
 E    5822   583.000       4.00000       0.00000       0.00000       0.00000
 E    5823   598.000       1.00000       0.00000       0.00000       0.00000
 E    5824   581.000       2.00000       0.00000       0.00000       0.00000
 E    5831   567.000       3.00000       0.00000       0.00000       0.00000
 E    5832   584.000       4.00000       0.00000       0.00000       0.00000
 E    5833   599.000       1.00000       0.00000       0.00000       0.00000
 E    5834   582.000       2.00000       0.00000       0.00000       0.00000
 E    5841   568.000       3.00000       0.00000       0.00000       0.00000
 E    5842   585.000       4.00000       0.00000       0.00000       0.00000
 E    5843   600.000       1.00000       0.00000       0.00000       0.00000
 E    5844   583.000       2.00000       0.00000       0.00000       0.00000
 E    5851   569.000       3.00000       0.00000       0.00000       0.00000
 E    5852   586.000       4.00000       0.00000       0.00000       0.00000
 E    5853   601.000       1.00000       0.00000       0.00000       0.00000
 E    5854   584.000       2.00000       0.00000       0.00000       0.00000
 E    5861   570.000       3.00000       0.00000       0.00000       0.00000
 E    5862   587.000       4.00000       0.00000       0.00000       0.00000
 E    5863   602.000       1.00000       0.00000       0.00000       0.00000
 E    5864   585.000       2.00000       0.00000       0.00000       0.00000
 E    5871   571.000       3.00000       0.00000       0.00000       0.00000
 E    5872   588.000       4.00000       0.00000       0.00000       0.00000
 E    5873   603.000       1.00000       0.00000       0.00000       0.00000
 E    5874   586.000       2.00000       0.00000       0.00000       0.00000
 E    5881   572.000       3.00000       0.00000       0.00000       0.00000
 E    5882   589.000       4.00000       0.00000       0.00000       0.00000
 E    5883   604.000       1.00000       0.00000       0.00000       0.00000
 E    5884   587.000       2.00000       0.00000       0.00000       0.00000
 E    5891   573.000       3.00000       0.00000       0.00000       0.00000
 E    5892   590.000       4.00000       0.00000       0.00000       0.00000
 E    5893   605.000       1.00000       0.00000       0.00000       0.00000
 E    5894   588.000       2.00000       0.00000       0.00000       0.00000
 E    5901   574.000       3.00000       0.00000       0.00000       0.00000
 E    5902   591.000       4.00000       0.00000       0.00000       0.00000
 E    5903   606.000       1.00000       0.00000       0.00000       0.00000
 E    5904   589.000       2.00000       0.00000       0.00000       0.00000
 E    5911   575.000       3.00000       0.00000       0.00000       0.00000
 E    5912   592.000       4.00000       0.00000       0.00000       0.00000
 E    5913   607.000       1.00000       0.00000       0.00000       0.00000
 E    5914   590.000       2.00000       0.00000       0.00000       0.00000
 E    5921   576.000       3.00000       0.00000       0.00000       0.00000
      5922   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5923   608.000       1.00000       0.00000       0.00000       0.00000
 E    5924   591.000       2.00000       0.00000       0.00000       0.00000
 E    5931   577.000       3.00000       0.00000       0.00000       0.00000
 E    5932   594.000       4.00000       0.00000       0.00000       0.00000
 E    5933   609.000       1.00000       0.00000       0.00000       0.00000
      5934   0.00000       0.00000       0.00000       0.00000       0.00000
 E    5941   578.000       3.00000       0.00000       0.00000       0.00000
 E    5942   595.000       4.00000       0.00000       0.00000       0.00000
 E    5943   610.000       1.00000       0.00000       0.00000       0.00000
 E    5944   593.000       2.00000       0.00000       0.00000       0.00000
 E    5951   579.000       3.00000       0.00000       0.00000       0.00000
 E    5952   596.000       4.00000       0.00000       0.00000       0.00000
 E    5953   611.000       1.00000       0.00000       0.00000       0.00000
 E    5954   594.000       2.00000       0.00000       0.00000       0.00000
 E    5961   580.000       3.00000       0.00000       0.00000       0.00000
 E    5962   597.000       4.00000       0.00000       0.00000       0.00000
 E    5963   612.000       1.00000       0.00000       0.00000       0.00000
 E    5964   595.000       2.00000       0.00000       0.00000       0.00000
 E    5971   581.000       3.00000       0.00000       0.00000       0.00000
 E    5972   598.000       4.00000       0.00000       0.00000       0.00000
 E    5973   613.000       1.00000       0.00000       0.00000       0.00000
 E    5974   596.000       2.00000       0.00000       0.00000       0.00000
 E    5981   582.000       3.00000       0.00000       0.00000       0.00000
 E    5982   599.000       4.00000       0.00000       0.00000       0.00000
 E    5983   614.000       1.00000       0.00000       0.00000       0.00000
 E    5984   597.000       2.00000       0.00000       0.00000       0.00000
 E    5991   583.000       3.00000       0.00000       0.00000       0.00000
 E    5992   600.000       4.00000       0.00000       0.00000       0.00000
 E    5993   615.000       1.00000       0.00000       0.00000       0.00000
 E    5994   598.000       2.00000       0.00000       0.00000       0.00000
 E    6001   584.000       3.00000       0.00000       0.00000       0.00000
 E    6002   601.000       4.00000       0.00000       0.00000       0.00000
 E    6003   616.000       1.00000       0.00000       0.00000       0.00000
 E    6004   599.000       2.00000       0.00000       0.00000       0.00000
 E    6011   585.000       3.00000       0.00000       0.00000       0.00000
 E    6012   602.000       4.00000       0.00000       0.00000       0.00000
 E    6013   617.000       1.00000       0.00000       0.00000       0.00000
 E    6014   600.000       2.00000       0.00000       0.00000       0.00000
 E    6021   586.000       3.00000       0.00000       0.00000       0.00000
 E    6022   603.000       4.00000       0.00000       0.00000       0.00000
 E    6023   618.000       1.00000       0.00000       0.00000       0.00000
 E    6024   601.000       2.00000       0.00000       0.00000       0.00000
 E    6031   587.000       3.00000       0.00000       0.00000       0.00000
 E    6032   604.000       4.00000       0.00000       0.00000       0.00000
 E    6033   619.000       1.00000       0.00000       0.00000       0.00000
 E    6034   602.000       2.00000       0.00000       0.00000       0.00000
 E    6041   588.000       3.00000       0.00000       0.00000       0.00000
 E    6042   605.000       4.00000       0.00000       0.00000       0.00000
 E    6043   620.000       1.00000       0.00000       0.00000       0.00000
 E    6044   603.000       2.00000       0.00000       0.00000       0.00000
 E    6051   589.000       3.00000       0.00000       0.00000       0.00000
 E    6052   606.000       4.00000       0.00000       0.00000       0.00000
 E    6053   621.000       1.00000       0.00000       0.00000       0.00000
 E    6054   604.000       2.00000       0.00000       0.00000       0.00000
 E    6061   590.000       3.00000       0.00000       0.00000       0.00000
 E    6062   607.000       4.00000       0.00000       0.00000       0.00000
 E    6063   622.000       1.00000       0.00000       0.00000       0.00000
 E    6064   605.000       2.00000       0.00000       0.00000       0.00000
 E    6071   591.000       3.00000       0.00000       0.00000       0.00000
 E    6072   608.000       4.00000       0.00000       0.00000       0.00000
 E    6073   623.000       1.00000       0.00000       0.00000       0.00000
 E    6074   606.000       2.00000       0.00000       0.00000       0.00000
 E    6081   592.000       3.00000       0.00000       0.00000       0.00000
      6082   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6083   624.000       1.00000       0.00000       0.00000       0.00000
 E    6084   607.000       2.00000       0.00000       0.00000       0.00000
 E    6091   593.000       3.00000       0.00000       0.00000       0.00000
 E    6092   610.000       4.00000       0.00000       0.00000       0.00000
 E    6093   625.000       1.00000       0.00000       0.00000       0.00000
      6094   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6101   594.000       3.00000       0.00000       0.00000       0.00000
 E    6102   611.000       4.00000       0.00000       0.00000       0.00000
 E    6103   626.000       1.00000       0.00000       0.00000       0.00000
 E    6104   609.000       2.00000       0.00000       0.00000       0.00000
 E    6111   595.000       3.00000       0.00000       0.00000       0.00000
 E    6112   612.000       4.00000       0.00000       0.00000       0.00000
 E    6113   627.000       1.00000       0.00000       0.00000       0.00000
 E    6114   610.000       2.00000       0.00000       0.00000       0.00000
 E    6121   596.000       3.00000       0.00000       0.00000       0.00000
 E    6122   613.000       4.00000       0.00000       0.00000       0.00000
 E    6123   628.000       1.00000       0.00000       0.00000       0.00000
 E    6124   611.000       2.00000       0.00000       0.00000       0.00000
 E    6131   597.000       3.00000       0.00000       0.00000       0.00000
 E    6132   614.000       4.00000       0.00000       0.00000       0.00000
 E    6133   629.000       1.00000       0.00000       0.00000       0.00000
 E    6134   612.000       2.00000       0.00000       0.00000       0.00000
 E    6141   598.000       3.00000       0.00000       0.00000       0.00000
 E    6142   615.000       4.00000       0.00000       0.00000       0.00000
 E    6143   630.000       1.00000       0.00000       0.00000       0.00000
 E    6144   613.000       2.00000       0.00000       0.00000       0.00000
 E    6151   599.000       3.00000       0.00000       0.00000       0.00000
 E    6152   616.000       4.00000       0.00000       0.00000       0.00000
 E    6153   631.000       1.00000       0.00000       0.00000       0.00000
 E    6154   614.000       2.00000       0.00000       0.00000       0.00000
 E    6161   600.000       3.00000       0.00000       0.00000       0.00000
 E    6162   617.000       4.00000       0.00000       0.00000       0.00000
 E    6163   632.000       1.00000       0.00000       0.00000       0.00000
 E    6164   615.000       2.00000       0.00000       0.00000       0.00000
 E    6171   601.000       3.00000       0.00000       0.00000       0.00000
 E    6172   618.000       4.00000       0.00000       0.00000       0.00000
 E    6173   633.000       1.00000       0.00000       0.00000       0.00000
 E    6174   616.000       2.00000       0.00000       0.00000       0.00000
 E    6181   602.000       3.00000       0.00000       0.00000       0.00000
 E    6182   619.000       4.00000       0.00000       0.00000       0.00000
 E    6183   634.000       1.00000       0.00000       0.00000       0.00000
 E    6184   617.000       2.00000       0.00000       0.00000       0.00000
 E    6191   603.000       3.00000       0.00000       0.00000       0.00000
 E    6192   620.000       4.00000       0.00000       0.00000       0.00000
 E    6193   635.000       1.00000       0.00000       0.00000       0.00000
 E    6194   618.000       2.00000       0.00000       0.00000       0.00000
 E    6201   604.000       3.00000       0.00000       0.00000       0.00000
 E    6202   621.000       4.00000       0.00000       0.00000       0.00000
 E    6203   636.000       1.00000       0.00000       0.00000       0.00000
 E    6204   619.000       2.00000       0.00000       0.00000       0.00000
 E    6211   605.000       3.00000       0.00000       0.00000       0.00000
 E    6212   622.000       4.00000       0.00000       0.00000       0.00000
 E    6213   637.000       1.00000       0.00000       0.00000       0.00000
 E    6214   620.000       2.00000       0.00000       0.00000       0.00000
 E    6221   606.000       3.00000       0.00000       0.00000       0.00000
 E    6222   623.000       4.00000       0.00000       0.00000       0.00000
 E    6223   638.000       1.00000       0.00000       0.00000       0.00000
 E    6224   621.000       2.00000       0.00000       0.00000       0.00000
 E    6231   607.000       3.00000       0.00000       0.00000       0.00000
 E    6232   624.000       4.00000       0.00000       0.00000       0.00000
 E    6233   639.000       1.00000       0.00000       0.00000       0.00000
 E    6234   622.000       2.00000       0.00000       0.00000       0.00000
 E    6241   608.000       3.00000       0.00000       0.00000       0.00000
      6242   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6243   640.000       1.00000       0.00000       0.00000       0.00000
 E    6244   623.000       2.00000       0.00000       0.00000       0.00000
 E    6251   609.000       3.00000       0.00000       0.00000       0.00000
 E    6252   626.000       4.00000       0.00000       0.00000       0.00000
 E    6253   641.000       1.00000       0.00000       0.00000       0.00000
      6254   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6261   610.000       3.00000       0.00000       0.00000       0.00000
 E    6262   627.000       4.00000       0.00000       0.00000       0.00000
 E    6263   642.000       1.00000       0.00000       0.00000       0.00000
 E    6264   625.000       2.00000       0.00000       0.00000       0.00000
 E    6271   611.000       3.00000       0.00000       0.00000       0.00000
 E    6272   628.000       4.00000       0.00000       0.00000       0.00000
 E    6273   643.000       1.00000       0.00000       0.00000       0.00000
 E    6274   626.000       2.00000       0.00000       0.00000       0.00000
 E    6281   612.000       3.00000       0.00000       0.00000       0.00000
 E    6282   629.000       4.00000       0.00000       0.00000       0.00000
 E    6283   644.000       1.00000       0.00000       0.00000       0.00000
 E    6284   627.000       2.00000       0.00000       0.00000       0.00000
 E    6291   613.000       3.00000       0.00000       0.00000       0.00000
 E    6292   630.000       4.00000       0.00000       0.00000       0.00000
 E    6293   645.000       1.00000       0.00000       0.00000       0.00000
 E    6294   628.000       2.00000       0.00000       0.00000       0.00000
 E    6301   614.000       3.00000       0.00000       0.00000       0.00000
 E    6302   631.000       4.00000       0.00000       0.00000       0.00000
 E    6303   646.000       1.00000       0.00000       0.00000       0.00000
 E    6304   629.000       2.00000       0.00000       0.00000       0.00000
 E    6311   615.000       3.00000       0.00000       0.00000       0.00000
 E    6312   632.000       4.00000       0.00000       0.00000       0.00000
 E    6313   647.000       1.00000       0.00000       0.00000       0.00000
 E    6314   630.000       2.00000       0.00000       0.00000       0.00000
 E    6321   616.000       3.00000       0.00000       0.00000       0.00000
 E    6322   633.000       4.00000       0.00000       0.00000       0.00000
 E    6323   648.000       1.00000       0.00000       0.00000       0.00000
 E    6324   631.000       2.00000       0.00000       0.00000       0.00000
 E    6331   617.000       3.00000       0.00000       0.00000       0.00000
 E    6332   634.000       4.00000       0.00000       0.00000       0.00000
 E    6333   649.000       1.00000       0.00000       0.00000       0.00000
 E    6334   632.000       2.00000       0.00000       0.00000       0.00000
 E    6341   618.000       3.00000       0.00000       0.00000       0.00000
 E    6342   635.000       4.00000       0.00000       0.00000       0.00000
 E    6343   650.000       1.00000       0.00000       0.00000       0.00000
 E    6344   633.000       2.00000       0.00000       0.00000       0.00000
 E    6351   619.000       3.00000       0.00000       0.00000       0.00000
 E    6352   636.000       4.00000       0.00000       0.00000       0.00000
 E    6353   651.000       1.00000       0.00000       0.00000       0.00000
 E    6354   634.000       2.00000       0.00000       0.00000       0.00000
 E    6361   620.000       3.00000       0.00000       0.00000       0.00000
 E    6362   637.000       4.00000       0.00000       0.00000       0.00000
 E    6363   652.000       1.00000       0.00000       0.00000       0.00000
 E    6364   635.000       2.00000       0.00000       0.00000       0.00000
 E    6371   621.000       3.00000       0.00000       0.00000       0.00000
 E    6372   638.000       4.00000       0.00000       0.00000       0.00000
 E    6373   653.000       1.00000       0.00000       0.00000       0.00000
 E    6374   636.000       2.00000       0.00000       0.00000       0.00000
 E    6381   622.000       3.00000       0.00000       0.00000       0.00000
 E    6382   639.000       4.00000       0.00000       0.00000       0.00000
 E    6383   654.000       1.00000       0.00000       0.00000       0.00000
 E    6384   637.000       2.00000       0.00000       0.00000       0.00000
 E    6391   623.000       3.00000       0.00000       0.00000       0.00000
 E    6392   640.000       4.00000       0.00000       0.00000       0.00000
 E    6393   655.000       1.00000       0.00000       0.00000       0.00000
 E    6394   638.000       2.00000       0.00000       0.00000       0.00000
 E    6401   624.000       3.00000       0.00000       0.00000       0.00000
      6402   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6403   656.000       1.00000       0.00000       0.00000       0.00000
 E    6404   639.000       2.00000       0.00000       0.00000       0.00000
 E    6411   625.000       3.00000       0.00000       0.00000       0.00000
 E    6412   642.000       4.00000       0.00000       0.00000       0.00000
 E    6413   657.000       1.00000       0.00000       0.00000       0.00000
      6414   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6421   626.000       3.00000       0.00000       0.00000       0.00000
 E    6422   643.000       4.00000       0.00000       0.00000       0.00000
 E    6423   658.000       1.00000       0.00000       0.00000       0.00000
 E    6424   641.000       2.00000       0.00000       0.00000       0.00000
 E    6431   627.000       3.00000       0.00000       0.00000       0.00000
 E    6432   644.000       4.00000       0.00000       0.00000       0.00000
 E    6433   659.000       1.00000       0.00000       0.00000       0.00000
 E    6434   642.000       2.00000       0.00000       0.00000       0.00000
 E    6441   628.000       3.00000       0.00000       0.00000       0.00000
 E    6442   645.000       4.00000       0.00000       0.00000       0.00000
 E    6443   660.000       1.00000       0.00000       0.00000       0.00000
 E    6444   643.000       2.00000       0.00000       0.00000       0.00000
 E    6451   629.000       3.00000       0.00000       0.00000       0.00000
 E    6452   646.000       4.00000       0.00000       0.00000       0.00000
 E    6453   661.000       1.00000       0.00000       0.00000       0.00000
 E    6454   644.000       2.00000       0.00000       0.00000       0.00000
 E    6461   630.000       3.00000       0.00000       0.00000       0.00000
 E    6462   647.000       4.00000       0.00000       0.00000       0.00000
 E    6463   662.000       1.00000       0.00000       0.00000       0.00000
 E    6464   645.000       2.00000       0.00000       0.00000       0.00000
 E    6471   631.000       3.00000       0.00000       0.00000       0.00000
 E    6472   648.000       4.00000       0.00000       0.00000       0.00000
 E    6473   663.000       1.00000       0.00000       0.00000       0.00000
 E    6474   646.000       2.00000       0.00000       0.00000       0.00000
 E    6481   632.000       3.00000       0.00000       0.00000       0.00000
 E    6482   649.000       4.00000       0.00000       0.00000       0.00000
 E    6483   664.000       1.00000       0.00000       0.00000       0.00000
 E    6484   647.000       2.00000       0.00000       0.00000       0.00000
 E    6491   633.000       3.00000       0.00000       0.00000       0.00000
 E    6492   650.000       4.00000       0.00000       0.00000       0.00000
 E    6493   665.000       1.00000       0.00000       0.00000       0.00000
 E    6494   648.000       2.00000       0.00000       0.00000       0.00000
 E    6501   634.000       3.00000       0.00000       0.00000       0.00000
 E    6502   651.000       4.00000       0.00000       0.00000       0.00000
 E    6503   666.000       1.00000       0.00000       0.00000       0.00000
 E    6504   649.000       2.00000       0.00000       0.00000       0.00000
 E    6511   635.000       3.00000       0.00000       0.00000       0.00000
 E    6512   652.000       4.00000       0.00000       0.00000       0.00000
 E    6513   667.000       1.00000       0.00000       0.00000       0.00000
 E    6514   650.000       2.00000       0.00000       0.00000       0.00000
 E    6521   636.000       3.00000       0.00000       0.00000       0.00000
 E    6522   653.000       4.00000       0.00000       0.00000       0.00000
 E    6523   668.000       1.00000       0.00000       0.00000       0.00000
 E    6524   651.000       2.00000       0.00000       0.00000       0.00000
 E    6531   637.000       3.00000       0.00000       0.00000       0.00000
 E    6532   654.000       4.00000       0.00000       0.00000       0.00000
 E    6533   669.000       1.00000       0.00000       0.00000       0.00000
 E    6534   652.000       2.00000       0.00000       0.00000       0.00000
 E    6541   638.000       3.00000       0.00000       0.00000       0.00000
 E    6542   655.000       4.00000       0.00000       0.00000       0.00000
 E    6543   670.000       1.00000       0.00000       0.00000       0.00000
 E    6544   653.000       2.00000       0.00000       0.00000       0.00000
 E    6551   639.000       3.00000       0.00000       0.00000       0.00000
 E    6552   656.000       4.00000       0.00000       0.00000       0.00000
 E    6553   671.000       1.00000       0.00000       0.00000       0.00000
 E    6554   654.000       2.00000       0.00000       0.00000       0.00000
 E    6561   640.000       3.00000       0.00000       0.00000       0.00000
      6562   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6563   672.000       1.00000       0.00000       0.00000       0.00000
 E    6564   655.000       2.00000       0.00000       0.00000       0.00000
 E    6571   641.000       3.00000       0.00000       0.00000       0.00000
 E    6572   658.000       4.00000       0.00000       0.00000       0.00000
 E    6573   673.000       1.00000       0.00000       0.00000       0.00000
      6574   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6581   642.000       3.00000       0.00000       0.00000       0.00000
 E    6582   659.000       4.00000       0.00000       0.00000       0.00000
 E    6583   674.000       1.00000       0.00000       0.00000       0.00000
 E    6584   657.000       2.00000       0.00000       0.00000       0.00000
 E    6591   643.000       3.00000       0.00000       0.00000       0.00000
 E    6592   660.000       4.00000       0.00000       0.00000       0.00000
 E    6593   675.000       1.00000       0.00000       0.00000       0.00000
 E    6594   658.000       2.00000       0.00000       0.00000       0.00000
 E    6601   644.000       3.00000       0.00000       0.00000       0.00000
 E    6602   661.000       4.00000       0.00000       0.00000       0.00000
 E    6603   676.000       1.00000       0.00000       0.00000       0.00000
 E    6604   659.000       2.00000       0.00000       0.00000       0.00000
 E    6611   645.000       3.00000       0.00000       0.00000       0.00000
 E    6612   662.000       4.00000       0.00000       0.00000       0.00000
 E    6613   677.000       1.00000       0.00000       0.00000       0.00000
 E    6614   660.000       2.00000       0.00000       0.00000       0.00000
 E    6621   646.000       3.00000       0.00000       0.00000       0.00000
 E    6622   663.000       4.00000       0.00000       0.00000       0.00000
 E    6623   678.000       1.00000       0.00000       0.00000       0.00000
 E    6624   661.000       2.00000       0.00000       0.00000       0.00000
 E    6631   647.000       3.00000       0.00000       0.00000       0.00000
 E    6632   664.000       4.00000       0.00000       0.00000       0.00000
 E    6633   679.000       1.00000       0.00000       0.00000       0.00000
 E    6634   662.000       2.00000       0.00000       0.00000       0.00000
 E    6641   648.000       3.00000       0.00000       0.00000       0.00000
 E    6642   665.000       4.00000       0.00000       0.00000       0.00000
 E    6643   680.000       1.00000       0.00000       0.00000       0.00000
 E    6644   663.000       2.00000       0.00000       0.00000       0.00000
 E    6651   649.000       3.00000       0.00000       0.00000       0.00000
 E    6652   666.000       4.00000       0.00000       0.00000       0.00000
 E    6653   681.000       1.00000       0.00000       0.00000       0.00000
 E    6654   664.000       2.00000       0.00000       0.00000       0.00000
 E    6661   650.000       3.00000       0.00000       0.00000       0.00000
 E    6662   667.000       4.00000       0.00000       0.00000       0.00000
 E    6663   682.000       1.00000       0.00000       0.00000       0.00000
 E    6664   665.000       2.00000       0.00000       0.00000       0.00000
 E    6671   651.000       3.00000       0.00000       0.00000       0.00000
 E    6672   668.000       4.00000       0.00000       0.00000       0.00000
 E    6673   683.000       1.00000       0.00000       0.00000       0.00000
 E    6674   666.000       2.00000       0.00000       0.00000       0.00000
 E    6681   652.000       3.00000       0.00000       0.00000       0.00000
 E    6682   669.000       4.00000       0.00000       0.00000       0.00000
 E    6683   684.000       1.00000       0.00000       0.00000       0.00000
 E    6684   667.000       2.00000       0.00000       0.00000       0.00000
 E    6691   653.000       3.00000       0.00000       0.00000       0.00000
 E    6692   670.000       4.00000       0.00000       0.00000       0.00000
 E    6693   685.000       1.00000       0.00000       0.00000       0.00000
 E    6694   668.000       2.00000       0.00000       0.00000       0.00000
 E    6701   654.000       3.00000       0.00000       0.00000       0.00000
 E    6702   671.000       4.00000       0.00000       0.00000       0.00000
 E    6703   686.000       1.00000       0.00000       0.00000       0.00000
 E    6704   669.000       2.00000       0.00000       0.00000       0.00000
 E    6711   655.000       3.00000       0.00000       0.00000       0.00000
 E    6712   672.000       4.00000       0.00000       0.00000       0.00000
 E    6713   687.000       1.00000       0.00000       0.00000       0.00000
 E    6714   670.000       2.00000       0.00000       0.00000       0.00000
 E    6721   656.000       3.00000       0.00000       0.00000       0.00000
      6722   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6723   688.000       1.00000       0.00000       0.00000       0.00000
 E    6724   671.000       2.00000       0.00000       0.00000       0.00000
 E    6731   657.000       3.00000       0.00000       0.00000       0.00000
 E    6732   674.000       4.00000       0.00000       0.00000       0.00000
 E    6733   689.000       1.00000       0.00000       0.00000       0.00000
      6734   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6741   658.000       3.00000       0.00000       0.00000       0.00000
 E    6742   675.000       4.00000       0.00000       0.00000       0.00000
 E    6743   690.000       1.00000       0.00000       0.00000       0.00000
 E    6744   673.000       2.00000       0.00000       0.00000       0.00000
 E    6751   659.000       3.00000       0.00000       0.00000       0.00000
 E    6752   676.000       4.00000       0.00000       0.00000       0.00000
 E    6753   691.000       1.00000       0.00000       0.00000       0.00000
 E    6754   674.000       2.00000       0.00000       0.00000       0.00000
 E    6761   660.000       3.00000       0.00000       0.00000       0.00000
 E    6762   677.000       4.00000       0.00000       0.00000       0.00000
 E    6763   692.000       1.00000       0.00000       0.00000       0.00000
 E    6764   675.000       2.00000       0.00000       0.00000       0.00000
 E    6771   661.000       3.00000       0.00000       0.00000       0.00000
 E    6772   678.000       4.00000       0.00000       0.00000       0.00000
 E    6773   693.000       1.00000       0.00000       0.00000       0.00000
 E    6774   676.000       2.00000       0.00000       0.00000       0.00000
 E    6781   662.000       3.00000       0.00000       0.00000       0.00000
 E    6782   679.000       4.00000       0.00000       0.00000       0.00000
 E    6783   694.000       1.00000       0.00000       0.00000       0.00000
 E    6784   677.000       2.00000       0.00000       0.00000       0.00000
 E    6791   663.000       3.00000       0.00000       0.00000       0.00000
 E    6792   680.000       4.00000       0.00000       0.00000       0.00000
 E    6793   695.000       1.00000       0.00000       0.00000       0.00000
 E    6794   678.000       2.00000       0.00000       0.00000       0.00000
 E    6801   664.000       3.00000       0.00000       0.00000       0.00000
 E    6802   681.000       4.00000       0.00000       0.00000       0.00000
 E    6803   696.000       1.00000       0.00000       0.00000       0.00000
 E    6804   679.000       2.00000       0.00000       0.00000       0.00000
 E    6811   665.000       3.00000       0.00000       0.00000       0.00000
 E    6812   682.000       4.00000       0.00000       0.00000       0.00000
 E    6813   697.000       1.00000       0.00000       0.00000       0.00000
 E    6814   680.000       2.00000       0.00000       0.00000       0.00000
 E    6821   666.000       3.00000       0.00000       0.00000       0.00000
 E    6822   683.000       4.00000       0.00000       0.00000       0.00000
 E    6823   698.000       1.00000       0.00000       0.00000       0.00000
 E    6824   681.000       2.00000       0.00000       0.00000       0.00000
 E    6831   667.000       3.00000       0.00000       0.00000       0.00000
 E    6832   684.000       4.00000       0.00000       0.00000       0.00000
 E    6833   699.000       1.00000       0.00000       0.00000       0.00000
 E    6834   682.000       2.00000       0.00000       0.00000       0.00000
 E    6841   668.000       3.00000       0.00000       0.00000       0.00000
 E    6842   685.000       4.00000       0.00000       0.00000       0.00000
 E    6843   700.000       1.00000       0.00000       0.00000       0.00000
 E    6844   683.000       2.00000       0.00000       0.00000       0.00000
 E    6851   669.000       3.00000       0.00000       0.00000       0.00000
 E    6852   686.000       4.00000       0.00000       0.00000       0.00000
 E    6853   701.000       1.00000       0.00000       0.00000       0.00000
 E    6854   684.000       2.00000       0.00000       0.00000       0.00000
 E    6861   670.000       3.00000       0.00000       0.00000       0.00000
 E    6862   687.000       4.00000       0.00000       0.00000       0.00000
 E    6863   702.000       1.00000       0.00000       0.00000       0.00000
 E    6864   685.000       2.00000       0.00000       0.00000       0.00000
 E    6871   671.000       3.00000       0.00000       0.00000       0.00000
 E    6872   688.000       4.00000       0.00000       0.00000       0.00000
 E    6873   703.000       1.00000       0.00000       0.00000       0.00000
 E    6874   686.000       2.00000       0.00000       0.00000       0.00000
 E    6881   672.000       3.00000       0.00000       0.00000       0.00000
      6882   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6883   704.000       1.00000       0.00000       0.00000       0.00000
 E    6884   687.000       2.00000       0.00000       0.00000       0.00000
 E    6891   673.000       3.00000       0.00000       0.00000       0.00000
 E    6892   690.000       4.00000       0.00000       0.00000       0.00000
 E    6893   705.000       1.00000       0.00000       0.00000       0.00000
      6894   0.00000       0.00000       0.00000       0.00000       0.00000
 E    6901   674.000       3.00000       0.00000       0.00000       0.00000
 E    6902   691.000       4.00000       0.00000       0.00000       0.00000
 E    6903   706.000       1.00000       0.00000       0.00000       0.00000
 E    6904   689.000       2.00000       0.00000       0.00000       0.00000
 E    6911   675.000       3.00000       0.00000       0.00000       0.00000
 E    6912   692.000       4.00000       0.00000       0.00000       0.00000
 E    6913   707.000       1.00000       0.00000       0.00000       0.00000
 E    6914   690.000       2.00000       0.00000       0.00000       0.00000
 E    6921   676.000       3.00000       0.00000       0.00000       0.00000
 E    6922   693.000       4.00000       0.00000       0.00000       0.00000
 E    6923   708.000       1.00000       0.00000       0.00000       0.00000
 E    6924   691.000       2.00000       0.00000       0.00000       0.00000
 E    6931   677.000       3.00000       0.00000       0.00000       0.00000
 E    6932   694.000       4.00000       0.00000       0.00000       0.00000
 E    6933   709.000       1.00000       0.00000       0.00000       0.00000
 E    6934   692.000       2.00000       0.00000       0.00000       0.00000
 E    6941   678.000       3.00000       0.00000       0.00000       0.00000
 E    6942   695.000       4.00000       0.00000       0.00000       0.00000
 E    6943   710.000       1.00000       0.00000       0.00000       0.00000
 E    6944   693.000       2.00000       0.00000       0.00000       0.00000
 E    6951   679.000       3.00000       0.00000       0.00000       0.00000
 E    6952   696.000       4.00000       0.00000       0.00000       0.00000
 E    6953   711.000       1.00000       0.00000       0.00000       0.00000
 E    6954   694.000       2.00000       0.00000       0.00000       0.00000
 E    6961   680.000       3.00000       0.00000       0.00000       0.00000
 E    6962   697.000       4.00000       0.00000       0.00000       0.00000
 E    6963   712.000       1.00000       0.00000       0.00000       0.00000
 E    6964   695.000       2.00000       0.00000       0.00000       0.00000
 E    6971   681.000       3.00000       0.00000       0.00000       0.00000
 E    6972   698.000       4.00000       0.00000       0.00000       0.00000
 E    6973   713.000       1.00000       0.00000       0.00000       0.00000
 E    6974   696.000       2.00000       0.00000       0.00000       0.00000
 E    6981   682.000       3.00000       0.00000       0.00000       0.00000
 E    6982   699.000       4.00000       0.00000       0.00000       0.00000
 E    6983   714.000       1.00000       0.00000       0.00000       0.00000
 E    6984   697.000       2.00000       0.00000       0.00000       0.00000
 E    6991   683.000       3.00000       0.00000       0.00000       0.00000
 E    6992   700.000       4.00000       0.00000       0.00000       0.00000
 E    6993   715.000       1.00000       0.00000       0.00000       0.00000
 E    6994   698.000       2.00000       0.00000       0.00000       0.00000
 E    7001   684.000       3.00000       0.00000       0.00000       0.00000
 E    7002   701.000       4.00000       0.00000       0.00000       0.00000
 E    7003   716.000       1.00000       0.00000       0.00000       0.00000
 E    7004   699.000       2.00000       0.00000       0.00000       0.00000
 E    7011   685.000       3.00000       0.00000       0.00000       0.00000
 E    7012   702.000       4.00000       0.00000       0.00000       0.00000
 E    7013   717.000       1.00000       0.00000       0.00000       0.00000
 E    7014   700.000       2.00000       0.00000       0.00000       0.00000
 E    7021   686.000       3.00000       0.00000       0.00000       0.00000
 E    7022   703.000       4.00000       0.00000       0.00000       0.00000
 E    7023   718.000       1.00000       0.00000       0.00000       0.00000
