[Nek5000-users] Problem in using .re2 file
Thu May 18 09:06:41 CDT 2017
How do you generate your mesh/rea?
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 18th May 2017 16:02
> To: nek5000-users at lists.mcs.anl.gov
> Subject: [Nek5000-users] Problem in using .re2 file
> Hi Neks,
>  I have encountered a problem while using .re2 file. When I use
>       it,
>       I get the following warning in the output file and the code hangs
>       up.
>     WARNINGb: Detected non-right-handed element.
>             Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
>           .0000E+00
> If, however, I use the full ASCII  .rea file, the code runs fine.
>       What
>       could be the problem in using .re2 file? Kindly suggest a remedy.
> I would like to mention that first I create the full ASCII .rea
>       file and generate
>       the .map file from it. Then, I use the executable "reatore2" to
>       make the
>       .re2 file and smaller ASCII .rea file. I do not make any change in
>       the smaller
>       ASCII .rea file.
> Many thanks,
> NN.
> Nek5000-users mailing list
