[Nek5000-users] Problem in using .re2 file
Fri May 19 04:50:29 CDT 2017
I just ran reatore2 and the resulting .re2 file works for me. Are you using the latest master available on GitHub or an older version?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 18th May 2017 16:37
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Problem in using .re2 file
> Please find attached a compressed folder that contains
> the ASCII file with mesh.
> NN.
> On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > I am looking for the ASCII file containing the mesh.
> >> Sent: Thursday 18th May 2017 16:24
> >> Please attached the .rea file. This is the smaller version (generated
> >> with the .re2 file). Please let me know if you want the full version as
> >> well.
> >> Thanks for your time.
> >> NN.
> >> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> Can you please post your .rea file
> >>>> Sent: Thursday 18th May 2017 16:13
> >>>> I have prepared the mesh using GAMBIT. Then using a converter I generated
> >>>> the .rea file in ASCII format. This .rea file works fine with NEK5000.
> >>>> However,
> >>>> when I convert to .re2 the problem shows up...
> >>>> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>>>> How do you generate your mesh/rea?
> >>>>>> Sent: Thursday 18th May 2017 16:02
> >>>>>> Subject: [Nek5000-users] Problem in using .re2 file
> >>>>>> Hi Neks,
> >>>>>>     I have encountered a problem while using .re2 file. When I use
> >>>>>>          it,
> >>>>>>          I get the following warning in the output file and the code hangs
> >>>>>>          up.
> >>>>>>        WARNINGb: Detected non-right-handed element.
> >>>>>>                Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
> >>>>>>              .0000E+00
> >>>>>> If, however, I use the full ASCII  .rea file, the code runs fine.
> >>>>>>          What
> >>>>>>          could be the problem in using .re2 file? Kindly suggest a remedy.
> >>>>>> I would like to mention that first I create the full ASCII .rea
> >>>>>>          file and generate
> >>>>>>          the .map file from it. Then, I use the executable "reatore2" to
> >>>>>>          make the
> >>>>>>          .re2 file and smaller ASCII .rea file. I do not make any change in
> >>>>>>          the smaller
> >>>>>>          ASCII .rea file.
> >>>>>> Many thanks,
> >>>>>> NN.
> >>>>>> _______________________________________________
> >>>>>> Nek5000-users mailing list
> >>>>>> Nek5000-users at lists.mcs.anl.gov
> >>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
