[Nek5000-users] simulation termination at istep=0 with NaN
Wed Jul 26 12:10:24 CDT 2017
Hello, Thanks for your help. Please see below for the log file.
Ajay
 Number of processors:           8
 REAL    wdsize      :           8
 INTEGER wdsize      :           4
 Timer accuracy      : 7.87E-07
 Reading
/home/ajay/nek5_svn/runs/smallcylinder/simplecylinder.rea
 mapping elements to processors
 Reading
/home/ajay/nek5_svn/runs/smallercylinder/simpleduct.map
           0        2827        2827       22620       22620  NELV
           1        2828        2828       22620       22620  NELV
           2        2827        2827       22620       22620  NELV
           3        2828        2828       22620       22620  NELV
           4        2827        2827       22620       22620  NELV
           5        2828        2828       22620       22620  NELV
           6        2827        2827       22620       22620  NELV
           7        2828        2828       22620       22620  NELV
 RANK     0 IEG      73      74      75      76      77      78
79      80
                     81      82      83      84      85      86
87      88
                     89      90      91      92      93      94
95      96
                     97      98      99     100     101     102     103
104
                    105     106     107     108     109     110     111
112
                  19702   19703   19704   19705   19706   19707   19708
19709
                  19710   19711   19712   19713   19714   19715   19716
19717
                  19718   19719   19720
 element load imbalance:            1        2827        2828
 done :: mapping elements to processors
           0  objects found
 103   Parameters from file:
   1      1.00000         p1  DENSITY
   2     -500.000         p2  VISCOS
   7      1.00000         p7  RHOCP
   8      1.00000         p8  CONDUCT
  11      10000           p11 NSTEPS
  12      0.10000E-05     p12 DT
  15      5               p15 IOSTEP
  18     -20.00000        p18 GRID
  19     -1.00000         p19 INTYPE
  20      10.0000         p20 NORDER
  26      1.00000         p26 COURANT/NTAU
  27      2.00000         p27 TORDER
  65      1.00000         p65 #iofiles (eg, 0 or 64); <0 --> sep. dirs
  66      4.00000         p66 output : <0=ascii, else binary
  67      4.00000         p67 restart: <0=ascii, else binary
  93      20.0000          p93 Number of previous pressure solns saved
  94      3.00000          p94 start projecting velocity after p94 step
  95      5.00000          p95 start projecting pressure after p95 step
  99      0.               p99   dealiasing: <0--> off/3--> old/4--> new
 102      1.00000          p102   Dump out divergence at each time step
 103     -1.00000          p103   weight of stabilizing filter (.01)
 nelgt/nelgv/lelt:       22620       22620        4800
 lx1  /lx2  /lx3 :           4           2           4
 done :: read .rea file   0.31992     sec
 Reset the target Courant number to .5
 setup mesh topology
   Right-handed check complete for   22620 elements. OK.
   setvert3d:   4      442198      623158      442198      442198
 call usrsetvert
 done :: usrsetvert
gs_setup: 30559 unique labels shared
   pairwise times (avg, min, max): 0.000139931 0.000135946 0.000145721
   crystal router                : 0.000256464 0.000254369 0.000258589
   all reduce                    : 0.00160212 0.00160019 0.00160458
   used all_to_all method: pairwise
   handle bytes (avg, min, max): 1.84397e+06 1811380 1886892
   buffer bytes (avg, min, max): 127744 104448 159248
   setupds time 2.7611E-01 seconds   0  4      442198       22620
           8  max multiplicity
 done :: setup mesh topology
 call usrdat
 done :: usrdat
 generate geometry data
 done :: generate geometry data
 call usrdat2
 done :: usrdat2
 regenerate geometry data           1
 done :: regenerate geometry data           1
 verify mesh topology
  0.000000000000000E+000   40.0000037000000       Xrange
 -0.999999929000000       0.999999933000000       Yrange
 -0.999999934000000       0.999999930000000       Zrange
 done :: verify mesh topology
 IFTRAN   = T
 IFFLOW   = T
 IFHEAT   = F
 IFSPLIT  = F
 IFLOMACH = F
 IFUSERVP = F
 IFUSERMV = F
 IFSTRS   = F
 IFCHAR   = F
 IFCYCLIC = F
 IFAXIS   = F
 IFMVBD   = F
 IFMELT   = F
 IFMODEL  = F
 IFKEPS   = F
 IFMOAB   = F
 IFNEKNEK = F
 IFSYNC   = T
 IFVCOR   = F
 IFINTQ   = F
 IFCWUZ   = F
 IFSWALL  = F
 IFGEOM   = F
 IFSURT   = F
 IFWCNO   = F
 IFCMT    = F
 IFVISC   = F
 IFFLTR   = F
 IFTMSH for field           1    =  F
 IFADVC for field           1    =  T
 IFNONL for field           1    =  F
 Dealiasing enabled, lxd=           6
 Estimated eigenvalues
 EIGAA =    1.64699045940739
 EIGGA =    96667.1875918256
 EIGAE =   6.168501609507998E-003
 EIGAS =   3.121097622977694E-004
 EIGGE =    96667.1875918256
 EIGGS =    2.00000000000000
  E-solver strategy:  1 itr
Matrix:   0 aa         4       4       4
  0 aa        Infinity  -4.08542E+02   7.41342E+01   0.00000E+00
  0 aa    -4.08542E+02   4.65569E+02  -1.31161E+02   0.00000E+00
  0 aa     7.41342E+01  -1.31161E+02   7.04788E+01   0.00000E+00
  0 aa     0.00000E+00   0.00000E+00   0.00000E+00   1.00000E+00
Matrix:   0 bb         4       4       4
  0 bb             NaN   0.00000E+00   0.00000E+00   0.00000E+00
  0 bb     0.00000E+00   2.66276E-02  -5.47992E-03   0.00000E+00
  0 bb     0.00000E+00  -5.47992E-03   2.45184E-02   0.00000E+00
  0 bb     0.00000E+00   0.00000E+00   0.00000E+00   1.00000E+00
 Error in generalev, info=           3           4           1
Matrix:   0 Aeig       4       4       4
  0 Aeig           NaN           NaN           NaN           NaN
Matrix:   0 Deig       1       4       4
  0 Deig           NaN           NaN           NaN           NaN
call exitt: dying ...
backtrace(): obtained 10 stack frames.
./nek5000() [0x6b38f9]
./nek5000() [0x8262fa]
./nek5000() [0x546de7]
./nek5000() [0x68bd34]
./nek5000() [0x66424d]
./nek5000() [0x40a834]
./nek5000() [0x408e17]
./nek5000() [0x408ca6]
/lib64/libc.so.6(__libc_start_main+0xf0) [0x7fb5451ef9f0]
./nek5000() [0x408b29]
total elapsed time             :   2.33935E+00 sec
total solver time incl. I/O    :   0.00000E+00 sec
time/timestep                  :   0.00000E+00 sec
CPU seconds/timestep/gridpt    :   0.00000E+00 sec
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170726/d8285e6e/attachment.html>
