[Nek5000-users] Nek: abnormal termination by signal 11
Sun Feb 19 15:32:02 CST 2017
Hello,
the error occurs both with a current github version (16..0.0) as well as an older svn version (1.0rc1 / SVN  r1115) and is reproducible on the IBM system. However, it seems that the svn version gives a longer error message:
2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: terminated by signal 11
2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: abnormal termination by signal 11 from rank 0
2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: 1 INFO RAS event
2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: most recent RAS event text: DDR Correctable Error Summary : count=36 MCFIR error status:  [MEMORY_CE] This bit is set when a memory CE is detected on a non-maintenance memory read op;
2017-02-19 22:05:06.740 (WARN ) [0x40000e19030] :3243396:ibm.runjob.client.Job: with severity INFO
Attached you find the output from the core file:
+++PARALLEL TOOLS CONSORTIUM LIGHTWEIGHT COREFILE FORMAT version 1.0
+++LCB 1.0
Program   : ./nek5000
Job ID    : 3243396
Personality:
   ABCDET coordinates : 0,0,0,0,0,0
   Rank               : 0
   Ranks per node     : 16
   DDR Size (MB)      : 16384
+++ID Rank: 0, TGID: 1, Core: 0, HWTID:0 TID: 1 State: RUN
***FAULT Encountered unhandled signal 0x0000000b (11) (SIGSEGV)
Generated by interrupt..................0x00000008 (Data TLB Miss Exception DEAR=0x00000000d716900c ESR=0x0000000000000000)
While executing instruction at..........0x00000000010eba68
Dereferencing memory at.................0x00000000d716900c
Fault occurred at timebase..............0x00000008296267c1
Tools attached (list of tool ids).......None
Currently running on hardware thread....Y
General Purpose Registers:
  r00=0000000000000001 r01=0000001fbfffb0c0 r02=0000000001ca4750 r03=0000000000000000 r04=00000000d7168fe8 r05=000000000000000c r06=0000000000000000 r07=0000003084023688
  r08=0000000001e034a8 r09=0000000001a12ff8 r10=0000000000000008 r11=00000610c0281600 r12=00000000010eba44 r13=0000001f88007700 r14=0000000000000014 r15=0000000000000000
  r16=000000000207c9a0 r17=0000000002a3eca0 r18=0000000002a1eec0 r19=00000000029f6a00 r20=0000000002a46400 r21=0000000002a47260 r22=0000000002a47118 r23=0000000000000001
  r24=0000000002a41ca0 r25=0000000001884460 r26=0000000002a44ca0 r27=0000000001e0bda0 r28=00000000022dc5a0 r29=0000000001bb7ae0 r30=00000000029f8200 r31=0000000002a47340
Special Purpose Registers:
  lr=00000000010eba44 cr=0000000022000284 xer=0000000020000000 ctr=0000000000000000
  msr=000000008002f000 dear=00000000d716900c esr=0000000000000000 fpscr=000000008a024000
  sprg0=0000000000000000 sprg1=0000000000000000 sprg2=0000000000000000 sprg3=0000000000000000 sprg4=0000000000000000
  sprg5=0000000000000000 sprg6=0000000000621d00 sprg7=0000000000000000 sprg8=0000000000000000
  srr0=00000000010eba68 srr1=000000008002f000 csrr0=0000000000000000 csrr1=0000000000000000  mcsrr0=0000000000000000 mcsrr1=0000000000000000
  dbcr0=0000000000000000 dbcr1=0000000000000000 dbcr2=0000000000000000 dbcr3=0000000000000000 dbsr=0000000000000000
Floating Point Registers:
  f00=4035e8a5e0d51774 4035e8a5e0d51774  4035e8a5e0d51774 4035e8a5e0d51774  f01=4035e8a5e0d51774 4035e8a5e0d51774  4035e8a5e0d51774 4035e8a5e0d51774
  f02=3e945cb95a0164cc 3e7f94d702f1d380  3e7f94d702f1d380 3e7f94d702f1d380  f03=3e9833a753a6edba 3e6eb76fcd2c476c  3e6eb76fcd2c476c 3e6eb76fcd2c476c
  f04=3e9ee5beff36cb8d 3e7ac85eae3f774b  3e7ac85eae3f774b 3e7ac85eae3f774b  f05=3ea3d3933ba0cb41 3e8182cef01595e9  3e8182cef01595e9 3e8182cef01595e9
  f06=3ea5216efdd7d0c3 3e64ddbc2370581a  3e64ddbc2370581a 3e64ddbc2370581a  f07=3eae38041864f7e0 3e922d2a351a4e3a  3e922d2a351a4e3a 3e922d2a351a4e3a
  f08=3eb3bf2d8e13a8e6 3e928cae0784b3d6  3e928cae0784b3d6 3e928cae0784b3d6  f09=3ebc41113831b3bc 3ea103c7543c15ab  3ea103c7543c15ab 3ea103c7543c15ab
