[Nek5000-users] Nek: abnormal termination by signal 11
Sun Feb 19 17:37:32 CST 2017
How can I reproduce the problem? Please provide a step-by-step instruction.
The core file (w/o debugging symbols) is pretty useless. Can you recompile with "-g" and try again. You may need use "addr2line" to get a human readable STACK.
Cheers,
Stefan
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Monday 20th February 2017 0:33
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Nek: abnormal termination by signal 11
> Hello,
> the error occurs both with a current github version (16..0.0) as well as an older svn version (1.0rc1 / SVN  r1115) and is reproducible on the IBM system. However, it seems that the svn version gives a longer error message:
> 2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: terminated by signal 11
> 2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: abnormal termination by signal 11 from rank 0
> 2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: 1 INFO RAS event
> 2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: most recent RAS event text: DDR Correctable Error Summary : count=36 MCFIR error status:  [MEMORY_CE] This bit is set when a memory CE is detected on a non-maintenance memory read op;
> 2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: with severity INFO
> Attached you find the output from the core file:
> +++PARALLEL TOOLS CONSORTIUM LIGHTWEIGHT COREFILE FORMAT version 1.0
> +++LCB 1.0
> Program   : ./nek5000
> Job ID    : 3243396
> Personality:
>    ABCDET coordinates : 0,0,0,0,0,0
>    Rank               : 0
>    Ranks per node     : 16
>    DDR Size (MB)      : 16384
> +++ID Rank: 0, TGID: 1, Core: 0, HWTID:0 TID: 1 State: RUN
> ***FAULT Encountered unhandled signal 0x0000000b (11) (SIGSEGV)
> Generated by interrupt..................0x00000008 (Data TLB Miss Exception DEAR=0x00000000d716900c ESR=0x0000000000000000)
> While executing instruction at..........0x00000000010eba68
> Dereferencing memory at.................0x00000000d716900c
> Fault occurred at timebase..............0x00000008296267c1
> Tools attached (list of tool ids).......None
> Currently running on hardware thread....Y
> General Purpose Registers:
>   r00=0000000000000001 r01=0000001fbfffb0c0 r02=0000000001ca4750 r03=0000000000000000 r04=00000000d7168fe8 r05=000000000000000c r06=0000000000000000 r07=0000003084023688
>   r08=0000000001e034a8 r09=0000000001a12ff8 r10=0000000000000008 r11=00000610c0281600 r12=00000000010eba44 r13=0000001f88007700 r14=0000000000000014 r15=0000000000000000
>   r16=000000000207c9a0 r17=0000000002a3eca0 r18=0000000002a1eec0 r19=00000000029f6a00 r20=0000000002a46400 r21=0000000002a47260 r22=0000000002a47118 r23=0000000000000001
>   r24=0000000002a41ca0 r25=0000000001884460 r26=0000000002a44ca0 r27=0000000001e0bda0 r28=00000000022dc5a0 r29=0000000001bb7ae0 r30=00000000029f8200 r31=0000000002a47340
> Special Purpose Registers:
>   lr=00000000010eba44 cr=0000000022000284 xer=0000000020000000 ctr=0000000000000000
>   msr=000000008002f000 dear=00000000d716900c esr=0000000000000000 fpscr=000000008a024000
>   sprg0=0000000000000000 sprg1=0000000000000000 sprg2=0000000000000000 sprg3=0000000000000000 sprg4=0000000000000000
>   sprg5=0000000000000000 sprg6=0000000000621d00 sprg7=0000000000000000 sprg8=0000000000000000
>   srr0=00000000010eba68 srr1=000000008002f000 csrr0=0000000000000000 csrr1=0000000000000000  mcsrr0=0000000000000000 mcsrr1=0000000000000000
>   dbcr0=0000000000000000 dbcr1=0000000000000000 dbcr2=0000000000000000 dbcr3=0000000000000000 dbsr=0000000000000000
> Floating Point Registers:
>   f00=4035e8a5e0d51774 4035e8a5e0d51774  4035e8a5e0d51774 4035e8a5e0d51774  f01=4035e8a5e0d51774 4035e8a5e0d51774  4035e8a5e0d51774 4035e8a5e0d51774
>   f02=3e945cb95a0164cc 3e7f94d702f1d380  3e7f94d702f1d380 3e7f94d702f1d380  f03=3e9833a753a6edba 3e6eb76fcd2c476c  3e6eb76fcd2c476c 3e6eb76fcd2c476c
>   f04=3e9ee5beff36cb8d 3e7ac85eae3f774b  3e7ac85eae3f774b 3e7ac85eae3f774b  f05=3ea3d3933ba0cb41 3e8182cef01595e9  3e8182cef01595e9 3e8182cef01595e9
