[Nek5000-users] How to use more than one box to generate one .rea file
Thu Mar 16 23:37:39 CDT 2017
Hi Hu,
Yes you can use multiple boxes to create a single mesh.. attached is an example of the box file that uses two boxes to mesh a 2D channel.. although, if you are breaking the box, you will not be able to use the periodic boundary conditions across two boxes i.e. if you break the box in the x-direction, both the boxes can have periodic faces in y-direction, but not in the x-direction because both the periodic faces are not attached to a single box.
In that case, you will have to use prenek’s autoperiodic feature to generate periodic boundary conditions.
Ketan
Desc: multi.box
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170317/f16e0c4b/attachment.obj>
