[Nek5000-users] Short test : dfh_cav
Tue Oct 10 08:39:23 CDT 2017
Just call gen_rea_full(0) and you're all set.
btw: re2torea works as well but you have to provide (in addition to .re2) a rea template!
Cheers,
Stefan
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday 10th October 2017 15:21
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Short test : dfh_cav
> Hi Samuel,
> try calling gen_rea(0) from your usrdat2() and modify the ASCII mesh & BC file newrea.out for the .rea's header and bottom part taken from, e.g., svn's examples/vortex/r1854a.rea but make sure that your first field file has coordinates.
> Also note that the .rea's p66 for postx has to be 4 for .fld and 6 for .f field files.
> Aleks
> From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Tuesday, October 10, 2017 8:08:08 AM
> Hi again,
> As I'm trying to visualize the case using postx, I get the error "can't
> open the file lin_dfh_cav_dir.rea". It seems normal because this file
> doesn't exist.
> I tried to use re2torea to create the file but it is not working.
> Does anyone has any suggestion ?
> Thanks,
> Samuel
> Le 2017-10-09 11:48, Samuel a écrit :
> > Hi,
> > Thank you for your quick answer guys.
> > Best regards,
> > Samuel
> Nek5000-users mailing list
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users <https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users>