  f10=3ec24a6da7c3f0cd 3ea0a7942eac5bbc  3ea0a7942eac5bbc 3ea0a7942eac5bbc  f11=3ec4bd386722b714 3e939655faf6323c  3e939655faf6323c 3e939655faf6323c
  f12=3ec839337bca16c0 3e9bdfd8a53afd64  3e9bdfd8a53afd64 3e9bdfd8a53afd64  f13=00000008296259e2 00000008296259e2  00000008296259e2 00000008296259e2
  f14=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f15=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f16=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f17=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f18=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f19=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f20=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f21=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f22=3ff0000000000000 3ff0000000000000  3ff0000000000000 3ff0000000000000  f23=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f24=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f25=4035e8a442afd2ec 4035e8a442afd2ec  4035e8a442afd2ec 4035e8a442afd2ec
  f26=3f95421081dc359d 3f95421081dc359d  3f95421081dc359d 3f95421081dc359d  f27=4035e8a5e0d51774 3fd2ba35bb6fe313  3fd2ba35bb6fe313 3fd2ba35bb6fe313
  f28=3eb0c6f7a0b5ed8d 3eb0c6f7a0b5ed8d  3eb0c6f7a0b5ed8d 3eb0c6f7a0b5ed8d  f29=0000000000000000 0000000000000000  0000000000000000 0000000000000000
  f30=0000000000000000 0000000000000000  0000000000000000 0000000000000000  f31=4035e89e6a4644de 4035e89e6a4644de  4035e89e6a4644de 4035e89e6a4644de
Memory:
  Shared memory: 0x0000003084000000 - 0x0000003087ffffff
  Heap: 0x0000001f88000000 - 0x0000001f881fffff (brk at 0x0000001f881f1000)
  MMap: 0x0000001f88200000 - 0x0000001fbfb00000
    Chunk Status Address            Size
    [ 0]: Busy   0x0000001f88200000 9506816
    [ 1]: Free   0x0000001f88b11000 922677248
  Stack Guard disabled
  Stack pointer: 0x0000001fbfffb0c0 (bottom at 0x0000001fbfffff80 with 20160 bytes in use)
        SSSUUU  GAI
TLB   V EA Range                          RA Range                          Size  ThID WIMGE RWXRWX XSSP TID  TL
  0:3 V 0000000000001000-00000000000FFFFF 0000000000001000-00000000000FFFFF 1MB   1111 --M-- R-X--- X--- 0000 00
  1:3 V 0000000000100000-00000000001FFFFF 0000000000100000-00000000001FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  2:2 V 0000010002000000-0000010002FFFFFF 0000010002000000-0000010002FFFFFF 16MB  1111 -IM-- RW---- ---- 0000 00
  2:3 V 0000000000200000-00000000002FFFFF 0000000000200000-00000000002FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  3:3 V 0000000000300000-00000000003FFFFF 0000000000300000-00000000003FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  4:3 V 0000000000400000-00000000004FFFFF 0000000000400000-00000000004FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  5:3 V 0000000000500000-00000000005FFFFF 0000000000500000-00000000005FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  6:3 V 0000000000600000-00000000006FFFFF 0000000000600000-00000000006FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  7:3 V 0000000000700000-00000000007FFFFF 0000000000700000-00000000007FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  8:3 V 0000000000800000-00000000008FFFFF 0000000000800000-00000000008FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
  9:3 V 0000000000900000-00000000009FFFFF 0000000000900000-00000000009FFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 10:3 V 0000000000A00000-0000000000AFFFFF 0000000000A00000-0000000000AFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 11:3 V 0000000000B00000-0000000000BFFFFF 0000000000B00000-0000000000BFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 12:3 V 0000000000C00000-0000000000CFFFFF 0000000000C00000-0000000000CFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 13:3 V 0000000000D00000-0000000000DFFFFF 0000000000D00000-0000000000DFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 14:3 V 0000000000E00000-0000000000EFFFFF 0000000000E00000-0000000000EFFFFF 1MB   1111 --M-- RWX--- ---- 0000 00