>   f06=3ea5216efdd7d0c3 3e64ddbc2370581a  3e64ddbc2370581a 3e64ddbc2370581a  f07=3eae38041864f7e0 3e922d2a351a4e3a  3e922d2a351a4e3a 3e922d2a351a4e3a
>   f08=3eb3bf2d8e13a8e6 3e928cae0784b3d6  3e928cae0784b3d6 3e928cae0784b3d6  f09=3ebc41113831b3bc 3ea103c7543c15ab  3ea103c7543c15ab 3ea103c7543c15ab
>   f10=3ec24a6da7c3f0cd 3ea0a7942eac5bbc  3ea0a7942eac5bbc 3ea0a7942eac5bbc  f11=3ec4bd386722b714 3e939655faf6323c  3e939655faf6323c 3e939655faf6323c
>   f12=3ec839337bca16c0 3e9bdfd8a53afd64  3e9bdfd8a53afd64 3e9bdfd8a53afd64  f13=00000008296259e2 00000008296259e2  00000008296259e2 00000008296259e2
>   f14=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f15=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f16=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f17=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f18=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f19=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f20=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f21=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f22=3ff0000000000000 3ff0000000000000  3ff0000000000000 3ff0000000000000  f23=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f24=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f25=4035e8a442afd2ec 4035e8a442afd2ec  4035e8a442afd2ec 4035e8a442afd2ec
>   f26=3f95421081dc359d 3f95421081dc359d  3f95421081dc359d 3f95421081dc359d  f27=4035e8a5e0d51774 3fd2ba35bb6fe313  3fd2ba35bb6fe313 3fd2ba35bb6fe313
>   f28=3eb0c6f7a0b5ed8d 3eb0c6f7a0b5ed8d  3eb0c6f7a0b5ed8d 3eb0c6f7a0b5ed8d  f29=0000000000000000 0000000000000000  0000000000000000 0000000000000000
>   f30=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f31=4035e89e6a4644de 4035e89e6a4644de  4035e89e6a4644de 4035e89e6a4644de
> Memory:
>   Shared memory: 0x0000003084000000 - 0x0000003087ffffff
>   Heap: 0x0000001f88000000 - 0x0000001f881fffff (brk at 0x0000001f881f1000)
>   MMap: 0x0000001f88200000 - 0x0000001fbfb00000
>     Chunk Status Address            Size
>     [ 0]: Busy   0x0000001f88200000 9506816
>     [ 1]: Free   0x0000001f88b11000 922677248
>   Stack Guard disabled
>   Stack pointer: 0x0000001fbfffb0c0 (bottom at 0x0000001fbfffff80 with 20160 bytes in use)
>        SSSUUU  GAI
> TLB   V EA Range                          RA Range                          Size  ThID WIMGE RWXRWX XSSP TID  TL
>   0:3 V 0000000000001000-00000000000FFFFF 0000000000001000-00000000000FFFFF 1MB   1111 --M-- R-X--- X--- 0000 00
>   1:3 V 0000000000100000-00000000001FFFFF 0000000000100000-00000000001FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   2:2 V 0000010002000000-0000010002FFFFFF 0000010002000000-0000010002FFFFFF 16MB  1111 -IM-- RW---- ---- 0000 00
>   2:3 V 0000000000200000-00000000002FFFFF 0000000000200000-00000000002FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   3:3 V 0000000000300000-00000000003FFFFF 0000000000300000-00000000003FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   4:3 V 0000000000400000-00000000004FFFFF 0000000000400000-00000000004FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   5:3 V 0000000000500000-00000000005FFFFF 0000000000500000-00000000005FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   6:3 V 0000000000600000-00000000006FFFFF 0000000000600000-00000000006FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   7:3 V 0000000000700000-00000000007FFFFF 0000000000700000-00000000007FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   8:3 V 0000000000800000-00000000008FFFFF 0000000000800000-00000000008FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>   9:3 V 0000000000900000-00000000009FFFFF 0000000000900000-00000000009FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  10:3 V 0000000000A00000-0000000000AFFFFF 0000000000A00000-0000000000AFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  11:3 V 0000000000B00000-0000000000BFFFFF 0000000000B00000-0000000000BFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  12:3 V 0000000000C00000-0000000000CFFFFF 0000000000C00000-0000000000CFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  13:3 V 0000000000D00000-0000000000DFFFFF 0000000000D00000-0000000000DFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  14:3 V 0000000000E00000-0000000000EFFFFF 0000000000E00000-0000000000EFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
