[Nek5000-users] Nek5000-users Digest, Vol 100, Issue 30
Tue Jun 27 19:06:09 CDT 2017
Hi Paul,
I changed the elements in the straight pipe which is I am doing at the
moment. I set the horizontal and vertical axis as 14 spectral elements in
the quarter-section for the simulation at Re=5300 based on bulk velocity.
And the pipe length is 25R. Do you think it's enough to run the simulation?
By the way, I run the simulation for a short time, after which I used visit
to check the mesh finding that there are several things inside the pipe
which are likely to be walls. And I found the mesh in visit shows that the
cross-sectional views are different in the outlet and inlet which is open
or closed. I set the axis view in visit to not show the axis.
Kind regards,
Jian
On 27 June 2017 at 18:00, <nek5000-users-request at lists.mcs.anl.gov> wrote:
> Send Nek5000-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         nek5000-users-owner at lists.mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Nek5000-users digest..."
> Today's Topics:
>    1. Re: Nek5000-users Digest, Vol 100, Issue 29
>       (nek5000-users at lists.mcs.anl.gov)
>    2. Re: Nek5000-users Digest, Vol 100, Issue 29
> Message: 1
> Date: Mon, 26 Jun 2017 18:06:06 +0100
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 100, Issue 29
> Message-ID:
>         <mailman.9646.1498496769.2967.nek5000-users at lists.mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> Hi Paul,
> Now the number of total elements is 576000 written in the rea file. By the
> way, would you please tell me the reason why only 1/1000 number of elements
> are needed indeed with SEM.
> Kind regards,
> Jian
> > Message: 2
> > Date: Mon, 26 Jun 2017 15:27:28 +0000
> > To: "nek5000-users at lists.mcs.anl.gov"
> >         <nek5000-users at lists.mcs.anl.gov>
> > Subject: Re: [Nek5000-users] genmap
> > Message-ID:
> >         <mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov>
> > Content-Type: text/plain; charset="us-ascii"
> > Dear Jiang,
> > I think you have too many elements.  Keep in mind that with the SEM you
> > need about 1/1000th of the number of elements that you would for FEM.
> > What is the largest SEM run you have made so far?
> > Best, Paul
> > ________________________________
> > From: nek5000-users-bounces at lists.mcs.anl.gov <
> > nek5000-users-bounces at lists.mcs.anl.gov> on behalf of
> > nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> > Sent: Monday, June 26, 2017 8:49:06 AM
> > Subject: [Nek5000-users] genmap
> > Hi Neks,
> > Is there anyone know the reason for the following error, in which there
> > are hundred millions of grid points in the geometry.
> >  ABORT: NELT>LELM, modify LELM in SIZE and recompile
> > I changed the LELM to be big enough, even equals to 7000000000000, but it
> > doesn't work though. I guess the reasons would be:
> > 1. genmap cannot regonize large elements mesh;
> > 2. I didn't get a recompilation after changing LELM parameter since I
> > don't know how to compile and thought genmap commond would be changed
> > automatically when the SIZE file in /home/bin/genmap was changed.
> > Kind regards,
> > Jian
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/
> > attachments/20170626/74ae123f/attachment-0001.html>
> > _______________________________________________
> > Nek5000-users at lists.mcs.anl.gov
> > End of Nek5000-users Digest, Vol 100, Issue 29
> attachments/20170626/a406c1da/attachment-0001.html>
> Message: 2
> Date: Mon, 26 Jun 2017 19:18:22 +0000
> Message-ID:
>         <mailman.9661.1498504705.2967.nek5000-users at lists.mcs.anl.gov>
> Dear Jiang,
> If you run with lx1=10 you have 1000 points per element.
> FEM never runs with 10th order - the SEM is meant to do this.
> What is the largest SEM problem you have run so far?  I recommend starting
> with a sequence of small ones just to get used to the workflow.
> Paul
> Sent: Monday, June 26, 2017 12:06:06 PM
> Hi Paul,
> Kind regards,
> Jian
> Message: 2
> From: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users@
> lists.mcs.anl.gov>
> To: "nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users@
> lists.mcs.anl.gov>"
>         <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users@
> lists.mcs.anl.gov>>
> Message-ID:
> <mailto:mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov>>
> Dear Jiang,
> Best, Paul
> From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-
> users-bounces at lists.mcs.anl.gov> <nek5000-users-bounces at lists.mcs.anl.gov
> <mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of
> nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <
> nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
> To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov
> Hi Neks,
> Kind regards,
> Jian
> Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
> attachments/20170626/ccc11744/attachment-0001.html>
> End of Nek5000-users Digest, Vol 100, Issue 30
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170628/3e7fa76e/attachment.html>
