[Nek5000-users] Short test : dfh_cav
Tue Oct 10 08:20:30 CDT 2017
Hi Samuel,
try calling gen_rea(0) from your usrdat2() and modify the ASCII mesh & BC file newrea.out for the .rea's header and bottom part taken from, e.g., svn's examples/vortex/r1854a.rea but make sure that your first field file has coordinates.
Also note that the .rea's p66 for postx has to be 4 for .fld and 6 for .f field files.
Aleks
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, October 10, 2017 8:08:08 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Short test : dfh_cav
Hi again,
As I'm trying to visualize the case using postx, I get the error "can't
open the file lin_dfh_cav_dir.rea". It seems normal because this file
doesn't exist.
I tried to use re2torea to create the file but it is not working.
Does anyone has any suggestion ?
Samuel
Le 2017-10-09 11:48, Samuel a écrit :
> Hi,
> Thank you for your quick answer guys.
> Best regards,
> Samuel
Nek5000-users mailing list
Nek5000-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20171010/4c414096/attachment-0001.html>
