[Nek5000-users] Problem in using .re2 file
Thu May 18 09:19:49 CDT 2017
Can you please post your .rea file
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 18th May 2017 16:13
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Problem in using .re2 file
> I have prepared the mesh using GAMBIT. Then using a converter I generated
> the .rea file in ASCII format. This .rea file works fine with NEK5000.
> However,
> when I convert to .re2 the problem shows up...
> On Thursday 18 May 2017 04:06 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > How do you generate your mesh/rea?
> >> Sent: Thursday 18th May 2017 16:02
> >> Subject: [Nek5000-users] Problem in using .re2 file
> >> Hi Neks,
> >>   I have encountered a problem while using .re2 file. When I use
> >>        it,
> >>        I get the following warning in the output file and the code hangs
> >>        up.
> >>      WARNINGb: Detected non-right-handed element.
> >>              Number   14621  V1-8:  -.1290E+21   .0000E+00   .6991E+01
> >>            .0000E+00
> >> If, however, I use the full ASCII  .rea file, the code runs fine.
> >>        What
> >>        could be the problem in using .re2 file? Kindly suggest a remedy.
> >> I would like to mention that first I create the full ASCII .rea
> >>        file and generate
> >>        the .map file from it. Then, I use the executable "reatore2" to
> >>        make the
> >>        .re2 file and smaller ASCII .rea file. I do not make any change in
> >>        the smaller
> >>        ASCII .rea file.
> >> Many thanks,
> >> NN.
> >> _______________________________________________
> >> Nek5000-users mailing list
> >> Nek5000-users at lists.mcs.anl.gov
> >> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