 E    7024   701.000       2.00000       0.00000       0.00000       0.00000
 E    7031   687.000       3.00000       0.00000       0.00000       0.00000
 E    7032   704.000       4.00000       0.00000       0.00000       0.00000
 E    7033   719.000       1.00000       0.00000       0.00000       0.00000
 E    7034   702.000       2.00000       0.00000       0.00000       0.00000
 E    7041   688.000       3.00000       0.00000       0.00000       0.00000
      7042   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7043   720.000       1.00000       0.00000       0.00000       0.00000
 E    7044   703.000       2.00000       0.00000       0.00000       0.00000
 E    7051   689.000       3.00000       0.00000       0.00000       0.00000
 E    7052   706.000       4.00000       0.00000       0.00000       0.00000
 E    7053   721.000       1.00000       0.00000       0.00000       0.00000
      7054   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7061   690.000       3.00000       0.00000       0.00000       0.00000
 E    7062   707.000       4.00000       0.00000       0.00000       0.00000
 E    7063   722.000       1.00000       0.00000       0.00000       0.00000
 E    7064   705.000       2.00000       0.00000       0.00000       0.00000
 E    7071   691.000       3.00000       0.00000       0.00000       0.00000
 E    7072   708.000       4.00000       0.00000       0.00000       0.00000
 E    7073   723.000       1.00000       0.00000       0.00000       0.00000
 E    7074   706.000       2.00000       0.00000       0.00000       0.00000
 E    7081   692.000       3.00000       0.00000       0.00000       0.00000
 E    7082   709.000       4.00000       0.00000       0.00000       0.00000
 E    7083   724.000       1.00000       0.00000       0.00000       0.00000
 E    7084   707.000       2.00000       0.00000       0.00000       0.00000
 E    7091   693.000       3.00000       0.00000       0.00000       0.00000
 E    7092   710.000       4.00000       0.00000       0.00000       0.00000
 E    7093   725.000       1.00000       0.00000       0.00000       0.00000
 E    7094   708.000       2.00000       0.00000       0.00000       0.00000
 E    7101   694.000       3.00000       0.00000       0.00000       0.00000
 E    7102   711.000       4.00000       0.00000       0.00000       0.00000
 E    7103   726.000       1.00000       0.00000       0.00000       0.00000
 E    7104   709.000       2.00000       0.00000       0.00000       0.00000
 E    7111   695.000       3.00000       0.00000       0.00000       0.00000
 E    7112   712.000       4.00000       0.00000       0.00000       0.00000
 E    7113   727.000       1.00000       0.00000       0.00000       0.00000
 E    7114   710.000       2.00000       0.00000       0.00000       0.00000
 E    7121   696.000       3.00000       0.00000       0.00000       0.00000
 E    7122   713.000       4.00000       0.00000       0.00000       0.00000
 E    7123   728.000       1.00000       0.00000       0.00000       0.00000
 E    7124   711.000       2.00000       0.00000       0.00000       0.00000
 E    7131   697.000       3.00000       0.00000       0.00000       0.00000
 E    7132   714.000       4.00000       0.00000       0.00000       0.00000
 E    7133   729.000       1.00000       0.00000       0.00000       0.00000
 E    7134   712.000       2.00000       0.00000       0.00000       0.00000
 E    7141   698.000       3.00000       0.00000       0.00000       0.00000
 E    7142   715.000       4.00000       0.00000       0.00000       0.00000
 E    7143   730.000       1.00000       0.00000       0.00000       0.00000
 E    7144   713.000       2.00000       0.00000       0.00000       0.00000
 E    7151   699.000       3.00000       0.00000       0.00000       0.00000
 E    7152   716.000       4.00000       0.00000       0.00000       0.00000
 E    7153   731.000       1.00000       0.00000       0.00000       0.00000
 E    7154   714.000       2.00000       0.00000       0.00000       0.00000
 E    7161   700.000       3.00000       0.00000       0.00000       0.00000
 E    7162   717.000       4.00000       0.00000       0.00000       0.00000
 E    7163   732.000       1.00000       0.00000       0.00000       0.00000
 E    7164   715.000       2.00000       0.00000       0.00000       0.00000
 E    7171   701.000       3.00000       0.00000       0.00000       0.00000
 E    7172   718.000       4.00000       0.00000       0.00000       0.00000
 E    7173   733.000       1.00000       0.00000       0.00000       0.00000
 E    7174   716.000       2.00000       0.00000       0.00000       0.00000
 E    7181   702.000       3.00000       0.00000       0.00000       0.00000
 E    7182   719.000       4.00000       0.00000       0.00000       0.00000
 E    7183   734.000       1.00000       0.00000       0.00000       0.00000
 E    7184   717.000       2.00000       0.00000       0.00000       0.00000
 E    7191   703.000       3.00000       0.00000       0.00000       0.00000
 E    7192   720.000       4.00000       0.00000       0.00000       0.00000
 E    7193   735.000       1.00000       0.00000       0.00000       0.00000
 E    7194   718.000       2.00000       0.00000       0.00000       0.00000
 E    7201   704.000       3.00000       0.00000       0.00000       0.00000
      7202   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7203   736.000       1.00000       0.00000       0.00000       0.00000
 E    7204   719.000       2.00000       0.00000       0.00000       0.00000
 E    7211   705.000       3.00000       0.00000       0.00000       0.00000
 E    7212   722.000       4.00000       0.00000       0.00000       0.00000
 E    7213   737.000       1.00000       0.00000       0.00000       0.00000
      7214   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7221   706.000       3.00000       0.00000       0.00000       0.00000
 E    7222   723.000       4.00000       0.00000       0.00000       0.00000
 E    7223   738.000       1.00000       0.00000       0.00000       0.00000
 E    7224   721.000       2.00000       0.00000       0.00000       0.00000
 E    7231   707.000       3.00000       0.00000       0.00000       0.00000
 E    7232   724.000       4.00000       0.00000       0.00000       0.00000
 E    7233   739.000       1.00000       0.00000       0.00000       0.00000
 E    7234   722.000       2.00000       0.00000       0.00000       0.00000
 E    7241   708.000       3.00000       0.00000       0.00000       0.00000
 E    7242   725.000       4.00000       0.00000       0.00000       0.00000
 E    7243   740.000       1.00000       0.00000       0.00000       0.00000
 E    7244   723.000       2.00000       0.00000       0.00000       0.00000
 E    7251   709.000       3.00000       0.00000       0.00000       0.00000
 E    7252   726.000       4.00000       0.00000       0.00000       0.00000
 E    7253   741.000       1.00000       0.00000       0.00000       0.00000
 E    7254   724.000       2.00000       0.00000       0.00000       0.00000
 E    7261   710.000       3.00000       0.00000       0.00000       0.00000
 E    7262   727.000       4.00000       0.00000       0.00000       0.00000
 E    7263   742.000       1.00000       0.00000       0.00000       0.00000
 E    7264   725.000       2.00000       0.00000       0.00000       0.00000
 E    7271   711.000       3.00000       0.00000       0.00000       0.00000
 E    7272   728.000       4.00000       0.00000       0.00000       0.00000
 E    7273   743.000       1.00000       0.00000       0.00000       0.00000
 E    7274   726.000       2.00000       0.00000       0.00000       0.00000
 E    7281   712.000       3.00000       0.00000       0.00000       0.00000
 E    7282   729.000       4.00000       0.00000       0.00000       0.00000
 E    7283   744.000       1.00000       0.00000       0.00000       0.00000
 E    7284   727.000       2.00000       0.00000       0.00000       0.00000
 E    7291   713.000       3.00000       0.00000       0.00000       0.00000
 E    7292   730.000       4.00000       0.00000       0.00000       0.00000
 E    7293   745.000       1.00000       0.00000       0.00000       0.00000
 E    7294   728.000       2.00000       0.00000       0.00000       0.00000
 E    7301   714.000       3.00000       0.00000       0.00000       0.00000
 E    7302   731.000       4.00000       0.00000       0.00000       0.00000
 E    7303   746.000       1.00000       0.00000       0.00000       0.00000
 E    7304   729.000       2.00000       0.00000       0.00000       0.00000
 E    7311   715.000       3.00000       0.00000       0.00000       0.00000
 E    7312   732.000       4.00000       0.00000       0.00000       0.00000
 E    7313   747.000       1.00000       0.00000       0.00000       0.00000
 E    7314   730.000       2.00000       0.00000       0.00000       0.00000
 E    7321   716.000       3.00000       0.00000       0.00000       0.00000
 E    7322   733.000       4.00000       0.00000       0.00000       0.00000
 E    7323   748.000       1.00000       0.00000       0.00000       0.00000
 E    7324   731.000       2.00000       0.00000       0.00000       0.00000
 E    7331   717.000       3.00000       0.00000       0.00000       0.00000
 E    7332   734.000       4.00000       0.00000       0.00000       0.00000
 E    7333   749.000       1.00000       0.00000       0.00000       0.00000
 E    7334   732.000       2.00000       0.00000       0.00000       0.00000
 E    7341   718.000       3.00000       0.00000       0.00000       0.00000
 E    7342   735.000       4.00000       0.00000       0.00000       0.00000
 E    7343   750.000       1.00000       0.00000       0.00000       0.00000
 E    7344   733.000       2.00000       0.00000       0.00000       0.00000
 E    7351   719.000       3.00000       0.00000       0.00000       0.00000
 E    7352   736.000       4.00000       0.00000       0.00000       0.00000
 E    7353   751.000       1.00000       0.00000       0.00000       0.00000
 E    7354   734.000       2.00000       0.00000       0.00000       0.00000
 E    7361   720.000       3.00000       0.00000       0.00000       0.00000
      7362   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7363   752.000       1.00000       0.00000       0.00000       0.00000
 E    7364   735.000       2.00000       0.00000       0.00000       0.00000
 E    7371   721.000       3.00000       0.00000       0.00000       0.00000
 E    7372   738.000       4.00000       0.00000       0.00000       0.00000
 E    7373   753.000       1.00000       0.00000       0.00000       0.00000
      7374   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7381   722.000       3.00000       0.00000       0.00000       0.00000
 E    7382   739.000       4.00000       0.00000       0.00000       0.00000
 E    7383   754.000       1.00000       0.00000       0.00000       0.00000
 E    7384   737.000       2.00000       0.00000       0.00000       0.00000
 E    7391   723.000       3.00000       0.00000       0.00000       0.00000
 E    7392   740.000       4.00000       0.00000       0.00000       0.00000
 E    7393   755.000       1.00000       0.00000       0.00000       0.00000
 E    7394   738.000       2.00000       0.00000       0.00000       0.00000
 E    7401   724.000       3.00000       0.00000       0.00000       0.00000
 E    7402   741.000       4.00000       0.00000       0.00000       0.00000
 E    7403   756.000       1.00000       0.00000       0.00000       0.00000
 E    7404   739.000       2.00000       0.00000       0.00000       0.00000
 E    7411   725.000       3.00000       0.00000       0.00000       0.00000
 E    7412   742.000       4.00000       0.00000       0.00000       0.00000
 E    7413   757.000       1.00000       0.00000       0.00000       0.00000
 E    7414   740.000       2.00000       0.00000       0.00000       0.00000
 E    7421   726.000       3.00000       0.00000       0.00000       0.00000
 E    7422   743.000       4.00000       0.00000       0.00000       0.00000
 E    7423   758.000       1.00000       0.00000       0.00000       0.00000
 E    7424   741.000       2.00000       0.00000       0.00000       0.00000
 E    7431   727.000       3.00000       0.00000       0.00000       0.00000
 E    7432   744.000       4.00000       0.00000       0.00000       0.00000
 E    7433   759.000       1.00000       0.00000       0.00000       0.00000
 E    7434   742.000       2.00000       0.00000       0.00000       0.00000
 E    7441   728.000       3.00000       0.00000       0.00000       0.00000
 E    7442   745.000       4.00000       0.00000       0.00000       0.00000
 E    7443   760.000       1.00000       0.00000       0.00000       0.00000
 E    7444   743.000       2.00000       0.00000       0.00000       0.00000
 E    7451   729.000       3.00000       0.00000       0.00000       0.00000
 E    7452   746.000       4.00000       0.00000       0.00000       0.00000
 E    7453   761.000       1.00000       0.00000       0.00000       0.00000
 E    7454   744.000       2.00000       0.00000       0.00000       0.00000
 E    7461   730.000       3.00000       0.00000       0.00000       0.00000
 E    7462   747.000       4.00000       0.00000       0.00000       0.00000
 E    7463   762.000       1.00000       0.00000       0.00000       0.00000
 E    7464   745.000       2.00000       0.00000       0.00000       0.00000
 E    7471   731.000       3.00000       0.00000       0.00000       0.00000
 E    7472   748.000       4.00000       0.00000       0.00000       0.00000
 E    7473   763.000       1.00000       0.00000       0.00000       0.00000
 E    7474   746.000       2.00000       0.00000       0.00000       0.00000
 E    7481   732.000       3.00000       0.00000       0.00000       0.00000
 E    7482   749.000       4.00000       0.00000       0.00000       0.00000
 E    7483   764.000       1.00000       0.00000       0.00000       0.00000
 E    7484   747.000       2.00000       0.00000       0.00000       0.00000
 E    7491   733.000       3.00000       0.00000       0.00000       0.00000
 E    7492   750.000       4.00000       0.00000       0.00000       0.00000
 E    7493   765.000       1.00000       0.00000       0.00000       0.00000
 E    7494   748.000       2.00000       0.00000       0.00000       0.00000
 E    7501   734.000       3.00000       0.00000       0.00000       0.00000
 E    7502   751.000       4.00000       0.00000       0.00000       0.00000
 E    7503   766.000       1.00000       0.00000       0.00000       0.00000
 E    7504   749.000       2.00000       0.00000       0.00000       0.00000
 E    7511   735.000       3.00000       0.00000       0.00000       0.00000
 E    7512   752.000       4.00000       0.00000       0.00000       0.00000
 E    7513   767.000       1.00000       0.00000       0.00000       0.00000
 E    7514   750.000       2.00000       0.00000       0.00000       0.00000
 E    7521   736.000       3.00000       0.00000       0.00000       0.00000
      7522   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7523   768.000       1.00000       0.00000       0.00000       0.00000
 E    7524   751.000       2.00000       0.00000       0.00000       0.00000
 E    7531   737.000       3.00000       0.00000       0.00000       0.00000
 E    7532   754.000       4.00000       0.00000       0.00000       0.00000
 mv   7533   0.00000       0.00000       0.00000       0.00000       0.00000
      7534   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7541   738.000       3.00000       0.00000       0.00000       0.00000
 E    7542   755.000       4.00000       0.00000       0.00000       0.00000
 mv   7543   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7544   753.000       2.00000       0.00000       0.00000       0.00000
 E    7551   739.000       3.00000       0.00000       0.00000       0.00000
 E    7552   756.000       4.00000       0.00000       0.00000       0.00000
 mv   7553   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7554   754.000       2.00000       0.00000       0.00000       0.00000
 E    7561   740.000       3.00000       0.00000       0.00000       0.00000
 E    7562   757.000       4.00000       0.00000       0.00000       0.00000
 mv   7563   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7564   755.000       2.00000       0.00000       0.00000       0.00000
 E    7571   741.000       3.00000       0.00000       0.00000       0.00000
 E    7572   758.000       4.00000       0.00000       0.00000       0.00000
 mv   7573   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7574   756.000       2.00000       0.00000       0.00000       0.00000
 E    7581   742.000       3.00000       0.00000       0.00000       0.00000
 E    7582   759.000       4.00000       0.00000       0.00000       0.00000
 mv   7583   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7584   757.000       2.00000       0.00000       0.00000       0.00000
 E    7591   743.000       3.00000       0.00000       0.00000       0.00000
 E    7592   760.000       4.00000       0.00000       0.00000       0.00000
 mv   7593   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7594   758.000       2.00000       0.00000       0.00000       0.00000
 E    7601   744.000       3.00000       0.00000       0.00000       0.00000
 E    7602   761.000       4.00000       0.00000       0.00000       0.00000
 mv   7603   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7604   759.000       2.00000       0.00000       0.00000       0.00000
 E    7611   745.000       3.00000       0.00000       0.00000       0.00000
 E    7612   762.000       4.00000       0.00000       0.00000       0.00000
 mv   7613   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7614   760.000       2.00000       0.00000       0.00000       0.00000
 E    7621   746.000       3.00000       0.00000       0.00000       0.00000
 E    7622   763.000       4.00000       0.00000       0.00000       0.00000
 mv   7623   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7624   761.000       2.00000       0.00000       0.00000       0.00000
 E    7631   747.000       3.00000       0.00000       0.00000       0.00000
 E    7632   764.000       4.00000       0.00000       0.00000       0.00000
 mv   7633   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7634   762.000       2.00000       0.00000       0.00000       0.00000
 E    7641   748.000       3.00000       0.00000       0.00000       0.00000
 E    7642   765.000       4.00000       0.00000       0.00000       0.00000
 mv   7643   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7644   763.000       2.00000       0.00000       0.00000       0.00000
 E    7651   749.000       3.00000       0.00000       0.00000       0.00000
 E    7652   766.000       4.00000       0.00000       0.00000       0.00000
 mv   7653   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7654   764.000       2.00000       0.00000       0.00000       0.00000
 E    7661   750.000       3.00000       0.00000       0.00000       0.00000
 E    7662   767.000       4.00000       0.00000       0.00000       0.00000
 mv   7663   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7664   765.000       2.00000       0.00000       0.00000       0.00000
 E    7671   751.000       3.00000       0.00000       0.00000       0.00000
 E    7672   768.000       4.00000       0.00000       0.00000       0.00000
 mv   7673   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7674   766.000       2.00000       0.00000       0.00000       0.00000
 E    7681   752.000       3.00000       0.00000       0.00000       0.00000
      7682   0.00000       0.00000       0.00000       0.00000       0.00000
 mv   7683   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7684   767.000       2.00000       0.00000       0.00000       0.00000
 mv   7691   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7692   770.000       4.00000       0.00000       0.00000       0.00000
 E    7693   785.000       1.00000       0.00000       0.00000       0.00000
      7694   0.00000       0.00000       0.00000       0.00000       0.00000
 mv   7701   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7702   771.000       4.00000       0.00000       0.00000       0.00000
 E    7703   786.000       1.00000       0.00000       0.00000       0.00000
 E    7704   769.000       2.00000       0.00000       0.00000       0.00000
 mv   7711   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7712   772.000       4.00000       0.00000       0.00000       0.00000
 E    7713   787.000       1.00000       0.00000       0.00000       0.00000
 E    7714   770.000       2.00000       0.00000       0.00000       0.00000
 mv   7721   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7722   773.000       4.00000       0.00000       0.00000       0.00000
 E    7723   788.000       1.00000       0.00000       0.00000       0.00000
 E    7724   771.000       2.00000       0.00000       0.00000       0.00000
 mv   7731   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7732   774.000       4.00000       0.00000       0.00000       0.00000
 E    7733   789.000       1.00000       0.00000       0.00000       0.00000
 E    7734   772.000       2.00000       0.00000       0.00000       0.00000
 mv   7741   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7742   775.000       4.00000       0.00000       0.00000       0.00000
 E    7743   790.000       1.00000       0.00000       0.00000       0.00000
 E    7744   773.000       2.00000       0.00000       0.00000       0.00000
 mv   7751   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7752   776.000       4.00000       0.00000       0.00000       0.00000
 E    7753   791.000       1.00000       0.00000       0.00000       0.00000
 E    7754   774.000       2.00000       0.00000       0.00000       0.00000
 mv   7761   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7762   777.000       4.00000       0.00000       0.00000       0.00000
 E    7763   792.000       1.00000       0.00000       0.00000       0.00000
 E    7764   775.000       2.00000       0.00000       0.00000       0.00000
 mv   7771   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7772   778.000       4.00000       0.00000       0.00000       0.00000
 E    7773   793.000       1.00000       0.00000       0.00000       0.00000
 E    7774   776.000       2.00000       0.00000       0.00000       0.00000
 mv   7781   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7782   779.000       4.00000       0.00000       0.00000       0.00000
 E    7783   794.000       1.00000       0.00000       0.00000       0.00000
 E    7784   777.000       2.00000       0.00000       0.00000       0.00000
 mv   7791   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7792   780.000       4.00000       0.00000       0.00000       0.00000
 E    7793   795.000       1.00000       0.00000       0.00000       0.00000
 E    7794   778.000       2.00000       0.00000       0.00000       0.00000
 mv   7801   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7802   781.000       4.00000       0.00000       0.00000       0.00000
 E    7803   796.000       1.00000       0.00000       0.00000       0.00000
 E    7804   779.000       2.00000       0.00000       0.00000       0.00000
 mv   7811   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7812   782.000       4.00000       0.00000       0.00000       0.00000
 E    7813   797.000       1.00000       0.00000       0.00000       0.00000
 E    7814   780.000       2.00000       0.00000       0.00000       0.00000
 mv   7821   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7822   783.000       4.00000       0.00000       0.00000       0.00000
 E    7823   798.000       1.00000       0.00000       0.00000       0.00000
 E    7824   781.000       2.00000       0.00000       0.00000       0.00000
 mv   7831   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7832   784.000       4.00000       0.00000       0.00000       0.00000
 E    7833   799.000       1.00000       0.00000       0.00000       0.00000
 E    7834   782.000       2.00000       0.00000       0.00000       0.00000
 mv   7841   0.00000       0.00000       0.00000       0.00000       0.00000
      7842   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7843   800.000       1.00000       0.00000       0.00000       0.00000
 E    7844   783.000       2.00000       0.00000       0.00000       0.00000
 E    7851   769.000       3.00000       0.00000       0.00000       0.00000
 E    7852   786.000       4.00000       0.00000       0.00000       0.00000
 E    7853   801.000       1.00000       0.00000       0.00000       0.00000
      7854   0.00000       0.00000       0.00000       0.00000       0.00000
 E    7861   770.000       3.00000       0.00000       0.00000       0.00000
 E    7862   787.000       4.00000       0.00000       0.00000       0.00000
 E    7863   802.000       1.00000       0.00000       0.00000       0.00000
 E    7864   785.000       2.00000       0.00000       0.00000       0.00000
 E    7871   771.000       3.00000       0.00000       0.00000       0.00000
 E    7872   788.000       4.00000       0.00000       0.00000       0.00000
 E    7873   803.000       1.00000       0.00000       0.00000       0.00000
 E    7874   786.000       2.00000       0.00000       0.00000       0.00000
 E    7881   772.000       3.00000       0.00000       0.00000       0.00000
 E    7882   789.000       4.00000       0.00000       0.00000       0.00000
 E    7883   804.000       1.00000       0.00000       0.00000       0.00000
 E    7884   787.000       2.00000       0.00000       0.00000       0.00000
 E    7891   773.000       3.00000       0.00000       0.00000       0.00000
 E    7892   790.000       4.00000       0.00000       0.00000       0.00000
 E    7893   805.000       1.00000       0.00000       0.00000       0.00000
 E    7894   788.000       2.00000       0.00000       0.00000       0.00000
 E    7901   774.000       3.00000       0.00000       0.00000       0.00000
 E    7902   791.000       4.00000       0.00000       0.00000       0.00000
 E    7903   806.000       1.00000       0.00000       0.00000       0.00000
 E    7904   789.000       2.00000       0.00000       0.00000       0.00000
 E    7911   775.000       3.00000       0.00000       0.00000       0.00000
 E    7912   792.000       4.00000       0.00000       0.00000       0.00000
 E    7913   807.000       1.00000       0.00000       0.00000       0.00000
 E    7914   790.000       2.00000       0.00000       0.00000       0.00000
 E    7921   776.000       3.00000       0.00000       0.00000       0.00000
 E    7922   793.000       4.00000       0.00000       0.00000       0.00000
 E    7923   808.000       1.00000       0.00000       0.00000       0.00000
 E    7924   791.000       2.00000       0.00000       0.00000       0.00000
 E    7931   777.000       3.00000       0.00000       0.00000       0.00000
 E    7932   794.000       4.00000       0.00000       0.00000       0.00000
 E    7933   809.000       1.00000       0.00000       0.00000       0.00000
 E    7934   792.000       2.00000       0.00000       0.00000       0.00000
 E    7941   778.000       3.00000       0.00000       0.00000       0.00000
 E    7942   795.000       4.00000       0.00000       0.00000       0.00000
 E    7943   810.000       1.00000       0.00000       0.00000       0.00000
 E    7944   793.000       2.00000       0.00000       0.00000       0.00000
 E    7951   779.000       3.00000       0.00000       0.00000       0.00000
 E    7952   796.000       4.00000       0.00000       0.00000       0.00000
 E    7953   811.000       1.00000       0.00000       0.00000       0.00000
 E    7954   794.000       2.00000       0.00000       0.00000       0.00000
 E    7961   780.000       3.00000       0.00000       0.00000       0.00000
 E    7962   797.000       4.00000       0.00000       0.00000       0.00000
 E    7963   812.000       1.00000       0.00000       0.00000       0.00000
 E    7964   795.000       2.00000       0.00000       0.00000       0.00000
 E    7971   781.000       3.00000       0.00000       0.00000       0.00000
 E    7972   798.000       4.00000       0.00000       0.00000       0.00000
 E    7973   813.000       1.00000       0.00000       0.00000       0.00000
 E    7974   796.000       2.00000       0.00000       0.00000       0.00000
 E    7981   782.000       3.00000       0.00000       0.00000       0.00000
 E    7982   799.000       4.00000       0.00000       0.00000       0.00000
 E    7983   814.000       1.00000       0.00000       0.00000       0.00000
 E    7984   797.000       2.00000       0.00000       0.00000       0.00000
 E    7991   783.000       3.00000       0.00000       0.00000       0.00000
 E    7992   800.000       4.00000       0.00000       0.00000       0.00000
 E    7993   815.000       1.00000       0.00000       0.00000       0.00000
 E    7994   798.000       2.00000       0.00000       0.00000       0.00000
 E    8001   784.000       3.00000       0.00000       0.00000       0.00000
      8002   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8003   816.000       1.00000       0.00000       0.00000       0.00000
 E    8004   799.000       2.00000       0.00000       0.00000       0.00000
 E    8011   785.000       3.00000       0.00000       0.00000       0.00000
 E    8012   802.000       4.00000       0.00000       0.00000       0.00000
 E    8013   817.000       1.00000       0.00000       0.00000       0.00000
      8014   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8021   786.000       3.00000       0.00000       0.00000       0.00000
 E    8022   803.000       4.00000       0.00000       0.00000       0.00000
 E    8023   818.000       1.00000       0.00000       0.00000       0.00000
 E    8024   801.000       2.00000       0.00000       0.00000       0.00000
 E    8031   787.000       3.00000       0.00000       0.00000       0.00000
 E    8032   804.000       4.00000       0.00000       0.00000       0.00000
 E    8033   819.000       1.00000       0.00000       0.00000       0.00000
 E    8034   802.000       2.00000       0.00000       0.00000       0.00000
 E    8041   788.000       3.00000       0.00000       0.00000       0.00000
 E    8042   805.000       4.00000       0.00000       0.00000       0.00000
 E    8043   820.000       1.00000       0.00000       0.00000       0.00000
 E    8044   803.000       2.00000       0.00000       0.00000       0.00000
 E    8051   789.000       3.00000       0.00000       0.00000       0.00000
 E    8052   806.000       4.00000       0.00000       0.00000       0.00000
 E    8053   821.000       1.00000       0.00000       0.00000       0.00000
 E    8054   804.000       2.00000       0.00000       0.00000       0.00000
 E    8061   790.000       3.00000       0.00000       0.00000       0.00000
 E    8062   807.000       4.00000       0.00000       0.00000       0.00000
 E    8063   822.000       1.00000       0.00000       0.00000       0.00000
 E    8064   805.000       2.00000       0.00000       0.00000       0.00000
 E    8071   791.000       3.00000       0.00000       0.00000       0.00000
 E    8072   808.000       4.00000       0.00000       0.00000       0.00000
 E    8073   823.000       1.00000       0.00000       0.00000       0.00000
 E    8074   806.000       2.00000       0.00000       0.00000       0.00000
 E    8081   792.000       3.00000       0.00000       0.00000       0.00000
 E    8082   809.000       4.00000       0.00000       0.00000       0.00000
 E    8083   824.000       1.00000       0.00000       0.00000       0.00000
 E    8084   807.000       2.00000       0.00000       0.00000       0.00000
 E    8091   793.000       3.00000       0.00000       0.00000       0.00000
 E    8092   810.000       4.00000       0.00000       0.00000       0.00000
 E    8093   825.000       1.00000       0.00000       0.00000       0.00000
 E    8094   808.000       2.00000       0.00000       0.00000       0.00000
 E    8101   794.000       3.00000       0.00000       0.00000       0.00000
 E    8102   811.000       4.00000       0.00000       0.00000       0.00000
 E    8103   826.000       1.00000       0.00000       0.00000       0.00000
 E    8104   809.000       2.00000       0.00000       0.00000       0.00000
 E    8111   795.000       3.00000       0.00000       0.00000       0.00000
 E    8112   812.000       4.00000       0.00000       0.00000       0.00000
 E    8113   827.000       1.00000       0.00000       0.00000       0.00000
 E    8114   810.000       2.00000       0.00000       0.00000       0.00000
 E    8121   796.000       3.00000       0.00000       0.00000       0.00000
 E    8122   813.000       4.00000       0.00000       0.00000       0.00000
 E    8123   828.000       1.00000       0.00000       0.00000       0.00000
 E    8124   811.000       2.00000       0.00000       0.00000       0.00000
 E    8131   797.000       3.00000       0.00000       0.00000       0.00000
 E    8132   814.000       4.00000       0.00000       0.00000       0.00000
 E    8133   829.000       1.00000       0.00000       0.00000       0.00000
 E    8134   812.000       2.00000       0.00000       0.00000       0.00000
 E    8141   798.000       3.00000       0.00000       0.00000       0.00000
 E    8142   815.000       4.00000       0.00000       0.00000       0.00000
 E    8143   830.000       1.00000       0.00000       0.00000       0.00000
 E    8144   813.000       2.00000       0.00000       0.00000       0.00000
 E    8151   799.000       3.00000       0.00000       0.00000       0.00000
 E    8152   816.000       4.00000       0.00000       0.00000       0.00000
 E    8153   831.000       1.00000       0.00000       0.00000       0.00000
 E    8154   814.000       2.00000       0.00000       0.00000       0.00000
 E    8161   800.000       3.00000       0.00000       0.00000       0.00000
      8162   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8163   832.000       1.00000       0.00000       0.00000       0.00000
 E    8164   815.000       2.00000       0.00000       0.00000       0.00000
 E    8171   801.000       3.00000       0.00000       0.00000       0.00000
 E    8172   818.000       4.00000       0.00000       0.00000       0.00000
 E    8173   833.000       1.00000       0.00000       0.00000       0.00000
      8174   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8181   802.000       3.00000       0.00000       0.00000       0.00000
 E    8182   819.000       4.00000       0.00000       0.00000       0.00000
 E    8183   834.000       1.00000       0.00000       0.00000       0.00000
 E    8184   817.000       2.00000       0.00000       0.00000       0.00000
 E    8191   803.000       3.00000       0.00000       0.00000       0.00000
 E    8192   820.000       4.00000       0.00000       0.00000       0.00000
 E    8193   835.000       1.00000       0.00000       0.00000       0.00000
 E    8194   818.000       2.00000       0.00000       0.00000       0.00000
 E    8201   804.000       3.00000       0.00000       0.00000       0.00000
 E    8202   821.000       4.00000       0.00000       0.00000       0.00000
 E    8203   836.000       1.00000       0.00000       0.00000       0.00000
 E    8204   819.000       2.00000       0.00000       0.00000       0.00000
 E    8211   805.000       3.00000       0.00000       0.00000       0.00000
 E    8212   822.000       4.00000       0.00000       0.00000       0.00000
 E    8213   837.000       1.00000       0.00000       0.00000       0.00000
 E    8214   820.000       2.00000       0.00000       0.00000       0.00000
 E    8221   806.000       3.00000       0.00000       0.00000       0.00000
 E    8222   823.000       4.00000       0.00000       0.00000       0.00000
 E    8223   838.000       1.00000       0.00000       0.00000       0.00000
 E    8224   821.000       2.00000       0.00000       0.00000       0.00000
 E    8231   807.000       3.00000       0.00000       0.00000       0.00000
 E    8232   824.000       4.00000       0.00000       0.00000       0.00000
 E    8233   839.000       1.00000       0.00000       0.00000       0.00000
 E    8234   822.000       2.00000       0.00000       0.00000       0.00000
 E    8241   808.000       3.00000       0.00000       0.00000       0.00000
 E    8242   825.000       4.00000       0.00000       0.00000       0.00000
 E    8243   840.000       1.00000       0.00000       0.00000       0.00000
 E    8244   823.000       2.00000       0.00000       0.00000       0.00000
 E    8251   809.000       3.00000       0.00000       0.00000       0.00000
