[Nek5000-users] Fwd: Re: proj_ortho error in pipe flow
Fri Sep 8 02:29:05 CDT 2017
Hi Neks,
sorry to revive this old thread again but I am still facing problems
with the projection for temperature and passive scalars.
I restart the simulation from a fully developed turbulent pipe flow
(Re_b=5300) with temperature and one passive scalar where I have set:
     20.0000     P093: Number of previous pressure solns saved
     0.00000     P094: start projecting velocity after p94 step
     9.00000     P095: start projecting pressure after p95 step
to achieve fully turbulent flow (velocity, temperature and passive
scalar look chaotic in instantaneous flow fields).
Now, when I set P094 to e.g. 9, I get the following error in the logfile
(complete logfile: https://paste.fedoraproject.org/paste/msifJj~amNLIqb6kVVQdOQ#):
Step     11, t= 6.2706400E+02, DT= 1.0000000E-03, C=  0.495 4.1211E+01
6.5177E+00
               Solving for Hmholtz scalars
           11  Project TEMP           7.8093E+11   7.8149E+11
9.9929E-01   1   0
           11  Error Hmholtz TEMP     100   2.0068E+25 9.5028E+14
1.0000E-06
         11proj_ortho:    1   2 TEMP   Detect rank deficiency:
-8.7444E+09  1.0000E+00
           11  Project PS 1           4.2282E+11   1.0213E+21
4.1398E-10   1   0
           11  Error Hmholtz PS 1     100   3.2943E+10 1.3653E+24
1.0000E-06
         11proj_ortho:    1   2 PS 1   Detect rank deficiency:
           11  Scalars done  6.2706E+02  4.3821E+00
               Solving for fluid
           11  Project velx           8.1238E-03   3.3574E-05
2.4196E+02   2   0
           11  Hmholtz velx       7   8.9632E-10   2.9060E-02 1.0000E-08
         11proj_ortho:    2   3 velx   project ok.  6.1900E-02 1.0000E+00
         11proj_ortho:    1   3 velx   project ok.  8.2185E-02 1.0000E+00
           11  Project vely           8.5570E-03   3.4362E-05
2.4902E+02   2   0
           11  Hmholtz vely       7   1.0419E-09   3.1223E-02 1.0000E-08
         11proj_ortho:    2   3 vely   project ok.  6.2766E-02 1.0000E+00
         11proj_ortho:    1   3 vely   project ok.  8.1871E-02 1.0000E+00
           11  Project velz           7.2548E-03   2.6975E-05
2.6895E+02   2   0
           11  Hmholtz velz       6   2.1993E-09   2.1138E-02 1.0000E-08
         11proj_ortho:    2   3 velz   project ok.  5.7485E-02 1.0000E+00
         11proj_ortho:    1   3 velz   project ok.  7.1883E-02 1.0000E+00
           11  U-PRES gmres      29   7.3794E-09   2.5720E-03
1.0000E-08   3.2994E-01   1.4955E+00
            11  DNORM, DIVEX  5.311956927469261E-007 7.379406391030144E-009
        11 0.6270640E+03  1.11112E-03  4.75093E-07  7.85398E-01
7.85398E-01 volflow Z
           11  Fluid done  6.2706E+02  2.7400E+00
           11  3 qfilt:  4.2972E-04  5.0005E-04  4.3352E-04
Can this be caused by a faulty mesh? I have generated the mesh myself.
Best Regards,
Steffen Straub
On 04/10/2017 07:00 PM, nek5000-users-request at lists.mcs.anl.gov wrote:
> Message: 1
> Date: Mon, 10 Apr 2017 14:32:33 +0200
> From: nek5000-users at lists.mcs.anl.gov
> To: <nek5000-users at lists.mcs.anl.gov>
> Subject: Re: [Nek5000-users] proj_ortho error in pipe flow
> Message-ID:
> 	<mailman.4827.1491827560.2967.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="windows-1252"; format=flowed
> Hi Paul & Philipp,
> thanks for your quick replies and suggestions. I started the simulation
> again with a slightly perturbed laminar flow field as initial conditions
> and there are no proj_ortho errors anymore.
> For now, this perturbation is more or less random and probably not ideal
> for tripping the laminar flow to turbulence. Therefore, I might try to
> implement a more effective numerical tripping method in the future. I
> can let you know when (and if) I succeed.
> The parameters p94 and p95 are set to "9" just because I have found that
> in another simulation somewhere. Do you suggest trying different values
> here?
> The Nek5000 version was downloaded as a zip file on 21/03/2017 so I
> suppose it is the commit 95b42f08c960d522679e0f0881d284ec841ae09
> \Steffen
> On 09/04/17 19:00, nek5000-users-request at lists.mcs.anl.gov wrote:
>> Message: 1
>> Date: Sat, 8 Apr 2017 19:55:36 +0200
>> To: nek5000-users at lists.mcs.anl.gov
>> Message-ID:
>> 	<mailman.4792.1491674149.2967.nek5000-users at lists.mcs.anl.gov>
>> Content-Type: text/plain; charset=windows-1252; format=flowed
>> Hi Steffen,
>> which revision of the code are you using? Is the initial field you are
>> using already turbulent, or are you going through transition? Any
>> special reason why you have 9 for p94/95?
