[Nek5000-users] Problem in using .re2 file
Fri May 19 05:22:59 CDT 2017
Thanks. I will do this and get back to the list in case I run into any
problem.
NN.
On Friday 19 May 2017 12:02 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Try to use reatore2 from the latest master and use the .re2 with the old Nek5000 version.
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Friday 19th May 2017 12:00
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Problem in using .re2 file
>>    Thanks for your time. I am using an older version of NEK5000.
>> To switch to the new version I might have to make significant
>> changes to some of the new core files. The changes were made by
>> earlier members of the research group in the old version.
>>    Is it possible to use .re2 using an older version of NEK5000 by
>> simply replacing some subroutines with new one?
>> NN.
>> On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> I just ran reatore2 and the resulting .re2 file works for me. Are you using the latest master available on GitHub or an older version?
>>>> Sent: Thursday 18th May 2017 16:37
>>>> Please find attached a compressed folder that contains
>>>> the ASCII file with mesh.
>>>> NN.
>>>> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> I am looking for the ASCII file containing the mesh.
>>>>>> Sent: Thursday 18th May 2017 16:24
>>>>>> Please attached the .rea file. This is the smaller version (generated
>>>>>> with the .re2 file). Please let me know if you want the full version as
>>>>>> well.
>>>>>> NN.
>>>>>> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Can you please post your .rea file
>>>>>>>> Sent: Thursday 18th May 2017 16:13
>>>>>>>> I have prepared the mesh using GAMBIT. Then using a converter I generated
>>>>>>>> the .rea file in ASCII format. This .rea file works fine with NEK5000.
>>>>>>>> However,
>>>>>>>> when I convert to .re2 the problem shows up...
>>>>>>>> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>>> How do you generate your mesh/rea?
>>>>>>>>>> Sent: Thursday 18th May 2017 16:02
>>>>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
>>>>>>>>>> Hi Neks,
>>>>>>>>>>       I have encountered a problem while using .re2 file. When I use
>>>>>>>>>>            it,
>>>>>>>>>>            I get the following warning in the output file and the code hangs
>>>>>>>>>>            up.
>>>>>>>>>>          WARNINGb: Detected non-right-handed element.
>>>>>>>>>>                  Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
>>>>>>>>>>                .0000E+00
>>>>>>>>>> If, however, I use the full ASCII  .rea file, the code runs fine.
>>>>>>>>>>            What
>>>>>>>>>>            could be the problem in using .re2 file? Kindly suggest a remedy.
>>>>>>>>>> I would like to mention that first I create the full ASCII .rea
>>>>>>>>>>            file and generate
>>>>>>>>>>            the .map file from it. Then, I use the executable "reatore2" to
>>>>>>>>>>            make the
>>>>>>>>>>            .re2 file and smaller ASCII .rea file. I do not make any change in
>>>>>>>>>>            the smaller
>>>>>>>>>>            ASCII .rea file.
>>>>>>>>>> Many thanks,
>>>>>>>>>> NN.
>>>>>>>>>> _______________________________________________
>>>>>>>>>> Nek5000-users mailing list
>>>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