 E    8252   826.000       4.00000       0.00000       0.00000       0.00000
 E    8253   841.000       1.00000       0.00000       0.00000       0.00000
 E    8254   824.000       2.00000       0.00000       0.00000       0.00000
 E    8261   810.000       3.00000       0.00000       0.00000       0.00000
 E    8262   827.000       4.00000       0.00000       0.00000       0.00000
 E    8263   842.000       1.00000       0.00000       0.00000       0.00000
 E    8264   825.000       2.00000       0.00000       0.00000       0.00000
 E    8271   811.000       3.00000       0.00000       0.00000       0.00000
 E    8272   828.000       4.00000       0.00000       0.00000       0.00000
 E    8273   843.000       1.00000       0.00000       0.00000       0.00000
 E    8274   826.000       2.00000       0.00000       0.00000       0.00000
 E    8281   812.000       3.00000       0.00000       0.00000       0.00000
 E    8282   829.000       4.00000       0.00000       0.00000       0.00000
 E    8283   844.000       1.00000       0.00000       0.00000       0.00000
 E    8284   827.000       2.00000       0.00000       0.00000       0.00000
 E    8291   813.000       3.00000       0.00000       0.00000       0.00000
 E    8292   830.000       4.00000       0.00000       0.00000       0.00000
 E    8293   845.000       1.00000       0.00000       0.00000       0.00000
 E    8294   828.000       2.00000       0.00000       0.00000       0.00000
 E    8301   814.000       3.00000       0.00000       0.00000       0.00000
 E    8302   831.000       4.00000       0.00000       0.00000       0.00000
 E    8303   846.000       1.00000       0.00000       0.00000       0.00000
 E    8304   829.000       2.00000       0.00000       0.00000       0.00000
 E    8311   815.000       3.00000       0.00000       0.00000       0.00000
 E    8312   832.000       4.00000       0.00000       0.00000       0.00000
 E    8313   847.000       1.00000       0.00000       0.00000       0.00000
 E    8314   830.000       2.00000       0.00000       0.00000       0.00000
 E    8321   816.000       3.00000       0.00000       0.00000       0.00000
      8322   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8323   848.000       1.00000       0.00000       0.00000       0.00000
 E    8324   831.000       2.00000       0.00000       0.00000       0.00000
 E    8331   817.000       3.00000       0.00000       0.00000       0.00000
 E    8332   834.000       4.00000       0.00000       0.00000       0.00000
 E    8333   849.000       1.00000       0.00000       0.00000       0.00000
      8334   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8341   818.000       3.00000       0.00000       0.00000       0.00000
 E    8342   835.000       4.00000       0.00000       0.00000       0.00000
 E    8343   850.000       1.00000       0.00000       0.00000       0.00000
 E    8344   833.000       2.00000       0.00000       0.00000       0.00000
 E    8351   819.000       3.00000       0.00000       0.00000       0.00000
 E    8352   836.000       4.00000       0.00000       0.00000       0.00000
 E    8353   851.000       1.00000       0.00000       0.00000       0.00000
 E    8354   834.000       2.00000       0.00000       0.00000       0.00000
 E    8361   820.000       3.00000       0.00000       0.00000       0.00000
 E    8362   837.000       4.00000       0.00000       0.00000       0.00000
 E    8363   852.000       1.00000       0.00000       0.00000       0.00000
 E    8364   835.000       2.00000       0.00000       0.00000       0.00000
 E    8371   821.000       3.00000       0.00000       0.00000       0.00000
 E    8372   838.000       4.00000       0.00000       0.00000       0.00000
 E    8373   853.000       1.00000       0.00000       0.00000       0.00000
 E    8374   836.000       2.00000       0.00000       0.00000       0.00000
 E    8381   822.000       3.00000       0.00000       0.00000       0.00000
 E    8382   839.000       4.00000       0.00000       0.00000       0.00000
 E    8383   854.000       1.00000       0.00000       0.00000       0.00000
 E    8384   837.000       2.00000       0.00000       0.00000       0.00000
 E    8391   823.000       3.00000       0.00000       0.00000       0.00000
 E    8392   840.000       4.00000       0.00000       0.00000       0.00000
 E    8393   855.000       1.00000       0.00000       0.00000       0.00000
 E    8394   838.000       2.00000       0.00000       0.00000       0.00000
 E    8401   824.000       3.00000       0.00000       0.00000       0.00000
 E    8402   841.000       4.00000       0.00000       0.00000       0.00000
 E    8403   856.000       1.00000       0.00000       0.00000       0.00000
 E    8404   839.000       2.00000       0.00000       0.00000       0.00000
 E    8411   825.000       3.00000       0.00000       0.00000       0.00000
 E    8412   842.000       4.00000       0.00000       0.00000       0.00000
 E    8413   857.000       1.00000       0.00000       0.00000       0.00000
 E    8414   840.000       2.00000       0.00000       0.00000       0.00000
 E    8421   826.000       3.00000       0.00000       0.00000       0.00000
 E    8422   843.000       4.00000       0.00000       0.00000       0.00000
 E    8423   858.000       1.00000       0.00000       0.00000       0.00000
 E    8424   841.000       2.00000       0.00000       0.00000       0.00000
 E    8431   827.000       3.00000       0.00000       0.00000       0.00000
 E    8432   844.000       4.00000       0.00000       0.00000       0.00000
 E    8433   859.000       1.00000       0.00000       0.00000       0.00000
 E    8434   842.000       2.00000       0.00000       0.00000       0.00000
 E    8441   828.000       3.00000       0.00000       0.00000       0.00000
 E    8442   845.000       4.00000       0.00000       0.00000       0.00000
 E    8443   860.000       1.00000       0.00000       0.00000       0.00000
 E    8444   843.000       2.00000       0.00000       0.00000       0.00000
 E    8451   829.000       3.00000       0.00000       0.00000       0.00000
 E    8452   846.000       4.00000       0.00000       0.00000       0.00000
 E    8453   861.000       1.00000       0.00000       0.00000       0.00000
 E    8454   844.000       2.00000       0.00000       0.00000       0.00000
 E    8461   830.000       3.00000       0.00000       0.00000       0.00000
 E    8462   847.000       4.00000       0.00000       0.00000       0.00000
 E    8463   862.000       1.00000       0.00000       0.00000       0.00000
 E    8464   845.000       2.00000       0.00000       0.00000       0.00000
 E    8471   831.000       3.00000       0.00000       0.00000       0.00000
 E    8472   848.000       4.00000       0.00000       0.00000       0.00000
 E    8473   863.000       1.00000       0.00000       0.00000       0.00000
 E    8474   846.000       2.00000       0.00000       0.00000       0.00000
 E    8481   832.000       3.00000       0.00000       0.00000       0.00000
      8482   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8483   864.000       1.00000       0.00000       0.00000       0.00000
 E    8484   847.000       2.00000       0.00000       0.00000       0.00000
 E    8491   833.000       3.00000       0.00000       0.00000       0.00000
 E    8492   850.000       4.00000       0.00000       0.00000       0.00000
 E    8493   865.000       1.00000       0.00000       0.00000       0.00000
      8494   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8501   834.000       3.00000       0.00000       0.00000       0.00000
 E    8502   851.000       4.00000       0.00000       0.00000       0.00000
 E    8503   866.000       1.00000       0.00000       0.00000       0.00000
 E    8504   849.000       2.00000       0.00000       0.00000       0.00000
 E    8511   835.000       3.00000       0.00000       0.00000       0.00000
 E    8512   852.000       4.00000       0.00000       0.00000       0.00000
 E    8513   867.000       1.00000       0.00000       0.00000       0.00000
 E    8514   850.000       2.00000       0.00000       0.00000       0.00000
 E    8521   836.000       3.00000       0.00000       0.00000       0.00000
 E    8522   853.000       4.00000       0.00000       0.00000       0.00000
 E    8523   868.000       1.00000       0.00000       0.00000       0.00000
 E    8524   851.000       2.00000       0.00000       0.00000       0.00000
 E    8531   837.000       3.00000       0.00000       0.00000       0.00000
 E    8532   854.000       4.00000       0.00000       0.00000       0.00000
 E    8533   869.000       1.00000       0.00000       0.00000       0.00000
 E    8534   852.000       2.00000       0.00000       0.00000       0.00000
 E    8541   838.000       3.00000       0.00000       0.00000       0.00000
 E    8542   855.000       4.00000       0.00000       0.00000       0.00000
 E    8543   870.000       1.00000       0.00000       0.00000       0.00000
 E    8544   853.000       2.00000       0.00000       0.00000       0.00000
 E    8551   839.000       3.00000       0.00000       0.00000       0.00000
 E    8552   856.000       4.00000       0.00000       0.00000       0.00000
 E    8553   871.000       1.00000       0.00000       0.00000       0.00000
 E    8554   854.000       2.00000       0.00000       0.00000       0.00000
 E    8561   840.000       3.00000       0.00000       0.00000       0.00000
 E    8562   857.000       4.00000       0.00000       0.00000       0.00000
 E    8563   872.000       1.00000       0.00000       0.00000       0.00000
 E    8564   855.000       2.00000       0.00000       0.00000       0.00000
 E    8571   841.000       3.00000       0.00000       0.00000       0.00000
 E    8572   858.000       4.00000       0.00000       0.00000       0.00000
 E    8573   873.000       1.00000       0.00000       0.00000       0.00000
 E    8574   856.000       2.00000       0.00000       0.00000       0.00000
 E    8581   842.000       3.00000       0.00000       0.00000       0.00000
 E    8582   859.000       4.00000       0.00000       0.00000       0.00000
 E    8583   874.000       1.00000       0.00000       0.00000       0.00000
 E    8584   857.000       2.00000       0.00000       0.00000       0.00000
 E    8591   843.000       3.00000       0.00000       0.00000       0.00000
 E    8592   860.000       4.00000       0.00000       0.00000       0.00000
 E    8593   875.000       1.00000       0.00000       0.00000       0.00000
 E    8594   858.000       2.00000       0.00000       0.00000       0.00000
 E    8601   844.000       3.00000       0.00000       0.00000       0.00000
 E    8602   861.000       4.00000       0.00000       0.00000       0.00000
 E    8603   876.000       1.00000       0.00000       0.00000       0.00000
 E    8604   859.000       2.00000       0.00000       0.00000       0.00000
 E    8611   845.000       3.00000       0.00000       0.00000       0.00000
 E    8612   862.000       4.00000       0.00000       0.00000       0.00000
 E    8613   877.000       1.00000       0.00000       0.00000       0.00000
 E    8614   860.000       2.00000       0.00000       0.00000       0.00000
 E    8621   846.000       3.00000       0.00000       0.00000       0.00000
 E    8622   863.000       4.00000       0.00000       0.00000       0.00000
 E    8623   878.000       1.00000       0.00000       0.00000       0.00000
 E    8624   861.000       2.00000       0.00000       0.00000       0.00000
 E    8631   847.000       3.00000       0.00000       0.00000       0.00000
 E    8632   864.000       4.00000       0.00000       0.00000       0.00000
 E    8633   879.000       1.00000       0.00000       0.00000       0.00000
 E    8634   862.000       2.00000       0.00000       0.00000       0.00000
 E    8641   848.000       3.00000       0.00000       0.00000       0.00000
      8642   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8643   880.000       1.00000       0.00000       0.00000       0.00000
 E    8644   863.000       2.00000       0.00000       0.00000       0.00000
 E    8651   849.000       3.00000       0.00000       0.00000       0.00000
 E    8652   866.000       4.00000       0.00000       0.00000       0.00000
 E    8653   881.000       1.00000       0.00000       0.00000       0.00000
      8654   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8661   850.000       3.00000       0.00000       0.00000       0.00000
 E    8662   867.000       4.00000       0.00000       0.00000       0.00000
 E    8663   882.000       1.00000       0.00000       0.00000       0.00000
 E    8664   865.000       2.00000       0.00000       0.00000       0.00000
 E    8671   851.000       3.00000       0.00000       0.00000       0.00000
 E    8672   868.000       4.00000       0.00000       0.00000       0.00000
 E    8673   883.000       1.00000       0.00000       0.00000       0.00000
 E    8674   866.000       2.00000       0.00000       0.00000       0.00000
 E    8681   852.000       3.00000       0.00000       0.00000       0.00000
 E    8682   869.000       4.00000       0.00000       0.00000       0.00000
 E    8683   884.000       1.00000       0.00000       0.00000       0.00000
 E    8684   867.000       2.00000       0.00000       0.00000       0.00000
 E    8691   853.000       3.00000       0.00000       0.00000       0.00000
 E    8692   870.000       4.00000       0.00000       0.00000       0.00000
 E    8693   885.000       1.00000       0.00000       0.00000       0.00000
 E    8694   868.000       2.00000       0.00000       0.00000       0.00000
 E    8701   854.000       3.00000       0.00000       0.00000       0.00000
 E    8702   871.000       4.00000       0.00000       0.00000       0.00000
 E    8703   886.000       1.00000       0.00000       0.00000       0.00000
 E    8704   869.000       2.00000       0.00000       0.00000       0.00000
 E    8711   855.000       3.00000       0.00000       0.00000       0.00000
 E    8712   872.000       4.00000       0.00000       0.00000       0.00000
 E    8713   887.000       1.00000       0.00000       0.00000       0.00000
 E    8714   870.000       2.00000       0.00000       0.00000       0.00000
 E    8721   856.000       3.00000       0.00000       0.00000       0.00000
 E    8722   873.000       4.00000       0.00000       0.00000       0.00000
 E    8723   888.000       1.00000       0.00000       0.00000       0.00000
 E    8724   871.000       2.00000       0.00000       0.00000       0.00000
 E    8731   857.000       3.00000       0.00000       0.00000       0.00000
 E    8732   874.000       4.00000       0.00000       0.00000       0.00000
 E    8733   889.000       1.00000       0.00000       0.00000       0.00000
 E    8734   872.000       2.00000       0.00000       0.00000       0.00000
 E    8741   858.000       3.00000       0.00000       0.00000       0.00000
 E    8742   875.000       4.00000       0.00000       0.00000       0.00000
 E    8743   890.000       1.00000       0.00000       0.00000       0.00000
 E    8744   873.000       2.00000       0.00000       0.00000       0.00000
 E    8751   859.000       3.00000       0.00000       0.00000       0.00000
 E    8752   876.000       4.00000       0.00000       0.00000       0.00000
 E    8753   891.000       1.00000       0.00000       0.00000       0.00000
 E    8754   874.000       2.00000       0.00000       0.00000       0.00000
 E    8761   860.000       3.00000       0.00000       0.00000       0.00000
 E    8762   877.000       4.00000       0.00000       0.00000       0.00000
 E    8763   892.000       1.00000       0.00000       0.00000       0.00000
 E    8764   875.000       2.00000       0.00000       0.00000       0.00000
 E    8771   861.000       3.00000       0.00000       0.00000       0.00000
 E    8772   878.000       4.00000       0.00000       0.00000       0.00000
 E    8773   893.000       1.00000       0.00000       0.00000       0.00000
 E    8774   876.000       2.00000       0.00000       0.00000       0.00000
 E    8781   862.000       3.00000       0.00000       0.00000       0.00000
 E    8782   879.000       4.00000       0.00000       0.00000       0.00000
 E    8783   894.000       1.00000       0.00000       0.00000       0.00000
 E    8784   877.000       2.00000       0.00000       0.00000       0.00000
 E    8791   863.000       3.00000       0.00000       0.00000       0.00000
 E    8792   880.000       4.00000       0.00000       0.00000       0.00000
 E    8793   895.000       1.00000       0.00000       0.00000       0.00000
 E    8794   878.000       2.00000       0.00000       0.00000       0.00000
 E    8801   864.000       3.00000       0.00000       0.00000       0.00000
      8802   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8803   896.000       1.00000       0.00000       0.00000       0.00000
 E    8804   879.000       2.00000       0.00000       0.00000       0.00000
 E    8811   865.000       3.00000       0.00000       0.00000       0.00000
 E    8812   882.000       4.00000       0.00000       0.00000       0.00000
 E    8813   897.000       1.00000       0.00000       0.00000       0.00000
      8814   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8821   866.000       3.00000       0.00000       0.00000       0.00000
 E    8822   883.000       4.00000       0.00000       0.00000       0.00000
 E    8823   898.000       1.00000       0.00000       0.00000       0.00000
 E    8824   881.000       2.00000       0.00000       0.00000       0.00000
 E    8831   867.000       3.00000       0.00000       0.00000       0.00000
 E    8832   884.000       4.00000       0.00000       0.00000       0.00000
 E    8833   899.000       1.00000       0.00000       0.00000       0.00000
 E    8834   882.000       2.00000       0.00000       0.00000       0.00000
 E    8841   868.000       3.00000       0.00000       0.00000       0.00000
 E    8842   885.000       4.00000       0.00000       0.00000       0.00000
 E    8843   900.000       1.00000       0.00000       0.00000       0.00000
 E    8844   883.000       2.00000       0.00000       0.00000       0.00000
 E    8851   869.000       3.00000       0.00000       0.00000       0.00000
 E    8852   886.000       4.00000       0.00000       0.00000       0.00000
 E    8853   901.000       1.00000       0.00000       0.00000       0.00000
 E    8854   884.000       2.00000       0.00000       0.00000       0.00000
 E    8861   870.000       3.00000       0.00000       0.00000       0.00000
 E    8862   887.000       4.00000       0.00000       0.00000       0.00000
 E    8863   902.000       1.00000       0.00000       0.00000       0.00000
 E    8864   885.000       2.00000       0.00000       0.00000       0.00000
 E    8871   871.000       3.00000       0.00000       0.00000       0.00000
 E    8872   888.000       4.00000       0.00000       0.00000       0.00000
 E    8873   903.000       1.00000       0.00000       0.00000       0.00000
 E    8874   886.000       2.00000       0.00000       0.00000       0.00000
 E    8881   872.000       3.00000       0.00000       0.00000       0.00000
 E    8882   889.000       4.00000       0.00000       0.00000       0.00000
 E    8883   904.000       1.00000       0.00000       0.00000       0.00000
 E    8884   887.000       2.00000       0.00000       0.00000       0.00000
 E    8891   873.000       3.00000       0.00000       0.00000       0.00000
 E    8892   890.000       4.00000       0.00000       0.00000       0.00000
 E    8893   905.000       1.00000       0.00000       0.00000       0.00000
 E    8894   888.000       2.00000       0.00000       0.00000       0.00000
 E    8901   874.000       3.00000       0.00000       0.00000       0.00000
 E    8902   891.000       4.00000       0.00000       0.00000       0.00000
 E    8903   906.000       1.00000       0.00000       0.00000       0.00000
 E    8904   889.000       2.00000       0.00000       0.00000       0.00000
 E    8911   875.000       3.00000       0.00000       0.00000       0.00000
 E    8912   892.000       4.00000       0.00000       0.00000       0.00000
 E    8913   907.000       1.00000       0.00000       0.00000       0.00000
 E    8914   890.000       2.00000       0.00000       0.00000       0.00000
 E    8921   876.000       3.00000       0.00000       0.00000       0.00000
 E    8922   893.000       4.00000       0.00000       0.00000       0.00000
 E    8923   908.000       1.00000       0.00000       0.00000       0.00000
 E    8924   891.000       2.00000       0.00000       0.00000       0.00000
 E    8931   877.000       3.00000       0.00000       0.00000       0.00000
 E    8932   894.000       4.00000       0.00000       0.00000       0.00000
 E    8933   909.000       1.00000       0.00000       0.00000       0.00000
 E    8934   892.000       2.00000       0.00000       0.00000       0.00000
 E    8941   878.000       3.00000       0.00000       0.00000       0.00000
 E    8942   895.000       4.00000       0.00000       0.00000       0.00000
 E    8943   910.000       1.00000       0.00000       0.00000       0.00000
 E    8944   893.000       2.00000       0.00000       0.00000       0.00000
 E    8951   879.000       3.00000       0.00000       0.00000       0.00000
 E    8952   896.000       4.00000       0.00000       0.00000       0.00000
 E    8953   911.000       1.00000       0.00000       0.00000       0.00000
 E    8954   894.000       2.00000       0.00000       0.00000       0.00000
 E    8961   880.000       3.00000       0.00000       0.00000       0.00000
      8962   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8963   912.000       1.00000       0.00000       0.00000       0.00000
 E    8964   895.000       2.00000       0.00000       0.00000       0.00000
 E    8971   881.000       3.00000       0.00000       0.00000       0.00000
 E    8972   898.000       4.00000       0.00000       0.00000       0.00000
 E    8973   913.000       1.00000       0.00000       0.00000       0.00000
      8974   0.00000       0.00000       0.00000       0.00000       0.00000
 E    8981   882.000       3.00000       0.00000       0.00000       0.00000
 E    8982   899.000       4.00000       0.00000       0.00000       0.00000
 E    8983   914.000       1.00000       0.00000       0.00000       0.00000
 E    8984   897.000       2.00000       0.00000       0.00000       0.00000
 E    8991   883.000       3.00000       0.00000       0.00000       0.00000
 E    8992   900.000       4.00000       0.00000       0.00000       0.00000
 E    8993   915.000       1.00000       0.00000       0.00000       0.00000
 E    8994   898.000       2.00000       0.00000       0.00000       0.00000
 E    9001   884.000       3.00000       0.00000       0.00000       0.00000
 E    9002   901.000       4.00000       0.00000       0.00000       0.00000
 E    9003   916.000       1.00000       0.00000       0.00000       0.00000
 E    9004   899.000       2.00000       0.00000       0.00000       0.00000
 E    9011   885.000       3.00000       0.00000       0.00000       0.00000
 E    9012   902.000       4.00000       0.00000       0.00000       0.00000
 E    9013   917.000       1.00000       0.00000       0.00000       0.00000
 E    9014   900.000       2.00000       0.00000       0.00000       0.00000
 E    9021   886.000       3.00000       0.00000       0.00000       0.00000
 E    9022   903.000       4.00000       0.00000       0.00000       0.00000
 E    9023   918.000       1.00000       0.00000       0.00000       0.00000
 E    9024   901.000       2.00000       0.00000       0.00000       0.00000
 E    9031   887.000       3.00000       0.00000       0.00000       0.00000
 E    9032   904.000       4.00000       0.00000       0.00000       0.00000
 E    9033   919.000       1.00000       0.00000       0.00000       0.00000
 E    9034   902.000       2.00000       0.00000       0.00000       0.00000
 E    9041   888.000       3.00000       0.00000       0.00000       0.00000
 E    9042   905.000       4.00000       0.00000       0.00000       0.00000
 E    9043   920.000       1.00000       0.00000       0.00000       0.00000
 E    9044   903.000       2.00000       0.00000       0.00000       0.00000
 E    9051   889.000       3.00000       0.00000       0.00000       0.00000
 E    9052   906.000       4.00000       0.00000       0.00000       0.00000
 E    9053   921.000       1.00000       0.00000       0.00000       0.00000
 E    9054   904.000       2.00000       0.00000       0.00000       0.00000
 E    9061   890.000       3.00000       0.00000       0.00000       0.00000
 E    9062   907.000       4.00000       0.00000       0.00000       0.00000
 E    9063   922.000       1.00000       0.00000       0.00000       0.00000
 E    9064   905.000       2.00000       0.00000       0.00000       0.00000
 E    9071   891.000       3.00000       0.00000       0.00000       0.00000
 E    9072   908.000       4.00000       0.00000       0.00000       0.00000
 E    9073   923.000       1.00000       0.00000       0.00000       0.00000
 E    9074   906.000       2.00000       0.00000       0.00000       0.00000
 E    9081   892.000       3.00000       0.00000       0.00000       0.00000
 E    9082   909.000       4.00000       0.00000       0.00000       0.00000
 E    9083   924.000       1.00000       0.00000       0.00000       0.00000
 E    9084   907.000       2.00000       0.00000       0.00000       0.00000
 E    9091   893.000       3.00000       0.00000       0.00000       0.00000
 E    9092   910.000       4.00000       0.00000       0.00000       0.00000
 E    9093   925.000       1.00000       0.00000       0.00000       0.00000
 E    9094   908.000       2.00000       0.00000       0.00000       0.00000
 E    9101   894.000       3.00000       0.00000       0.00000       0.00000
 E    9102   911.000       4.00000       0.00000       0.00000       0.00000
 E    9103   926.000       1.00000       0.00000       0.00000       0.00000
 E    9104   909.000       2.00000       0.00000       0.00000       0.00000
 E    9111   895.000       3.00000       0.00000       0.00000       0.00000
 E    9112   912.000       4.00000       0.00000       0.00000       0.00000
 E    9113   927.000       1.00000       0.00000       0.00000       0.00000
 E    9114   910.000       2.00000       0.00000       0.00000       0.00000
 E    9121   896.000       3.00000       0.00000       0.00000       0.00000
      9122   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9123   928.000       1.00000       0.00000       0.00000       0.00000
 E    9124   911.000       2.00000       0.00000       0.00000       0.00000
 E    9131   897.000       3.00000       0.00000       0.00000       0.00000
 E    9132   914.000       4.00000       0.00000       0.00000       0.00000
 E    9133   929.000       1.00000       0.00000       0.00000       0.00000
      9134   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9141   898.000       3.00000       0.00000       0.00000       0.00000
 E    9142   915.000       4.00000       0.00000       0.00000       0.00000
 E    9143   930.000       1.00000       0.00000       0.00000       0.00000
 E    9144   913.000       2.00000       0.00000       0.00000       0.00000
 E    9151   899.000       3.00000       0.00000       0.00000       0.00000
 E    9152   916.000       4.00000       0.00000       0.00000       0.00000
 E    9153   931.000       1.00000       0.00000       0.00000       0.00000
 E    9154   914.000       2.00000       0.00000       0.00000       0.00000
 E    9161   900.000       3.00000       0.00000       0.00000       0.00000
 E    9162   917.000       4.00000       0.00000       0.00000       0.00000
 E    9163   932.000       1.00000       0.00000       0.00000       0.00000
 E    9164   915.000       2.00000       0.00000       0.00000       0.00000
 E    9171   901.000       3.00000       0.00000       0.00000       0.00000
 E    9172   918.000       4.00000       0.00000       0.00000       0.00000
 E    9173   933.000       1.00000       0.00000       0.00000       0.00000
 E    9174   916.000       2.00000       0.00000       0.00000       0.00000
 E    9181   902.000       3.00000       0.00000       0.00000       0.00000
 E    9182   919.000       4.00000       0.00000       0.00000       0.00000
 E    9183   934.000       1.00000       0.00000       0.00000       0.00000
 E    9184   917.000       2.00000       0.00000       0.00000       0.00000
 E    9191   903.000       3.00000       0.00000       0.00000       0.00000
 E    9192   920.000       4.00000       0.00000       0.00000       0.00000
 E    9193   935.000       1.00000       0.00000       0.00000       0.00000
 E    9194   918.000       2.00000       0.00000       0.00000       0.00000
 E    9201   904.000       3.00000       0.00000       0.00000       0.00000
 E    9202   921.000       4.00000       0.00000       0.00000       0.00000
 E    9203   936.000       1.00000       0.00000       0.00000       0.00000
 E    9204   919.000       2.00000       0.00000       0.00000       0.00000
 E    9211   905.000       3.00000       0.00000       0.00000       0.00000
 E    9212   922.000       4.00000       0.00000       0.00000       0.00000
 E    9213   937.000       1.00000       0.00000       0.00000       0.00000
 E    9214   920.000       2.00000       0.00000       0.00000       0.00000
 E    9221   906.000       3.00000       0.00000       0.00000       0.00000
 E    9222   923.000       4.00000       0.00000       0.00000       0.00000
 E    9223   938.000       1.00000       0.00000       0.00000       0.00000
 E    9224   921.000       2.00000       0.00000       0.00000       0.00000
 E    9231   907.000       3.00000       0.00000       0.00000       0.00000
 E    9232   924.000       4.00000       0.00000       0.00000       0.00000
 E    9233   939.000       1.00000       0.00000       0.00000       0.00000
 E    9234   922.000       2.00000       0.00000       0.00000       0.00000
 E    9241   908.000       3.00000       0.00000       0.00000       0.00000
 E    9242   925.000       4.00000       0.00000       0.00000       0.00000
 E    9243   940.000       1.00000       0.00000       0.00000       0.00000
 E    9244   923.000       2.00000       0.00000       0.00000       0.00000
 E    9251   909.000       3.00000       0.00000       0.00000       0.00000
 E    9252   926.000       4.00000       0.00000       0.00000       0.00000
 E    9253   941.000       1.00000       0.00000       0.00000       0.00000
 E    9254   924.000       2.00000       0.00000       0.00000       0.00000
 E    9261   910.000       3.00000       0.00000       0.00000       0.00000
 E    9262   927.000       4.00000       0.00000       0.00000       0.00000
 E    9263   942.000       1.00000       0.00000       0.00000       0.00000
 E    9264   925.000       2.00000       0.00000       0.00000       0.00000
 E    9271   911.000       3.00000       0.00000       0.00000       0.00000
 E    9272   928.000       4.00000       0.00000       0.00000       0.00000
 E    9273   943.000       1.00000       0.00000       0.00000       0.00000
 E    9274   926.000       2.00000       0.00000       0.00000       0.00000
 E    9281   912.000       3.00000       0.00000       0.00000       0.00000
      9282   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9283   944.000       1.00000       0.00000       0.00000       0.00000
 E    9284   927.000       2.00000       0.00000       0.00000       0.00000
 E    9291   913.000       3.00000       0.00000       0.00000       0.00000
 E    9292   930.000       4.00000       0.00000       0.00000       0.00000
 E    9293   945.000       1.00000       0.00000       0.00000       0.00000
      9294   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9301   914.000       3.00000       0.00000       0.00000       0.00000
 E    9302   931.000       4.00000       0.00000       0.00000       0.00000
 E    9303   946.000       1.00000       0.00000       0.00000       0.00000
 E    9304   929.000       2.00000       0.00000       0.00000       0.00000
 E    9311   915.000       3.00000       0.00000       0.00000       0.00000
 E    9312   932.000       4.00000       0.00000       0.00000       0.00000
 E    9313   947.000       1.00000       0.00000       0.00000       0.00000
 E    9314   930.000       2.00000       0.00000       0.00000       0.00000
 E    9321   916.000       3.00000       0.00000       0.00000       0.00000
 E    9322   933.000       4.00000       0.00000       0.00000       0.00000
 E    9323   948.000       1.00000       0.00000       0.00000       0.00000
 E    9324   931.000       2.00000       0.00000       0.00000       0.00000
 E    9331   917.000       3.00000       0.00000       0.00000       0.00000
 E    9332   934.000       4.00000       0.00000       0.00000       0.00000
 E    9333   949.000       1.00000       0.00000       0.00000       0.00000
 E    9334   932.000       2.00000       0.00000       0.00000       0.00000
 E    9341   918.000       3.00000       0.00000       0.00000       0.00000
 E    9342   935.000       4.00000       0.00000       0.00000       0.00000
 E    9343   950.000       1.00000       0.00000       0.00000       0.00000
 E    9344   933.000       2.00000       0.00000       0.00000       0.00000
 E    9351   919.000       3.00000       0.00000       0.00000       0.00000
 E    9352   936.000       4.00000       0.00000       0.00000       0.00000
 E    9353   951.000       1.00000       0.00000       0.00000       0.00000
 E    9354   934.000       2.00000       0.00000       0.00000       0.00000
 E    9361   920.000       3.00000       0.00000       0.00000       0.00000
 E    9362   937.000       4.00000       0.00000       0.00000       0.00000
 E    9363   952.000       1.00000       0.00000       0.00000       0.00000
 E    9364   935.000       2.00000       0.00000       0.00000       0.00000
 E    9371   921.000       3.00000       0.00000       0.00000       0.00000
 E    9372   938.000       4.00000       0.00000       0.00000       0.00000
 E    9373   953.000       1.00000       0.00000       0.00000       0.00000
 E    9374   936.000       2.00000       0.00000       0.00000       0.00000
 E    9381   922.000       3.00000       0.00000       0.00000       0.00000
 E    9382   939.000       4.00000       0.00000       0.00000       0.00000
 E    9383   954.000       1.00000       0.00000       0.00000       0.00000
 E    9384   937.000       2.00000       0.00000       0.00000       0.00000
 E    9391   923.000       3.00000       0.00000       0.00000       0.00000
 E    9392   940.000       4.00000       0.00000       0.00000       0.00000
 E    9393   955.000       1.00000       0.00000       0.00000       0.00000
 E    9394   938.000       2.00000       0.00000       0.00000       0.00000
 E    9401   924.000       3.00000       0.00000       0.00000       0.00000
 E    9402   941.000       4.00000       0.00000       0.00000       0.00000
 E    9403   956.000       1.00000       0.00000       0.00000       0.00000
 E    9404   939.000       2.00000       0.00000       0.00000       0.00000
 E    9411   925.000       3.00000       0.00000       0.00000       0.00000
 E    9412   942.000       4.00000       0.00000       0.00000       0.00000
 E    9413   957.000       1.00000       0.00000       0.00000       0.00000
 E    9414   940.000       2.00000       0.00000       0.00000       0.00000
 E    9421   926.000       3.00000       0.00000       0.00000       0.00000
 E    9422   943.000       4.00000       0.00000       0.00000       0.00000
 E    9423   958.000       1.00000       0.00000       0.00000       0.00000
 E    9424   941.000       2.00000       0.00000       0.00000       0.00000
 E    9431   927.000       3.00000       0.00000       0.00000       0.00000
 E    9432   944.000       4.00000       0.00000       0.00000       0.00000
 E    9433   959.000       1.00000       0.00000       0.00000       0.00000
 E    9434   942.000       2.00000       0.00000       0.00000       0.00000
 E    9441   928.000       3.00000       0.00000       0.00000       0.00000
      9442   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9443   960.000       1.00000       0.00000       0.00000       0.00000
 E    9444   943.000       2.00000       0.00000       0.00000       0.00000
 E    9451   929.000       3.00000       0.00000       0.00000       0.00000
 E    9452   946.000       4.00000       0.00000       0.00000       0.00000
 E    9453   961.000       1.00000       0.00000       0.00000       0.00000