 16:3 V 0000000001000000-00000000010FFFFF 0000000001000000-00000000010FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 17:3 V 0000000001100000-00000000011FFFFF 0000000001100000-00000000011FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 18:2 V 0000000001200000-00000000012FFFFF 0000000001200000-00000000012FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 18:3 V 000003FDC0000000-000003FDFFFFFFFF 000003FDC0000000-000003FDFFFFFFFF 1GB   1111 -IMG- RWXrw- ---- 00E5 00
 19:2 V 0000001F88000000-0000001FC7FFEFFF 0000003008000000-000000303FFFFFFF 1GB   1111 --M-- RWXrwx X--- 03ED 00
 19:3 V 0000000001300000-00000000013FFFFF 0000000001300000-00000000013FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 20:3 V 0000000001400000-00000000014FFFFF 0000000001400000-00000000014FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 21:2 V 0000000001500000-00000000015FFFFF 0000000001500000-00000000015FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 21:3 V 0005000001500000-00050000015FFFFF 000003FDE8000000-000003FDE80FFFFF 1MB   1111 -IM-- RW-rw- ---- 0000 00
 22:2 V 0000000001600000-00000000016FFFFF 0000000001600000-00000000016FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 22:3 V 0005000001600000-00050000016FFFFF 000003FDFE200000-000003FDFE2FFFFF 1MB   1111 -IM-- RW-rw- ---- 0000 00
 23:3 V 0000000001700000-00000000017FFFFF 0000000001700000-00000000017FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 24:3 V 0000000001800000-00000000018FFFFF 0000000001800000-00000000018FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 25:3 V 0000000001900000-00000000019FFFFF 0000000001900000-00000000019FFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 26:3 V 0000000001A00000-0000000001AFFFFF 0000000001A00000-0000000001AFFFFF 1MB   1111 --M-- RWXr-x ---- 0000 00
 27:3 V 0000001F88000000-0000001FC7FFEFFF 0000000008000000-000000003FFFFFFF 1GB   1111 --M-- RWXrwx X--- 00E5 00
 33:3 V 000403F100000000-000403F13FFFFFFF 0000010100000000-000001013FFFFFFF 1GB   1111 -IM-- RWXrw- ---- 00E5 00
 34:3 V 0000000002000000-0000000002FFFFFF 0000001002000000-0000001002FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 35:3 V 0000000003000000-0000000003FFFFFF 0000001003000000-0000001003FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 36:3 V 0000003084000000-0000003084FFFFFF 0000002004000000-0000002004FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 37:3 V 0000003085000000-0000003085FFFFFF 0000002005000000-0000002005FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 38:2 V 0000003086000000-0000003086FFFFFF 0000002006000000-0000002006FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 38:3 V 00040610C0000000-00040610FFFFFFFF 00000100C0000000-00000100FFFFFFFF 1GB   1111 -IM-- RWXrw- ---- 00E5 00
 39:3 V 0000003087000000-0000003087FFFFFF 0000002007000000-0000002007FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 40:3 V 0000001F88000000-0000001FC7FFEFFF 0000004008000000-000000403FFFFFFF 1GB   1111 --M-- RWXrwx X--- 0456 00
 42:3 V 0000000002000000-0000000002FFFFFF 0000002002000000-0000002002FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 43:3 V 0000000003000000-0000000003FFFFFF 0000002003000000-0000002003FFFFFF 16MB  1111 --M-- RWXrwx ---- 0328 00
 44:3 V 0000003084000000-0000003084FFFFFF 0000001004000000-0000001004FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 45:3 V 0000003085000000-0000003085FFFFFF 0000001005000000-0000001005FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 46:3 V 0000003086000000-0000003086FFFFFF 0000001006000000-0000001006FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 47:3 V 0000003087000000-0000003087FFFFFF 0000001007000000-0000001007FFFFFF 16MB  1111 --M-- RWXrwx ---- 02A0 00
 51:3 V 0000000001B00000-0000000001BFFFFF 0000002001B00000-0000002001BFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
 52:3 V 0000000001C00000-0000000001CFFFFF 0000002001C00000-0000002001CFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
