[Nek5000-users] Read file without using load_fld nor mfi subroutines
Tue May 30 08:54:20 CDT 2017
Hi;
The easies solution would be to copy your velocity and pressure to
temporary arrays before reading the file and placing them back later on.
e.g.
       real tmp_vel(lx1*ly1*lz1*lelv,ldim), tmp_pr(lx2*ly2*lz2*lelv)
       common /SCREV/ tmp_vel, tmp_pres
       integer n_tot
       call opcopy(tmp_vel(1,1),tmp_vel(1,2),tmp_vel(1,ndim),vx,vy,vz)
       n_tot = nx2*ny2*nz2*nelv
       call copy(tmp_pr,pr)
!     read file and use variables
       call opcopy(vx,vy,vz,tmp_vel(1,1),tmp_vel(1,2),tmp_vel(1,ndim))
       call copy(pr,tmp_pr)
Regards
Adam
On 30/05/17 15:32, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Neks,
> I may have a problem when I'm trying to read velocity field (only
> velocity field, I don't need pressure.) so I can assign specific
> boundary conditions using userbc().
> My questions are : 1) Is it possible to read velocity fields in nek
> that are contained in .f000* files without modifying the pressure "pr"
> nor the velocity fields "vx,vy,vz" ?
>                               2) Is there any subroutine (besides
> load_fld or mfi) that would allow me to read .f000* files?
> When I use the mfi (in ic.f) subroutine, it looks like the pressure
> field is modified and hence I'm quickly running into errors like the
> following:
> 100 **ERROR**: Failed in HMHOLTZ: VELX          NaN          NaN
> 1.0000E-12.
> If I use load_fld() I seem to me going back to the initial conditions.
> Thank you for your help,
> Arnold
> Nek5000-users mailing list