      9454   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9461   930.000       3.00000       0.00000       0.00000       0.00000
 E    9462   947.000       4.00000       0.00000       0.00000       0.00000
 E    9463   962.000       1.00000       0.00000       0.00000       0.00000
 E    9464   945.000       2.00000       0.00000       0.00000       0.00000
 E    9471   931.000       3.00000       0.00000       0.00000       0.00000
 E    9472   948.000       4.00000       0.00000       0.00000       0.00000
 E    9473   963.000       1.00000       0.00000       0.00000       0.00000
 E    9474   946.000       2.00000       0.00000       0.00000       0.00000
 E    9481   932.000       3.00000       0.00000       0.00000       0.00000
 E    9482   949.000       4.00000       0.00000       0.00000       0.00000
 E    9483   964.000       1.00000       0.00000       0.00000       0.00000
 E    9484   947.000       2.00000       0.00000       0.00000       0.00000
 E    9491   933.000       3.00000       0.00000       0.00000       0.00000
 E    9492   950.000       4.00000       0.00000       0.00000       0.00000
 E    9493   965.000       1.00000       0.00000       0.00000       0.00000
 E    9494   948.000       2.00000       0.00000       0.00000       0.00000
 E    9501   934.000       3.00000       0.00000       0.00000       0.00000
 E    9502   951.000       4.00000       0.00000       0.00000       0.00000
 E    9503   966.000       1.00000       0.00000       0.00000       0.00000
 E    9504   949.000       2.00000       0.00000       0.00000       0.00000
 E    9511   935.000       3.00000       0.00000       0.00000       0.00000
 E    9512   952.000       4.00000       0.00000       0.00000       0.00000
 E    9513   967.000       1.00000       0.00000       0.00000       0.00000
 E    9514   950.000       2.00000       0.00000       0.00000       0.00000
 E    9521   936.000       3.00000       0.00000       0.00000       0.00000
 E    9522   953.000       4.00000       0.00000       0.00000       0.00000
 E    9523   968.000       1.00000       0.00000       0.00000       0.00000
 E    9524   951.000       2.00000       0.00000       0.00000       0.00000
 E    9531   937.000       3.00000       0.00000       0.00000       0.00000
 E    9532   954.000       4.00000       0.00000       0.00000       0.00000
 E    9533   969.000       1.00000       0.00000       0.00000       0.00000
 E    9534   952.000       2.00000       0.00000       0.00000       0.00000
 E    9541   938.000       3.00000       0.00000       0.00000       0.00000
 E    9542   955.000       4.00000       0.00000       0.00000       0.00000
 E    9543   970.000       1.00000       0.00000       0.00000       0.00000
 E    9544   953.000       2.00000       0.00000       0.00000       0.00000
 E    9551   939.000       3.00000       0.00000       0.00000       0.00000
 E    9552   956.000       4.00000       0.00000       0.00000       0.00000
 E    9553   971.000       1.00000       0.00000       0.00000       0.00000
 E    9554   954.000       2.00000       0.00000       0.00000       0.00000
 E    9561   940.000       3.00000       0.00000       0.00000       0.00000
 E    9562   957.000       4.00000       0.00000       0.00000       0.00000
 E    9563   972.000       1.00000       0.00000       0.00000       0.00000
 E    9564   955.000       2.00000       0.00000       0.00000       0.00000
 E    9571   941.000       3.00000       0.00000       0.00000       0.00000
 E    9572   958.000       4.00000       0.00000       0.00000       0.00000
 E    9573   973.000       1.00000       0.00000       0.00000       0.00000
 E    9574   956.000       2.00000       0.00000       0.00000       0.00000
 E    9581   942.000       3.00000       0.00000       0.00000       0.00000
 E    9582   959.000       4.00000       0.00000       0.00000       0.00000
 E    9583   974.000       1.00000       0.00000       0.00000       0.00000
 E    9584   957.000       2.00000       0.00000       0.00000       0.00000
 E    9591   943.000       3.00000       0.00000       0.00000       0.00000
 E    9592   960.000       4.00000       0.00000       0.00000       0.00000
 E    9593   975.000       1.00000       0.00000       0.00000       0.00000
 E    9594   958.000       2.00000       0.00000       0.00000       0.00000
 E    9601   944.000       3.00000       0.00000       0.00000       0.00000
      9602   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9603   976.000       1.00000       0.00000       0.00000       0.00000
 E    9604   959.000       2.00000       0.00000       0.00000       0.00000
 E    9611   945.000       3.00000       0.00000       0.00000       0.00000
 E    9612   962.000       4.00000       0.00000       0.00000       0.00000
 E    9613   977.000       1.00000       0.00000       0.00000       0.00000
      9614   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9621   946.000       3.00000       0.00000       0.00000       0.00000
 E    9622   963.000       4.00000       0.00000       0.00000       0.00000
 E    9623   978.000       1.00000       0.00000       0.00000       0.00000
 E    9624   961.000       2.00000       0.00000       0.00000       0.00000
 E    9631   947.000       3.00000       0.00000       0.00000       0.00000
 E    9632   964.000       4.00000       0.00000       0.00000       0.00000
 E    9633   979.000       1.00000       0.00000       0.00000       0.00000
 E    9634   962.000       2.00000       0.00000       0.00000       0.00000
 E    9641   948.000       3.00000       0.00000       0.00000       0.00000
 E    9642   965.000       4.00000       0.00000       0.00000       0.00000
 E    9643   980.000       1.00000       0.00000       0.00000       0.00000
 E    9644   963.000       2.00000       0.00000       0.00000       0.00000
 E    9651   949.000       3.00000       0.00000       0.00000       0.00000
 E    9652   966.000       4.00000       0.00000       0.00000       0.00000
 E    9653   981.000       1.00000       0.00000       0.00000       0.00000
 E    9654   964.000       2.00000       0.00000       0.00000       0.00000
 E    9661   950.000       3.00000       0.00000       0.00000       0.00000
 E    9662   967.000       4.00000       0.00000       0.00000       0.00000
 E    9663   982.000       1.00000       0.00000       0.00000       0.00000
 E    9664   965.000       2.00000       0.00000       0.00000       0.00000
 E    9671   951.000       3.00000       0.00000       0.00000       0.00000
 E    9672   968.000       4.00000       0.00000       0.00000       0.00000
 E    9673   983.000       1.00000       0.00000       0.00000       0.00000
 E    9674   966.000       2.00000       0.00000       0.00000       0.00000
 E    9681   952.000       3.00000       0.00000       0.00000       0.00000
 E    9682   969.000       4.00000       0.00000       0.00000       0.00000
 E    9683   984.000       1.00000       0.00000       0.00000       0.00000
 E    9684   967.000       2.00000       0.00000       0.00000       0.00000
 E    9691   953.000       3.00000       0.00000       0.00000       0.00000
 E    9692   970.000       4.00000       0.00000       0.00000       0.00000
 E    9693   985.000       1.00000       0.00000       0.00000       0.00000
 E    9694   968.000       2.00000       0.00000       0.00000       0.00000
 E    9701   954.000       3.00000       0.00000       0.00000       0.00000
 E    9702   971.000       4.00000       0.00000       0.00000       0.00000
 E    9703   986.000       1.00000       0.00000       0.00000       0.00000
 E    9704   969.000       2.00000       0.00000       0.00000       0.00000
 E    9711   955.000       3.00000       0.00000       0.00000       0.00000
 E    9712   972.000       4.00000       0.00000       0.00000       0.00000
 E    9713   987.000       1.00000       0.00000       0.00000       0.00000
 E    9714   970.000       2.00000       0.00000       0.00000       0.00000
 E    9721   956.000       3.00000       0.00000       0.00000       0.00000
 E    9722   973.000       4.00000       0.00000       0.00000       0.00000
 E    9723   988.000       1.00000       0.00000       0.00000       0.00000
 E    9724   971.000       2.00000       0.00000       0.00000       0.00000
 E    9731   957.000       3.00000       0.00000       0.00000       0.00000
 E    9732   974.000       4.00000       0.00000       0.00000       0.00000
 E    9733   989.000       1.00000       0.00000       0.00000       0.00000
 E    9734   972.000       2.00000       0.00000       0.00000       0.00000
 E    9741   958.000       3.00000       0.00000       0.00000       0.00000
 E    9742   975.000       4.00000       0.00000       0.00000       0.00000
 E    9743   990.000       1.00000       0.00000       0.00000       0.00000
 E    9744   973.000       2.00000       0.00000       0.00000       0.00000
 E    9751   959.000       3.00000       0.00000       0.00000       0.00000
 E    9752   976.000       4.00000       0.00000       0.00000       0.00000
 E    9753   991.000       1.00000       0.00000       0.00000       0.00000
 E    9754   974.000       2.00000       0.00000       0.00000       0.00000
 E    9761   960.000       3.00000       0.00000       0.00000       0.00000
      9762   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9763   992.000       1.00000       0.00000       0.00000       0.00000
 E    9764   975.000       2.00000       0.00000       0.00000       0.00000
 E    9771   961.000       3.00000       0.00000       0.00000       0.00000
 E    9772   978.000       4.00000       0.00000       0.00000       0.00000
 E    9773   993.000       1.00000       0.00000       0.00000       0.00000
      9774   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9781   962.000       3.00000       0.00000       0.00000       0.00000
 E    9782   979.000       4.00000       0.00000       0.00000       0.00000
 E    9783   994.000       1.00000       0.00000       0.00000       0.00000
 E    9784   977.000       2.00000       0.00000       0.00000       0.00000
 E    9791   963.000       3.00000       0.00000       0.00000       0.00000
 E    9792   980.000       4.00000       0.00000       0.00000       0.00000
 E    9793   995.000       1.00000       0.00000       0.00000       0.00000
 E    9794   978.000       2.00000       0.00000       0.00000       0.00000
 E    9801   964.000       3.00000       0.00000       0.00000       0.00000
 E    9802   981.000       4.00000       0.00000       0.00000       0.00000
 E    9803   996.000       1.00000       0.00000       0.00000       0.00000
 E    9804   979.000       2.00000       0.00000       0.00000       0.00000
 E    9811   965.000       3.00000       0.00000       0.00000       0.00000
 E    9812   982.000       4.00000       0.00000       0.00000       0.00000
 E    9813   997.000       1.00000       0.00000       0.00000       0.00000
 E    9814   980.000       2.00000       0.00000       0.00000       0.00000
 E    9821   966.000       3.00000       0.00000       0.00000       0.00000
 E    9822   983.000       4.00000       0.00000       0.00000       0.00000
 E    9823   998.000       1.00000       0.00000       0.00000       0.00000
 E    9824   981.000       2.00000       0.00000       0.00000       0.00000
 E    9831   967.000       3.00000       0.00000       0.00000       0.00000
 E    9832   984.000       4.00000       0.00000       0.00000       0.00000
 E    9833   999.000       1.00000       0.00000       0.00000       0.00000
 E    9834   982.000       2.00000       0.00000       0.00000       0.00000
 E    9841   968.000       3.00000       0.00000       0.00000       0.00000
 E    9842   985.000       4.00000       0.00000       0.00000       0.00000
 E    9843   1000.00       1.00000       0.00000       0.00000       0.00000
 E    9844   983.000       2.00000       0.00000       0.00000       0.00000
 E    9851   969.000       3.00000       0.00000       0.00000       0.00000
 E    9852   986.000       4.00000       0.00000       0.00000       0.00000
 E    9853   1001.00       1.00000       0.00000       0.00000       0.00000
 E    9854   984.000       2.00000       0.00000       0.00000       0.00000
 E    9861   970.000       3.00000       0.00000       0.00000       0.00000
 E    9862   987.000       4.00000       0.00000       0.00000       0.00000
 E    9863   1002.00       1.00000       0.00000       0.00000       0.00000
 E    9864   985.000       2.00000       0.00000       0.00000       0.00000
 E    9871   971.000       3.00000       0.00000       0.00000       0.00000
 E    9872   988.000       4.00000       0.00000       0.00000       0.00000
 E    9873   1003.00       1.00000       0.00000       0.00000       0.00000
 E    9874   986.000       2.00000       0.00000       0.00000       0.00000
 E    9881   972.000       3.00000       0.00000       0.00000       0.00000
 E    9882   989.000       4.00000       0.00000       0.00000       0.00000
 E    9883   1004.00       1.00000       0.00000       0.00000       0.00000
 E    9884   987.000       2.00000       0.00000       0.00000       0.00000
 E    9891   973.000       3.00000       0.00000       0.00000       0.00000
 E    9892   990.000       4.00000       0.00000       0.00000       0.00000
 E    9893   1005.00       1.00000       0.00000       0.00000       0.00000
 E    9894   988.000       2.00000       0.00000       0.00000       0.00000
 E    9901   974.000       3.00000       0.00000       0.00000       0.00000
 E    9902   991.000       4.00000       0.00000       0.00000       0.00000
 E    9903   1006.00       1.00000       0.00000       0.00000       0.00000
 E    9904   989.000       2.00000       0.00000       0.00000       0.00000
 E    9911   975.000       3.00000       0.00000       0.00000       0.00000
 E    9912   992.000       4.00000       0.00000       0.00000       0.00000
 E    9913   1007.00       1.00000       0.00000       0.00000       0.00000
 E    9914   990.000       2.00000       0.00000       0.00000       0.00000
 E    9921   976.000       3.00000       0.00000       0.00000       0.00000
      9922   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9923   1008.00       1.00000       0.00000       0.00000       0.00000
 E    9924   991.000       2.00000       0.00000       0.00000       0.00000
 E    9931   977.000       3.00000       0.00000       0.00000       0.00000
 E    9932   994.000       4.00000       0.00000       0.00000       0.00000
 E    9933   1009.00       1.00000       0.00000       0.00000       0.00000
      9934   0.00000       0.00000       0.00000       0.00000       0.00000
 E    9941   978.000       3.00000       0.00000       0.00000       0.00000
 E    9942   995.000       4.00000       0.00000       0.00000       0.00000
 E    9943   1010.00       1.00000       0.00000       0.00000       0.00000
 E    9944   993.000       2.00000       0.00000       0.00000       0.00000
 E    9951   979.000       3.00000       0.00000       0.00000       0.00000
 E    9952   996.000       4.00000       0.00000       0.00000       0.00000
 E    9953   1011.00       1.00000       0.00000       0.00000       0.00000
 E    9954   994.000       2.00000       0.00000       0.00000       0.00000
 E    9961   980.000       3.00000       0.00000       0.00000       0.00000
 E    9962   997.000       4.00000       0.00000       0.00000       0.00000
 E    9963   1012.00       1.00000       0.00000       0.00000       0.00000
 E    9964   995.000       2.00000       0.00000       0.00000       0.00000
 E    9971   981.000       3.00000       0.00000       0.00000       0.00000
 E    9972   998.000       4.00000       0.00000       0.00000       0.00000
 E    9973   1013.00       1.00000       0.00000       0.00000       0.00000
 E    9974   996.000       2.00000       0.00000       0.00000       0.00000
 E    9981   982.000       3.00000       0.00000       0.00000       0.00000
 E    9982   999.000       4.00000       0.00000       0.00000       0.00000
 E    9983   1014.00       1.00000       0.00000       0.00000       0.00000
 E    9984   997.000       2.00000       0.00000       0.00000       0.00000
 E    9991   983.000       3.00000       0.00000       0.00000       0.00000
 E    9992   1000.00       4.00000       0.00000       0.00000       0.00000
 E    9993   1015.00       1.00000       0.00000       0.00000       0.00000
 E    9994   998.000       2.00000       0.00000       0.00000       0.00000
 E   10001   984.000       3.00000       0.00000       0.00000       0.00000
 E   10002   1001.00       4.00000       0.00000       0.00000       0.00000
 E   10003   1016.00       1.00000       0.00000       0.00000       0.00000
 E   10004   999.000       2.00000       0.00000       0.00000       0.00000
 E   10011   985.000       3.00000       0.00000       0.00000       0.00000
 E   10012   1002.00       4.00000       0.00000       0.00000       0.00000
 E   10013   1017.00       1.00000       0.00000       0.00000       0.00000
 E   10014   1000.00       2.00000       0.00000       0.00000       0.00000
 E   10021   986.000       3.00000       0.00000       0.00000       0.00000
 E   10022   1003.00       4.00000       0.00000       0.00000       0.00000
 E   10023   1018.00       1.00000       0.00000       0.00000       0.00000
 E   10024   1001.00       2.00000       0.00000       0.00000       0.00000
 E   10031   987.000       3.00000       0.00000       0.00000       0.00000
 E   10032   1004.00       4.00000       0.00000       0.00000       0.00000
 E   10033   1019.00       1.00000       0.00000       0.00000       0.00000
 E   10034   1002.00       2.00000       0.00000       0.00000       0.00000
 E   10041   988.000       3.00000       0.00000       0.00000       0.00000
 E   10042   1005.00       4.00000       0.00000       0.00000       0.00000
 E   10043   1020.00       1.00000       0.00000       0.00000       0.00000
 E   10044   1003.00       2.00000       0.00000       0.00000       0.00000
 E   10051   989.000       3.00000       0.00000       0.00000       0.00000
 E   10052   1006.00       4.00000       0.00000       0.00000       0.00000
 E   10053   1021.00       1.00000       0.00000       0.00000       0.00000
 E   10054   1004.00       2.00000       0.00000       0.00000       0.00000
 E   10061   990.000       3.00000       0.00000       0.00000       0.00000
 E   10062   1007.00       4.00000       0.00000       0.00000       0.00000
 E   10063   1022.00       1.00000       0.00000       0.00000       0.00000
 E   10064   1005.00       2.00000       0.00000       0.00000       0.00000
 E   10071   991.000       3.00000       0.00000       0.00000       0.00000
 E   10072   1008.00       4.00000       0.00000       0.00000       0.00000
 E   10073   1023.00       1.00000       0.00000       0.00000       0.00000
 E   10074   1006.00       2.00000       0.00000       0.00000       0.00000
 E   10081   992.000       3.00000       0.00000       0.00000       0.00000
     10082   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10083   1024.00       1.00000       0.00000       0.00000       0.00000
 E   10084   1007.00       2.00000       0.00000       0.00000       0.00000
 E   10091   993.000       3.00000       0.00000       0.00000       0.00000
 E   10092   1010.00       4.00000       0.00000       0.00000       0.00000
 v   10093   0.00000       0.00000       0.00000       0.00000       0.00000
     10094   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10101   994.000       3.00000       0.00000       0.00000       0.00000
 E   10102   1011.00       4.00000       0.00000       0.00000       0.00000
 v   10103   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10104   1009.00       2.00000       0.00000       0.00000       0.00000
 E   10111   995.000       3.00000       0.00000       0.00000       0.00000
 E   10112   1012.00       4.00000       0.00000       0.00000       0.00000
 v   10113   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10114   1010.00       2.00000       0.00000       0.00000       0.00000
 E   10121   996.000       3.00000       0.00000       0.00000       0.00000
 E   10122   1013.00       4.00000       0.00000       0.00000       0.00000
 v   10123   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10124   1011.00       2.00000       0.00000       0.00000       0.00000
 E   10131   997.000       3.00000       0.00000       0.00000       0.00000
 E   10132   1014.00       4.00000       0.00000       0.00000       0.00000
 v   10133   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10134   1012.00       2.00000       0.00000       0.00000       0.00000
 E   10141   998.000       3.00000       0.00000       0.00000       0.00000
 E   10142   1015.00       4.00000       0.00000       0.00000       0.00000
 v   10143   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10144   1013.00       2.00000       0.00000       0.00000       0.00000
 E   10151   999.000       3.00000       0.00000       0.00000       0.00000
 E   10152   1016.00       4.00000       0.00000       0.00000       0.00000
 v   10153   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10154   1014.00       2.00000       0.00000       0.00000       0.00000
 E   10161   1000.00       3.00000       0.00000       0.00000       0.00000
 E   10162   1017.00       4.00000       0.00000       0.00000       0.00000
 v   10163   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10164   1015.00       2.00000       0.00000       0.00000       0.00000
 E   10171   1001.00       3.00000       0.00000       0.00000       0.00000
 E   10172   1018.00       4.00000       0.00000       0.00000       0.00000
 v   10173   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10174   1016.00       2.00000       0.00000       0.00000       0.00000
 E   10181   1002.00       3.00000       0.00000       0.00000       0.00000
 E   10182   1019.00       4.00000       0.00000       0.00000       0.00000
 v   10183   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10184   1017.00       2.00000       0.00000       0.00000       0.00000
 E   10191   1003.00       3.00000       0.00000       0.00000       0.00000
 E   10192   1020.00       4.00000       0.00000       0.00000       0.00000
 v   10193   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10194   1018.00       2.00000       0.00000       0.00000       0.00000
 E   10201   1004.00       3.00000       0.00000       0.00000       0.00000
 E   10202   1021.00       4.00000       0.00000       0.00000       0.00000
 v   10203   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10204   1019.00       2.00000       0.00000       0.00000       0.00000
 E   10211   1005.00       3.00000       0.00000       0.00000       0.00000
 E   10212   1022.00       4.00000       0.00000       0.00000       0.00000
 v   10213   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10214   1020.00       2.00000       0.00000       0.00000       0.00000
 E   10221   1006.00       3.00000       0.00000       0.00000       0.00000
 E   10222   1023.00       4.00000       0.00000       0.00000       0.00000
 v   10223   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10224   1021.00       2.00000       0.00000       0.00000       0.00000
 E   10231   1007.00       3.00000       0.00000       0.00000       0.00000
 E   10232   1024.00       4.00000       0.00000       0.00000       0.00000
 v   10233   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10234   1022.00       2.00000       0.00000       0.00000       0.00000
 E   10241   1008.00       3.00000       0.00000       0.00000       0.00000
     10242   0.00000       0.00000       0.00000       0.00000       0.00000
 v   10243   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10244   1023.00       2.00000       0.00000       0.00000       0.00000
 v   10251   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10252   1026.00       4.00000       0.00000       0.00000       0.00000
 E   10253   1041.00       1.00000       0.00000       0.00000       0.00000
     10254   0.00000       0.00000       0.00000       0.00000       0.00000
 v   10261   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10262   1027.00       4.00000       0.00000       0.00000       0.00000
 E   10263   1042.00       1.00000       0.00000       0.00000       0.00000
 E   10264   1025.00       2.00000       0.00000       0.00000       0.00000
 v   10271   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10272   1028.00       4.00000       0.00000       0.00000       0.00000
 E   10273   1043.00       1.00000       0.00000       0.00000       0.00000
 E   10274   1026.00       2.00000       0.00000       0.00000       0.00000
 v   10281   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10282   1029.00       4.00000       0.00000       0.00000       0.00000
 E   10283   1044.00       1.00000       0.00000       0.00000       0.00000
 E   10284   1027.00       2.00000       0.00000       0.00000       0.00000
 v   10291   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10292   1030.00       4.00000       0.00000       0.00000       0.00000
 E   10293   1045.00       1.00000       0.00000       0.00000       0.00000
 E   10294   1028.00       2.00000       0.00000       0.00000       0.00000
 v   10301   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10302   1031.00       4.00000       0.00000       0.00000       0.00000
 E   10303   1046.00       1.00000       0.00000       0.00000       0.00000
 E   10304   1029.00       2.00000       0.00000       0.00000       0.00000
 v   10311   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10312   1032.00       4.00000       0.00000       0.00000       0.00000
 E   10313   1047.00       1.00000       0.00000       0.00000       0.00000
 E   10314   1030.00       2.00000       0.00000       0.00000       0.00000
 v   10321   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10322   1033.00       4.00000       0.00000       0.00000       0.00000
 E   10323   1048.00       1.00000       0.00000       0.00000       0.00000
 E   10324   1031.00       2.00000       0.00000       0.00000       0.00000
 v   10331   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10332   1034.00       4.00000       0.00000       0.00000       0.00000
 E   10333   1049.00       1.00000       0.00000       0.00000       0.00000
 E   10334   1032.00       2.00000       0.00000       0.00000       0.00000
 v   10341   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10342   1035.00       4.00000       0.00000       0.00000       0.00000
 E   10343   1050.00       1.00000       0.00000       0.00000       0.00000
 E   10344   1033.00       2.00000       0.00000       0.00000       0.00000
 v   10351   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10352   1036.00       4.00000       0.00000       0.00000       0.00000
 E   10353   1051.00       1.00000       0.00000       0.00000       0.00000
 E   10354   1034.00       2.00000       0.00000       0.00000       0.00000
 v   10361   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10362   1037.00       4.00000       0.00000       0.00000       0.00000
 E   10363   1052.00       1.00000       0.00000       0.00000       0.00000
 E   10364   1035.00       2.00000       0.00000       0.00000       0.00000
 v   10371   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10372   1038.00       4.00000       0.00000       0.00000       0.00000
 E   10373   1053.00       1.00000       0.00000       0.00000       0.00000
 E   10374   1036.00       2.00000       0.00000       0.00000       0.00000
 v   10381   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10382   1039.00       4.00000       0.00000       0.00000       0.00000
 E   10383   1054.00       1.00000       0.00000       0.00000       0.00000
 E   10384   1037.00       2.00000       0.00000       0.00000       0.00000
 v   10391   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10392   1040.00       4.00000       0.00000       0.00000       0.00000
 E   10393   1055.00       1.00000       0.00000       0.00000       0.00000
 E   10394   1038.00       2.00000       0.00000       0.00000       0.00000
 v   10401   0.00000       0.00000       0.00000       0.00000       0.00000
 O   10402   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10403   1056.00       1.00000       0.00000       0.00000       0.00000
 E   10404   1039.00       2.00000       0.00000       0.00000       0.00000
 E   10411   1025.00       3.00000       0.00000       0.00000       0.00000
 E   10412   1042.00       4.00000       0.00000       0.00000       0.00000
 E   10413   1057.00       1.00000       0.00000       0.00000       0.00000
     10414   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10421   1026.00       3.00000       0.00000       0.00000       0.00000
 E   10422   1043.00       4.00000       0.00000       0.00000       0.00000
 E   10423   1058.00       1.00000       0.00000       0.00000       0.00000
 E   10424   1041.00       2.00000       0.00000       0.00000       0.00000
 E   10431   1027.00       3.00000       0.00000       0.00000       0.00000
 E   10432   1044.00       4.00000       0.00000       0.00000       0.00000
 E   10433   1059.00       1.00000       0.00000       0.00000       0.00000
 E   10434   1042.00       2.00000       0.00000       0.00000       0.00000
 E   10441   1028.00       3.00000       0.00000       0.00000       0.00000
 E   10442   1045.00       4.00000       0.00000       0.00000       0.00000
 E   10443   1060.00       1.00000       0.00000       0.00000       0.00000
 E   10444   1043.00       2.00000       0.00000       0.00000       0.00000
 E   10451   1029.00       3.00000       0.00000       0.00000       0.00000
 E   10452   1046.00       4.00000       0.00000       0.00000       0.00000
 E   10453   1061.00       1.00000       0.00000       0.00000       0.00000
 E   10454   1044.00       2.00000       0.00000       0.00000       0.00000
 E   10461   1030.00       3.00000       0.00000       0.00000       0.00000
 E   10462   1047.00       4.00000       0.00000       0.00000       0.00000
 E   10463   1062.00       1.00000       0.00000       0.00000       0.00000
 E   10464   1045.00       2.00000       0.00000       0.00000       0.00000
 E   10471   1031.00       3.00000       0.00000       0.00000       0.00000
 E   10472   1048.00       4.00000       0.00000       0.00000       0.00000
 E   10473   1063.00       1.00000       0.00000       0.00000       0.00000
 E   10474   1046.00       2.00000       0.00000       0.00000       0.00000
 E   10481   1032.00       3.00000       0.00000       0.00000       0.00000
 E   10482   1049.00       4.00000       0.00000       0.00000       0.00000
 E   10483   1064.00       1.00000       0.00000       0.00000       0.00000
 E   10484   1047.00       2.00000       0.00000       0.00000       0.00000
 E   10491   1033.00       3.00000       0.00000       0.00000       0.00000
 E   10492   1050.00       4.00000       0.00000       0.00000       0.00000
 E   10493   1065.00       1.00000       0.00000       0.00000       0.00000
 E   10494   1048.00       2.00000       0.00000       0.00000       0.00000
 E   10501   1034.00       3.00000       0.00000       0.00000       0.00000
 E   10502   1051.00       4.00000       0.00000       0.00000       0.00000
 E   10503   1066.00       1.00000       0.00000       0.00000       0.00000
 E   10504   1049.00       2.00000       0.00000       0.00000       0.00000
 E   10511   1035.00       3.00000       0.00000       0.00000       0.00000
 E   10512   1052.00       4.00000       0.00000       0.00000       0.00000
 E   10513   1067.00       1.00000       0.00000       0.00000       0.00000
 E   10514   1050.00       2.00000       0.00000       0.00000       0.00000
 E   10521   1036.00       3.00000       0.00000       0.00000       0.00000
 E   10522   1053.00       4.00000       0.00000       0.00000       0.00000
 E   10523   1068.00       1.00000       0.00000       0.00000       0.00000
 E   10524   1051.00       2.00000       0.00000       0.00000       0.00000
 E   10531   1037.00       3.00000       0.00000       0.00000       0.00000
 E   10532   1054.00       4.00000       0.00000       0.00000       0.00000
 E   10533   1069.00       1.00000       0.00000       0.00000       0.00000
 E   10534   1052.00       2.00000       0.00000       0.00000       0.00000
 E   10541   1038.00       3.00000       0.00000       0.00000       0.00000
 E   10542   1055.00       4.00000       0.00000       0.00000       0.00000
 E   10543   1070.00       1.00000       0.00000       0.00000       0.00000
 E   10544   1053.00       2.00000       0.00000       0.00000       0.00000
 E   10551   1039.00       3.00000       0.00000       0.00000       0.00000
 E   10552   1056.00       4.00000       0.00000       0.00000       0.00000
 E   10553   1071.00       1.00000       0.00000       0.00000       0.00000
 E   10554   1054.00       2.00000       0.00000       0.00000       0.00000
 E   10561   1040.00       3.00000       0.00000       0.00000       0.00000
 O   10562   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10563   1072.00       1.00000       0.00000       0.00000       0.00000
 E   10564   1055.00       2.00000       0.00000       0.00000       0.00000
 E   10571   1041.00       3.00000       0.00000       0.00000       0.00000
 E   10572   1058.00       4.00000       0.00000       0.00000       0.00000
 E   10573   1073.00       1.00000       0.00000       0.00000       0.00000
     10574   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10581   1042.00       3.00000       0.00000       0.00000       0.00000
 E   10582   1059.00       4.00000       0.00000       0.00000       0.00000
 E   10583   1074.00       1.00000       0.00000       0.00000       0.00000
 E   10584   1057.00       2.00000       0.00000       0.00000       0.00000
 E   10591   1043.00       3.00000       0.00000       0.00000       0.00000
 E   10592   1060.00       4.00000       0.00000       0.00000       0.00000
 E   10593   1075.00       1.00000       0.00000       0.00000       0.00000
 E   10594   1058.00       2.00000       0.00000       0.00000       0.00000
 E   10601   1044.00       3.00000       0.00000       0.00000       0.00000
 E   10602   1061.00       4.00000       0.00000       0.00000       0.00000
 E   10603   1076.00       1.00000       0.00000       0.00000       0.00000
 E   10604   1059.00       2.00000       0.00000       0.00000       0.00000
 E   10611   1045.00       3.00000       0.00000       0.00000       0.00000
 E   10612   1062.00       4.00000       0.00000       0.00000       0.00000
 E   10613   1077.00       1.00000       0.00000       0.00000       0.00000
 E   10614   1060.00       2.00000       0.00000       0.00000       0.00000
 E   10621   1046.00       3.00000       0.00000       0.00000       0.00000
 E   10622   1063.00       4.00000       0.00000       0.00000       0.00000
 E   10623   1078.00       1.00000       0.00000       0.00000       0.00000
 E   10624   1061.00       2.00000       0.00000       0.00000       0.00000
 E   10631   1047.00       3.00000       0.00000       0.00000       0.00000
 E   10632   1064.00       4.00000       0.00000       0.00000       0.00000
 E   10633   1079.00       1.00000       0.00000       0.00000       0.00000
 E   10634   1062.00       2.00000       0.00000       0.00000       0.00000
 E   10641   1048.00       3.00000       0.00000       0.00000       0.00000
 E   10642   1065.00       4.00000       0.00000       0.00000       0.00000
 E   10643   1080.00       1.00000       0.00000       0.00000       0.00000
 E   10644   1063.00       2.00000       0.00000       0.00000       0.00000
 E   10651   1049.00       3.00000       0.00000       0.00000       0.00000
 E   10652   1066.00       4.00000       0.00000       0.00000       0.00000
 E   10653   1081.00       1.00000       0.00000       0.00000       0.00000
 E   10654   1064.00       2.00000       0.00000       0.00000       0.00000
 E   10661   1050.00       3.00000       0.00000       0.00000       0.00000
 E   10662   1067.00       4.00000       0.00000       0.00000       0.00000
 E   10663   1082.00       1.00000       0.00000       0.00000       0.00000
 E   10664   1065.00       2.00000       0.00000       0.00000       0.00000
 E   10671   1051.00       3.00000       0.00000       0.00000       0.00000
 E   10672   1068.00       4.00000       0.00000       0.00000       0.00000
 E   10673   1083.00       1.00000       0.00000       0.00000       0.00000
 E   10674   1066.00       2.00000       0.00000       0.00000       0.00000