>  16:3 V 0000000001000000-00000000010FFFFF 0000000001000000-00000000010FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  17:3 V 0000000001100000-00000000011FFFFF 0000000001100000-00000000011FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  18:2 V 0000000001200000-00000000012FFFFF 0000000001200000-00000000012FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  18:3 V 000003FDC0000000-000003FDFFFFFFFF 000003FDC0000000-000003FDFFFFFFFF 1GB   1111 -IMG- RWXrw- ---- 00E5 00
>  19:2 V 0000001F88000000-0000001FC7FFEFFF 0000003008000000-000000303FFFFFFF 1GB   1111 --M-- RWXrwx X--- 03ED 00
>  19:3 V 0000000001300000-00000000013FFFFF 0000000001300000-00000000013FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  20:3 V 0000000001400000-00000000014FFFFF 0000000001400000-00000000014FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  21:2 V 0000000001500000-00000000015FFFFF 0000000001500000-00000000015FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  21:3 V 0005000001500000-00050000015FFFFF 000003FDE8000000-000003FDE80FFFFF 1MB   1111 -IM-- RW-rw- ---- 0000 00
>  22:2 V 0000000001600000-00000000016FFFFF 0000000001600000-00000000016FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  22:3 V 0005000001600000-00050000016FFFFF 000003FDFE200000-000003FDFE2FFFFF 1MB   1111 -IM-- RW-rw- ---- 0000 00
>  23:3 V 0000000001700000-00000000017FFFFF 0000000001700000-00000000017FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  24:3 V 0000000001800000-00000000018FFFFF 0000000001800000-00000000018FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  25:3 V 0000000001900000-00000000019FFFFF 0000000001900000-00000000019FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  26:3 V 0000000001A00000-0000000001AFFFFF 0000000001A00000-0000000001AFFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
>  27:3 V 0000001F88000000-0000001FC7FFEFFF 0000000008000000-000000003FFFFFFF 1GB   1111 --M-- RWXrwx X--- 00E5 00
>  33:3 V 000403F100000000-000403F13FFFFFFF 0000010100000000-000001013FFFFFFF 1GB   1111 -IM-- RWXrw- ---- 00E5 00
>  34:3 V 0000000002000000-0000000002FFFFFF 0000001002000000-0000001002FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  35:3 V 0000000003000000-0000000003FFFFFF 0000001003000000-0000001003FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  36:3 V 0000003084000000-0000003084FFFFFF 0000002004000000-0000002004FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  37:3 V 0000003085000000-0000003085FFFFFF 0000002005000000-0000002005FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  38:2 V 0000003086000000-0000003086FFFFFF 0000002006000000-0000002006FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  38:3 V 00040610C0000000-00040610FFFFFFFF 00000100C0000000-00000100FFFFFFFF 1GB   1111 -IM-- RWXrw- ---- 00E5 00
>  39:3 V 0000003087000000-0000003087FFFFFF 0000002007000000-0000002007FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  40:3 V 0000001F88000000-0000001FC7FFEFFF 0000004008000000-000000403FFFFFFF 1GB   1111 --M-- RWXrwx X--- 0456 00
>  42:3 V 0000000002000000-0000000002FFFFFF 0000002002000000-0000002002FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  43:3 V 0000000003000000-0000000003FFFFFF 0000002003000000-0000002003FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
>  44:3 V 0000003084000000-0000003084FFFFFF 0000001004000000-0000001004FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  45:3 V 0000003085000000-0000003085FFFFFF 0000001005000000-0000001005FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  46:3 V 0000003086000000-0000003086FFFFFF 0000001006000000-0000001006FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  47:3 V 0000003087000000-0000003087FFFFFF 0000001007000000-0000001007FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
>  51:3 V 0000000001B00000-0000000001BFFFFF 0000002001B00000-0000002001BFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
