[Nek5000-users] Nek5000-users Digest, Vol 100, Issue 30
Wed Jun 28 00:08:07 CDT 2017
Hi Jian,
Have a look at the "pipe" example.
I would expect the total element count to be about 10,000-30,000
for well resolved pipe flow at Re=5300.
There is a README on how to construct the mesh.
Please let me know if that helps...
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Tuesday, June 27, 2017 7:06:09 PM
To: nek5000-users at lists.mcs.anl.gov
Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 100, Issue 30
Hi Paul,
I changed the elements in the straight pipe which is I am doing at the moment. I set the horizontal and vertical axis as 14 spectral elements in the quarter-section for the simulation at Re=5300 based on bulk velocity. And the pipe length is 25R. Do you think it's enough to run the simulation? By the way, I run the simulation for a short time, after which I used visit to check the mesh finding that there are several things inside the pipe which are likely to be walls. And I found the mesh in visit shows that the cross-sectional views are different in the outlet and inlet which is open or closed. I set the axis view in visit to not show the axis.
Kind regards,
Jian
On 27 June 2017 at 18:00, <nek5000-users-request at lists.mcs.anl.gov<mailto:nek5000-users-request at lists.mcs.anl.gov>> wrote:
Send Nek5000-users mailing list submissions to
        nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        nek5000-users-owner at lists.mcs.anl.gov<mailto:nek5000-users-owner at lists.mcs.anl.gov>
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Nek5000-users digest..."
Today's Topics:
   1. Re: Nek5000-users Digest, Vol 100, Issue 29
      (nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>)
   2. Re: Nek5000-users Digest, Vol 100, Issue 29
Message: 1
Date: Mon, 26 Jun 2017 18:06:06 +0100
From: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>
Subject: Re: [Nek5000-users] Nek5000-users Digest, Vol 100, Issue 29
Message-ID:
        <mailman.9646.1498496769.2967.nek5000-users at lists.mcs.anl.gov<mailto:mailman.9646.1498496769.2967.nek5000-users at lists.mcs.anl.gov>>
Content-Type: text/plain; charset="utf-8"
Hi Paul,
Now the number of total elements is 576000 written in the rea file. By the
way, would you please tell me the reason why only 1/1000 number of elements
are needed indeed with SEM.
Kind regards,
Jian
> Message: 2
> Date: Mon, 26 Jun 2017 15:27:28 +0000
> To: "nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>"
>         <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
> Subject: Re: [Nek5000-users] genmap
> Message-ID:
>         <mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov<mailto:mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov>>
> Content-Type: text/plain; charset="us-ascii"
> Dear Jiang,
> I think you have too many elements.  Keep in mind that with the SEM you
> need about 1/1000th of the number of elements that you would for FEM.
> What is the largest SEM run you have made so far?
> Best, Paul
> ________________________________
> From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> <
> nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of
> nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
> Sent: Monday, June 26, 2017 8:49:06 AM
> Subject: [Nek5000-users] genmap
> Hi Neks,
> Is there anyone know the reason for the following error, in which there
> are hundred millions of grid points in the geometry.
>  ABORT: NELT>LELM, modify LELM in SIZE and recompile
> I changed the LELM to be big enough, even equals to 7000000000000, but it
> doesn't work though. I guess the reasons would be:
> 1. genmap cannot regonize large elements mesh;
> 2. I didn't get a recompilation after changing LELM parameter since I
> don't know how to compile and thought genmap commond would be changed
> automatically when the SIZE file in /home/bin/genmap was changed.
> Kind regards,
> Jian
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/
> attachments/20170626/74ae123f/attachment-0001.html>
> Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>
> End of Nek5000-users Digest, Vol 100, Issue 29
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170626/a406c1da/attachment-0001.html>
Message: 2
Date: Mon, 26 Jun 2017 19:18:22 +0000
Message-ID:
        <mailman.9661.1498504705.2967.nek5000-users at lists.mcs.anl.gov<mailto:mailman.9661.1498504705.2967.nek5000-users at lists.mcs.anl.gov>>
Dear Jiang,
If you run with lx1=10 you have 1000 points per element.
FEM never runs with 10th order - the SEM is meant to do this.
What is the largest SEM problem you have run so far?  I recommend starting with a sequence of small ones just to get used to the workflow.
Paul
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov> <nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>> on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Sent: Monday, June 26, 2017 12:06:06 PM
Hi Paul,
Now the number of total elements is 576000 written in the rea file. By the way, would you please tell me the reason why only 1/1000 number of elements are needed indeed with SEM.
Kind regards,
Jian
Message: 2
From: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
To: "nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>"
        <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>>
Message-ID:
        <mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov<mailto:mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov><mailto:mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov<mailto:mailman.9625.1498490850.2967.nek5000-users at lists.mcs.anl.gov>>>
Dear Jiang,
I think you have too many elements.  Keep in mind that with the SEM you need about 1/1000th of the number of elements that you would for FEM.
Best, Paul
From: nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov><mailto:nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>> <nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov><mailto:nek5000-users-bounces at lists.mcs.anl.gov<mailto:nek5000-users-bounces at lists.mcs.anl.gov>>> on behalf of nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>> <nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>>
To: nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov><mailto:nek5000-users at lists.mcs.anl.gov<mailto:nek5000-users at lists.mcs.anl.gov>>
Hi Neks,
Is there anyone know the reason for the following error, in which there are hundred millions of grid points in the geometry.
I changed the LELM to be big enough, even equals to 7000000000000, but it doesn't work though. I guess the reasons would be:
2. I didn't get a recompilation after changing LELM parameter since I don't know how to compile and thought genmap commond would be changed automatically when the SIZE file in /home/bin/genmap was changed.
Kind regards,
Jian
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170626/74ae123f/attachment-0001.html>
Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov><mailto:Nek5000-users at lists.mcs.anl.gov<mailto:Nek5000-users at lists.mcs.anl.gov>>
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170626/ccc11744/attachment-0001.html>
End of Nek5000-users Digest, Vol 100, Issue 30
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170628/ab86fae9/attachment-0001.html>
