[Nek5000-users] Nek: abnormal termination by signal 11
Thu Feb 23 08:01:13 CST 2017
Sorry Stefan, i misinterpreted your question. I have tested some of the example cases and they run fine. I have uploaded a case that produces the error here:
https://uni-muenster.sciebo.de/index.php/s/8WgujGKLQNLzk3k <https://uni-muenster.sciebo.de/index.php/s/8WgujGKLQNLzk3k>
I am not sure whether you really need the large restart file. Either way, this case runs fine on an Intel system but crashes on the first time step on IBM.
I think my core file came from a case compiled with "-g“. The cluster is pretty busy at the moment so I can’t really test that much.
Best wishes,
Jan
> Am 20.02.2017 um 00:37 schrieb nek5000-users at lists.mcs.anl.gov:
> How can I reproduce the problem? Please provide a step-by-step instruction.
> The core file (w/o debugging symbols) is pretty useless. Can you recompile with "-g" and try again. You may need use "addr2line" to get a human readable STACK.
> Cheers,
> Stefan
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20170223/ca772b86/attachment.html>
