[Nek5000-users] Problem in using .re2 file
Fri May 19 05:00:35 CDT 2017
  Thanks for your time. I am using an older version of NEK5000.
To switch to the new version I might have to make significant
changes to some of the new core files. The changes were made by
earlier members of the research group in the old version.
  Is it possible to use .re2 using an older version of NEK5000 by
simply replacing some subroutines with new one?
NN.
On Friday 19 May 2017 11:50 AM, nek5000-users at lists.mcs.anl.gov wrote:
> I just ran reatore2 and the resulting .re2 file works for me. Are you using the latest master available on GitHub or an older version?
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 18th May 2017 16:37
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Problem in using .re2 file
>> Please find attached a compressed folder that contains
>> the ASCII file with mesh.
>> NN.
>> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> I am looking for the ASCII file containing the mesh.
>>>> Sent: Thursday 18th May 2017 16:24
>>>> Please attached the .rea file. This is the smaller version (generated
>>>> with the .re2 file). Please let me know if you want the full version as
>>>> well.
>>>> NN.
>>>> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Can you please post your .rea file
>>>>>> Sent: Thursday 18th May 2017 16:13
>>>>>> I have prepared the mesh using GAMBIT. Then using a converter I generated
>>>>>> the .rea file in ASCII format. This .rea file works fine with NEK5000.
>>>>>> However,
>>>>>> when I convert to .re2 the problem shows up...
>>>>>> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> How do you generate your mesh/rea?
>>>>>>>> Sent: Thursday 18th May 2017 16:02
>>>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
>>>>>>>> Hi Neks,
>>>>>>>>      I have encountered a problem while using .re2 file. When I use
>>>>>>>>           it,
>>>>>>>>           I get the following warning in the output file and the code hangs
>>>>>>>>           up.
>>>>>>>>         WARNINGb: Detected non-right-handed element.
>>>>>>>>                 Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
>>>>>>>>               .0000E+00
>>>>>>>> If, however, I use the full ASCII  .rea file, the code runs fine.
>>>>>>>>           What
>>>>>>>>           could be the problem in using .re2 file? Kindly suggest a remedy.
>>>>>>>> I would like to mention that first I create the full ASCII .rea
>>>>>>>>           file and generate
>>>>>>>>           the .map file from it. Then, I use the executable "reatore2" to
>>>>>>>>           make the
>>>>>>>>           .re2 file and smaller ASCII .rea file. I do not make any change in
>>>>>>>>           the smaller
>>>>>>>>           ASCII .rea file.
>>>>>>>> Many thanks,
>>>>>>>> NN.
>>>>>>>> _______________________________________________
>>>>>>>> Nek5000-users mailing list
>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