 E   10681   1052.00       3.00000       0.00000       0.00000       0.00000
 E   10682   1069.00       4.00000       0.00000       0.00000       0.00000
 E   10683   1084.00       1.00000       0.00000       0.00000       0.00000
 E   10684   1067.00       2.00000       0.00000       0.00000       0.00000
 E   10691   1053.00       3.00000       0.00000       0.00000       0.00000
 E   10692   1070.00       4.00000       0.00000       0.00000       0.00000
 E   10693   1085.00       1.00000       0.00000       0.00000       0.00000
 E   10694   1068.00       2.00000       0.00000       0.00000       0.00000
 E   10701   1054.00       3.00000       0.00000       0.00000       0.00000
 E   10702   1071.00       4.00000       0.00000       0.00000       0.00000
 E   10703   1086.00       1.00000       0.00000       0.00000       0.00000
 E   10704   1069.00       2.00000       0.00000       0.00000       0.00000
 E   10711   1055.00       3.00000       0.00000       0.00000       0.00000
 E   10712   1072.00       4.00000       0.00000       0.00000       0.00000
 E   10713   1087.00       1.00000       0.00000       0.00000       0.00000
 E   10714   1070.00       2.00000       0.00000       0.00000       0.00000
 E   10721   1056.00       3.00000       0.00000       0.00000       0.00000
 O   10722   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10723   1088.00       1.00000       0.00000       0.00000       0.00000
 E   10724   1071.00       2.00000       0.00000       0.00000       0.00000
 E   10731   1057.00       3.00000       0.00000       0.00000       0.00000
 E   10732   1074.00       4.00000       0.00000       0.00000       0.00000
 E   10733   1089.00       1.00000       0.00000       0.00000       0.00000
     10734   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10741   1058.00       3.00000       0.00000       0.00000       0.00000
 E   10742   1075.00       4.00000       0.00000       0.00000       0.00000
 E   10743   1090.00       1.00000       0.00000       0.00000       0.00000
 E   10744   1073.00       2.00000       0.00000       0.00000       0.00000
 E   10751   1059.00       3.00000       0.00000       0.00000       0.00000
 E   10752   1076.00       4.00000       0.00000       0.00000       0.00000
 E   10753   1091.00       1.00000       0.00000       0.00000       0.00000
 E   10754   1074.00       2.00000       0.00000       0.00000       0.00000
 E   10761   1060.00       3.00000       0.00000       0.00000       0.00000
 E   10762   1077.00       4.00000       0.00000       0.00000       0.00000
 E   10763   1092.00       1.00000       0.00000       0.00000       0.00000
 E   10764   1075.00       2.00000       0.00000       0.00000       0.00000
 E   10771   1061.00       3.00000       0.00000       0.00000       0.00000
 E   10772   1078.00       4.00000       0.00000       0.00000       0.00000
 E   10773   1093.00       1.00000       0.00000       0.00000       0.00000
 E   10774   1076.00       2.00000       0.00000       0.00000       0.00000
 E   10781   1062.00       3.00000       0.00000       0.00000       0.00000
 E   10782   1079.00       4.00000       0.00000       0.00000       0.00000
 E   10783   1094.00       1.00000       0.00000       0.00000       0.00000
 E   10784   1077.00       2.00000       0.00000       0.00000       0.00000
 E   10791   1063.00       3.00000       0.00000       0.00000       0.00000
 E   10792   1080.00       4.00000       0.00000       0.00000       0.00000
 E   10793   1095.00       1.00000       0.00000       0.00000       0.00000
 E   10794   1078.00       2.00000       0.00000       0.00000       0.00000
 E   10801   1064.00       3.00000       0.00000       0.00000       0.00000
 E   10802   1081.00       4.00000       0.00000       0.00000       0.00000
 E   10803   1096.00       1.00000       0.00000       0.00000       0.00000
 E   10804   1079.00       2.00000       0.00000       0.00000       0.00000
 E   10811   1065.00       3.00000       0.00000       0.00000       0.00000
 E   10812   1082.00       4.00000       0.00000       0.00000       0.00000
 E   10813   1097.00       1.00000       0.00000       0.00000       0.00000
 E   10814   1080.00       2.00000       0.00000       0.00000       0.00000
 E   10821   1066.00       3.00000       0.00000       0.00000       0.00000
 E   10822   1083.00       4.00000       0.00000       0.00000       0.00000
 E   10823   1098.00       1.00000       0.00000       0.00000       0.00000
 E   10824   1081.00       2.00000       0.00000       0.00000       0.00000
 E   10831   1067.00       3.00000       0.00000       0.00000       0.00000
 E   10832   1084.00       4.00000       0.00000       0.00000       0.00000
 E   10833   1099.00       1.00000       0.00000       0.00000       0.00000
 E   10834   1082.00       2.00000       0.00000       0.00000       0.00000
 E   10841   1068.00       3.00000       0.00000       0.00000       0.00000
 E   10842   1085.00       4.00000       0.00000       0.00000       0.00000
 E   10843   1100.00       1.00000       0.00000       0.00000       0.00000
 E   10844   1083.00       2.00000       0.00000       0.00000       0.00000
 E   10851   1069.00       3.00000       0.00000       0.00000       0.00000
 E   10852   1086.00       4.00000       0.00000       0.00000       0.00000
 E   10853   1101.00       1.00000       0.00000       0.00000       0.00000
 E   10854   1084.00       2.00000       0.00000       0.00000       0.00000
 E   10861   1070.00       3.00000       0.00000       0.00000       0.00000
 E   10862   1087.00       4.00000       0.00000       0.00000       0.00000
 E   10863   1102.00       1.00000       0.00000       0.00000       0.00000
 E   10864   1085.00       2.00000       0.00000       0.00000       0.00000
 E   10871   1071.00       3.00000       0.00000       0.00000       0.00000
 E   10872   1088.00       4.00000       0.00000       0.00000       0.00000
 E   10873   1103.00       1.00000       0.00000       0.00000       0.00000
 E   10874   1086.00       2.00000       0.00000       0.00000       0.00000
 E   10881   1072.00       3.00000       0.00000       0.00000       0.00000
 O   10882   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10883   1104.00       1.00000       0.00000       0.00000       0.00000
 E   10884   1087.00       2.00000       0.00000       0.00000       0.00000
 E   10891   1073.00       3.00000       0.00000       0.00000       0.00000
 E   10892   1090.00       4.00000       0.00000       0.00000       0.00000
 E   10893   1105.00       1.00000       0.00000       0.00000       0.00000
     10894   0.00000       0.00000       0.00000       0.00000       0.00000
 E   10901   1074.00       3.00000       0.00000       0.00000       0.00000
 E   10902   1091.00       4.00000       0.00000       0.00000       0.00000
 E   10903   1106.00       1.00000       0.00000       0.00000       0.00000
 E   10904   1089.00       2.00000       0.00000       0.00000       0.00000
 E   10911   1075.00       3.00000       0.00000       0.00000       0.00000
 E   10912   1092.00       4.00000       0.00000       0.00000       0.00000
 E   10913   1107.00       1.00000       0.00000       0.00000       0.00000
 E   10914   1090.00       2.00000       0.00000       0.00000       0.00000
 E   10921   1076.00       3.00000       0.00000       0.00000       0.00000
 E   10922   1093.00       4.00000       0.00000       0.00000       0.00000
 E   10923   1108.00       1.00000       0.00000       0.00000       0.00000
 E   10924   1091.00       2.00000       0.00000       0.00000       0.00000
 E   10931   1077.00       3.00000       0.00000       0.00000       0.00000
 E   10932   1094.00       4.00000       0.00000       0.00000       0.00000
 E   10933   1109.00       1.00000       0.00000       0.00000       0.00000
 E   10934   1092.00       2.00000       0.00000       0.00000       0.00000
 E   10941   1078.00       3.00000       0.00000       0.00000       0.00000
 E   10942   1095.00       4.00000       0.00000       0.00000       0.00000
 E   10943   1110.00       1.00000       0.00000       0.00000       0.00000
 E   10944   1093.00       2.00000       0.00000       0.00000       0.00000
 E   10951   1079.00       3.00000       0.00000       0.00000       0.00000
 E   10952   1096.00       4.00000       0.00000       0.00000       0.00000
 E   10953   1111.00       1.00000       0.00000       0.00000       0.00000
 E   10954   1094.00       2.00000       0.00000       0.00000       0.00000
 E   10961   1080.00       3.00000       0.00000       0.00000       0.00000
 E   10962   1097.00       4.00000       0.00000       0.00000       0.00000
 E   10963   1112.00       1.00000       0.00000       0.00000       0.00000
 E   10964   1095.00       2.00000       0.00000       0.00000       0.00000
 E   10971   1081.00       3.00000       0.00000       0.00000       0.00000
 E   10972   1098.00       4.00000       0.00000       0.00000       0.00000
 E   10973   1113.00       1.00000       0.00000       0.00000       0.00000
 E   10974   1096.00       2.00000       0.00000       0.00000       0.00000
 E   10981   1082.00       3.00000       0.00000       0.00000       0.00000
 E   10982   1099.00       4.00000       0.00000       0.00000       0.00000
 E   10983   1114.00       1.00000       0.00000       0.00000       0.00000
 E   10984   1097.00       2.00000       0.00000       0.00000       0.00000
 E   10991   1083.00       3.00000       0.00000       0.00000       0.00000
 E   10992   1100.00       4.00000       0.00000       0.00000       0.00000
 E   10993   1115.00       1.00000       0.00000       0.00000       0.00000
 E   10994   1098.00       2.00000       0.00000       0.00000       0.00000
 E   11001   1084.00       3.00000       0.00000       0.00000       0.00000
 E   11002   1101.00       4.00000       0.00000       0.00000       0.00000
 E   11003   1116.00       1.00000       0.00000       0.00000       0.00000
 E   11004   1099.00       2.00000       0.00000       0.00000       0.00000
 E   11011   1085.00       3.00000       0.00000       0.00000       0.00000
 E   11012   1102.00       4.00000       0.00000       0.00000       0.00000
 E   11013   1117.00       1.00000       0.00000       0.00000       0.00000
 E   11014   1100.00       2.00000       0.00000       0.00000       0.00000
 E   11021   1086.00       3.00000       0.00000       0.00000       0.00000
 E   11022   1103.00       4.00000       0.00000       0.00000       0.00000
 E   11023   1118.00       1.00000       0.00000       0.00000       0.00000
 E   11024   1101.00       2.00000       0.00000       0.00000       0.00000
 E   11031   1087.00       3.00000       0.00000       0.00000       0.00000
 E   11032   1104.00       4.00000       0.00000       0.00000       0.00000
 E   11033   1119.00       1.00000       0.00000       0.00000       0.00000
 E   11034   1102.00       2.00000       0.00000       0.00000       0.00000
 E   11041   1088.00       3.00000       0.00000       0.00000       0.00000
 O   11042   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11043   1120.00       1.00000       0.00000       0.00000       0.00000
 E   11044   1103.00       2.00000       0.00000       0.00000       0.00000
 E   11051   1089.00       3.00000       0.00000       0.00000       0.00000
 E   11052   1106.00       4.00000       0.00000       0.00000       0.00000
 E   11053   1121.00       1.00000       0.00000       0.00000       0.00000
     11054   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11061   1090.00       3.00000       0.00000       0.00000       0.00000
 E   11062   1107.00       4.00000       0.00000       0.00000       0.00000
 E   11063   1122.00       1.00000       0.00000       0.00000       0.00000
 E   11064   1105.00       2.00000       0.00000       0.00000       0.00000
 E   11071   1091.00       3.00000       0.00000       0.00000       0.00000
 E   11072   1108.00       4.00000       0.00000       0.00000       0.00000
 E   11073   1123.00       1.00000       0.00000       0.00000       0.00000
 E   11074   1106.00       2.00000       0.00000       0.00000       0.00000
 E   11081   1092.00       3.00000       0.00000       0.00000       0.00000
 E   11082   1109.00       4.00000       0.00000       0.00000       0.00000
 E   11083   1124.00       1.00000       0.00000       0.00000       0.00000
 E   11084   1107.00       2.00000       0.00000       0.00000       0.00000
 E   11091   1093.00       3.00000       0.00000       0.00000       0.00000
 E   11092   1110.00       4.00000       0.00000       0.00000       0.00000
 E   11093   1125.00       1.00000       0.00000       0.00000       0.00000
 E   11094   1108.00       2.00000       0.00000       0.00000       0.00000
 E   11101   1094.00       3.00000       0.00000       0.00000       0.00000
 E   11102   1111.00       4.00000       0.00000       0.00000       0.00000
 E   11103   1126.00       1.00000       0.00000       0.00000       0.00000
 E   11104   1109.00       2.00000       0.00000       0.00000       0.00000
 E   11111   1095.00       3.00000       0.00000       0.00000       0.00000
 E   11112   1112.00       4.00000       0.00000       0.00000       0.00000
 E   11113   1127.00       1.00000       0.00000       0.00000       0.00000
 E   11114   1110.00       2.00000       0.00000       0.00000       0.00000
 E   11121   1096.00       3.00000       0.00000       0.00000       0.00000
 E   11122   1113.00       4.00000       0.00000       0.00000       0.00000
 E   11123   1128.00       1.00000       0.00000       0.00000       0.00000
 E   11124   1111.00       2.00000       0.00000       0.00000       0.00000
 E   11131   1097.00       3.00000       0.00000       0.00000       0.00000
 E   11132   1114.00       4.00000       0.00000       0.00000       0.00000
 E   11133   1129.00       1.00000       0.00000       0.00000       0.00000
 E   11134   1112.00       2.00000       0.00000       0.00000       0.00000
 E   11141   1098.00       3.00000       0.00000       0.00000       0.00000
 E   11142   1115.00       4.00000       0.00000       0.00000       0.00000
 E   11143   1130.00       1.00000       0.00000       0.00000       0.00000
 E   11144   1113.00       2.00000       0.00000       0.00000       0.00000
 E   11151   1099.00       3.00000       0.00000       0.00000       0.00000
 E   11152   1116.00       4.00000       0.00000       0.00000       0.00000
 E   11153   1131.00       1.00000       0.00000       0.00000       0.00000
 E   11154   1114.00       2.00000       0.00000       0.00000       0.00000
 E   11161   1100.00       3.00000       0.00000       0.00000       0.00000
 E   11162   1117.00       4.00000       0.00000       0.00000       0.00000
 E   11163   1132.00       1.00000       0.00000       0.00000       0.00000
 E   11164   1115.00       2.00000       0.00000       0.00000       0.00000
 E   11171   1101.00       3.00000       0.00000       0.00000       0.00000
 E   11172   1118.00       4.00000       0.00000       0.00000       0.00000
 E   11173   1133.00       1.00000       0.00000       0.00000       0.00000
 E   11174   1116.00       2.00000       0.00000       0.00000       0.00000
 E   11181   1102.00       3.00000       0.00000       0.00000       0.00000
 E   11182   1119.00       4.00000       0.00000       0.00000       0.00000
 E   11183   1134.00       1.00000       0.00000       0.00000       0.00000
 E   11184   1117.00       2.00000       0.00000       0.00000       0.00000
 E   11191   1103.00       3.00000       0.00000       0.00000       0.00000
 E   11192   1120.00       4.00000       0.00000       0.00000       0.00000
 E   11193   1135.00       1.00000       0.00000       0.00000       0.00000
 E   11194   1118.00       2.00000       0.00000       0.00000       0.00000
 E   11201   1104.00       3.00000       0.00000       0.00000       0.00000
 O   11202   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11203   1136.00       1.00000       0.00000       0.00000       0.00000
 E   11204   1119.00       2.00000       0.00000       0.00000       0.00000
 E   11211   1105.00       3.00000       0.00000       0.00000       0.00000
 E   11212   1122.00       4.00000       0.00000       0.00000       0.00000
 E   11213   1137.00       1.00000       0.00000       0.00000       0.00000
     11214   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11221   1106.00       3.00000       0.00000       0.00000       0.00000
 E   11222   1123.00       4.00000       0.00000       0.00000       0.00000
 E   11223   1138.00       1.00000       0.00000       0.00000       0.00000
 E   11224   1121.00       2.00000       0.00000       0.00000       0.00000
 E   11231   1107.00       3.00000       0.00000       0.00000       0.00000
 E   11232   1124.00       4.00000       0.00000       0.00000       0.00000
 E   11233   1139.00       1.00000       0.00000       0.00000       0.00000
 E   11234   1122.00       2.00000       0.00000       0.00000       0.00000
 E   11241   1108.00       3.00000       0.00000       0.00000       0.00000
 E   11242   1125.00       4.00000       0.00000       0.00000       0.00000
 E   11243   1140.00       1.00000       0.00000       0.00000       0.00000
 E   11244   1123.00       2.00000       0.00000       0.00000       0.00000
 E   11251   1109.00       3.00000       0.00000       0.00000       0.00000
 E   11252   1126.00       4.00000       0.00000       0.00000       0.00000
 E   11253   1141.00       1.00000       0.00000       0.00000       0.00000
 E   11254   1124.00       2.00000       0.00000       0.00000       0.00000
 E   11261   1110.00       3.00000       0.00000       0.00000       0.00000
 E   11262   1127.00       4.00000       0.00000       0.00000       0.00000
 E   11263   1142.00       1.00000       0.00000       0.00000       0.00000
 E   11264   1125.00       2.00000       0.00000       0.00000       0.00000
 E   11271   1111.00       3.00000       0.00000       0.00000       0.00000
 E   11272   1128.00       4.00000       0.00000       0.00000       0.00000
 E   11273   1143.00       1.00000       0.00000       0.00000       0.00000
 E   11274   1126.00       2.00000       0.00000       0.00000       0.00000
 E   11281   1112.00       3.00000       0.00000       0.00000       0.00000
 E   11282   1129.00       4.00000       0.00000       0.00000       0.00000
 E   11283   1144.00       1.00000       0.00000       0.00000       0.00000
 E   11284   1127.00       2.00000       0.00000       0.00000       0.00000
 E   11291   1113.00       3.00000       0.00000       0.00000       0.00000
 E   11292   1130.00       4.00000       0.00000       0.00000       0.00000
 E   11293   1145.00       1.00000       0.00000       0.00000       0.00000
 E   11294   1128.00       2.00000       0.00000       0.00000       0.00000
 E   11301   1114.00       3.00000       0.00000       0.00000       0.00000
 E   11302   1131.00       4.00000       0.00000       0.00000       0.00000
 E   11303   1146.00       1.00000       0.00000       0.00000       0.00000
 E   11304   1129.00       2.00000       0.00000       0.00000       0.00000
 E   11311   1115.00       3.00000       0.00000       0.00000       0.00000
 E   11312   1132.00       4.00000       0.00000       0.00000       0.00000
 E   11313   1147.00       1.00000       0.00000       0.00000       0.00000
 E   11314   1130.00       2.00000       0.00000       0.00000       0.00000
 E   11321   1116.00       3.00000       0.00000       0.00000       0.00000
 E   11322   1133.00       4.00000       0.00000       0.00000       0.00000
 E   11323   1148.00       1.00000       0.00000       0.00000       0.00000
 E   11324   1131.00       2.00000       0.00000       0.00000       0.00000
 E   11331   1117.00       3.00000       0.00000       0.00000       0.00000
 E   11332   1134.00       4.00000       0.00000       0.00000       0.00000
 E   11333   1149.00       1.00000       0.00000       0.00000       0.00000
 E   11334   1132.00       2.00000       0.00000       0.00000       0.00000
 E   11341   1118.00       3.00000       0.00000       0.00000       0.00000
 E   11342   1135.00       4.00000       0.00000       0.00000       0.00000
 E   11343   1150.00       1.00000       0.00000       0.00000       0.00000
 E   11344   1133.00       2.00000       0.00000       0.00000       0.00000
 E   11351   1119.00       3.00000       0.00000       0.00000       0.00000
 E   11352   1136.00       4.00000       0.00000       0.00000       0.00000
 E   11353   1151.00       1.00000       0.00000       0.00000       0.00000
 E   11354   1134.00       2.00000       0.00000       0.00000       0.00000
 E   11361   1120.00       3.00000       0.00000       0.00000       0.00000
 O   11362   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11363   1152.00       1.00000       0.00000       0.00000       0.00000
 E   11364   1135.00       2.00000       0.00000       0.00000       0.00000
 E   11371   1121.00       3.00000       0.00000       0.00000       0.00000
 E   11372   1138.00       4.00000       0.00000       0.00000       0.00000
 E   11373   1153.00       1.00000       0.00000       0.00000       0.00000
     11374   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11381   1122.00       3.00000       0.00000       0.00000       0.00000
 E   11382   1139.00       4.00000       0.00000       0.00000       0.00000
 E   11383   1154.00       1.00000       0.00000       0.00000       0.00000
 E   11384   1137.00       2.00000       0.00000       0.00000       0.00000
 E   11391   1123.00       3.00000       0.00000       0.00000       0.00000
 E   11392   1140.00       4.00000       0.00000       0.00000       0.00000
 E   11393   1155.00       1.00000       0.00000       0.00000       0.00000
 E   11394   1138.00       2.00000       0.00000       0.00000       0.00000
 E   11401   1124.00       3.00000       0.00000       0.00000       0.00000
 E   11402   1141.00       4.00000       0.00000       0.00000       0.00000
 E   11403   1156.00       1.00000       0.00000       0.00000       0.00000
 E   11404   1139.00       2.00000       0.00000       0.00000       0.00000
 E   11411   1125.00       3.00000       0.00000       0.00000       0.00000
 E   11412   1142.00       4.00000       0.00000       0.00000       0.00000
 E   11413   1157.00       1.00000       0.00000       0.00000       0.00000
 E   11414   1140.00       2.00000       0.00000       0.00000       0.00000
 E   11421   1126.00       3.00000       0.00000       0.00000       0.00000
 E   11422   1143.00       4.00000       0.00000       0.00000       0.00000
 E   11423   1158.00       1.00000       0.00000       0.00000       0.00000
 E   11424   1141.00       2.00000       0.00000       0.00000       0.00000
 E   11431   1127.00       3.00000       0.00000       0.00000       0.00000
 E   11432   1144.00       4.00000       0.00000       0.00000       0.00000
 E   11433   1159.00       1.00000       0.00000       0.00000       0.00000
 E   11434   1142.00       2.00000       0.00000       0.00000       0.00000
 E   11441   1128.00       3.00000       0.00000       0.00000       0.00000
 E   11442   1145.00       4.00000       0.00000       0.00000       0.00000
 E   11443   1160.00       1.00000       0.00000       0.00000       0.00000
 E   11444   1143.00       2.00000       0.00000       0.00000       0.00000
 E   11451   1129.00       3.00000       0.00000       0.00000       0.00000
 E   11452   1146.00       4.00000       0.00000       0.00000       0.00000
 E   11453   1161.00       1.00000       0.00000       0.00000       0.00000
 E   11454   1144.00       2.00000       0.00000       0.00000       0.00000
 E   11461   1130.00       3.00000       0.00000       0.00000       0.00000
 E   11462   1147.00       4.00000       0.00000       0.00000       0.00000
 E   11463   1162.00       1.00000       0.00000       0.00000       0.00000
 E   11464   1145.00       2.00000       0.00000       0.00000       0.00000
 E   11471   1131.00       3.00000       0.00000       0.00000       0.00000
 E   11472   1148.00       4.00000       0.00000       0.00000       0.00000
 E   11473   1163.00       1.00000       0.00000       0.00000       0.00000
 E   11474   1146.00       2.00000       0.00000       0.00000       0.00000
 E   11481   1132.00       3.00000       0.00000       0.00000       0.00000
 E   11482   1149.00       4.00000       0.00000       0.00000       0.00000
 E   11483   1164.00       1.00000       0.00000       0.00000       0.00000
 E   11484   1147.00       2.00000       0.00000       0.00000       0.00000
 E   11491   1133.00       3.00000       0.00000       0.00000       0.00000
 E   11492   1150.00       4.00000       0.00000       0.00000       0.00000
 E   11493   1165.00       1.00000       0.00000       0.00000       0.00000
 E   11494   1148.00       2.00000       0.00000       0.00000       0.00000
 E   11501   1134.00       3.00000       0.00000       0.00000       0.00000
 E   11502   1151.00       4.00000       0.00000       0.00000       0.00000
 E   11503   1166.00       1.00000       0.00000       0.00000       0.00000
 E   11504   1149.00       2.00000       0.00000       0.00000       0.00000
 E   11511   1135.00       3.00000       0.00000       0.00000       0.00000
 E   11512   1152.00       4.00000       0.00000       0.00000       0.00000
 E   11513   1167.00       1.00000       0.00000       0.00000       0.00000
 E   11514   1150.00       2.00000       0.00000       0.00000       0.00000
 E   11521   1136.00       3.00000       0.00000       0.00000       0.00000
 O   11522   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11523   1168.00       1.00000       0.00000       0.00000       0.00000
 E   11524   1151.00       2.00000       0.00000       0.00000       0.00000
 E   11531   1137.00       3.00000       0.00000       0.00000       0.00000
 E   11532   1154.00       4.00000       0.00000       0.00000       0.00000
 E   11533   1169.00       1.00000       0.00000       0.00000       0.00000
     11534   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11541   1138.00       3.00000       0.00000       0.00000       0.00000
 E   11542   1155.00       4.00000       0.00000       0.00000       0.00000
 E   11543   1170.00       1.00000       0.00000       0.00000       0.00000
 E   11544   1153.00       2.00000       0.00000       0.00000       0.00000
 E   11551   1139.00       3.00000       0.00000       0.00000       0.00000
 E   11552   1156.00       4.00000       0.00000       0.00000       0.00000
 E   11553   1171.00       1.00000       0.00000       0.00000       0.00000
 E   11554   1154.00       2.00000       0.00000       0.00000       0.00000
 E   11561   1140.00       3.00000       0.00000       0.00000       0.00000
 E   11562   1157.00       4.00000       0.00000       0.00000       0.00000
 E   11563   1172.00       1.00000       0.00000       0.00000       0.00000
 E   11564   1155.00       2.00000       0.00000       0.00000       0.00000
 E   11571   1141.00       3.00000       0.00000       0.00000       0.00000
 E   11572   1158.00       4.00000       0.00000       0.00000       0.00000
 E   11573   1173.00       1.00000       0.00000       0.00000       0.00000
 E   11574   1156.00       2.00000       0.00000       0.00000       0.00000
 E   11581   1142.00       3.00000       0.00000       0.00000       0.00000
 E   11582   1159.00       4.00000       0.00000       0.00000       0.00000
 E   11583   1174.00       1.00000       0.00000       0.00000       0.00000
 E   11584   1157.00       2.00000       0.00000       0.00000       0.00000
 E   11591   1143.00       3.00000       0.00000       0.00000       0.00000
 E   11592   1160.00       4.00000       0.00000       0.00000       0.00000
 E   11593   1175.00       1.00000       0.00000       0.00000       0.00000
 E   11594   1158.00       2.00000       0.00000       0.00000       0.00000
 E   11601   1144.00       3.00000       0.00000       0.00000       0.00000
 E   11602   1161.00       4.00000       0.00000       0.00000       0.00000
 E   11603   1176.00       1.00000       0.00000       0.00000       0.00000
 E   11604   1159.00       2.00000       0.00000       0.00000       0.00000
 E   11611   1145.00       3.00000       0.00000       0.00000       0.00000
 E   11612   1162.00       4.00000       0.00000       0.00000       0.00000
 E   11613   1177.00       1.00000       0.00000       0.00000       0.00000
 E   11614   1160.00       2.00000       0.00000       0.00000       0.00000
 E   11621   1146.00       3.00000       0.00000       0.00000       0.00000
 E   11622   1163.00       4.00000       0.00000       0.00000       0.00000
 E   11623   1178.00       1.00000       0.00000       0.00000       0.00000
 E   11624   1161.00       2.00000       0.00000       0.00000       0.00000
 E   11631   1147.00       3.00000       0.00000       0.00000       0.00000
 E   11632   1164.00       4.00000       0.00000       0.00000       0.00000
 E   11633   1179.00       1.00000       0.00000       0.00000       0.00000
 E   11634   1162.00       2.00000       0.00000       0.00000       0.00000
 E   11641   1148.00       3.00000       0.00000       0.00000       0.00000
 E   11642   1165.00       4.00000       0.00000       0.00000       0.00000
 E   11643   1180.00       1.00000       0.00000       0.00000       0.00000
 E   11644   1163.00       2.00000       0.00000       0.00000       0.00000
 E   11651   1149.00       3.00000       0.00000       0.00000       0.00000
 E   11652   1166.00       4.00000       0.00000       0.00000       0.00000
 E   11653   1181.00       1.00000       0.00000       0.00000       0.00000
 E   11654   1164.00       2.00000       0.00000       0.00000       0.00000
 E   11661   1150.00       3.00000       0.00000       0.00000       0.00000
 E   11662   1167.00       4.00000       0.00000       0.00000       0.00000
 E   11663   1182.00       1.00000       0.00000       0.00000       0.00000
 E   11664   1165.00       2.00000       0.00000       0.00000       0.00000
 E   11671   1151.00       3.00000       0.00000       0.00000       0.00000
 E   11672   1168.00       4.00000       0.00000       0.00000       0.00000
 E   11673   1183.00       1.00000       0.00000       0.00000       0.00000
 E   11674   1166.00       2.00000       0.00000       0.00000       0.00000
 E   11681   1152.00       3.00000       0.00000       0.00000       0.00000
 O   11682   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11683   1184.00       1.00000       0.00000       0.00000       0.00000
 E   11684   1167.00       2.00000       0.00000       0.00000       0.00000
 E   11691   1153.00       3.00000       0.00000       0.00000       0.00000
 E   11692   1170.00       4.00000       0.00000       0.00000       0.00000
 E   11693   1185.00       1.00000       0.00000       0.00000       0.00000
     11694   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11701   1154.00       3.00000       0.00000       0.00000       0.00000
 E   11702   1171.00       4.00000       0.00000       0.00000       0.00000
 E   11703   1186.00       1.00000       0.00000       0.00000       0.00000
 E   11704   1169.00       2.00000       0.00000       0.00000       0.00000
 E   11711   1155.00       3.00000       0.00000       0.00000       0.00000
 E   11712   1172.00       4.00000       0.00000       0.00000       0.00000
 E   11713   1187.00       1.00000       0.00000       0.00000       0.00000
 E   11714   1170.00       2.00000       0.00000       0.00000       0.00000
 E   11721   1156.00       3.00000       0.00000       0.00000       0.00000
 E   11722   1173.00       4.00000       0.00000       0.00000       0.00000
 E   11723   1188.00       1.00000       0.00000       0.00000       0.00000
 E   11724   1171.00       2.00000       0.00000       0.00000       0.00000
 E   11731   1157.00       3.00000       0.00000       0.00000       0.00000
 E   11732   1174.00       4.00000       0.00000       0.00000       0.00000
 E   11733   1189.00       1.00000       0.00000       0.00000       0.00000
 E   11734   1172.00       2.00000       0.00000       0.00000       0.00000
 E   11741   1158.00       3.00000       0.00000       0.00000       0.00000
 E   11742   1175.00       4.00000       0.00000       0.00000       0.00000
 E   11743   1190.00       1.00000       0.00000       0.00000       0.00000
 E   11744   1173.00       2.00000       0.00000       0.00000       0.00000
 E   11751   1159.00       3.00000       0.00000       0.00000       0.00000
 E   11752   1176.00       4.00000       0.00000       0.00000       0.00000
 E   11753   1191.00       1.00000       0.00000       0.00000       0.00000
 E   11754   1174.00       2.00000       0.00000       0.00000       0.00000
 E   11761   1160.00       3.00000       0.00000       0.00000       0.00000
 E   11762   1177.00       4.00000       0.00000       0.00000       0.00000
 E   11763   1192.00       1.00000       0.00000       0.00000       0.00000
 E   11764   1175.00       2.00000       0.00000       0.00000       0.00000
 E   11771   1161.00       3.00000       0.00000       0.00000       0.00000
 E   11772   1178.00       4.00000       0.00000       0.00000       0.00000
 E   11773   1193.00       1.00000       0.00000       0.00000       0.00000
 E   11774   1176.00       2.00000       0.00000       0.00000       0.00000
 E   11781   1162.00       3.00000       0.00000       0.00000       0.00000
 E   11782   1179.00       4.00000       0.00000       0.00000       0.00000
 E   11783   1194.00       1.00000       0.00000       0.00000       0.00000
 E   11784   1177.00       2.00000       0.00000       0.00000       0.00000
 E   11791   1163.00       3.00000       0.00000       0.00000       0.00000
 E   11792   1180.00       4.00000       0.00000       0.00000       0.00000
 E   11793   1195.00       1.00000       0.00000       0.00000       0.00000
 E   11794   1178.00       2.00000       0.00000       0.00000       0.00000
 E   11801   1164.00       3.00000       0.00000       0.00000       0.00000
 E   11802   1181.00       4.00000       0.00000       0.00000       0.00000
 E   11803   1196.00       1.00000       0.00000       0.00000       0.00000
 E   11804   1179.00       2.00000       0.00000       0.00000       0.00000
 E   11811   1165.00       3.00000       0.00000       0.00000       0.00000
 E   11812   1182.00       4.00000       0.00000       0.00000       0.00000
 E   11813   1197.00       1.00000       0.00000       0.00000       0.00000
 E   11814   1180.00       2.00000       0.00000       0.00000       0.00000
 E   11821   1166.00       3.00000       0.00000       0.00000       0.00000
 E   11822   1183.00       4.00000       0.00000       0.00000       0.00000
 E   11823   1198.00       1.00000       0.00000       0.00000       0.00000
 E   11824   1181.00       2.00000       0.00000       0.00000       0.00000
 E   11831   1167.00       3.00000       0.00000       0.00000       0.00000
 E   11832   1184.00       4.00000       0.00000       0.00000       0.00000
 E   11833   1199.00       1.00000       0.00000       0.00000       0.00000
 E   11834   1182.00       2.00000       0.00000       0.00000       0.00000
 E   11841   1168.00       3.00000       0.00000       0.00000       0.00000
 O   11842   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11843   1200.00       1.00000       0.00000       0.00000       0.00000
 E   11844   1183.00       2.00000       0.00000       0.00000       0.00000
 E   11851   1169.00       3.00000       0.00000       0.00000       0.00000
 E   11852   1186.00       4.00000       0.00000       0.00000       0.00000
 E   11853   1201.00       1.00000       0.00000       0.00000       0.00000
     11854   0.00000       0.00000       0.00000       0.00000       0.00000
 E   11861   1170.00       3.00000       0.00000       0.00000       0.00000
 E   11862   1187.00       4.00000       0.00000       0.00000       0.00000
 E   11863   1202.00       1.00000       0.00000       0.00000       0.00000
 E   11864   1185.00       2.00000       0.00000       0.00000       0.00000
 E   11871   1171.00       3.00000       0.00000       0.00000       0.00000
 E   11872   1188.00       4.00000       0.00000       0.00000       0.00000
 E   11873   1203.00       1.00000       0.00000       0.00000       0.00000
 E   11874   1186.00       2.00000       0.00000       0.00000       0.00000
 E   11881   1172.00       3.00000       0.00000       0.00000       0.00000
 E   11882   1189.00       4.00000       0.00000       0.00000       0.00000
 E   11883   1204.00       1.00000       0.00000       0.00000       0.00000