>  52:3 V 0000000001C00000-0000000001CFFFFF 0000002001C00000-0000002001CFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
>  53:3 V 0000000001D00000-0000000001DFFFFF 0000002001D00000-0000002001DFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
>  54:3 V 0000000001E00000-0000000001EFFFFF 0000002001E00000-0000002001EFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
>  55:3 V 0000000001F00000-0000000001FFFFFF 0000002001F00000-0000002001FFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
>  59:3 V 0000000001B00000-0000000001BFFFFF 0000001001B00000-0000001001BFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
>  60:3 V 0000000001C00000-0000000001CFFFFF 0000001001C00000-0000001001CFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
>  61:3 V 0000000001D00000-0000000001DFFFFF 0000001001D00000-0000001001DFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
>  62:3 V 0000000001E00000-0000000001EFFFFF 0000001001E00000-0000001001EFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
>  63:3 V 0000000001F00000-0000000001FFFFFF 0000001001F00000-0000001001FFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
>  64:3 V 0000007001000000-0000007040FFEFFF 0000000001000000-000000003FFFFFFF 1GB   1111 --M-- RWXr-- X--- 0000 00
>  65:3 V 0000007040000000-000000707FFFFFFF 0000000040000000-000000007FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  66:3 V 0000007080000000-00000070BFFFFFFF 0000000080000000-00000000BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  67:3 V 00000070C0000000-00000070FFFFFFFF 00000000C0000000-00000000FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  68:3 V 0000007100000000-000000713FFFFFFF 0000000100000000-000000013FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  69:3 V 0000007140000000-000000717FFFFFFF 0000000140000000-000000017FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  70:3 V 0000007180000000-00000071BFFFFFFF 0000000180000000-00000001BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  71:3 V 00000071C0000000-00000071FFFFFFFF 00000001C0000000-00000001FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  72:2 V 0000000001E00000-0000000001EFFFFF 0000004001E00000-0000004001EFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
>  72:3 V 0000007200000000-000000723FFFFFFF 0000000200000000-000000023FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  73:2 V 0000000001F00000-0000000001FFFFFF 0000004001F00000-0000004001FFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
>  73:3 V 0000007240000000-000000727FFFFFFF 0000000240000000-000000027FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  74:2 V 0000000001C00000-0000000001CFFFFF 0000004001C00000-0000004001CFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
>  74:3 V 0000007280000000-00000072BFFFFFFF 0000000280000000-00000002BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  75:2 V 0000000001D00000-0000000001DFFFFF 0000004001D00000-0000004001DFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
>  75:3 V 00000072C0000000-00000072FFFFFFFF 00000002C0000000-00000002FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  76:3 V 0000007300000000-000000733FFFFFFF 0000000300000000-000000033FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  77:2 V 0000000001B00000-0000000001BFFFFF 0000004001B00000-0000004001BFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
>  77:3 V 0000007340000000-000000737FFFFFFF 0000000340000000-000000037FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  78:3 V 0000007380000000-00000073BFFFFFFF 0000000380000000-00000003BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  79:3 V 00000073C0000000-00000073FFFFFFFF 00000003C0000000-00000003FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
>  84:3 V 0000000002000000-0000000002FFFFFF 0000004002000000-0000004002FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  85:3 V 0000000003000000-0000000003FFFFFF 0000004003000000-0000004003FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  86:3 V 0000001F88000000-0000001FC7FFEFFF 0000002008000000-000000203FFFFFFF 1GB   1111 --M-- RWXrwx X--- 0328 00