 53:3 V 0000000001D00000-0000000001DFFFFF 0000002001D00000-0000002001DFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
 54:3 V 0000000001E00000-0000000001EFFFFF 0000002001E00000-0000002001EFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
 55:3 V 0000000001F00000-0000000001FFFFFF 0000002001F00000-0000002001FFFFFF 1MB   1111 --M-- RWXrwx ---- 0328 00
 59:3 V 0000000001B00000-0000000001BFFFFF 0000001001B00000-0000001001BFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
 60:3 V 0000000001C00000-0000000001CFFFFF 0000001001C00000-0000001001CFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
 61:3 V 0000000001D00000-0000000001DFFFFF 0000001001D00000-0000001001DFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
 62:3 V 0000000001E00000-0000000001EFFFFF 0000001001E00000-0000001001EFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
 63:3 V 0000000001F00000-0000000001FFFFFF 0000001001F00000-0000001001FFFFFF 1MB   1111 --M-- RWXrwx ---- 02A0 00
 64:3 V 0000007001000000-0000007040FFEFFF 0000000001000000-000000003FFFFFFF 1GB   1111 --M-- RWXr-- X--- 0000 00
 65:3 V 0000007040000000-000000707FFFFFFF 0000000040000000-000000007FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 66:3 V 0000007080000000-00000070BFFFFFFF 0000000080000000-00000000BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 67:3 V 00000070C0000000-00000070FFFFFFFF 00000000C0000000-00000000FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 68:3 V 0000007100000000-000000713FFFFFFF 0000000100000000-000000013FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 69:3 V 0000007140000000-000000717FFFFFFF 0000000140000000-000000017FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 70:3 V 0000007180000000-00000071BFFFFFFF 0000000180000000-00000001BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 71:3 V 00000071C0000000-00000071FFFFFFFF 00000001C0000000-00000001FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 72:2 V 0000000001E00000-0000000001EFFFFF 0000004001E00000-0000004001EFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
 72:3 V 0000007200000000-000000723FFFFFFF 0000000200000000-000000023FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 73:2 V 0000000001F00000-0000000001FFFFFF 0000004001F00000-0000004001FFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
 73:3 V 0000007240000000-000000727FFFFFFF 0000000240000000-000000027FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 74:2 V 0000000001C00000-0000000001CFFFFF 0000004001C00000-0000004001CFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
 74:3 V 0000007280000000-00000072BFFFFFFF 0000000280000000-00000002BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 75:2 V 0000000001D00000-0000000001DFFFFF 0000004001D00000-0000004001DFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
 75:3 V 00000072C0000000-00000072FFFFFFFF 00000002C0000000-00000002FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 76:3 V 0000007300000000-000000733FFFFFFF 0000000300000000-000000033FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 77:2 V 0000000001B00000-0000000001BFFFFF 0000004001B00000-0000004001BFFFFF 1MB   1111 --M-- RWXrwx ---- 0456 00
 77:3 V 0000007340000000-000000737FFFFFFF 0000000340000000-000000037FFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 78:3 V 0000007380000000-00000073BFFFFFFF 0000000380000000-00000003BFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 79:3 V 00000073C0000000-00000073FFFFFFFF 00000003C0000000-00000003FFFFFFFF 1GB   1111 --M-- RWXr-- ---- 0000 00
 84:3 V 0000000002000000-0000000002FFFFFF 0000004002000000-0000004002FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 85:3 V 0000000003000000-0000000003FFFFFF 0000004003000000-0000004003FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 86:3 V 0000001F88000000-0000001FC7FFEFFF 0000002008000000-000000203FFFFFFF 1GB   1111 --M-- RWXrwx X--- 0328 00