 E   11884   1187.00       2.00000       0.00000       0.00000       0.00000
 E   11891   1173.00       3.00000       0.00000       0.00000       0.00000
 E   11892   1190.00       4.00000       0.00000       0.00000       0.00000
 E   11893   1205.00       1.00000       0.00000       0.00000       0.00000
 E   11894   1188.00       2.00000       0.00000       0.00000       0.00000
 E   11901   1174.00       3.00000       0.00000       0.00000       0.00000
 E   11902   1191.00       4.00000       0.00000       0.00000       0.00000
 E   11903   1206.00       1.00000       0.00000       0.00000       0.00000
 E   11904   1189.00       2.00000       0.00000       0.00000       0.00000
 E   11911   1175.00       3.00000       0.00000       0.00000       0.00000
 E   11912   1192.00       4.00000       0.00000       0.00000       0.00000
 E   11913   1207.00       1.00000       0.00000       0.00000       0.00000
 E   11914   1190.00       2.00000       0.00000       0.00000       0.00000
 E   11921   1176.00       3.00000       0.00000       0.00000       0.00000
 E   11922   1193.00       4.00000       0.00000       0.00000       0.00000
 E   11923   1208.00       1.00000       0.00000       0.00000       0.00000
 E   11924   1191.00       2.00000       0.00000       0.00000       0.00000
 E   11931   1177.00       3.00000       0.00000       0.00000       0.00000
 E   11932   1194.00       4.00000       0.00000       0.00000       0.00000
 E   11933   1209.00       1.00000       0.00000       0.00000       0.00000
 E   11934   1192.00       2.00000       0.00000       0.00000       0.00000
 E   11941   1178.00       3.00000       0.00000       0.00000       0.00000
 E   11942   1195.00       4.00000       0.00000       0.00000       0.00000
 E   11943   1210.00       1.00000       0.00000       0.00000       0.00000
 E   11944   1193.00       2.00000       0.00000       0.00000       0.00000
 E   11951   1179.00       3.00000       0.00000       0.00000       0.00000
 E   11952   1196.00       4.00000       0.00000       0.00000       0.00000
 E   11953   1211.00       1.00000       0.00000       0.00000       0.00000
 E   11954   1194.00       2.00000       0.00000       0.00000       0.00000
 E   11961   1180.00       3.00000       0.00000       0.00000       0.00000
 E   11962   1197.00       4.00000       0.00000       0.00000       0.00000
 E   11963   1212.00       1.00000       0.00000       0.00000       0.00000
 E   11964   1195.00       2.00000       0.00000       0.00000       0.00000
 E   11971   1181.00       3.00000       0.00000       0.00000       0.00000
 E   11972   1198.00       4.00000       0.00000       0.00000       0.00000
 E   11973   1213.00       1.00000       0.00000       0.00000       0.00000
 E   11974   1196.00       2.00000       0.00000       0.00000       0.00000
 E   11981   1182.00       3.00000       0.00000       0.00000       0.00000
 E   11982   1199.00       4.00000       0.00000       0.00000       0.00000
 E   11983   1214.00       1.00000       0.00000       0.00000       0.00000
 E   11984   1197.00       2.00000       0.00000       0.00000       0.00000
 E   11991   1183.00       3.00000       0.00000       0.00000       0.00000
 E   11992   1200.00       4.00000       0.00000       0.00000       0.00000
 E   11993   1215.00       1.00000       0.00000       0.00000       0.00000
 E   11994   1198.00       2.00000       0.00000       0.00000       0.00000
 E   12001   1184.00       3.00000       0.00000       0.00000       0.00000
 O   12002   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12003   1216.00       1.00000       0.00000       0.00000       0.00000
 E   12004   1199.00       2.00000       0.00000       0.00000       0.00000
 E   12011   1185.00       3.00000       0.00000       0.00000       0.00000
 E   12012   1202.00       4.00000       0.00000       0.00000       0.00000
 E   12013   1217.00       1.00000       0.00000       0.00000       0.00000
     12014   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12021   1186.00       3.00000       0.00000       0.00000       0.00000
 E   12022   1203.00       4.00000       0.00000       0.00000       0.00000
 E   12023   1218.00       1.00000       0.00000       0.00000       0.00000
 E   12024   1201.00       2.00000       0.00000       0.00000       0.00000
 E   12031   1187.00       3.00000       0.00000       0.00000       0.00000
 E   12032   1204.00       4.00000       0.00000       0.00000       0.00000
 E   12033   1219.00       1.00000       0.00000       0.00000       0.00000
 E   12034   1202.00       2.00000       0.00000       0.00000       0.00000
 E   12041   1188.00       3.00000       0.00000       0.00000       0.00000
 E   12042   1205.00       4.00000       0.00000       0.00000       0.00000
 E   12043   1220.00       1.00000       0.00000       0.00000       0.00000
 E   12044   1203.00       2.00000       0.00000       0.00000       0.00000
 E   12051   1189.00       3.00000       0.00000       0.00000       0.00000
 E   12052   1206.00       4.00000       0.00000       0.00000       0.00000
 E   12053   1221.00       1.00000       0.00000       0.00000       0.00000
 E   12054   1204.00       2.00000       0.00000       0.00000       0.00000
 E   12061   1190.00       3.00000       0.00000       0.00000       0.00000
 E   12062   1207.00       4.00000       0.00000       0.00000       0.00000
 E   12063   1222.00       1.00000       0.00000       0.00000       0.00000
 E   12064   1205.00       2.00000       0.00000       0.00000       0.00000
 E   12071   1191.00       3.00000       0.00000       0.00000       0.00000
 E   12072   1208.00       4.00000       0.00000       0.00000       0.00000
 E   12073   1223.00       1.00000       0.00000       0.00000       0.00000
 E   12074   1206.00       2.00000       0.00000       0.00000       0.00000
 E   12081   1192.00       3.00000       0.00000       0.00000       0.00000
 E   12082   1209.00       4.00000       0.00000       0.00000       0.00000
 E   12083   1224.00       1.00000       0.00000       0.00000       0.00000
 E   12084   1207.00       2.00000       0.00000       0.00000       0.00000
 E   12091   1193.00       3.00000       0.00000       0.00000       0.00000
 E   12092   1210.00       4.00000       0.00000       0.00000       0.00000
 E   12093   1225.00       1.00000       0.00000       0.00000       0.00000
 E   12094   1208.00       2.00000       0.00000       0.00000       0.00000
 E   12101   1194.00       3.00000       0.00000       0.00000       0.00000
 E   12102   1211.00       4.00000       0.00000       0.00000       0.00000
 E   12103   1226.00       1.00000       0.00000       0.00000       0.00000
 E   12104   1209.00       2.00000       0.00000       0.00000       0.00000
 E   12111   1195.00       3.00000       0.00000       0.00000       0.00000
 E   12112   1212.00       4.00000       0.00000       0.00000       0.00000
 E   12113   1227.00       1.00000       0.00000       0.00000       0.00000
 E   12114   1210.00       2.00000       0.00000       0.00000       0.00000
 E   12121   1196.00       3.00000       0.00000       0.00000       0.00000
 E   12122   1213.00       4.00000       0.00000       0.00000       0.00000
 E   12123   1228.00       1.00000       0.00000       0.00000       0.00000
 E   12124   1211.00       2.00000       0.00000       0.00000       0.00000
 E   12131   1197.00       3.00000       0.00000       0.00000       0.00000
 E   12132   1214.00       4.00000       0.00000       0.00000       0.00000
 E   12133   1229.00       1.00000       0.00000       0.00000       0.00000
 E   12134   1212.00       2.00000       0.00000       0.00000       0.00000
 E   12141   1198.00       3.00000       0.00000       0.00000       0.00000
 E   12142   1215.00       4.00000       0.00000       0.00000       0.00000
 E   12143   1230.00       1.00000       0.00000       0.00000       0.00000
 E   12144   1213.00       2.00000       0.00000       0.00000       0.00000
 E   12151   1199.00       3.00000       0.00000       0.00000       0.00000
 E   12152   1216.00       4.00000       0.00000       0.00000       0.00000
 E   12153   1231.00       1.00000       0.00000       0.00000       0.00000
 E   12154   1214.00       2.00000       0.00000       0.00000       0.00000
 E   12161   1200.00       3.00000       0.00000       0.00000       0.00000
 O   12162   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12163   1232.00       1.00000       0.00000       0.00000       0.00000
 E   12164   1215.00       2.00000       0.00000       0.00000       0.00000
 E   12171   1201.00       3.00000       0.00000       0.00000       0.00000
 E   12172   1218.00       4.00000       0.00000       0.00000       0.00000
 E   12173   1233.00       1.00000       0.00000       0.00000       0.00000
     12174   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12181   1202.00       3.00000       0.00000       0.00000       0.00000
 E   12182   1219.00       4.00000       0.00000       0.00000       0.00000
 E   12183   1234.00       1.00000       0.00000       0.00000       0.00000
 E   12184   1217.00       2.00000       0.00000       0.00000       0.00000
 E   12191   1203.00       3.00000       0.00000       0.00000       0.00000
 E   12192   1220.00       4.00000       0.00000       0.00000       0.00000
 E   12193   1235.00       1.00000       0.00000       0.00000       0.00000
 E   12194   1218.00       2.00000       0.00000       0.00000       0.00000
 E   12201   1204.00       3.00000       0.00000       0.00000       0.00000
 E   12202   1221.00       4.00000       0.00000       0.00000       0.00000
 E   12203   1236.00       1.00000       0.00000       0.00000       0.00000
 E   12204   1219.00       2.00000       0.00000       0.00000       0.00000
 E   12211   1205.00       3.00000       0.00000       0.00000       0.00000
 E   12212   1222.00       4.00000       0.00000       0.00000       0.00000
 E   12213   1237.00       1.00000       0.00000       0.00000       0.00000
 E   12214   1220.00       2.00000       0.00000       0.00000       0.00000
 E   12221   1206.00       3.00000       0.00000       0.00000       0.00000
 E   12222   1223.00       4.00000       0.00000       0.00000       0.00000
 E   12223   1238.00       1.00000       0.00000       0.00000       0.00000
 E   12224   1221.00       2.00000       0.00000       0.00000       0.00000
 E   12231   1207.00       3.00000       0.00000       0.00000       0.00000
 E   12232   1224.00       4.00000       0.00000       0.00000       0.00000
 E   12233   1239.00       1.00000       0.00000       0.00000       0.00000
 E   12234   1222.00       2.00000       0.00000       0.00000       0.00000
 E   12241   1208.00       3.00000       0.00000       0.00000       0.00000
 E   12242   1225.00       4.00000       0.00000       0.00000       0.00000
 E   12243   1240.00       1.00000       0.00000       0.00000       0.00000
 E   12244   1223.00       2.00000       0.00000       0.00000       0.00000
 E   12251   1209.00       3.00000       0.00000       0.00000       0.00000
 E   12252   1226.00       4.00000       0.00000       0.00000       0.00000
 E   12253   1241.00       1.00000       0.00000       0.00000       0.00000
 E   12254   1224.00       2.00000       0.00000       0.00000       0.00000
 E   12261   1210.00       3.00000       0.00000       0.00000       0.00000
 E   12262   1227.00       4.00000       0.00000       0.00000       0.00000
 E   12263   1242.00       1.00000       0.00000       0.00000       0.00000
 E   12264   1225.00       2.00000       0.00000       0.00000       0.00000
 E   12271   1211.00       3.00000       0.00000       0.00000       0.00000
 E   12272   1228.00       4.00000       0.00000       0.00000       0.00000
 E   12273   1243.00       1.00000       0.00000       0.00000       0.00000
 E   12274   1226.00       2.00000       0.00000       0.00000       0.00000
 E   12281   1212.00       3.00000       0.00000       0.00000       0.00000
 E   12282   1229.00       4.00000       0.00000       0.00000       0.00000
 E   12283   1244.00       1.00000       0.00000       0.00000       0.00000
 E   12284   1227.00       2.00000       0.00000       0.00000       0.00000
 E   12291   1213.00       3.00000       0.00000       0.00000       0.00000
 E   12292   1230.00       4.00000       0.00000       0.00000       0.00000
 E   12293   1245.00       1.00000       0.00000       0.00000       0.00000
 E   12294   1228.00       2.00000       0.00000       0.00000       0.00000
 E   12301   1214.00       3.00000       0.00000       0.00000       0.00000
 E   12302   1231.00       4.00000       0.00000       0.00000       0.00000
 E   12303   1246.00       1.00000       0.00000       0.00000       0.00000
 E   12304   1229.00       2.00000       0.00000       0.00000       0.00000
 E   12311   1215.00       3.00000       0.00000       0.00000       0.00000
 E   12312   1232.00       4.00000       0.00000       0.00000       0.00000
 E   12313   1247.00       1.00000       0.00000       0.00000       0.00000
 E   12314   1230.00       2.00000       0.00000       0.00000       0.00000
 E   12321   1216.00       3.00000       0.00000       0.00000       0.00000
 O   12322   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12323   1248.00       1.00000       0.00000       0.00000       0.00000
 E   12324   1231.00       2.00000       0.00000       0.00000       0.00000
 E   12331   1217.00       3.00000       0.00000       0.00000       0.00000
 E   12332   1234.00       4.00000       0.00000       0.00000       0.00000
 E   12333   1249.00       1.00000       0.00000       0.00000       0.00000
     12334   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12341   1218.00       3.00000       0.00000       0.00000       0.00000
 E   12342   1235.00       4.00000       0.00000       0.00000       0.00000
 E   12343   1250.00       1.00000       0.00000       0.00000       0.00000
 E   12344   1233.00       2.00000       0.00000       0.00000       0.00000
 E   12351   1219.00       3.00000       0.00000       0.00000       0.00000
 E   12352   1236.00       4.00000       0.00000       0.00000       0.00000
 E   12353   1251.00       1.00000       0.00000       0.00000       0.00000
 E   12354   1234.00       2.00000       0.00000       0.00000       0.00000
 E   12361   1220.00       3.00000       0.00000       0.00000       0.00000
 E   12362   1237.00       4.00000       0.00000       0.00000       0.00000
 E   12363   1252.00       1.00000       0.00000       0.00000       0.00000
 E   12364   1235.00       2.00000       0.00000       0.00000       0.00000
 E   12371   1221.00       3.00000       0.00000       0.00000       0.00000
 E   12372   1238.00       4.00000       0.00000       0.00000       0.00000
 E   12373   1253.00       1.00000       0.00000       0.00000       0.00000
 E   12374   1236.00       2.00000       0.00000       0.00000       0.00000
 E   12381   1222.00       3.00000       0.00000       0.00000       0.00000
 E   12382   1239.00       4.00000       0.00000       0.00000       0.00000
 E   12383   1254.00       1.00000       0.00000       0.00000       0.00000
 E   12384   1237.00       2.00000       0.00000       0.00000       0.00000
 E   12391   1223.00       3.00000       0.00000       0.00000       0.00000
 E   12392   1240.00       4.00000       0.00000       0.00000       0.00000
 E   12393   1255.00       1.00000       0.00000       0.00000       0.00000
 E   12394   1238.00       2.00000       0.00000       0.00000       0.00000
 E   12401   1224.00       3.00000       0.00000       0.00000       0.00000
 E   12402   1241.00       4.00000       0.00000       0.00000       0.00000
 E   12403   1256.00       1.00000       0.00000       0.00000       0.00000
 E   12404   1239.00       2.00000       0.00000       0.00000       0.00000
 E   12411   1225.00       3.00000       0.00000       0.00000       0.00000
 E   12412   1242.00       4.00000       0.00000       0.00000       0.00000
 E   12413   1257.00       1.00000       0.00000       0.00000       0.00000
 E   12414   1240.00       2.00000       0.00000       0.00000       0.00000
 E   12421   1226.00       3.00000       0.00000       0.00000       0.00000
 E   12422   1243.00       4.00000       0.00000       0.00000       0.00000
 E   12423   1258.00       1.00000       0.00000       0.00000       0.00000
 E   12424   1241.00       2.00000       0.00000       0.00000       0.00000
 E   12431   1227.00       3.00000       0.00000       0.00000       0.00000
 E   12432   1244.00       4.00000       0.00000       0.00000       0.00000
 E   12433   1259.00       1.00000       0.00000       0.00000       0.00000
 E   12434   1242.00       2.00000       0.00000       0.00000       0.00000
 E   12441   1228.00       3.00000       0.00000       0.00000       0.00000
 E   12442   1245.00       4.00000       0.00000       0.00000       0.00000
 E   12443   1260.00       1.00000       0.00000       0.00000       0.00000
 E   12444   1243.00       2.00000       0.00000       0.00000       0.00000
 E   12451   1229.00       3.00000       0.00000       0.00000       0.00000
 E   12452   1246.00       4.00000       0.00000       0.00000       0.00000
 E   12453   1261.00       1.00000       0.00000       0.00000       0.00000
 E   12454   1244.00       2.00000       0.00000       0.00000       0.00000
 E   12461   1230.00       3.00000       0.00000       0.00000       0.00000
 E   12462   1247.00       4.00000       0.00000       0.00000       0.00000
 E   12463   1262.00       1.00000       0.00000       0.00000       0.00000
 E   12464   1245.00       2.00000       0.00000       0.00000       0.00000
 E   12471   1231.00       3.00000       0.00000       0.00000       0.00000
 E   12472   1248.00       4.00000       0.00000       0.00000       0.00000
 E   12473   1263.00       1.00000       0.00000       0.00000       0.00000
 E   12474   1246.00       2.00000       0.00000       0.00000       0.00000
 E   12481   1232.00       3.00000       0.00000       0.00000       0.00000
 O   12482   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12483   1264.00       1.00000       0.00000       0.00000       0.00000
 E   12484   1247.00       2.00000       0.00000       0.00000       0.00000
 E   12491   1233.00       3.00000       0.00000       0.00000       0.00000
 E   12492   1250.00       4.00000       0.00000       0.00000       0.00000
 E   12493   1265.00       1.00000       0.00000       0.00000       0.00000
     12494   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12501   1234.00       3.00000       0.00000       0.00000       0.00000
 E   12502   1251.00       4.00000       0.00000       0.00000       0.00000
 E   12503   1266.00       1.00000       0.00000       0.00000       0.00000
 E   12504   1249.00       2.00000       0.00000       0.00000       0.00000
 E   12511   1235.00       3.00000       0.00000       0.00000       0.00000
 E   12512   1252.00       4.00000       0.00000       0.00000       0.00000
 E   12513   1267.00       1.00000       0.00000       0.00000       0.00000
 E   12514   1250.00       2.00000       0.00000       0.00000       0.00000
 E   12521   1236.00       3.00000       0.00000       0.00000       0.00000
 E   12522   1253.00       4.00000       0.00000       0.00000       0.00000
 E   12523   1268.00       1.00000       0.00000       0.00000       0.00000
 E   12524   1251.00       2.00000       0.00000       0.00000       0.00000
 E   12531   1237.00       3.00000       0.00000       0.00000       0.00000
 E   12532   1254.00       4.00000       0.00000       0.00000       0.00000
 E   12533   1269.00       1.00000       0.00000       0.00000       0.00000
 E   12534   1252.00       2.00000       0.00000       0.00000       0.00000
 E   12541   1238.00       3.00000       0.00000       0.00000       0.00000
 E   12542   1255.00       4.00000       0.00000       0.00000       0.00000
 E   12543   1270.00       1.00000       0.00000       0.00000       0.00000
 E   12544   1253.00       2.00000       0.00000       0.00000       0.00000
 E   12551   1239.00       3.00000       0.00000       0.00000       0.00000
 E   12552   1256.00       4.00000       0.00000       0.00000       0.00000
 E   12553   1271.00       1.00000       0.00000       0.00000       0.00000
 E   12554   1254.00       2.00000       0.00000       0.00000       0.00000
 E   12561   1240.00       3.00000       0.00000       0.00000       0.00000
 E   12562   1257.00       4.00000       0.00000       0.00000       0.00000
 E   12563   1272.00       1.00000       0.00000       0.00000       0.00000
 E   12564   1255.00       2.00000       0.00000       0.00000       0.00000
 E   12571   1241.00       3.00000       0.00000       0.00000       0.00000
 E   12572   1258.00       4.00000       0.00000       0.00000       0.00000
 E   12573   1273.00       1.00000       0.00000       0.00000       0.00000
 E   12574   1256.00       2.00000       0.00000       0.00000       0.00000
 E   12581   1242.00       3.00000       0.00000       0.00000       0.00000
 E   12582   1259.00       4.00000       0.00000       0.00000       0.00000
 E   12583   1274.00       1.00000       0.00000       0.00000       0.00000
 E   12584   1257.00       2.00000       0.00000       0.00000       0.00000
 E   12591   1243.00       3.00000       0.00000       0.00000       0.00000
 E   12592   1260.00       4.00000       0.00000       0.00000       0.00000
 E   12593   1275.00       1.00000       0.00000       0.00000       0.00000
 E   12594   1258.00       2.00000       0.00000       0.00000       0.00000
 E   12601   1244.00       3.00000       0.00000       0.00000       0.00000
 E   12602   1261.00       4.00000       0.00000       0.00000       0.00000
 E   12603   1276.00       1.00000       0.00000       0.00000       0.00000
 E   12604   1259.00       2.00000       0.00000       0.00000       0.00000
 E   12611   1245.00       3.00000       0.00000       0.00000       0.00000
 E   12612   1262.00       4.00000       0.00000       0.00000       0.00000
 E   12613   1277.00       1.00000       0.00000       0.00000       0.00000
 E   12614   1260.00       2.00000       0.00000       0.00000       0.00000
 E   12621   1246.00       3.00000       0.00000       0.00000       0.00000
 E   12622   1263.00       4.00000       0.00000       0.00000       0.00000
 E   12623   1278.00       1.00000       0.00000       0.00000       0.00000
 E   12624   1261.00       2.00000       0.00000       0.00000       0.00000
 E   12631   1247.00       3.00000       0.00000       0.00000       0.00000
 E   12632   1264.00       4.00000       0.00000       0.00000       0.00000
 E   12633   1279.00       1.00000       0.00000       0.00000       0.00000
 E   12634   1262.00       2.00000       0.00000       0.00000       0.00000
 E   12641   1248.00       3.00000       0.00000       0.00000       0.00000
 O   12642   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12643   1280.00       1.00000       0.00000       0.00000       0.00000
 E   12644   1263.00       2.00000       0.00000       0.00000       0.00000
 E   12651   1249.00       3.00000       0.00000       0.00000       0.00000
 E   12652   1266.00       4.00000       0.00000       0.00000       0.00000
     12653   0.00000       0.00000       0.00000       0.00000       0.00000
     12654   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12661   1250.00       3.00000       0.00000       0.00000       0.00000
 E   12662   1267.00       4.00000       0.00000       0.00000       0.00000
     12663   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12664   1265.00       2.00000       0.00000       0.00000       0.00000
 E   12671   1251.00       3.00000       0.00000       0.00000       0.00000
 E   12672   1268.00       4.00000       0.00000       0.00000       0.00000
     12673   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12674   1266.00       2.00000       0.00000       0.00000       0.00000
 E   12681   1252.00       3.00000       0.00000       0.00000       0.00000
 E   12682   1269.00       4.00000       0.00000       0.00000       0.00000
     12683   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12684   1267.00       2.00000       0.00000       0.00000       0.00000
 E   12691   1253.00       3.00000       0.00000       0.00000       0.00000
 E   12692   1270.00       4.00000       0.00000       0.00000       0.00000
     12693   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12694   1268.00       2.00000       0.00000       0.00000       0.00000
 E   12701   1254.00       3.00000       0.00000       0.00000       0.00000
 E   12702   1271.00       4.00000       0.00000       0.00000       0.00000
     12703   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12704   1269.00       2.00000       0.00000       0.00000       0.00000
 E   12711   1255.00       3.00000       0.00000       0.00000       0.00000
 E   12712   1272.00       4.00000       0.00000       0.00000       0.00000
     12713   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12714   1270.00       2.00000       0.00000       0.00000       0.00000
 E   12721   1256.00       3.00000       0.00000       0.00000       0.00000
 E   12722   1273.00       4.00000       0.00000       0.00000       0.00000
     12723   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12724   1271.00       2.00000       0.00000       0.00000       0.00000
 E   12731   1257.00       3.00000       0.00000       0.00000       0.00000
 E   12732   1274.00       4.00000       0.00000       0.00000       0.00000
     12733   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12734   1272.00       2.00000       0.00000       0.00000       0.00000
 E   12741   1258.00       3.00000       0.00000       0.00000       0.00000
 E   12742   1275.00       4.00000       0.00000       0.00000       0.00000
     12743   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12744   1273.00       2.00000       0.00000       0.00000       0.00000
 E   12751   1259.00       3.00000       0.00000       0.00000       0.00000
 E   12752   1276.00       4.00000       0.00000       0.00000       0.00000
     12753   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12754   1274.00       2.00000       0.00000       0.00000       0.00000
 E   12761   1260.00       3.00000       0.00000       0.00000       0.00000
 E   12762   1277.00       4.00000       0.00000       0.00000       0.00000
     12763   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12764   1275.00       2.00000       0.00000       0.00000       0.00000
 E   12771   1261.00       3.00000       0.00000       0.00000       0.00000
 E   12772   1278.00       4.00000       0.00000       0.00000       0.00000
     12773   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12774   1276.00       2.00000       0.00000       0.00000       0.00000
 E   12781   1262.00       3.00000       0.00000       0.00000       0.00000
 E   12782   1279.00       4.00000       0.00000       0.00000       0.00000
     12783   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12784   1277.00       2.00000       0.00000       0.00000       0.00000
 E   12791   1263.00       3.00000       0.00000       0.00000       0.00000
 E   12792   1280.00       4.00000       0.00000       0.00000       0.00000
     12793   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12794   1278.00       2.00000       0.00000       0.00000       0.00000
 E   12801   1264.00       3.00000       0.00000       0.00000       0.00000
 O   12802   0.00000       0.00000       0.00000       0.00000       0.00000
     12803   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12804   1279.00       2.00000       0.00000       0.00000       0.00000
     12811   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12812   1282.00       4.00000       0.00000       0.00000       0.00000
 E   12813   1297.00       1.00000       0.00000       0.00000       0.00000
     12814   0.00000       0.00000       0.00000       0.00000       0.00000
     12821   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12822   1283.00       4.00000       0.00000       0.00000       0.00000
 E   12823   1298.00       1.00000       0.00000       0.00000       0.00000
 E   12824   1281.00       2.00000       0.00000       0.00000       0.00000
     12831   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12832   1284.00       4.00000       0.00000       0.00000       0.00000
 E   12833   1299.00       1.00000       0.00000       0.00000       0.00000
 E   12834   1282.00       2.00000       0.00000       0.00000       0.00000
     12841   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12842   1285.00       4.00000       0.00000       0.00000       0.00000
 E   12843   1300.00       1.00000       0.00000       0.00000       0.00000
 E   12844   1283.00       2.00000       0.00000       0.00000       0.00000
     12851   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12852   1286.00       4.00000       0.00000       0.00000       0.00000
 E   12853   1301.00       1.00000       0.00000       0.00000       0.00000
 E   12854   1284.00       2.00000       0.00000       0.00000       0.00000
     12861   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12862   1287.00       4.00000       0.00000       0.00000       0.00000
 E   12863   1302.00       1.00000       0.00000       0.00000       0.00000
 E   12864   1285.00       2.00000       0.00000       0.00000       0.00000
     12871   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12872   1288.00       4.00000       0.00000       0.00000       0.00000
 E   12873   1303.00       1.00000       0.00000       0.00000       0.00000
 E   12874   1286.00       2.00000       0.00000       0.00000       0.00000
     12881   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12882   1289.00       4.00000       0.00000       0.00000       0.00000
 E   12883   1304.00       1.00000       0.00000       0.00000       0.00000
 E   12884   1287.00       2.00000       0.00000       0.00000       0.00000
     12891   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12892   1290.00       4.00000       0.00000       0.00000       0.00000
 E   12893   1305.00       1.00000       0.00000       0.00000       0.00000
 E   12894   1288.00       2.00000       0.00000       0.00000       0.00000
     12901   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12902   1291.00       4.00000       0.00000       0.00000       0.00000
 E   12903   1306.00       1.00000       0.00000       0.00000       0.00000
 E   12904   1289.00       2.00000       0.00000       0.00000       0.00000
     12911   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12912   1292.00       4.00000       0.00000       0.00000       0.00000
 E   12913   1307.00       1.00000       0.00000       0.00000       0.00000
 E   12914   1290.00       2.00000       0.00000       0.00000       0.00000
     12921   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12922   1293.00       4.00000       0.00000       0.00000       0.00000
 E   12923   1308.00       1.00000       0.00000       0.00000       0.00000
 E   12924   1291.00       2.00000       0.00000       0.00000       0.00000
     12931   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12932   1294.00       4.00000       0.00000       0.00000       0.00000
 E   12933   1309.00       1.00000       0.00000       0.00000       0.00000
 E   12934   1292.00       2.00000       0.00000       0.00000       0.00000
     12941   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12942   1295.00       4.00000       0.00000       0.00000       0.00000
 E   12943   1310.00       1.00000       0.00000       0.00000       0.00000
 E   12944   1293.00       2.00000       0.00000       0.00000       0.00000
     12951   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12952   1296.00       4.00000       0.00000       0.00000       0.00000
 E   12953   1311.00       1.00000       0.00000       0.00000       0.00000
 E   12954   1294.00       2.00000       0.00000       0.00000       0.00000
     12961   0.00000       0.00000       0.00000       0.00000       0.00000
 O   12962   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12963   1312.00       1.00000       0.00000       0.00000       0.00000
 E   12964   1295.00       2.00000       0.00000       0.00000       0.00000
 E   12971   1281.00       3.00000       0.00000       0.00000       0.00000
 E   12972   1298.00       4.00000       0.00000       0.00000       0.00000
 E   12973   1313.00       1.00000       0.00000       0.00000       0.00000
     12974   0.00000       0.00000       0.00000       0.00000       0.00000
 E   12981   1282.00       3.00000       0.00000       0.00000       0.00000
 E   12982   1299.00       4.00000       0.00000       0.00000       0.00000
 E   12983   1314.00       1.00000       0.00000       0.00000       0.00000
 E   12984   1297.00       2.00000       0.00000       0.00000       0.00000
 E   12991   1283.00       3.00000       0.00000       0.00000       0.00000
 E   12992   1300.00       4.00000       0.00000       0.00000       0.00000
 E   12993   1315.00       1.00000       0.00000       0.00000       0.00000
 E   12994   1298.00       2.00000       0.00000       0.00000       0.00000
 E   13001   1284.00       3.00000       0.00000       0.00000       0.00000
 E   13002   1301.00       4.00000       0.00000       0.00000       0.00000
 E   13003   1316.00       1.00000       0.00000       0.00000       0.00000
 E   13004   1299.00       2.00000       0.00000       0.00000       0.00000
 E   13011   1285.00       3.00000       0.00000       0.00000       0.00000
 E   13012   1302.00       4.00000       0.00000       0.00000       0.00000
 E   13013   1317.00       1.00000       0.00000       0.00000       0.00000
 E   13014   1300.00       2.00000       0.00000       0.00000       0.00000
 E   13021   1286.00       3.00000       0.00000       0.00000       0.00000
 E   13022   1303.00       4.00000       0.00000       0.00000       0.00000
 E   13023   1318.00       1.00000       0.00000       0.00000       0.00000
 E   13024   1301.00       2.00000       0.00000       0.00000       0.00000
 E   13031   1287.00       3.00000       0.00000       0.00000       0.00000
 E   13032   1304.00       4.00000       0.00000       0.00000       0.00000
 E   13033   1319.00       1.00000       0.00000       0.00000       0.00000
 E   13034   1302.00       2.00000       0.00000       0.00000       0.00000
 E   13041   1288.00       3.00000       0.00000       0.00000       0.00000
 E   13042   1305.00       4.00000       0.00000       0.00000       0.00000
 E   13043   1320.00       1.00000       0.00000       0.00000       0.00000
 E   13044   1303.00       2.00000       0.00000       0.00000       0.00000
 E   13051   1289.00       3.00000       0.00000       0.00000       0.00000
 E   13052   1306.00       4.00000       0.00000       0.00000       0.00000
 E   13053   1321.00       1.00000       0.00000       0.00000       0.00000
 E   13054   1304.00       2.00000       0.00000       0.00000       0.00000
 E   13061   1290.00       3.00000       0.00000       0.00000       0.00000
 E   13062   1307.00       4.00000       0.00000       0.00000       0.00000
 E   13063   1322.00       1.00000       0.00000       0.00000       0.00000
 E   13064   1305.00       2.00000       0.00000       0.00000       0.00000
 E   13071   1291.00       3.00000       0.00000       0.00000       0.00000
 E   13072   1308.00       4.00000       0.00000       0.00000       0.00000
 E   13073   1323.00       1.00000       0.00000       0.00000       0.00000
 E   13074   1306.00       2.00000       0.00000       0.00000       0.00000
 E   13081   1292.00       3.00000       0.00000       0.00000       0.00000
 E   13082   1309.00       4.00000       0.00000       0.00000       0.00000
 E   13083   1324.00       1.00000       0.00000       0.00000       0.00000
 E   13084   1307.00       2.00000       0.00000       0.00000       0.00000
 E   13091   1293.00       3.00000       0.00000       0.00000       0.00000
 E   13092   1310.00       4.00000       0.00000       0.00000       0.00000
 E   13093   1325.00       1.00000       0.00000       0.00000       0.00000
 E   13094   1308.00       2.00000       0.00000       0.00000       0.00000
 E   13101   1294.00       3.00000       0.00000       0.00000       0.00000
 E   13102   1311.00       4.00000       0.00000       0.00000       0.00000
 E   13103   1326.00       1.00000       0.00000       0.00000       0.00000
