[Nek5000-users] Full restart with increasing lx (nek5000-users at lists.mcs.anl.gov)
Tue May 23 15:56:30 CDT 2017
Dear Juan Diego,
Good point.
I guess in this case I would just use the last restart file ----
The point of "full restart" is to give a carbon copy of the preceding run.  If lx1 has changed,
however, then the notion of a carbon copy is lost.
I do see, however, that there would be value to full restart with different lx1.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov [nek5000-users-bounces at lists.mcs.anl.gov] on behalf of nek5000-users at lists.mcs.anl.gov [nek5000-users at lists.mcs.anl.gov]
Sent: Tuesday, May 23, 2017 3:34 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Full restart with increasing lx (nek5000-users at lists.mcs.anl.gov)
Hello,
I've been able to use the full restart function increasing lx1, but in my case I had to change the timestep size (DT) in order to satisfy the CFL condition, so the solution that was saved did not work properly with the full restart because it was obtained using a different DT. So this is something for you to consider.
Best,
Juan Diego
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170523/e496d2c4/attachment.html>