>  88:3 V 0000003086000000-0000003086FFFFFF 0000004006000000-0000004006FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  89:3 V 0000003087000000-0000003087FFFFFF 0000004007000000-0000004007FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  90:3 V 0000003084000000-0000003084FFFFFF 0000004004000000-0000004004FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  91:3 V 0000003085000000-0000003085FFFFFF 0000004005000000-0000004005FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
>  94:3 V 0000001F88000000-0000001FC7FFEFFF 0000001008000000-000000103FFFFFFF 1GB   1111 --M-- RWXrwx X--- 02A0 00
>  96:3 V 0000003085000000-0000003085FFFFFF 0000003005000000-0000003005FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
>  97:3 V 0000003084000000-0000003084FFFFFF 0000003004000000-0000003004FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
>  98:3 V 0000003087000000-0000003087FFFFFF 0000003007000000-0000003007FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
>  99:3 V 0000003086000000-0000003086FFFFFF 0000003006000000-0000003006FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
> 102:3 V 0000000003000000-0000000003FFFFFF 0000000003000000-0000000003FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 103:3 V 0000000002000000-0000000002FFFFFF 0000000002000000-0000000002FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 104:3 V 0000003085000000-0000003085FFFFFF 0000000005000000-0000000005FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 105:3 V 0000003084000000-0000003084FFFFFF 0000000004000000-0000000004FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 106:3 V 0000003087000000-0000003087FFFFFF 0000000007000000-0000000007FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 107:3 V 0000003086000000-0000003086FFFFFF 0000000006000000-0000000006FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
> 110:3 V 0000000003000000-0000000003FFFFFF 0000003003000000-0000003003FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
> 111:3 V 0000000002000000-0000000002FFFFFF 0000003002000000-0000003002FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
> 112:3 V 0000000001D00000-0000000001DFFFFF 0000003001D00000-0000003001DFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
> 113:3 V 0000000001C00000-0000000001CFFFFF 0000003001C00000-0000003001CFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
> 114:3 V 0000000001F00000-0000000001FFFFFF 0000003001F00000-0000003001FFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
> 115:3 V 0000000001E00000-0000000001EFFFFF 0000003001E00000-0000003001EFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
> 118:3 V 0000000001B00000-0000000001BFFFFF 0000003001B00000-0000003001BFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
> 120:3 V 0000000001D00000-0000000001DFFFFF 0000000001D00000-0000000001DFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
> 121:3 V 0000000001C00000-0000000001CFFFFF 0000000001C00000-0000000001CFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
> 122:3 V 0000000001F00000-0000000001FFFFFF 0000000001F00000-0000000001FFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
> 123:3 V 0000000001E00000-0000000001EFFFFF 0000000001E00000-0000000001EFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
> 126:3 V 0000000001B00000-0000000001BFFFFF 0000000001B00000-0000000001BFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
> 127:3 V 000003FFC0000000-000003FFFFFFFFFF 000003FFC0000000-000003FFFFFFFFFF 1GB   1111 -IMG- RWX--- ---1 0000 00
> +++STACK
> Frame Address     Saved Link Reg
> 0000001fbfffb0c0  00000000010eba44
> 0000001fbfffb220  00000000010dda3c
> 0000001fbfffb400  0000000001061894
> 0000001fbfffb4e0  00000000010fb01c
> 0000001fbfffb600  0000000001094f0c
> 0000001fbfffb6e0  000000000100a4d0
> 0000001fbfffb7c0  0000000001007cc0
> 0000001fbfffb8a0  0000000001007e50
> 0000001fbfffb940  00000000010074f0
> 0000001fbfffba20  00000000010067fc
> 0000001fbfffbaa0  00000000017d7418
> 0000001fbfffbd80  00000000017d7714
> 0000001fbfffbe40  0000000000000000
> ---STACK
> Interrupt Summary:
>   System Calls 7673
>   External Input Interrupts 2
>   Data TLB Interrupts 1
> ---ID
> ---LCB
> Nek5000-users mailing list