 88:3 V 0000003086000000-0000003086FFFFFF 0000004006000000-0000004006FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 89:3 V 0000003087000000-0000003087FFFFFF 0000004007000000-0000004007FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 90:3 V 0000003084000000-0000003084FFFFFF 0000004004000000-0000004004FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 91:3 V 0000003085000000-0000003085FFFFFF 0000004005000000-0000004005FFFFFF 16MB  1111 --M-- RWXrwx ---- 0456 00
 94:3 V 0000001F88000000-0000001FC7FFEFFF 0000001008000000-000000103FFFFFFF 1GB   1111 --M-- RWXrwx X--- 02A0 00
 96:3 V 0000003085000000-0000003085FFFFFF 0000003005000000-0000003005FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
 97:3 V 0000003084000000-0000003084FFFFFF 0000003004000000-0000003004FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
 98:3 V 0000003087000000-0000003087FFFFFF 0000003007000000-0000003007FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
 99:3 V 0000003086000000-0000003086FFFFFF 0000003006000000-0000003006FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
102:3 V 0000000003000000-0000000003FFFFFF 0000000003000000-0000000003FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
103:3 V 0000000002000000-0000000002FFFFFF 0000000002000000-0000000002FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
104:3 V 0000003085000000-0000003085FFFFFF 0000000005000000-0000000005FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
105:3 V 0000003084000000-0000003084FFFFFF 0000000004000000-0000000004FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
106:3 V 0000003087000000-0000003087FFFFFF 0000000007000000-0000000007FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
107:3 V 0000003086000000-0000003086FFFFFF 0000000006000000-0000000006FFFFFF 16MB  1111 --M-- RWXrwx ---- 00E5 00
110:3 V 0000000003000000-0000000003FFFFFF 0000003003000000-0000003003FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
111:3 V 0000000002000000-0000000002FFFFFF 0000003002000000-0000003002FFFFFF 16MB  1111 --M-- RWXrwx ---- 03ED 00
112:3 V 0000000001D00000-0000000001DFFFFF 0000003001D00000-0000003001DFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
113:3 V 0000000001C00000-0000000001CFFFFF 0000003001C00000-0000003001CFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
114:3 V 0000000001F00000-0000000001FFFFFF 0000003001F00000-0000003001FFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
115:3 V 0000000001E00000-0000000001EFFFFF 0000003001E00000-0000003001EFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
118:3 V 0000000001B00000-0000000001BFFFFF 0000003001B00000-0000003001BFFFFF 1MB   1111 --M-- RWXrwx ---- 03ED 00
120:3 V 0000000001D00000-0000000001DFFFFF 0000000001D00000-0000000001DFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
121:3 V 0000000001C00000-0000000001CFFFFF 0000000001C00000-0000000001CFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
122:3 V 0000000001F00000-0000000001FFFFFF 0000000001F00000-0000000001FFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
123:3 V 0000000001E00000-0000000001EFFFFF 0000000001E00000-0000000001EFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
126:3 V 0000000001B00000-0000000001BFFFFF 0000000001B00000-0000000001BFFFFF 1MB   1111 --M-- RWXrwx ---- 00E5 00
127:3 V 000003FFC0000000-000003FFFFFFFFFF 000003FFC0000000-000003FFFFFFFFFF 1GB   1111 -IMG- RWX--- ---1 0000 00
+++STACK
Frame Address     Saved Link Reg
0000001fbfffb0c0  00000000010eba44
0000001fbfffb220  00000000010dda3c
0000001fbfffb400  0000000001061894
0000001fbfffb4e0  00000000010fb01c
0000001fbfffb600  0000000001094f0c
0000001fbfffb6e0  000000000100a4d0
0000001fbfffb7c0  0000000001007cc0
0000001fbfffb8a0  0000000001007e50
0000001fbfffb940  00000000010074f0
0000001fbfffba20  00000000010067fc
0000001fbfffbaa0  00000000017d7418
0000001fbfffbd80  00000000017d7714
0000001fbfffbe40  0000000000000000
---STACK
Interrupt Summary:
  System Calls 7673
  External Input Interrupts 2
  Data TLB Interrupts 1
---ID
---LCB
