[Nek5000-users] Full restart with increasing lx (nek5000-users at lists.mcs.anl.gov)
Wed May 24 01:48:29 CDT 2017
I guess the way to go, if you want to have full restart, is to first
reduce the time step with the old resolution, save the three restart
files (in the latest version only three files are necessary for order
three) with the new time step but old resolution, and then restart...
Philipp
On 2017-05-23 22:56, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Juan Diego,
> Good point.
> I guess in this case I would just use the last restart file ----
> The point of "full restart" is to give a carbon copy of the preceding
> run.  If lx1 has changed,
> however, then the notion of a carbon copy is lost.
> I do see, however, that there would be value to full restart with
> different lx1.
> Paul
> *From:* nek5000-users-bounces at lists.mcs.anl.gov
> [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of
> nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
> *Sent:* Tuesday, May 23, 2017 3:34 PM
> *To:* nek5000-users at lists.mcs.anl.gov
> *Subject:* Re: [Nek5000-users] Full restart with increasing lx
> Hello,
> I've been able to use the full restart function increasing lx1, but in
> my case I had to change the timestep size (DT) in order to satisfy the
> CFL condition, so the solution that was saved did not work properly with
> the full restart because it was obtained using a different DT. So this
> is something for you to consider.
> Best,
> Juan Diego
> Nek5000-users mailing list
