[Nek5000-users] Nek: abnormal termination by signal 11
Thu Feb 23 10:06:34 CST 2017
Please use addr2line to translate the STACK section in your code file. This will tell us where the SEGFAULT happens.
-----Original message-----
> From:nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
> Sent: Thursday 23rd February 2017 17:01
> To: nek5000-users at lists.mcs.anl.gov
> Subject: Re: [Nek5000-users] Nek: abnormal termination by signal 11
> Sorry Stefan, i misinterpreted your question. I have tested some of the example cases and they run fine. I have uploaded a case that produces the error here:
> https://uni-muenster.sciebo.de/index.php/s/8WgujGKLQNLzk3k <https://uni-muenster.sciebo.de/index.php/s/8WgujGKLQNLzk3k>I am not sure whether you really need the large restart file. Either way, this case runs fine on an Intel system but crashes on the first time step on IBM.
> I think my core file came from a case compiled with "-g“. The cluster is pretty busy at the moment so I can’t really test that much.
> Best wishes,
> Jan<br class="" />Am 20.02.2017 um 00:37 schrieb nek5000-users at lists.mcs.anl.gov <mailto:nek5000-users at lists.mcs.anl.gov>:
> <br class="Apple-interchange-newline" />How can I reproduce the problem? Please provide a step-by-step instruction. <br class="" />The core file (w/o debugging symbols) is pretty useless. Can you recompile with "-g" and try again. You may need use "addr2line" to get a human readable STACK.<br class="" /><br class="" />Cheers,<br class="" />Stefan<br class="" /><br class="" /><br class="" />Nek5000-users mailing list<br class="" />Nek5000-users at lists.mcs.anl.gov <mailto:Nek5000-users at lists.mcs.anl.gov><br class="" />https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users<br class="" /><br class="" />_______________________________________________
