[Nek5000-users] Problem in using .re2 file
Fri May 19 05:48:39 CDT 2017
Can you run the .re2 file with the latest master. Just to double check if this really cures your problem.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday 19th May 2017 12:44
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Problem in using .re2 file
> I am getting the same problem of "non-right handed elements" even if
> I use reatore2 from the latest master.
> NN.
> On Friday 19 May 2017 12:22 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Thanks. I will do this and get back to the list in case I run into any
> > problem.
> > NN.
> > On Friday 19 May 2017 12:02 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >> Try to use reatore2 from the latest master and use the .re2 with the
> >> old Nek5000 version.
> >>> Sent: Friday 19th May 2017 12:00
> >>>    Thanks for your time. I am using an older version of NEK5000.
> >>> To switch to the new version I might have to make significant
> >>> changes to some of the new core files. The changes were made by
> >>> earlier members of the research group in the old version.
> >>>    Is it possible to use .re2 using an older version of NEK5000 by
> >>> simply replacing some subroutines with new one?
> >>> NN.
> >>> On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
> >>>> I just ran reatore2 and the resulting .re2 file works for me. Are
> >>>> you using the latest master available on GitHub or an older version?
> >>>>> Sent: Thursday 18th May 2017 16:37
> >>>>> Please find attached a compressed folder that contains
> >>>>> the ASCII file with mesh.
> >>>>> NN.
> >>>>> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov
> >>>>> wrote:
> >>>>>> I am looking for the ASCII file containing the mesh.
> >>>>>>> Sent: Thursday 18th May 2017 16:24
> >>>>>>> Please attached the .rea file. This is the smaller version
> >>>>>>> (generated
> >>>>>>> with the .re2 file). Please let me know if you want the full
> >>>>>>> version as
> >>>>>>> well.
> >>>>>>> NN.
> >>>>>>> On Thursday 18 May 2017 04:19 PM,
> >>>>>>>> Can you please post your .rea file
> >>>>>>>>> Sent: Thursday 18th May 2017 16:13
> >>>>>>>>> I have prepared the mesh using GAMBIT. Then using a converter
> >>>>>>>>> I generated
> >>>>>>>>> the .rea file in ASCII format. This .rea file works fine with
> >>>>>>>>> NEK5000.
> >>>>>>>>> However,
> >>>>>>>>> when I convert to .re2 the problem shows up...
> >>>>>>>>> On Thursday 18 May 2017 04:06 PM,
> >>>>>>>>>> How do you generate your mesh/rea?
> >>>>>>>>>>> Sent: Thursday 18th May 2017 16:02
> >>>>>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
> >>>>>>>>>>> Hi Neks,
> >>>>>>>>>>>       I have encountered a problem while using .re2 file.
> >>>>>>>>>>> When I use
> >>>>>>>>>>>            it,
> >>>>>>>>>>>            I get the following warning in the output file
> >>>>>>>>>>> and the code hangs
> >>>>>>>>>>>            up.
> >>>>>>>>>>>          WARNINGb: Detected non-right-handed element.
> >>>>>>>>>>>                  Number   14621  V1-8: -.1290E+21
> >>>>>>>>>>> .0000E+00   .6991E+01
> >>>>>>>>>>>                .0000E+00
> >>>>>>>>>>> If, however, I use the full ASCII  .rea file, the code runs
> >>>>>>>>>>> fine.
> >>>>>>>>>>>            What
> >>>>>>>>>>>            could be the problem in using .re2 file? Kindly
> >>>>>>>>>>> suggest a remedy.
> >>>>>>>>>>> I would like to mention that first I create the full ASCII .rea
> >>>>>>>>>>>            file and generate
> >>>>>>>>>>>            the .map file from it. Then, I use the executable
> >>>>>>>>>>> "reatore2" to
> >>>>>>>>>>>            make the
> >>>>>>>>>>>            .re2 file and smaller ASCII .rea file. I do not
> >>>>>>>>>>> make any change in
> >>>>>>>>>>>            the smaller
> >>>>>>>>>>>            ASCII .rea file.
> >>>>>>>>>>> Many thanks,
> >>>>>>>>>>> NN.
> >>>>>>>>>>> _______________________________________________
> >>>>>>>>>>> Nek5000-users mailing list
> >>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
> >>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
