[Nek5000-users] Problem in using .re2 file
Fri May 19 05:02:24 CDT 2017
Try to use reatore2 from the latest master and use the .re2 with the old Nek5000 version.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Friday 19th May 2017 12:00
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Problem in using .re2 file
>   Thanks for your time. I am using an older version of NEK5000.
> To switch to the new version I might have to make significant
> changes to some of the new core files. The changes were made by
> earlier members of the research group in the old version.
>   Is it possible to use .re2 using an older version of NEK5000 by
> simply replacing some subroutines with new one?
> NN.
> On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
> > I just ran reatore2 and the resulting .re2 file works for me. Are you using the latest master available on GitHub or an older version?
> >> Sent: Thursday 18th May 2017 16:37
> >> Please find attached a compressed folder that contains
> >> the ASCII file with mesh.
> >> NN.
> >> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> I am looking for the ASCII file containing the mesh.
> >>>> Sent: Thursday 18th May 2017 16:24
> >>>> Please attached the .rea file. This is the smaller version (generated
> >>>> with the .re2 file). Please let me know if you want the full version as
> >>>> well.
> >>>> NN.
> >>>> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>>>> Can you please post your .rea file
> >>>>>> Sent: Thursday 18th May 2017 16:13
> >>>>>> I have prepared the mesh using GAMBIT. Then using a converter I generated
> >>>>>> the .rea file in ASCII format. This .rea file works fine with NEK5000.
> >>>>>> However,
> >>>>>> when I convert to .re2 the problem shows up...
> >>>>>> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>>>>>> How do you generate your mesh/rea?
> >>>>>>>> Sent: Thursday 18th May 2017 16:02
> >>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
> >>>>>>>> Hi Neks,
> >>>>>>>>      I have encountered a problem while using .re2 file. When I use
> >>>>>>>>           it,
> >>>>>>>>           I get the following warning in the output file and the code hangs
> >>>>>>>>           up.
> >>>>>>>>         WARNINGb: Detected non-right-handed element.
> >>>>>>>>                 Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
> >>>>>>>>               .0000E+00
> >>>>>>>> If, however, I use the full ASCII  .rea file, the code runs fine.
> >>>>>>>>           What
> >>>>>>>>           could be the problem in using .re2 file? Kindly suggest a remedy.
> >>>>>>>> I would like to mention that first I create the full ASCII .rea
> >>>>>>>>           file and generate
> >>>>>>>>           the .map file from it. Then, I use the executable "reatore2" to
> >>>>>>>>           make the
> >>>>>>>>           .re2 file and smaller ASCII .rea file. I do not make any change in
> >>>>>>>>           the smaller
> >>>>>>>>           ASCII .rea file.
> >>>>>>>> Many thanks,
> >>>>>>>> NN.
> >>>>>>>> _______________________________________________
> >>>>>>>> Nek5000-users mailing list
> >>>>>>>> Nek5000-users at lists.mcs.anl.gov
> >>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
