[Nek5000-users] Problem in using .re2 file
Thu May 18 09:31:52 CDT 2017
I am looking for the ASCII file containing the mesh.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 18th May 2017 16:24
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Problem in using .re2 file
> Please attached the .rea file. This is the smaller version (generated
> with the .re2 file). Please let me know if you want the full version as
> well.
> Thanks for your time.
> NN.
> On Thursday 18 May 2017 04:19 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Can you please post your .rea file
> >> Sent: Thursday 18th May 2017 16:13
> >> I have prepared the mesh using GAMBIT. Then using a converter I generated
> >> the .rea file in ASCII format. This .rea file works fine with NEK5000.
> >> However,
> >> when I convert to .re2 the problem shows up...
> >> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
> >>> How do you generate your mesh/rea?
> >>>> Sent: Thursday 18th May 2017 16:02
> >>>> Subject: [Nek5000-users] Problem in using .re2 file
> >>>> Hi Neks,
> >>>>    I have encountered a problem while using .re2 file. When I use
> >>>>         it,
> >>>>         I get the following warning in the output file and the code hangs
> >>>>         up.
> >>>>       WARNINGb: Detected non-right-handed element.
> >>>>               Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
> >>>>             .0000E+00
> >>>> If, however, I use the full ASCII  .rea file, the code runs fine.
> >>>>         What
> >>>>         could be the problem in using .re2 file? Kindly suggest a remedy.
> >>>> I would like to mention that first I create the full ASCII .rea
> >>>>         file and generate
> >>>>         the .map file from it. Then, I use the executable "reatore2" to
> >>>>         make the
> >>>>         .re2 file and smaller ASCII .rea file. I do not make any change in
> >>>>         the smaller
> >>>>         ASCII .rea file.
> >>>> Many thanks,
> >>>> NN.
> >>>> _______________________________________________
> >>>> Nek5000-users mailing list
> >>>> Nek5000-users at lists.mcs.anl.gov
> >>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
