[Nek5000-users] Short test : dfh_cav
Tue Oct 10 08:13:25 CDT 2017
Could you post the error messages you are seeing when you are running re2torea script? I believe this script is not working properly.
How did you generate your re2 file?
> On Oct 10, 2017, at 9:08 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi again,
> As I'm trying to visualize the case using postx, I get the error "can't open the file lin_dfh_cav_dir.rea". It seems normal because this file doesn't exist.
> I tried to use re2torea to create the file but it is not working.
> Does anyone has any suggestion ?
> Thanks,
> Samuel
> Le 2017-10-09 11:48, Samuel a écrit :
>> Hi,
>> Thank you for your quick answer guys.
>> Best regards,
>> Samuel
> Nek5000-users mailing list
