[Nek5000-users] Problem in using .re2 file
Thu May 18 09:13:08 CDT 2017
I have prepared the mesh using GAMBIT. Then using a converter I generated
the .rea file in ASCII format. This .rea file works fine with NEK5000.
However,
when I convert to .re2 the problem shows up...
On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
> How do you generate your mesh/rea?
> -----Original message-----
>> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
>> Sent: Thursday 18th May 2017 16:02
>> To: nek5000-users at lists.mcs.anl.gov
>> Subject: [Nek5000-users] Problem in using .re2 file
>> Hi Neks,
>>   I have encountered a problem while using .re2 file. When I use
>>        it,
>>        I get the following warning in the output file and the code hangs
>>        up.
>>      WARNINGb: Detected non-right-handed element.
>>              Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
>>            .0000E+00
>> If, however, I use the full ASCII  .rea file, the code runs fine.
>>        What
>>        could be the problem in using .re2 file? Kindly suggest a remedy.
>> I would like to mention that first I create the full ASCII .rea
>>        file and generate
>>        the .map file from it. Then, I use the executable "reatore2" to
>>        make the
>>        .re2 file and smaller ASCII .rea file. I do not make any change in
>>        the smaller
>>        ASCII .rea file.
>> Many thanks,
>> NN.
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
