[Nek5000-users] Problem in using .re2 file
Thu May 18 09:37:21 CDT 2017
Please find attached a compressed folder that contains
the ASCII file with mesh.
NN.
On Thursday 18 May 2017 04:31 PM, nek5000-users at lists.mcs.anl.gov wrote:
> I am looking for the ASCII file containing the mesh.
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 18th May 2017 16:24
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: Re: [Nek5000-users] Problem in using .re2 file
>> Please attached the .rea file. This is the smaller version (generated
>> with the .re2 file). Please let me know if you want the full version as
>> well.
>> Thanks for your time.
>> NN.
>> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Can you please post your .rea file
>>>> Sent: Thursday 18th May 2017 16:13
>>>> I have prepared the mesh using GAMBIT. Then using a converter I generated
>>>> the .rea file in ASCII format. This .rea file works fine with NEK5000.
>>>> However,
>>>> when I convert to .re2 the problem shows up...
>>>> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> How do you generate your mesh/rea?
>>>>>> Sent: Thursday 18th May 2017 16:02
>>>>>> Subject: [Nek5000-users] Problem in using .re2 file
>>>>>> Hi Neks,
>>>>>>     I have encountered a problem while using .re2 file. When I use
>>>>>>          it,
>>>>>>          I get the following warning in the output file and the code hangs
>>>>>>          up.
>>>>>>        WARNINGb: Detected non-right-handed element.
>>>>>>                Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
>>>>>>              .0000E+00
>>>>>> If, however, I use the full ASCII  .rea file, the code runs fine.
>>>>>>          What
>>>>>>          could be the problem in using .re2 file? Kindly suggest a remedy.
>>>>>> I would like to mention that first I create the full ASCII .rea
>>>>>>          file and generate
>>>>>>          the .map file from it. Then, I use the executable "reatore2" to
>>>>>>          make the
>>>>>>          .re2 file and smaller ASCII .rea file. I do not make any change in
>>>>>>          the smaller
>>>>>>          ASCII .rea file.
>>>>>> Many thanks,
>>>>>> NN.
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170518/a97af200/attachment-0001.bin>