 E   13104   1309.00       2.00000       0.00000       0.00000       0.00000
 E   13111   1295.00       3.00000       0.00000       0.00000       0.00000
 E   13112   1312.00       4.00000       0.00000       0.00000       0.00000
 E   13113   1327.00       1.00000       0.00000       0.00000       0.00000
 E   13114   1310.00       2.00000       0.00000       0.00000       0.00000
 E   13121   1296.00       3.00000       0.00000       0.00000       0.00000
 O   13122   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13123   1328.00       1.00000       0.00000       0.00000       0.00000
 E   13124   1311.00       2.00000       0.00000       0.00000       0.00000
 E   13131   1297.00       3.00000       0.00000       0.00000       0.00000
 E   13132   1314.00       4.00000       0.00000       0.00000       0.00000
 E   13133   1329.00       1.00000       0.00000       0.00000       0.00000
     13134   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13141   1298.00       3.00000       0.00000       0.00000       0.00000
 E   13142   1315.00       4.00000       0.00000       0.00000       0.00000
 E   13143   1330.00       1.00000       0.00000       0.00000       0.00000
 E   13144   1313.00       2.00000       0.00000       0.00000       0.00000
 E   13151   1299.00       3.00000       0.00000       0.00000       0.00000
 E   13152   1316.00       4.00000       0.00000       0.00000       0.00000
 E   13153   1331.00       1.00000       0.00000       0.00000       0.00000
 E   13154   1314.00       2.00000       0.00000       0.00000       0.00000
 E   13161   1300.00       3.00000       0.00000       0.00000       0.00000
 E   13162   1317.00       4.00000       0.00000       0.00000       0.00000
 E   13163   1332.00       1.00000       0.00000       0.00000       0.00000
 E   13164   1315.00       2.00000       0.00000       0.00000       0.00000
 E   13171   1301.00       3.00000       0.00000       0.00000       0.00000
 E   13172   1318.00       4.00000       0.00000       0.00000       0.00000
 E   13173   1333.00       1.00000       0.00000       0.00000       0.00000
 E   13174   1316.00       2.00000       0.00000       0.00000       0.00000
 E   13181   1302.00       3.00000       0.00000       0.00000       0.00000
 E   13182   1319.00       4.00000       0.00000       0.00000       0.00000
 E   13183   1334.00       1.00000       0.00000       0.00000       0.00000
 E   13184   1317.00       2.00000       0.00000       0.00000       0.00000
 E   13191   1303.00       3.00000       0.00000       0.00000       0.00000
 E   13192   1320.00       4.00000       0.00000       0.00000       0.00000
 E   13193   1335.00       1.00000       0.00000       0.00000       0.00000
 E   13194   1318.00       2.00000       0.00000       0.00000       0.00000
 E   13201   1304.00       3.00000       0.00000       0.00000       0.00000
 E   13202   1321.00       4.00000       0.00000       0.00000       0.00000
 E   13203   1336.00       1.00000       0.00000       0.00000       0.00000
 E   13204   1319.00       2.00000       0.00000       0.00000       0.00000
 E   13211   1305.00       3.00000       0.00000       0.00000       0.00000
 E   13212   1322.00       4.00000       0.00000       0.00000       0.00000
 E   13213   1337.00       1.00000       0.00000       0.00000       0.00000
 E   13214   1320.00       2.00000       0.00000       0.00000       0.00000
 E   13221   1306.00       3.00000       0.00000       0.00000       0.00000
 E   13222   1323.00       4.00000       0.00000       0.00000       0.00000
 E   13223   1338.00       1.00000       0.00000       0.00000       0.00000
 E   13224   1321.00       2.00000       0.00000       0.00000       0.00000
 E   13231   1307.00       3.00000       0.00000       0.00000       0.00000
 E   13232   1324.00       4.00000       0.00000       0.00000       0.00000
 E   13233   1339.00       1.00000       0.00000       0.00000       0.00000
 E   13234   1322.00       2.00000       0.00000       0.00000       0.00000
 E   13241   1308.00       3.00000       0.00000       0.00000       0.00000
 E   13242   1325.00       4.00000       0.00000       0.00000       0.00000
 E   13243   1340.00       1.00000       0.00000       0.00000       0.00000
 E   13244   1323.00       2.00000       0.00000       0.00000       0.00000
 E   13251   1309.00       3.00000       0.00000       0.00000       0.00000
 E   13252   1326.00       4.00000       0.00000       0.00000       0.00000
 E   13253   1341.00       1.00000       0.00000       0.00000       0.00000
 E   13254   1324.00       2.00000       0.00000       0.00000       0.00000
 E   13261   1310.00       3.00000       0.00000       0.00000       0.00000
 E   13262   1327.00       4.00000       0.00000       0.00000       0.00000
 E   13263   1342.00       1.00000       0.00000       0.00000       0.00000
 E   13264   1325.00       2.00000       0.00000       0.00000       0.00000
 E   13271   1311.00       3.00000       0.00000       0.00000       0.00000
 E   13272   1328.00       4.00000       0.00000       0.00000       0.00000
 E   13273   1343.00       1.00000       0.00000       0.00000       0.00000
 E   13274   1326.00       2.00000       0.00000       0.00000       0.00000
 E   13281   1312.00       3.00000       0.00000       0.00000       0.00000
 O   13282   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13283   1344.00       1.00000       0.00000       0.00000       0.00000
 E   13284   1327.00       2.00000       0.00000       0.00000       0.00000
 E   13291   1313.00       3.00000       0.00000       0.00000       0.00000
 E   13292   1330.00       4.00000       0.00000       0.00000       0.00000
 E   13293   1345.00       1.00000       0.00000       0.00000       0.00000
     13294   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13301   1314.00       3.00000       0.00000       0.00000       0.00000
 E   13302   1331.00       4.00000       0.00000       0.00000       0.00000
 E   13303   1346.00       1.00000       0.00000       0.00000       0.00000
 E   13304   1329.00       2.00000       0.00000       0.00000       0.00000
 E   13311   1315.00       3.00000       0.00000       0.00000       0.00000
 E   13312   1332.00       4.00000       0.00000       0.00000       0.00000
 E   13313   1347.00       1.00000       0.00000       0.00000       0.00000
 E   13314   1330.00       2.00000       0.00000       0.00000       0.00000
 E   13321   1316.00       3.00000       0.00000       0.00000       0.00000
 E   13322   1333.00       4.00000       0.00000       0.00000       0.00000
 E   13323   1348.00       1.00000       0.00000       0.00000       0.00000
 E   13324   1331.00       2.00000       0.00000       0.00000       0.00000
 E   13331   1317.00       3.00000       0.00000       0.00000       0.00000
 E   13332   1334.00       4.00000       0.00000       0.00000       0.00000
 E   13333   1349.00       1.00000       0.00000       0.00000       0.00000
 E   13334   1332.00       2.00000       0.00000       0.00000       0.00000
 E   13341   1318.00       3.00000       0.00000       0.00000       0.00000
 E   13342   1335.00       4.00000       0.00000       0.00000       0.00000
 E   13343   1350.00       1.00000       0.00000       0.00000       0.00000
 E   13344   1333.00       2.00000       0.00000       0.00000       0.00000
 E   13351   1319.00       3.00000       0.00000       0.00000       0.00000
 E   13352   1336.00       4.00000       0.00000       0.00000       0.00000
 E   13353   1351.00       1.00000       0.00000       0.00000       0.00000
 E   13354   1334.00       2.00000       0.00000       0.00000       0.00000
 E   13361   1320.00       3.00000       0.00000       0.00000       0.00000
 E   13362   1337.00       4.00000       0.00000       0.00000       0.00000
 E   13363   1352.00       1.00000       0.00000       0.00000       0.00000
 E   13364   1335.00       2.00000       0.00000       0.00000       0.00000
 E   13371   1321.00       3.00000       0.00000       0.00000       0.00000
 E   13372   1338.00       4.00000       0.00000       0.00000       0.00000
 E   13373   1353.00       1.00000       0.00000       0.00000       0.00000
 E   13374   1336.00       2.00000       0.00000       0.00000       0.00000
 E   13381   1322.00       3.00000       0.00000       0.00000       0.00000
 E   13382   1339.00       4.00000       0.00000       0.00000       0.00000
 E   13383   1354.00       1.00000       0.00000       0.00000       0.00000
 E   13384   1337.00       2.00000       0.00000       0.00000       0.00000
 E   13391   1323.00       3.00000       0.00000       0.00000       0.00000
 E   13392   1340.00       4.00000       0.00000       0.00000       0.00000
 E   13393   1355.00       1.00000       0.00000       0.00000       0.00000
 E   13394   1338.00       2.00000       0.00000       0.00000       0.00000
 E   13401   1324.00       3.00000       0.00000       0.00000       0.00000
 E   13402   1341.00       4.00000       0.00000       0.00000       0.00000
 E   13403   1356.00       1.00000       0.00000       0.00000       0.00000
 E   13404   1339.00       2.00000       0.00000       0.00000       0.00000
 E   13411   1325.00       3.00000       0.00000       0.00000       0.00000
 E   13412   1342.00       4.00000       0.00000       0.00000       0.00000
 E   13413   1357.00       1.00000       0.00000       0.00000       0.00000
 E   13414   1340.00       2.00000       0.00000       0.00000       0.00000
 E   13421   1326.00       3.00000       0.00000       0.00000       0.00000
 E   13422   1343.00       4.00000       0.00000       0.00000       0.00000
 E   13423   1358.00       1.00000       0.00000       0.00000       0.00000
 E   13424   1341.00       2.00000       0.00000       0.00000       0.00000
 E   13431   1327.00       3.00000       0.00000       0.00000       0.00000
 E   13432   1344.00       4.00000       0.00000       0.00000       0.00000
 E   13433   1359.00       1.00000       0.00000       0.00000       0.00000
 E   13434   1342.00       2.00000       0.00000       0.00000       0.00000
 E   13441   1328.00       3.00000       0.00000       0.00000       0.00000
 O   13442   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13443   1360.00       1.00000       0.00000       0.00000       0.00000
 E   13444   1343.00       2.00000       0.00000       0.00000       0.00000
 E   13451   1329.00       3.00000       0.00000       0.00000       0.00000
 E   13452   1346.00       4.00000       0.00000       0.00000       0.00000
 E   13453   1361.00       1.00000       0.00000       0.00000       0.00000
     13454   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13461   1330.00       3.00000       0.00000       0.00000       0.00000
 E   13462   1347.00       4.00000       0.00000       0.00000       0.00000
 E   13463   1362.00       1.00000       0.00000       0.00000       0.00000
 E   13464   1345.00       2.00000       0.00000       0.00000       0.00000
 E   13471   1331.00       3.00000       0.00000       0.00000       0.00000
 E   13472   1348.00       4.00000       0.00000       0.00000       0.00000
 E   13473   1363.00       1.00000       0.00000       0.00000       0.00000
 E   13474   1346.00       2.00000       0.00000       0.00000       0.00000
 E   13481   1332.00       3.00000       0.00000       0.00000       0.00000
 E   13482   1349.00       4.00000       0.00000       0.00000       0.00000
 E   13483   1364.00       1.00000       0.00000       0.00000       0.00000
 E   13484   1347.00       2.00000       0.00000       0.00000       0.00000
 E   13491   1333.00       3.00000       0.00000       0.00000       0.00000
 E   13492   1350.00       4.00000       0.00000       0.00000       0.00000
 E   13493   1365.00       1.00000       0.00000       0.00000       0.00000
 E   13494   1348.00       2.00000       0.00000       0.00000       0.00000
 E   13501   1334.00       3.00000       0.00000       0.00000       0.00000
 E   13502   1351.00       4.00000       0.00000       0.00000       0.00000
 E   13503   1366.00       1.00000       0.00000       0.00000       0.00000
 E   13504   1349.00       2.00000       0.00000       0.00000       0.00000
 E   13511   1335.00       3.00000       0.00000       0.00000       0.00000
 E   13512   1352.00       4.00000       0.00000       0.00000       0.00000
 E   13513   1367.00       1.00000       0.00000       0.00000       0.00000
 E   13514   1350.00       2.00000       0.00000       0.00000       0.00000
 E   13521   1336.00       3.00000       0.00000       0.00000       0.00000
 E   13522   1353.00       4.00000       0.00000       0.00000       0.00000
 E   13523   1368.00       1.00000       0.00000       0.00000       0.00000
 E   13524   1351.00       2.00000       0.00000       0.00000       0.00000
 E   13531   1337.00       3.00000       0.00000       0.00000       0.00000
 E   13532   1354.00       4.00000       0.00000       0.00000       0.00000
 E   13533   1369.00       1.00000       0.00000       0.00000       0.00000
 E   13534   1352.00       2.00000       0.00000       0.00000       0.00000
 E   13541   1338.00       3.00000       0.00000       0.00000       0.00000
 E   13542   1355.00       4.00000       0.00000       0.00000       0.00000
 E   13543   1370.00       1.00000       0.00000       0.00000       0.00000
 E   13544   1353.00       2.00000       0.00000       0.00000       0.00000
 E   13551   1339.00       3.00000       0.00000       0.00000       0.00000
 E   13552   1356.00       4.00000       0.00000       0.00000       0.00000
 E   13553   1371.00       1.00000       0.00000       0.00000       0.00000
 E   13554   1354.00       2.00000       0.00000       0.00000       0.00000
 E   13561   1340.00       3.00000       0.00000       0.00000       0.00000
 E   13562   1357.00       4.00000       0.00000       0.00000       0.00000
 E   13563   1372.00       1.00000       0.00000       0.00000       0.00000
 E   13564   1355.00       2.00000       0.00000       0.00000       0.00000
 E   13571   1341.00       3.00000       0.00000       0.00000       0.00000
 E   13572   1358.00       4.00000       0.00000       0.00000       0.00000
 E   13573   1373.00       1.00000       0.00000       0.00000       0.00000
 E   13574   1356.00       2.00000       0.00000       0.00000       0.00000
 E   13581   1342.00       3.00000       0.00000       0.00000       0.00000
 E   13582   1359.00       4.00000       0.00000       0.00000       0.00000
 E   13583   1374.00       1.00000       0.00000       0.00000       0.00000
 E   13584   1357.00       2.00000       0.00000       0.00000       0.00000
 E   13591   1343.00       3.00000       0.00000       0.00000       0.00000
 E   13592   1360.00       4.00000       0.00000       0.00000       0.00000
 E   13593   1375.00       1.00000       0.00000       0.00000       0.00000
 E   13594   1358.00       2.00000       0.00000       0.00000       0.00000
 E   13601   1344.00       3.00000       0.00000       0.00000       0.00000
 O   13602   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13603   1376.00       1.00000       0.00000       0.00000       0.00000
 E   13604   1359.00       2.00000       0.00000       0.00000       0.00000
 E   13611   1345.00       3.00000       0.00000       0.00000       0.00000
 E   13612   1362.00       4.00000       0.00000       0.00000       0.00000
 E   13613   1377.00       1.00000       0.00000       0.00000       0.00000
     13614   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13621   1346.00       3.00000       0.00000       0.00000       0.00000
 E   13622   1363.00       4.00000       0.00000       0.00000       0.00000
 E   13623   1378.00       1.00000       0.00000       0.00000       0.00000
 E   13624   1361.00       2.00000       0.00000       0.00000       0.00000
 E   13631   1347.00       3.00000       0.00000       0.00000       0.00000
 E   13632   1364.00       4.00000       0.00000       0.00000       0.00000
 E   13633   1379.00       1.00000       0.00000       0.00000       0.00000
 E   13634   1362.00       2.00000       0.00000       0.00000       0.00000
 E   13641   1348.00       3.00000       0.00000       0.00000       0.00000
 E   13642   1365.00       4.00000       0.00000       0.00000       0.00000
 E   13643   1380.00       1.00000       0.00000       0.00000       0.00000
 E   13644   1363.00       2.00000       0.00000       0.00000       0.00000
 E   13651   1349.00       3.00000       0.00000       0.00000       0.00000
 E   13652   1366.00       4.00000       0.00000       0.00000       0.00000
 E   13653   1381.00       1.00000       0.00000       0.00000       0.00000
 E   13654   1364.00       2.00000       0.00000       0.00000       0.00000
 E   13661   1350.00       3.00000       0.00000       0.00000       0.00000
 E   13662   1367.00       4.00000       0.00000       0.00000       0.00000
 E   13663   1382.00       1.00000       0.00000       0.00000       0.00000
 E   13664   1365.00       2.00000       0.00000       0.00000       0.00000
 E   13671   1351.00       3.00000       0.00000       0.00000       0.00000
 E   13672   1368.00       4.00000       0.00000       0.00000       0.00000
 E   13673   1383.00       1.00000       0.00000       0.00000       0.00000
 E   13674   1366.00       2.00000       0.00000       0.00000       0.00000
 E   13681   1352.00       3.00000       0.00000       0.00000       0.00000
 E   13682   1369.00       4.00000       0.00000       0.00000       0.00000
 E   13683   1384.00       1.00000       0.00000       0.00000       0.00000
 E   13684   1367.00       2.00000       0.00000       0.00000       0.00000
 E   13691   1353.00       3.00000       0.00000       0.00000       0.00000
 E   13692   1370.00       4.00000       0.00000       0.00000       0.00000
 E   13693   1385.00       1.00000       0.00000       0.00000       0.00000
 E   13694   1368.00       2.00000       0.00000       0.00000       0.00000
 E   13701   1354.00       3.00000       0.00000       0.00000       0.00000
 E   13702   1371.00       4.00000       0.00000       0.00000       0.00000
 E   13703   1386.00       1.00000       0.00000       0.00000       0.00000
 E   13704   1369.00       2.00000       0.00000       0.00000       0.00000
 E   13711   1355.00       3.00000       0.00000       0.00000       0.00000
 E   13712   1372.00       4.00000       0.00000       0.00000       0.00000
 E   13713   1387.00       1.00000       0.00000       0.00000       0.00000
 E   13714   1370.00       2.00000       0.00000       0.00000       0.00000
 E   13721   1356.00       3.00000       0.00000       0.00000       0.00000
 E   13722   1373.00       4.00000       0.00000       0.00000       0.00000
 E   13723   1388.00       1.00000       0.00000       0.00000       0.00000
 E   13724   1371.00       2.00000       0.00000       0.00000       0.00000
 E   13731   1357.00       3.00000       0.00000       0.00000       0.00000
 E   13732   1374.00       4.00000       0.00000       0.00000       0.00000
 E   13733   1389.00       1.00000       0.00000       0.00000       0.00000
 E   13734   1372.00       2.00000       0.00000       0.00000       0.00000
 E   13741   1358.00       3.00000       0.00000       0.00000       0.00000
 E   13742   1375.00       4.00000       0.00000       0.00000       0.00000
 E   13743   1390.00       1.00000       0.00000       0.00000       0.00000
 E   13744   1373.00       2.00000       0.00000       0.00000       0.00000
 E   13751   1359.00       3.00000       0.00000       0.00000       0.00000
 E   13752   1376.00       4.00000       0.00000       0.00000       0.00000
 E   13753   1391.00       1.00000       0.00000       0.00000       0.00000
 E   13754   1374.00       2.00000       0.00000       0.00000       0.00000
 E   13761   1360.00       3.00000       0.00000       0.00000       0.00000
 O   13762   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13763   1392.00       1.00000       0.00000       0.00000       0.00000
 E   13764   1375.00       2.00000       0.00000       0.00000       0.00000
 E   13771   1361.00       3.00000       0.00000       0.00000       0.00000
 E   13772   1378.00       4.00000       0.00000       0.00000       0.00000
 E   13773   1393.00       1.00000       0.00000       0.00000       0.00000
     13774   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13781   1362.00       3.00000       0.00000       0.00000       0.00000
 E   13782   1379.00       4.00000       0.00000       0.00000       0.00000
 E   13783   1394.00       1.00000       0.00000       0.00000       0.00000
 E   13784   1377.00       2.00000       0.00000       0.00000       0.00000
 E   13791   1363.00       3.00000       0.00000       0.00000       0.00000
 E   13792   1380.00       4.00000       0.00000       0.00000       0.00000
 E   13793   1395.00       1.00000       0.00000       0.00000       0.00000
 E   13794   1378.00       2.00000       0.00000       0.00000       0.00000
 E   13801   1364.00       3.00000       0.00000       0.00000       0.00000
 E   13802   1381.00       4.00000       0.00000       0.00000       0.00000
 E   13803   1396.00       1.00000       0.00000       0.00000       0.00000
 E   13804   1379.00       2.00000       0.00000       0.00000       0.00000
 E   13811   1365.00       3.00000       0.00000       0.00000       0.00000
 E   13812   1382.00       4.00000       0.00000       0.00000       0.00000
 E   13813   1397.00       1.00000       0.00000       0.00000       0.00000
 E   13814   1380.00       2.00000       0.00000       0.00000       0.00000
 E   13821   1366.00       3.00000       0.00000       0.00000       0.00000
 E   13822   1383.00       4.00000       0.00000       0.00000       0.00000
 E   13823   1398.00       1.00000       0.00000       0.00000       0.00000
 E   13824   1381.00       2.00000       0.00000       0.00000       0.00000
 E   13831   1367.00       3.00000       0.00000       0.00000       0.00000
 E   13832   1384.00       4.00000       0.00000       0.00000       0.00000
 E   13833   1399.00       1.00000       0.00000       0.00000       0.00000
 E   13834   1382.00       2.00000       0.00000       0.00000       0.00000
 E   13841   1368.00       3.00000       0.00000       0.00000       0.00000
 E   13842   1385.00       4.00000       0.00000       0.00000       0.00000
 E   13843   1400.00       1.00000       0.00000       0.00000       0.00000
 E   13844   1383.00       2.00000       0.00000       0.00000       0.00000
 E   13851   1369.00       3.00000       0.00000       0.00000       0.00000
 E   13852   1386.00       4.00000       0.00000       0.00000       0.00000
 E   13853   1401.00       1.00000       0.00000       0.00000       0.00000
 E   13854   1384.00       2.00000       0.00000       0.00000       0.00000
 E   13861   1370.00       3.00000       0.00000       0.00000       0.00000
 E   13862   1387.00       4.00000       0.00000       0.00000       0.00000
 E   13863   1402.00       1.00000       0.00000       0.00000       0.00000
 E   13864   1385.00       2.00000       0.00000       0.00000       0.00000
 E   13871   1371.00       3.00000       0.00000       0.00000       0.00000
 E   13872   1388.00       4.00000       0.00000       0.00000       0.00000
 E   13873   1403.00       1.00000       0.00000       0.00000       0.00000
 E   13874   1386.00       2.00000       0.00000       0.00000       0.00000
 E   13881   1372.00       3.00000       0.00000       0.00000       0.00000
 E   13882   1389.00       4.00000       0.00000       0.00000       0.00000
 E   13883   1404.00       1.00000       0.00000       0.00000       0.00000
 E   13884   1387.00       2.00000       0.00000       0.00000       0.00000
 E   13891   1373.00       3.00000       0.00000       0.00000       0.00000
 E   13892   1390.00       4.00000       0.00000       0.00000       0.00000
 E   13893   1405.00       1.00000       0.00000       0.00000       0.00000
 E   13894   1388.00       2.00000       0.00000       0.00000       0.00000
 E   13901   1374.00       3.00000       0.00000       0.00000       0.00000
 E   13902   1391.00       4.00000       0.00000       0.00000       0.00000
 E   13903   1406.00       1.00000       0.00000       0.00000       0.00000
 E   13904   1389.00       2.00000       0.00000       0.00000       0.00000
 E   13911   1375.00       3.00000       0.00000       0.00000       0.00000
 E   13912   1392.00       4.00000       0.00000       0.00000       0.00000
 E   13913   1407.00       1.00000       0.00000       0.00000       0.00000
 E   13914   1390.00       2.00000       0.00000       0.00000       0.00000
 E   13921   1376.00       3.00000       0.00000       0.00000       0.00000
 O   13922   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13923   1408.00       1.00000       0.00000       0.00000       0.00000
 E   13924   1391.00       2.00000       0.00000       0.00000       0.00000
 E   13931   1377.00       3.00000       0.00000       0.00000       0.00000
 E   13932   1394.00       4.00000       0.00000       0.00000       0.00000
 E   13933   1409.00       1.00000       0.00000       0.00000       0.00000
     13934   0.00000       0.00000       0.00000       0.00000       0.00000
 E   13941   1378.00       3.00000       0.00000       0.00000       0.00000
 E   13942   1395.00       4.00000       0.00000       0.00000       0.00000
 E   13943   1410.00       1.00000       0.00000       0.00000       0.00000
 E   13944   1393.00       2.00000       0.00000       0.00000       0.00000
 E   13951   1379.00       3.00000       0.00000       0.00000       0.00000
 E   13952   1396.00       4.00000       0.00000       0.00000       0.00000
 E   13953   1411.00       1.00000       0.00000       0.00000       0.00000
 E   13954   1394.00       2.00000       0.00000       0.00000       0.00000
 E   13961   1380.00       3.00000       0.00000       0.00000       0.00000
 E   13962   1397.00       4.00000       0.00000       0.00000       0.00000
 E   13963   1412.00       1.00000       0.00000       0.00000       0.00000
 E   13964   1395.00       2.00000       0.00000       0.00000       0.00000
 E   13971   1381.00       3.00000       0.00000       0.00000       0.00000
 E   13972   1398.00       4.00000       0.00000       0.00000       0.00000
 E   13973   1413.00       1.00000       0.00000       0.00000       0.00000
 E   13974   1396.00       2.00000       0.00000       0.00000       0.00000
 E   13981   1382.00       3.00000       0.00000       0.00000       0.00000
 E   13982   1399.00       4.00000       0.00000       0.00000       0.00000
 E   13983   1414.00       1.00000       0.00000       0.00000       0.00000
 E   13984   1397.00       2.00000       0.00000       0.00000       0.00000
 E   13991   1383.00       3.00000       0.00000       0.00000       0.00000
 E   13992   1400.00       4.00000       0.00000       0.00000       0.00000
 E   13993   1415.00       1.00000       0.00000       0.00000       0.00000
 E   13994   1398.00       2.00000       0.00000       0.00000       0.00000
 E   14001   1384.00       3.00000       0.00000       0.00000       0.00000
 E   14002   1401.00       4.00000       0.00000       0.00000       0.00000
 E   14003   1416.00       1.00000       0.00000       0.00000       0.00000
 E   14004   1399.00       2.00000       0.00000       0.00000       0.00000
 E   14011   1385.00       3.00000       0.00000       0.00000       0.00000
 E   14012   1402.00       4.00000       0.00000       0.00000       0.00000
 E   14013   1417.00       1.00000       0.00000       0.00000       0.00000
 E   14014   1400.00       2.00000       0.00000       0.00000       0.00000
 E   14021   1386.00       3.00000       0.00000       0.00000       0.00000
 E   14022   1403.00       4.00000       0.00000       0.00000       0.00000
 E   14023   1418.00       1.00000       0.00000       0.00000       0.00000
 E   14024   1401.00       2.00000       0.00000       0.00000       0.00000
 E   14031   1387.00       3.00000       0.00000       0.00000       0.00000
 E   14032   1404.00       4.00000       0.00000       0.00000       0.00000
 E   14033   1419.00       1.00000       0.00000       0.00000       0.00000
 E   14034   1402.00       2.00000       0.00000       0.00000       0.00000
 E   14041   1388.00       3.00000       0.00000       0.00000       0.00000
 E   14042   1405.00       4.00000       0.00000       0.00000       0.00000
 E   14043   1420.00       1.00000       0.00000       0.00000       0.00000
 E   14044   1403.00       2.00000       0.00000       0.00000       0.00000
 E   14051   1389.00       3.00000       0.00000       0.00000       0.00000
 E   14052   1406.00       4.00000       0.00000       0.00000       0.00000
 E   14053   1421.00       1.00000       0.00000       0.00000       0.00000
 E   14054   1404.00       2.00000       0.00000       0.00000       0.00000
 E   14061   1390.00       3.00000       0.00000       0.00000       0.00000
 E   14062   1407.00       4.00000       0.00000       0.00000       0.00000
 E   14063   1422.00       1.00000       0.00000       0.00000       0.00000
 E   14064   1405.00       2.00000       0.00000       0.00000       0.00000
 E   14071   1391.00       3.00000       0.00000       0.00000       0.00000
 E   14072   1408.00       4.00000       0.00000       0.00000       0.00000
 E   14073   1423.00       1.00000       0.00000       0.00000       0.00000
 E   14074   1406.00       2.00000       0.00000       0.00000       0.00000
 E   14081   1392.00       3.00000       0.00000       0.00000       0.00000
 O   14082   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14083   1424.00       1.00000       0.00000       0.00000       0.00000
 E   14084   1407.00       2.00000       0.00000       0.00000       0.00000
 E   14091   1393.00       3.00000       0.00000       0.00000       0.00000
 E   14092   1410.00       4.00000       0.00000       0.00000       0.00000
 E   14093   1425.00       1.00000       0.00000       0.00000       0.00000
     14094   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14101   1394.00       3.00000       0.00000       0.00000       0.00000
 E   14102   1411.00       4.00000       0.00000       0.00000       0.00000
 E   14103   1426.00       1.00000       0.00000       0.00000       0.00000
 E   14104   1409.00       2.00000       0.00000       0.00000       0.00000
 E   14111   1395.00       3.00000       0.00000       0.00000       0.00000
 E   14112   1412.00       4.00000       0.00000       0.00000       0.00000
 E   14113   1427.00       1.00000       0.00000       0.00000       0.00000
 E   14114   1410.00       2.00000       0.00000       0.00000       0.00000
 E   14121   1396.00       3.00000       0.00000       0.00000       0.00000
 E   14122   1413.00       4.00000       0.00000       0.00000       0.00000
 E   14123   1428.00       1.00000       0.00000       0.00000       0.00000
 E   14124   1411.00       2.00000       0.00000       0.00000       0.00000
 E   14131   1397.00       3.00000       0.00000       0.00000       0.00000
 E   14132   1414.00       4.00000       0.00000       0.00000       0.00000
 E   14133   1429.00       1.00000       0.00000       0.00000       0.00000
 E   14134   1412.00       2.00000       0.00000       0.00000       0.00000
 E   14141   1398.00       3.00000       0.00000       0.00000       0.00000
 E   14142   1415.00       4.00000       0.00000       0.00000       0.00000
 E   14143   1430.00       1.00000       0.00000       0.00000       0.00000
 E   14144   1413.00       2.00000       0.00000       0.00000       0.00000
 E   14151   1399.00       3.00000       0.00000       0.00000       0.00000
 E   14152   1416.00       4.00000       0.00000       0.00000       0.00000
 E   14153   1431.00       1.00000       0.00000       0.00000       0.00000
 E   14154   1414.00       2.00000       0.00000       0.00000       0.00000
 E   14161   1400.00       3.00000       0.00000       0.00000       0.00000
 E   14162   1417.00       4.00000       0.00000       0.00000       0.00000
 E   14163   1432.00       1.00000       0.00000       0.00000       0.00000
 E   14164   1415.00       2.00000       0.00000       0.00000       0.00000
 E   14171   1401.00       3.00000       0.00000       0.00000       0.00000
 E   14172   1418.00       4.00000       0.00000       0.00000       0.00000
 E   14173   1433.00       1.00000       0.00000       0.00000       0.00000
 E   14174   1416.00       2.00000       0.00000       0.00000       0.00000
 E   14181   1402.00       3.00000       0.00000       0.00000       0.00000
 E   14182   1419.00       4.00000       0.00000       0.00000       0.00000
 E   14183   1434.00       1.00000       0.00000       0.00000       0.00000
 E   14184   1417.00       2.00000       0.00000       0.00000       0.00000
 E   14191   1403.00       3.00000       0.00000       0.00000       0.00000
 E   14192   1420.00       4.00000       0.00000       0.00000       0.00000
 E   14193   1435.00       1.00000       0.00000       0.00000       0.00000
 E   14194   1418.00       2.00000       0.00000       0.00000       0.00000
 E   14201   1404.00       3.00000       0.00000       0.00000       0.00000
 E   14202   1421.00       4.00000       0.00000       0.00000       0.00000
 E   14203   1436.00       1.00000       0.00000       0.00000       0.00000
 E   14204   1419.00       2.00000       0.00000       0.00000       0.00000
 E   14211   1405.00       3.00000       0.00000       0.00000       0.00000
 E   14212   1422.00       4.00000       0.00000       0.00000       0.00000
 E   14213   1437.00       1.00000       0.00000       0.00000       0.00000
 E   14214   1420.00       2.00000       0.00000       0.00000       0.00000
 E   14221   1406.00       3.00000       0.00000       0.00000       0.00000
 E   14222   1423.00       4.00000       0.00000       0.00000       0.00000
 E   14223   1438.00       1.00000       0.00000       0.00000       0.00000
 E   14224   1421.00       2.00000       0.00000       0.00000       0.00000
 E   14231   1407.00       3.00000       0.00000       0.00000       0.00000
 E   14232   1424.00       4.00000       0.00000       0.00000       0.00000
 E   14233   1439.00       1.00000       0.00000       0.00000       0.00000
 E   14234   1422.00       2.00000       0.00000       0.00000       0.00000
 E   14241   1408.00       3.00000       0.00000       0.00000       0.00000
 O   14242   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14243   1440.00       1.00000       0.00000       0.00000       0.00000
 E   14244   1423.00       2.00000       0.00000       0.00000       0.00000
 E   14251   1409.00       3.00000       0.00000       0.00000       0.00000
 E   14252   1426.00       4.00000       0.00000       0.00000       0.00000
 E   14253   1441.00       1.00000       0.00000       0.00000       0.00000
     14254   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14261   1410.00       3.00000       0.00000       0.00000       0.00000
 E   14262   1427.00       4.00000       0.00000       0.00000       0.00000
 E   14263   1442.00       1.00000       0.00000       0.00000       0.00000
 E   14264   1425.00       2.00000       0.00000       0.00000       0.00000
 E   14271   1411.00       3.00000       0.00000       0.00000       0.00000
 E   14272   1428.00       4.00000       0.00000       0.00000       0.00000
 E   14273   1443.00       1.00000       0.00000       0.00000       0.00000
 E   14274   1426.00       2.00000       0.00000       0.00000       0.00000
 E   14281   1412.00       3.00000       0.00000       0.00000       0.00000
 E   14282   1429.00       4.00000       0.00000       0.00000       0.00000
 E   14283   1444.00       1.00000       0.00000       0.00000       0.00000
 E   14284   1427.00       2.00000       0.00000       0.00000       0.00000
 E   14291   1413.00       3.00000       0.00000       0.00000       0.00000
 E   14292   1430.00       4.00000       0.00000       0.00000       0.00000
 E   14293   1445.00       1.00000       0.00000       0.00000       0.00000
 E   14294   1428.00       2.00000       0.00000       0.00000       0.00000
 E   14301   1414.00       3.00000       0.00000       0.00000       0.00000
 E   14302   1431.00       4.00000       0.00000       0.00000       0.00000
 E   14303   1446.00       1.00000       0.00000       0.00000       0.00000
 E   14304   1429.00       2.00000       0.00000       0.00000       0.00000
 E   14311   1415.00       3.00000       0.00000       0.00000       0.00000
 E   14312   1432.00       4.00000       0.00000       0.00000       0.00000
