[Nek5000-users] Problem in using .re2 file
Fri May 19 05:45:49 CDT 2017
I am getting the same problem of "non-right handed elements" even if
I use reatore2 from the latest master.
NN.
On Friday 19 May 2017 12:22 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks. I will do this and get back to the list in case I run into any
> problem.
> NN.
> On Friday 19 May 2017 12:02 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Try to use reatore2 from the latest master and use the .re2 with the
>> old Nek5000 version.
>> -----Original message-----
>>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>>> Sent: Friday 19th May 2017 12:00
>>> To: nek5000-users at lists.mcs.anl.gov
>>> Subject: Re: [Nek5000-users] Problem in using .re2 file
>>>    Thanks for your time. I am using an older version of NEK5000.
>>> To switch to the new version I might have to make significant
>>> changes to some of the new core files. The changes were made by
>>> earlier members of the research group in the old version.
>>>    Is it possible to use .re2 using an older version of NEK5000 by
>>> simply replacing some subroutines with new one?
>>> NN.
>>> On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> I just ran reatore2 and the resulting .re2 file works for me. Are
>>>> you using the latest master available on GitHub or an older version?
>>>>> Sent: Thursday 18th May 2017 16:37
>>>>> Please find attached a compressed folder that contains
>>>>> the ASCII file with mesh.
>>>>> NN.
>>>>> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov
>>>>> wrote:
>>>>>> I am looking for the ASCII file containing the mesh.
>>>>>>> Sent: Thursday 18th May 2017 16:24
>>>>>>> Please attached the .rea file. This is the smaller version
>>>>>>> (generated
>>>>>>> with the .re2 file). Please let me know if you want the full
>>>>>>> version as
>>>>>>> well.
>>>>>>> NN.
>>>>>>> On Thursday 18 May 2017 04:19 PM,
>>>>>>>> Can you please post your .rea file
>>>>>>>>> Sent: Thursday 18th May 2017 16:13
>>>>>>>>> I have prepared the mesh using GAMBIT. Then using a converter
>>>>>>>>> I generated
>>>>>>>>> the .rea file in ASCII format. This .rea file works fine with
>>>>>>>>> NEK5000.
>>>>>>>>> However,
>>>>>>>>> when I convert to .re2 the problem shows up...
>>>>>>>>> On Thursday 18 May 2017 04:06 PM,
>>>>>>>>>> How do you generate your mesh/rea?
>>>>>>>>>>> Sent: Thursday 18th May 2017 16:02
>>>>>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
>>>>>>>>>>> Hi Neks,
>>>>>>>>>>>       I have encountered a problem while using .re2 file.
>>>>>>>>>>> When I use
>>>>>>>>>>>            it,
>>>>>>>>>>>            I get the following warning in the output file
>>>>>>>>>>> and the code hangs
>>>>>>>>>>>            up.
>>>>>>>>>>>          WARNINGb: Detected non-right-handed element.
>>>>>>>>>>>                  Number   14621  V1-8: -.1290E+21
>>>>>>>>>>> .0000E+00   .6991E+01
>>>>>>>>>>>                .0000E+00
>>>>>>>>>>> If, however, I use the full ASCII  .rea file, the code runs
>>>>>>>>>>> fine.
>>>>>>>>>>>            What
>>>>>>>>>>>            could be the problem in using .re2 file? Kindly
>>>>>>>>>>> suggest a remedy.
>>>>>>>>>>> I would like to mention that first I create the full ASCII .rea
>>>>>>>>>>>            file and generate
>>>>>>>>>>>            the .map file from it. Then, I use the executable
>>>>>>>>>>> "reatore2" to
>>>>>>>>>>>            make the
>>>>>>>>>>>            .re2 file and smaller ASCII .rea file. I do not
>>>>>>>>>>> make any change in
>>>>>>>>>>>            the smaller
>>>>>>>>>>>            ASCII .rea file.
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> NN.
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
