[Nek5000-users] Problem in using .re2 file
Fri May 19 08:54:43 CDT 2017
  I tried .re2 file with the latest master and it runs fine. So I guess
the problem is
with the older version of NEK5000. Now I have to track the modifications
made
by earlier members of my research group and implement  them in new version.
Thanks very much for your inputs.
NN.
On Friday 19 May 2017 12:48 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Can you run the .re2 file with the latest master. Just to double check if this really cures your problem.
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Friday 19th May 2017 12:44
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Problem in using .re2 file
>> I am getting the same problem of "non-right handed elements" even if
>> I use reatore2 from the latest master.
>> NN.
>> On Friday 19 May 2017 12:22 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Thanks. I will do this and get back to the list in case I run into any
>>> problem.
>>> NN.
>>> On Friday 19 May 2017 12:02 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Try to use reatore2 from the latest master and use the .re2 with the
>>>> old Nek5000 version.
>>>>> Sent: Friday 19th May 2017 12:00
>>>>>     Thanks for your time. I am using an older version of NEK5000.
>>>>> To switch to the new version I might have to make significant
>>>>> changes to some of the new core files. The changes were made by
>>>>> earlier members of the research group in the old version.
>>>>>     Is it possible to use .re2 using an older version of NEK5000 by
>>>>> simply replacing some subroutines with new one?
>>>>> NN.
>>>>> On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> I just ran reatore2 and the resulting .re2 file works for me. Are
>>>>>> you using the latest master available on GitHub or an older version?
>>>>>>> Sent: Thursday 18th May 2017 16:37
>>>>>>> Please find attached a compressed folder that contains
>>>>>>> the ASCII file with mesh.
>>>>>>> NN.
>>>>>>> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov
>>>>>>> wrote:
>>>>>>>> I am looking for the ASCII file containing the mesh.
>>>>>>>>> Sent: Thursday 18th May 2017 16:24
>>>>>>>>> Please attached the .rea file. This is the smaller version
>>>>>>>>> (generated
>>>>>>>>> with the .re2 file). Please let me know if you want the full
>>>>>>>>> version as
>>>>>>>>> well.
>>>>>>>>> NN.
>>>>>>>>> On Thursday 18 May 2017 04:19 PM,
>>>>>>>>>> Can you please post your .rea file
>>>>>>>>>>> Sent: Thursday 18th May 2017 16:13
>>>>>>>>>>> I have prepared the mesh using GAMBIT. Then using a converter
>>>>>>>>>>> I generated
>>>>>>>>>>> the .rea file in ASCII format. This .rea file works fine with
>>>>>>>>>>> NEK5000.
>>>>>>>>>>> However,
>>>>>>>>>>> when I convert to .re2 the problem shows up...
>>>>>>>>>>> On Thursday 18 May 2017 04:06 PM,
>>>>>>>>>>>> How do you generate your mesh/rea?
>>>>>>>>>>>>> Sent: Thursday 18th May 2017 16:02
>>>>>>>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
>>>>>>>>>>>>> Hi Neks,
>>>>>>>>>>>>>        I have encountered a problem while using .re2 file.
>>>>>>>>>>>>> When I use
>>>>>>>>>>>>>             it,
>>>>>>>>>>>>>             I get the following warning in the output file
>>>>>>>>>>>>> and the code hangs
>>>>>>>>>>>>>             up.
>>>>>>>>>>>>>           WARNINGb: Detected non-right-handed element.
>>>>>>>>>>>>>                   Number   14621  V1-8: -.1290E+21
>>>>>>>>>>>>> .0000E+00   .6991E+01
>>>>>>>>>>>>>                 .0000E+00
>>>>>>>>>>>>> If, however, I use the full ASCII  .rea file, the code runs
>>>>>>>>>>>>> fine.
>>>>>>>>>>>>>             What
>>>>>>>>>>>>>             could be the problem in using .re2 file? Kindly
>>>>>>>>>>>>> suggest a remedy.
>>>>>>>>>>>>> I would like to mention that first I create the full ASCII .rea
>>>>>>>>>>>>>             file and generate
>>>>>>>>>>>>>             the .map file from it. Then, I use the executable
>>>>>>>>>>>>> "reatore2" to
>>>>>>>>>>>>>             make the
>>>>>>>>>>>>>             .re2 file and smaller ASCII .rea file. I do not
>>>>>>>>>>>>> make any change in
>>>>>>>>>>>>>             the smaller
>>>>>>>>>>>>>             ASCII .rea file.
>>>>>>>>>>>>> Many thanks,
>>>>>>>>>>>>> NN.
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