>> Philipp
>> On 2017-04-07 19:54, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Steffen,
>>> It looks like your solution is hitting a steady-state condition and that the
>>> projection onto prior solutions is thus projecting in to a set of linearly-dependent
>>> vectors.
>>> In principle, the code is supposed to correct for this condition but apparently
>>> it is not doing so correctly.
>>> I see you're running at Re > 5000, so presumably you are interested in turbulence,
>>> rather than laminar steady state.   I would recommend adding a random perturbation
>>> to the initial condition or, better still, adding something with bound vorticity near the
>>> walls that will get stretched and bring about a more rapid transition.
>>> I find that something like the attached works well with channel flow (snap through within
>>> about 10 convective time units).  I was disappointed that it didn't work as well with pipe
>>> flow, where I had to go up to Re=40k to get the thing started and then bring it down.
>>> I assume this has something to do with the lack of linear transition in Hagen-Poiseuille flow.
>>> If you find a better mechanism to speed transition, I'd be interested to find out about it.
>>> Best,
>>> Paul
>>> ________________________________________
>>> From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
>>> Sent: Friday, April 07, 2017 10:18 AM
>>> Subject: [Nek5000-users] proj_ortho error in pipe flow
>>> Dear Nek users,
>>> I am running a simple pipe flow on a Cray XC40 (Hazel Hen). After 32
>>> steps, I get this problem (see attachment for complete logfile):
>>> Step     32, t= 3.2000000E-02, DT= 1.0000000E-03, C=  0.025 3.2660E-01
>>> 1.0526E-02
>>>                 Solving for fluid
>>>             32  Project velx           6.6444E-09   2.4759E-09
>>> 2.6836E+00   8   0
>>>             32  Hmholtz velx       1   3.9238E-09   6.7918E-07 1.0000E-08
>>>             32  Project vely           6.8730E-09   2.1046E-09
>>> 3.2656E+00   8   0
>>>             32  Hmholtz vely       1   3.6166E-09   5.9974E-07 1.0000E-08
>>>             32  Project velz           5.2396E-03   2.5121E-06
>>> 2.0858E+03   8   0
>>>             32  Hmholtz velz       3   7.6028E-10   9.3795E-04 1.0000E-08
>>>           32proj_ortho:    2   8 velz   Detect rank deficiency: NaN
>>> 1.0000E+00
>>>           32proj_ortho:    1   8 velz   Detect rank deficiency: NaN
>>> 1.0000E+00
>>>             32  U-PRES gmres      29   9.9376E-09   5.2213E-04
>>> 1.0000E-08   8.7926E-03   1.7780E-02
>>>              32  DNORM, DIVEX  2.704668739973178E-005 9.937641774554489E-009
>>>          32 0.3200000E-01  1.61568E-01  6.88948E-05  7.85330E-01
>>> 7.85399E-01 volflow Z
>>>             32  Fluid done  3.2000E-02  2.4042E-02
>>> In the next step I get CFL, CTarg! and the simulation exits.
>>> This problem does neither show up on my local machine nor on another
>>> smaller cluster. Moreover, when I set either parameter 94 or 95 to 0, I
>>> do not see this error. It only appears when p94 and p95 are both unequal
>>> 0. In my case I set them to 9.
>>> Do you know what might be causing this issue and how to solve it for the
>>> Cray XC40 system?
>>> Best Regards
>>> Steffen
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Message: 2
> Date: Mon, 10 Apr 2017 14:42:42 +0200
> Message-ID:
> 	<mailman.4836.1491828206.2967.nek5000-users at lists.mcs.anl.gov>
> ok, great!
> As Paul says, ideally one wants an initial condition that quickly leads
> to turbulence, and that is done with some streamwise vorticity near the
> walls. The way we typically do that is not with an initial condition,
> but rather with our trip force, because this leads to an efficient
> vertical mixing (across the shear), and thus to quick transition. We
> then turn the force off after a short time. This way, you do not need to
> care much about continuity, and you can just have a force in the
> wall-normal direction at some selected positions in the flow. This works
> well for higher Reynolds numbers, at least from our experience.
> Another thought that one could experiment a bit is to use the synthetic
> eddy method as a way to generate not just boundary conditions, but also
> initial conditions.
> Philipp
> On 2017-04-10 14:32, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Paul & Philipp,
>> here?
>> \Steffen
>>> Message: 1
>>> Message-ID:
>>> Hi Steffen,
>>> Philipp
>>>> Hi Steffen,
>>>> that the
>>>> linearly-dependent
>>>> vectors.
>>>> apparently
>>>> in turbulence,
>>>> perturbation
>>>> then bring it down.
>>>> Best,
>>>> Paul
>>>> Dear Nek users,
>>>> 1.0526E-02
>>>>                 Solving for fluid
>>>> 2.6836E+00   8   0
>>>> 3.2656E+00   8   0
>>>> 2.0858E+03   8   0
>>>> 1.0000E+00
>>>> 1.0000E+00
>>>> Cray XC40 system?
>>>> Best Regards
>>>> Steffen
> End of Nek5000-users Digest, Vol 98, Issue 5
