[Nek5000-users] Read file without using load_fld nor mfi subroutines
Tue May 30 08:32:38 CDT 2017
Hi Neks,
I may have a problem when I'm trying to read velocity field (only
velocity field, I don't need pressure.) so I can assign specific
boundary conditions using userbc().
My questions are : 1) Is it possible to read velocity fields in nek that
are contained in .f000* files without modifying the pressure "pr" nor
the velocity fields "vx,vy,vz" ?
                               2) Is there any subroutine (besides
load_fld or mfi) that would allow me to read .f000* files?
When I use the mfi (in ic.f) subroutine, it looks like the pressure
field is modified and hence I'm quickly running into errors like the
following:
100 **ERROR**: Failed in HMHOLTZ: VELX          NaN          NaN 1.0000E-12.
If I use load_fld() I seem to me going back to the initial conditions.
Thank you for your help,
Arnold
