[Nek5000-users] How to use more than one box to generate one .rea file
Fri Mar 17 08:34:12 CDT 2017
Thanks, Ketan. Your example box file is very helpful!
Hu
> -----Original Messages-----
> From: nek5000-users at lists.mcs.anl.gov
> Sent Time: Friday, March 17, 2017
> To: "nek5000-users at lists.mcs.anl.gov" <nek5000-users at lists.mcs.anl.gov>
> Cc:
> Subject: Re: [Nek5000-users] How to use more than one box to generate one .rea file
> Hi Hu,
> Yes you can use multiple boxes to create a single mesh.. attached is an example of the box file that uses two boxes to mesh a 2D channel.. although, if you are breaking the box, you will not be able to use the periodic boundary conditions across two boxes i.e. if you break the box in the x-direction, both the boxes can have periodic faces in y-direction, but not in the x-direction because both the periodic faces are not attached to a single box.
> In that case, you will have to use prenek’s autoperiodic feature to generate periodic boundary conditions.
> Ketan