 E   14313   1447.00       1.00000       0.00000       0.00000       0.00000
 E   14314   1430.00       2.00000       0.00000       0.00000       0.00000
 E   14321   1416.00       3.00000       0.00000       0.00000       0.00000
 E   14322   1433.00       4.00000       0.00000       0.00000       0.00000
 E   14323   1448.00       1.00000       0.00000       0.00000       0.00000
 E   14324   1431.00       2.00000       0.00000       0.00000       0.00000
 E   14331   1417.00       3.00000       0.00000       0.00000       0.00000
 E   14332   1434.00       4.00000       0.00000       0.00000       0.00000
 E   14333   1449.00       1.00000       0.00000       0.00000       0.00000
 E   14334   1432.00       2.00000       0.00000       0.00000       0.00000
 E   14341   1418.00       3.00000       0.00000       0.00000       0.00000
 E   14342   1435.00       4.00000       0.00000       0.00000       0.00000
 E   14343   1450.00       1.00000       0.00000       0.00000       0.00000
 E   14344   1433.00       2.00000       0.00000       0.00000       0.00000
 E   14351   1419.00       3.00000       0.00000       0.00000       0.00000
 E   14352   1436.00       4.00000       0.00000       0.00000       0.00000
 E   14353   1451.00       1.00000       0.00000       0.00000       0.00000
 E   14354   1434.00       2.00000       0.00000       0.00000       0.00000
 E   14361   1420.00       3.00000       0.00000       0.00000       0.00000
 E   14362   1437.00       4.00000       0.00000       0.00000       0.00000
 E   14363   1452.00       1.00000       0.00000       0.00000       0.00000
 E   14364   1435.00       2.00000       0.00000       0.00000       0.00000
 E   14371   1421.00       3.00000       0.00000       0.00000       0.00000
 E   14372   1438.00       4.00000       0.00000       0.00000       0.00000
 E   14373   1453.00       1.00000       0.00000       0.00000       0.00000
 E   14374   1436.00       2.00000       0.00000       0.00000       0.00000
 E   14381   1422.00       3.00000       0.00000       0.00000       0.00000
 E   14382   1439.00       4.00000       0.00000       0.00000       0.00000
 E   14383   1454.00       1.00000       0.00000       0.00000       0.00000
 E   14384   1437.00       2.00000       0.00000       0.00000       0.00000
 E   14391   1423.00       3.00000       0.00000       0.00000       0.00000
 E   14392   1440.00       4.00000       0.00000       0.00000       0.00000
 E   14393   1455.00       1.00000       0.00000       0.00000       0.00000
 E   14394   1438.00       2.00000       0.00000       0.00000       0.00000
 E   14401   1424.00       3.00000       0.00000       0.00000       0.00000
 O   14402   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14403   1456.00       1.00000       0.00000       0.00000       0.00000
 E   14404   1439.00       2.00000       0.00000       0.00000       0.00000
 E   14411   1425.00       3.00000       0.00000       0.00000       0.00000
 E   14412   1442.00       4.00000       0.00000       0.00000       0.00000
 E   14413   1457.00       1.00000       0.00000       0.00000       0.00000
     14414   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14421   1426.00       3.00000       0.00000       0.00000       0.00000
 E   14422   1443.00       4.00000       0.00000       0.00000       0.00000
 E   14423   1458.00       1.00000       0.00000       0.00000       0.00000
 E   14424   1441.00       2.00000       0.00000       0.00000       0.00000
 E   14431   1427.00       3.00000       0.00000       0.00000       0.00000
 E   14432   1444.00       4.00000       0.00000       0.00000       0.00000
 E   14433   1459.00       1.00000       0.00000       0.00000       0.00000
 E   14434   1442.00       2.00000       0.00000       0.00000       0.00000
 E   14441   1428.00       3.00000       0.00000       0.00000       0.00000
 E   14442   1445.00       4.00000       0.00000       0.00000       0.00000
 E   14443   1460.00       1.00000       0.00000       0.00000       0.00000
 E   14444   1443.00       2.00000       0.00000       0.00000       0.00000
 E   14451   1429.00       3.00000       0.00000       0.00000       0.00000
 E   14452   1446.00       4.00000       0.00000       0.00000       0.00000
 E   14453   1461.00       1.00000       0.00000       0.00000       0.00000
 E   14454   1444.00       2.00000       0.00000       0.00000       0.00000
 E   14461   1430.00       3.00000       0.00000       0.00000       0.00000
 E   14462   1447.00       4.00000       0.00000       0.00000       0.00000
 E   14463   1462.00       1.00000       0.00000       0.00000       0.00000
 E   14464   1445.00       2.00000       0.00000       0.00000       0.00000
 E   14471   1431.00       3.00000       0.00000       0.00000       0.00000
 E   14472   1448.00       4.00000       0.00000       0.00000       0.00000
 E   14473   1463.00       1.00000       0.00000       0.00000       0.00000
 E   14474   1446.00       2.00000       0.00000       0.00000       0.00000
 E   14481   1432.00       3.00000       0.00000       0.00000       0.00000
 E   14482   1449.00       4.00000       0.00000       0.00000       0.00000
 E   14483   1464.00       1.00000       0.00000       0.00000       0.00000
 E   14484   1447.00       2.00000       0.00000       0.00000       0.00000
 E   14491   1433.00       3.00000       0.00000       0.00000       0.00000
 E   14492   1450.00       4.00000       0.00000       0.00000       0.00000
 E   14493   1465.00       1.00000       0.00000       0.00000       0.00000
 E   14494   1448.00       2.00000       0.00000       0.00000       0.00000
 E   14501   1434.00       3.00000       0.00000       0.00000       0.00000
 E   14502   1451.00       4.00000       0.00000       0.00000       0.00000
 E   14503   1466.00       1.00000       0.00000       0.00000       0.00000
 E   14504   1449.00       2.00000       0.00000       0.00000       0.00000
 E   14511   1435.00       3.00000       0.00000       0.00000       0.00000
 E   14512   1452.00       4.00000       0.00000       0.00000       0.00000
 E   14513   1467.00       1.00000       0.00000       0.00000       0.00000
 E   14514   1450.00       2.00000       0.00000       0.00000       0.00000
 E   14521   1436.00       3.00000       0.00000       0.00000       0.00000
 E   14522   1453.00       4.00000       0.00000       0.00000       0.00000
 E   14523   1468.00       1.00000       0.00000       0.00000       0.00000
 E   14524   1451.00       2.00000       0.00000       0.00000       0.00000
 E   14531   1437.00       3.00000       0.00000       0.00000       0.00000
 E   14532   1454.00       4.00000       0.00000       0.00000       0.00000
 E   14533   1469.00       1.00000       0.00000       0.00000       0.00000
 E   14534   1452.00       2.00000       0.00000       0.00000       0.00000
 E   14541   1438.00       3.00000       0.00000       0.00000       0.00000
 E   14542   1455.00       4.00000       0.00000       0.00000       0.00000
 E   14543   1470.00       1.00000       0.00000       0.00000       0.00000
 E   14544   1453.00       2.00000       0.00000       0.00000       0.00000
 E   14551   1439.00       3.00000       0.00000       0.00000       0.00000
 E   14552   1456.00       4.00000       0.00000       0.00000       0.00000
 E   14553   1471.00       1.00000       0.00000       0.00000       0.00000
 E   14554   1454.00       2.00000       0.00000       0.00000       0.00000
 E   14561   1440.00       3.00000       0.00000       0.00000       0.00000
 O   14562   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14563   1472.00       1.00000       0.00000       0.00000       0.00000
 E   14564   1455.00       2.00000       0.00000       0.00000       0.00000
 E   14571   1441.00       3.00000       0.00000       0.00000       0.00000
 E   14572   1458.00       4.00000       0.00000       0.00000       0.00000
 E   14573   1473.00       1.00000       0.00000       0.00000       0.00000
     14574   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14581   1442.00       3.00000       0.00000       0.00000       0.00000
 E   14582   1459.00       4.00000       0.00000       0.00000       0.00000
 E   14583   1474.00       1.00000       0.00000       0.00000       0.00000
 E   14584   1457.00       2.00000       0.00000       0.00000       0.00000
 E   14591   1443.00       3.00000       0.00000       0.00000       0.00000
 E   14592   1460.00       4.00000       0.00000       0.00000       0.00000
 E   14593   1475.00       1.00000       0.00000       0.00000       0.00000
 E   14594   1458.00       2.00000       0.00000       0.00000       0.00000
 E   14601   1444.00       3.00000       0.00000       0.00000       0.00000
 E   14602   1461.00       4.00000       0.00000       0.00000       0.00000
 E   14603   1476.00       1.00000       0.00000       0.00000       0.00000
 E   14604   1459.00       2.00000       0.00000       0.00000       0.00000
 E   14611   1445.00       3.00000       0.00000       0.00000       0.00000
 E   14612   1462.00       4.00000       0.00000       0.00000       0.00000
 E   14613   1477.00       1.00000       0.00000       0.00000       0.00000
 E   14614   1460.00       2.00000       0.00000       0.00000       0.00000
 E   14621   1446.00       3.00000       0.00000       0.00000       0.00000
 E   14622   1463.00       4.00000       0.00000       0.00000       0.00000
 E   14623   1478.00       1.00000       0.00000       0.00000       0.00000
 E   14624   1461.00       2.00000       0.00000       0.00000       0.00000
 E   14631   1447.00       3.00000       0.00000       0.00000       0.00000
 E   14632   1464.00       4.00000       0.00000       0.00000       0.00000
 E   14633   1479.00       1.00000       0.00000       0.00000       0.00000
 E   14634   1462.00       2.00000       0.00000       0.00000       0.00000
 E   14641   1448.00       3.00000       0.00000       0.00000       0.00000
 E   14642   1465.00       4.00000       0.00000       0.00000       0.00000
 E   14643   1480.00       1.00000       0.00000       0.00000       0.00000
 E   14644   1463.00       2.00000       0.00000       0.00000       0.00000
 E   14651   1449.00       3.00000       0.00000       0.00000       0.00000
 E   14652   1466.00       4.00000       0.00000       0.00000       0.00000
 E   14653   1481.00       1.00000       0.00000       0.00000       0.00000
 E   14654   1464.00       2.00000       0.00000       0.00000       0.00000
 E   14661   1450.00       3.00000       0.00000       0.00000       0.00000
 E   14662   1467.00       4.00000       0.00000       0.00000       0.00000
 E   14663   1482.00       1.00000       0.00000       0.00000       0.00000
 E   14664   1465.00       2.00000       0.00000       0.00000       0.00000
 E   14671   1451.00       3.00000       0.00000       0.00000       0.00000
 E   14672   1468.00       4.00000       0.00000       0.00000       0.00000
 E   14673   1483.00       1.00000       0.00000       0.00000       0.00000
 E   14674   1466.00       2.00000       0.00000       0.00000       0.00000
 E   14681   1452.00       3.00000       0.00000       0.00000       0.00000
 E   14682   1469.00       4.00000       0.00000       0.00000       0.00000
 E   14683   1484.00       1.00000       0.00000       0.00000       0.00000
 E   14684   1467.00       2.00000       0.00000       0.00000       0.00000
 E   14691   1453.00       3.00000       0.00000       0.00000       0.00000
 E   14692   1470.00       4.00000       0.00000       0.00000       0.00000
 E   14693   1485.00       1.00000       0.00000       0.00000       0.00000
 E   14694   1468.00       2.00000       0.00000       0.00000       0.00000
 E   14701   1454.00       3.00000       0.00000       0.00000       0.00000
 E   14702   1471.00       4.00000       0.00000       0.00000       0.00000
 E   14703   1486.00       1.00000       0.00000       0.00000       0.00000
 E   14704   1469.00       2.00000       0.00000       0.00000       0.00000
 E   14711   1455.00       3.00000       0.00000       0.00000       0.00000
 E   14712   1472.00       4.00000       0.00000       0.00000       0.00000
 E   14713   1487.00       1.00000       0.00000       0.00000       0.00000
 E   14714   1470.00       2.00000       0.00000       0.00000       0.00000
 E   14721   1456.00       3.00000       0.00000       0.00000       0.00000
 O   14722   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14723   1488.00       1.00000       0.00000       0.00000       0.00000
 E   14724   1471.00       2.00000       0.00000       0.00000       0.00000
 E   14731   1457.00       3.00000       0.00000       0.00000       0.00000
 E   14732   1474.00       4.00000       0.00000       0.00000       0.00000
 E   14733   1489.00       1.00000       0.00000       0.00000       0.00000
     14734   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14741   1458.00       3.00000       0.00000       0.00000       0.00000
 E   14742   1475.00       4.00000       0.00000       0.00000       0.00000
 E   14743   1490.00       1.00000       0.00000       0.00000       0.00000
 E   14744   1473.00       2.00000       0.00000       0.00000       0.00000
 E   14751   1459.00       3.00000       0.00000       0.00000       0.00000
 E   14752   1476.00       4.00000       0.00000       0.00000       0.00000
 E   14753   1491.00       1.00000       0.00000       0.00000       0.00000
 E   14754   1474.00       2.00000       0.00000       0.00000       0.00000
 E   14761   1460.00       3.00000       0.00000       0.00000       0.00000
 E   14762   1477.00       4.00000       0.00000       0.00000       0.00000
 E   14763   1492.00       1.00000       0.00000       0.00000       0.00000
 E   14764   1475.00       2.00000       0.00000       0.00000       0.00000
 E   14771   1461.00       3.00000       0.00000       0.00000       0.00000
 E   14772   1478.00       4.00000       0.00000       0.00000       0.00000
 E   14773   1493.00       1.00000       0.00000       0.00000       0.00000
 E   14774   1476.00       2.00000       0.00000       0.00000       0.00000
 E   14781   1462.00       3.00000       0.00000       0.00000       0.00000
 E   14782   1479.00       4.00000       0.00000       0.00000       0.00000
 E   14783   1494.00       1.00000       0.00000       0.00000       0.00000
 E   14784   1477.00       2.00000       0.00000       0.00000       0.00000
 E   14791   1463.00       3.00000       0.00000       0.00000       0.00000
 E   14792   1480.00       4.00000       0.00000       0.00000       0.00000
 E   14793   1495.00       1.00000       0.00000       0.00000       0.00000
 E   14794   1478.00       2.00000       0.00000       0.00000       0.00000
 E   14801   1464.00       3.00000       0.00000       0.00000       0.00000
 E   14802   1481.00       4.00000       0.00000       0.00000       0.00000
 E   14803   1496.00       1.00000       0.00000       0.00000       0.00000
 E   14804   1479.00       2.00000       0.00000       0.00000       0.00000
 E   14811   1465.00       3.00000       0.00000       0.00000       0.00000
 E   14812   1482.00       4.00000       0.00000       0.00000       0.00000
 E   14813   1497.00       1.00000       0.00000       0.00000       0.00000
 E   14814   1480.00       2.00000       0.00000       0.00000       0.00000
 E   14821   1466.00       3.00000       0.00000       0.00000       0.00000
 E   14822   1483.00       4.00000       0.00000       0.00000       0.00000
 E   14823   1498.00       1.00000       0.00000       0.00000       0.00000
 E   14824   1481.00       2.00000       0.00000       0.00000       0.00000
 E   14831   1467.00       3.00000       0.00000       0.00000       0.00000
 E   14832   1484.00       4.00000       0.00000       0.00000       0.00000
 E   14833   1499.00       1.00000       0.00000       0.00000       0.00000
 E   14834   1482.00       2.00000       0.00000       0.00000       0.00000
 E   14841   1468.00       3.00000       0.00000       0.00000       0.00000
 E   14842   1485.00       4.00000       0.00000       0.00000       0.00000
 E   14843   1500.00       1.00000       0.00000       0.00000       0.00000
 E   14844   1483.00       2.00000       0.00000       0.00000       0.00000
 E   14851   1469.00       3.00000       0.00000       0.00000       0.00000
 E   14852   1486.00       4.00000       0.00000       0.00000       0.00000
 E   14853   1501.00       1.00000       0.00000       0.00000       0.00000
 E   14854   1484.00       2.00000       0.00000       0.00000       0.00000
 E   14861   1470.00       3.00000       0.00000       0.00000       0.00000
 E   14862   1487.00       4.00000       0.00000       0.00000       0.00000
 E   14863   1502.00       1.00000       0.00000       0.00000       0.00000
 E   14864   1485.00       2.00000       0.00000       0.00000       0.00000
 E   14871   1471.00       3.00000       0.00000       0.00000       0.00000
 E   14872   1488.00       4.00000       0.00000       0.00000       0.00000
 E   14873   1503.00       1.00000       0.00000       0.00000       0.00000
 E   14874   1486.00       2.00000       0.00000       0.00000       0.00000
 E   14881   1472.00       3.00000       0.00000       0.00000       0.00000
 O   14882   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14883   1504.00       1.00000       0.00000       0.00000       0.00000
 E   14884   1487.00       2.00000       0.00000       0.00000       0.00000
 E   14891   1473.00       3.00000       0.00000       0.00000       0.00000
 E   14892   1490.00       4.00000       0.00000       0.00000       0.00000
 E   14893   1505.00       1.00000       0.00000       0.00000       0.00000
     14894   0.00000       0.00000       0.00000       0.00000       0.00000
 E   14901   1474.00       3.00000       0.00000       0.00000       0.00000
 E   14902   1491.00       4.00000       0.00000       0.00000       0.00000
 E   14903   1506.00       1.00000       0.00000       0.00000       0.00000
 E   14904   1489.00       2.00000       0.00000       0.00000       0.00000
 E   14911   1475.00       3.00000       0.00000       0.00000       0.00000
 E   14912   1492.00       4.00000       0.00000       0.00000       0.00000
 E   14913   1507.00       1.00000       0.00000       0.00000       0.00000
 E   14914   1490.00       2.00000       0.00000       0.00000       0.00000
 E   14921   1476.00       3.00000       0.00000       0.00000       0.00000
 E   14922   1493.00       4.00000       0.00000       0.00000       0.00000
 E   14923   1508.00       1.00000       0.00000       0.00000       0.00000
 E   14924   1491.00       2.00000       0.00000       0.00000       0.00000
 E   14931   1477.00       3.00000       0.00000       0.00000       0.00000
 E   14932   1494.00       4.00000       0.00000       0.00000       0.00000
 E   14933   1509.00       1.00000       0.00000       0.00000       0.00000
 E   14934   1492.00       2.00000       0.00000       0.00000       0.00000
 E   14941   1478.00       3.00000       0.00000       0.00000       0.00000
 E   14942   1495.00       4.00000       0.00000       0.00000       0.00000
 E   14943   1510.00       1.00000       0.00000       0.00000       0.00000
 E   14944   1493.00       2.00000       0.00000       0.00000       0.00000
 E   14951   1479.00       3.00000       0.00000       0.00000       0.00000
 E   14952   1496.00       4.00000       0.00000       0.00000       0.00000
 E   14953   1511.00       1.00000       0.00000       0.00000       0.00000
 E   14954   1494.00       2.00000       0.00000       0.00000       0.00000
 E   14961   1480.00       3.00000       0.00000       0.00000       0.00000
 E   14962   1497.00       4.00000       0.00000       0.00000       0.00000
 E   14963   1512.00       1.00000       0.00000       0.00000       0.00000
 E   14964   1495.00       2.00000       0.00000       0.00000       0.00000
 E   14971   1481.00       3.00000       0.00000       0.00000       0.00000
 E   14972   1498.00       4.00000       0.00000       0.00000       0.00000
 E   14973   1513.00       1.00000       0.00000       0.00000       0.00000
 E   14974   1496.00       2.00000       0.00000       0.00000       0.00000
 E   14981   1482.00       3.00000       0.00000       0.00000       0.00000
 E   14982   1499.00       4.00000       0.00000       0.00000       0.00000
 E   14983   1514.00       1.00000       0.00000       0.00000       0.00000
 E   14984   1497.00       2.00000       0.00000       0.00000       0.00000
 E   14991   1483.00       3.00000       0.00000       0.00000       0.00000
 E   14992   1500.00       4.00000       0.00000       0.00000       0.00000
 E   14993   1515.00       1.00000       0.00000       0.00000       0.00000
 E   14994   1498.00       2.00000       0.00000       0.00000       0.00000
 E   15001   1484.00       3.00000       0.00000       0.00000       0.00000
 E   15002   1501.00       4.00000       0.00000       0.00000       0.00000
 E   15003   1516.00       1.00000       0.00000       0.00000       0.00000
 E   15004   1499.00       2.00000       0.00000       0.00000       0.00000
 E   15011   1485.00       3.00000       0.00000       0.00000       0.00000
 E   15012   1502.00       4.00000       0.00000       0.00000       0.00000
 E   15013   1517.00       1.00000       0.00000       0.00000       0.00000
 E   15014   1500.00       2.00000       0.00000       0.00000       0.00000
 E   15021   1486.00       3.00000       0.00000       0.00000       0.00000
 E   15022   1503.00       4.00000       0.00000       0.00000       0.00000
 E   15023   1518.00       1.00000       0.00000       0.00000       0.00000
 E   15024   1501.00       2.00000       0.00000       0.00000       0.00000
 E   15031   1487.00       3.00000       0.00000       0.00000       0.00000
 E   15032   1504.00       4.00000       0.00000       0.00000       0.00000
 E   15033   1519.00       1.00000       0.00000       0.00000       0.00000
 E   15034   1502.00       2.00000       0.00000       0.00000       0.00000
 E   15041   1488.00       3.00000       0.00000       0.00000       0.00000
 O   15042   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15043   1520.00       1.00000       0.00000       0.00000       0.00000
 E   15044   1503.00       2.00000       0.00000       0.00000       0.00000
 E   15051   1489.00       3.00000       0.00000       0.00000       0.00000
 E   15052   1506.00       4.00000       0.00000       0.00000       0.00000
 E   15053   1521.00       1.00000       0.00000       0.00000       0.00000
     15054   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15061   1490.00       3.00000       0.00000       0.00000       0.00000
 E   15062   1507.00       4.00000       0.00000       0.00000       0.00000
 E   15063   1522.00       1.00000       0.00000       0.00000       0.00000
 E   15064   1505.00       2.00000       0.00000       0.00000       0.00000
 E   15071   1491.00       3.00000       0.00000       0.00000       0.00000
 E   15072   1508.00       4.00000       0.00000       0.00000       0.00000
 E   15073   1523.00       1.00000       0.00000       0.00000       0.00000
 E   15074   1506.00       2.00000       0.00000       0.00000       0.00000
 E   15081   1492.00       3.00000       0.00000       0.00000       0.00000
 E   15082   1509.00       4.00000       0.00000       0.00000       0.00000
 E   15083   1524.00       1.00000       0.00000       0.00000       0.00000
 E   15084   1507.00       2.00000       0.00000       0.00000       0.00000
 E   15091   1493.00       3.00000       0.00000       0.00000       0.00000
 E   15092   1510.00       4.00000       0.00000       0.00000       0.00000
 E   15093   1525.00       1.00000       0.00000       0.00000       0.00000
 E   15094   1508.00       2.00000       0.00000       0.00000       0.00000
 E   15101   1494.00       3.00000       0.00000       0.00000       0.00000
 E   15102   1511.00       4.00000       0.00000       0.00000       0.00000
 E   15103   1526.00       1.00000       0.00000       0.00000       0.00000
 E   15104   1509.00       2.00000       0.00000       0.00000       0.00000
 E   15111   1495.00       3.00000       0.00000       0.00000       0.00000
 E   15112   1512.00       4.00000       0.00000       0.00000       0.00000
 E   15113   1527.00       1.00000       0.00000       0.00000       0.00000
 E   15114   1510.00       2.00000       0.00000       0.00000       0.00000
 E   15121   1496.00       3.00000       0.00000       0.00000       0.00000
 E   15122   1513.00       4.00000       0.00000       0.00000       0.00000
 E   15123   1528.00       1.00000       0.00000       0.00000       0.00000
 E   15124   1511.00       2.00000       0.00000       0.00000       0.00000
 E   15131   1497.00       3.00000       0.00000       0.00000       0.00000
 E   15132   1514.00       4.00000       0.00000       0.00000       0.00000
 E   15133   1529.00       1.00000       0.00000       0.00000       0.00000
 E   15134   1512.00       2.00000       0.00000       0.00000       0.00000
 E   15141   1498.00       3.00000       0.00000       0.00000       0.00000
 E   15142   1515.00       4.00000       0.00000       0.00000       0.00000
 E   15143   1530.00       1.00000       0.00000       0.00000       0.00000
 E   15144   1513.00       2.00000       0.00000       0.00000       0.00000
 E   15151   1499.00       3.00000       0.00000       0.00000       0.00000
 E   15152   1516.00       4.00000       0.00000       0.00000       0.00000
 E   15153   1531.00       1.00000       0.00000       0.00000       0.00000
 E   15154   1514.00       2.00000       0.00000       0.00000       0.00000
 E   15161   1500.00       3.00000       0.00000       0.00000       0.00000
 E   15162   1517.00       4.00000       0.00000       0.00000       0.00000
 E   15163   1532.00       1.00000       0.00000       0.00000       0.00000
 E   15164   1515.00       2.00000       0.00000       0.00000       0.00000
 E   15171   1501.00       3.00000       0.00000       0.00000       0.00000
 E   15172   1518.00       4.00000       0.00000       0.00000       0.00000
 E   15173   1533.00       1.00000       0.00000       0.00000       0.00000
 E   15174   1516.00       2.00000       0.00000       0.00000       0.00000
 E   15181   1502.00       3.00000       0.00000       0.00000       0.00000
 E   15182   1519.00       4.00000       0.00000       0.00000       0.00000
 E   15183   1534.00       1.00000       0.00000       0.00000       0.00000
 E   15184   1517.00       2.00000       0.00000       0.00000       0.00000
 E   15191   1503.00       3.00000       0.00000       0.00000       0.00000
 E   15192   1520.00       4.00000       0.00000       0.00000       0.00000
 E   15193   1535.00       1.00000       0.00000       0.00000       0.00000
 E   15194   1518.00       2.00000       0.00000       0.00000       0.00000
 E   15201   1504.00       3.00000       0.00000       0.00000       0.00000
 O   15202   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15203   1536.00       1.00000       0.00000       0.00000       0.00000
 E   15204   1519.00       2.00000       0.00000       0.00000       0.00000
 E   15211   1505.00       3.00000       0.00000       0.00000       0.00000
 E   15212   1522.00       4.00000       0.00000       0.00000       0.00000
 v   15213   0.00000       0.00000       0.00000       0.00000       0.00000
     15214   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15221   1506.00       3.00000       0.00000       0.00000       0.00000
 E   15222   1523.00       4.00000       0.00000       0.00000       0.00000
 v   15223   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15224   1521.00       2.00000       0.00000       0.00000       0.00000
 E   15231   1507.00       3.00000       0.00000       0.00000       0.00000
 E   15232   1524.00       4.00000       0.00000       0.00000       0.00000
 v   15233   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15234   1522.00       2.00000       0.00000       0.00000       0.00000
 E   15241   1508.00       3.00000       0.00000       0.00000       0.00000
 E   15242   1525.00       4.00000       0.00000       0.00000       0.00000
 v   15243   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15244   1523.00       2.00000       0.00000       0.00000       0.00000
 E   15251   1509.00       3.00000       0.00000       0.00000       0.00000
 E   15252   1526.00       4.00000       0.00000       0.00000       0.00000
 v   15253   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15254   1524.00       2.00000       0.00000       0.00000       0.00000
 E   15261   1510.00       3.00000       0.00000       0.00000       0.00000
 E   15262   1527.00       4.00000       0.00000       0.00000       0.00000
 v   15263   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15264   1525.00       2.00000       0.00000       0.00000       0.00000
 E   15271   1511.00       3.00000       0.00000       0.00000       0.00000
 E   15272   1528.00       4.00000       0.00000       0.00000       0.00000
 v   15273   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15274   1526.00       2.00000       0.00000       0.00000       0.00000
 E   15281   1512.00       3.00000       0.00000       0.00000       0.00000
 E   15282   1529.00       4.00000       0.00000       0.00000       0.00000
 v   15283   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15284   1527.00       2.00000       0.00000       0.00000       0.00000
 E   15291   1513.00       3.00000       0.00000       0.00000       0.00000
 E   15292   1530.00       4.00000       0.00000       0.00000       0.00000
 v   15293   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15294   1528.00       2.00000       0.00000       0.00000       0.00000
 E   15301   1514.00       3.00000       0.00000       0.00000       0.00000
 E   15302   1531.00       4.00000       0.00000       0.00000       0.00000
 v   15303   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15304   1529.00       2.00000       0.00000       0.00000       0.00000
 E   15311   1515.00       3.00000       0.00000       0.00000       0.00000
 E   15312   1532.00       4.00000       0.00000       0.00000       0.00000
 v   15313   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15314   1530.00       2.00000       0.00000       0.00000       0.00000
 E   15321   1516.00       3.00000       0.00000       0.00000       0.00000
 E   15322   1533.00       4.00000       0.00000       0.00000       0.00000
 v   15323   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15324   1531.00       2.00000       0.00000       0.00000       0.00000
 E   15331   1517.00       3.00000       0.00000       0.00000       0.00000
 E   15332   1534.00       4.00000       0.00000       0.00000       0.00000
 v   15333   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15334   1532.00       2.00000       0.00000       0.00000       0.00000
 E   15341   1518.00       3.00000       0.00000       0.00000       0.00000
 E   15342   1535.00       4.00000       0.00000       0.00000       0.00000
 v   15343   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15344   1533.00       2.00000       0.00000       0.00000       0.00000
 E   15351   1519.00       3.00000       0.00000       0.00000       0.00000
 E   15352   1536.00       4.00000       0.00000       0.00000       0.00000
 v   15353   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15354   1534.00       2.00000       0.00000       0.00000       0.00000
 E   15361   1520.00       3.00000       0.00000       0.00000       0.00000
 O   15362   0.00000       0.00000       0.00000       0.00000       0.00000
 v   15363   0.00000       0.00000       0.00000       0.00000       0.00000
 E   15364   1535.00       2.00000       0.00000       0.00000       0.00000
  ***** NO THERMAL BOUNDARY CONDITIONS *****
           0  PRESOLVE/RESTART OPTIONS  *****
           7          INITIAL CONDITIONS *****
C Default
C Default
C Default
C Default
C Default
C Default
C Default
  ***** DRIVE FORCE DATA ***** BODY FORCE, FLOW, Q
           4                  Lines of Drive force data follow
C
C
C
C
  ***** Variable Property Data ***** Overrrides Parameter data.
           1  Lines follow.
           0  PACKETS OF DATA FOLLOW
  ***** HISTORY AND INTEGRAL DATA *****
           0    POINTS.  Hcode, I,J,H,IEL
  ***** OUTPUT FIELD SPECIFICATION *****
           6  SPECIFICATIONS FOLLOW
 T       COORDINATES
 T       VELOCITY
 T       PRESSURE
 T       TEMPERATURE
 F       TEMPERATURE GRADIENT
           0       PASSIVE SCALARS
  ***** OBJECT SPECIFICATION *****
       0 Surface Objects
       0 Volume  Objects
       0 Edge    Objects
       0 Point   Objects
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      udiff  = 0
      utrans = 0
      return
      end
c-----------------------------------------------------------------------
      subroutine userf  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ffx = 0.
      ffy = 0.
      ffz = 0.
      return
      end
      subroutine userq  (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      qvol   = 0.0
      source = 0.0
      return
      end
      subroutine userbc (ix,iy,iz,iside,ieg)
      include 'SIZE'
      include 'TSTEP'
      include 'INPUT'
      include 'NEKUSE'
      frequency = param(33)
      amplitude = param(34)
      if (x .lt. -1.1) then
        ux=1
        uy=0.
        uz=0.
      else if (y.lt.-29 .or. y.gt.29) then
        ux=1
        uy=0.
        uz=0.
      else
        call u_meshv(ux,uy,uz,x,y,z,time, frequency, amplitude)
      endif
      return
      end
      subroutine useric (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      ux=0.0
      uy=0.0
      uz=0.0
      return
      end
      subroutine usrdat
      include 'SIZE'
      include 'TOTAL'
      return
      end
      subroutine usrdat3
      return
      end
      subroutine usrdat2
      include 'SIZE'
      include 'TOTAL'
       param(66) = 0.
       param(67) = 0.
      ifxyo = .true.
      return
      end
      subroutine userchk
      include 'SIZE'
      include 'TOTAL'
      include 'RESTART'
      parameter (lt=lx1*ly1*lz1*lelv)
      common /scrns/ vort(lt,3), w1(lt), w2(lt)
      n = nx1*ny1*nz1*nelv
      call comp_vort3(vort , w1, w2, vx, vy, vz)
      call copy (T,vort,n)    ! Vorticity --> T
      ifto = .true.           ! Dump vorticity as T
      return
      end
      subroutine u_meshv(ux,uy,uz,x,y,z,time, frequency, amplitude)
      one          = 1.0
      pi           = 4.0*atan(one)
      omega        = frequency*2*pi
      ux = 0.0
      uy = amplitude * sin(omega*time)
      uz = 0.0
      return
      end
c
c     Include file to dimension static arrays
c     and to set some hardwired run-time parameters
c
      integer ldim,lx1,lxd,lx2,lx1m,lelg,lelt,lpmin,lpmax,ldimt
      integer lpelt,lbelt,toteq,lcvelt
      integer lelx,lely,lelz,mxprev,lgmres,lorder,lhis
      integer maxobj,lpert,nsessmax,lxo
      integer lfdm
      ! BASIC
      parameter (ldim=2)               ! domain dimension (2 or 3)
      parameter (lx1=16)                ! p-order (avoid uneven and values <6)
      parameter (lxd=24)                ! p-order for over-integration (dealiasing)
      parameter (lx2=lx1)             ! p-order for pressure (lx1 or lx1-2)
      parameter (lelg=4000)            ! max total number of elements
      parameter (lpmin=1)              ! min MPI ranks
      parameter (lpmax=64)           ! max MPI ranks
      parameter (ldimt=1)              ! max auxiliary fields (temperature + scalars)
      ! OPTIONAL
      parameter (lhis=100)             ! max history points
      parameter (maxobj=4)             ! max number of objects
      parameter (lpert=1)              ! max perturbation modes
      parameter (toteq=1)              ! max number of conserved scalars in cmt
      parameter (nsessmax=1)           ! max sessions
      parameter (lxo=lx1)              ! max grid size on output (lxo>=lx1)
      parameter (lelx=1,lely=1,lelz=1) ! global tensor mesh dimensions
      parameter (mxprev=20,lgmres=30)  ! max dim of projection & Krylov space
      parameter (lorder=3)             ! max order in time
      parameter (lelt=lelg/lpmin + 4)  ! max number of local elements per MPI rank
      parameter (lx1m=lx1)               ! polynomial order mesh solver
      parameter (lbelt=1)              ! mhd
      parameter (lpelt=1)              ! linear stability
      parameter (lcvelt=1)             ! cvode
      parameter (lfdm=0)               ! == 1 for fast diagonalization method
      ! INTERNALS
      include 'SIZE.inc'
